Hi Sir,
After calibration, what conditions could cause current and temperature errors?
The temperature is -20°C, but the internal temperature is 26.5°C.
In idle mode, the current is -87xx mA.
Thank you.
Hi Sir,
Thank you.
This question has been assigned and will be reviewed when possible. In the meantime please attach your .gg and/or .log files associated with this project.
Thank you,
Alan
Hello Iris,
To follow up on the last message this issue is most likely due to the gauge not being setup, I would recommend starting with calibration >> chemID selection >> Data memory setup >> learning cycle.
Thank you,
Alan
