BQ79731-Q1: Clarification on pin number and pin name
Part Number: BQ79731-Q1
In the BQ79731-Q1 datasheet, pin 48 is marked as "NC" (No Connect), whereas in the EVM board it is labeled as "CP" – internal charge pump. Could you clarify which should be considered for circuit design? If the CP signal is indeed present on this pin, would a bypass capacitor be required?
