TPS51200: Required information COO ( Country of Origin) details
Part Number: TPS51200
MANF_P/N Description Quantity
TPS73001DBVR IC REG LIN POS ADJ 200MA SOT23-6 40
TPS51200DRCT IC SINK/SOURCE DDR REG 10-SON 40
TXS0108ERGYR IC TRNSLTR BIDIRECTIONAL 20TSSOP 320
SN74LVC1G11DCKR IC GATE AND 1CH 3-INP SC70-6 40
LM2776DBVR /LM2776DBVT IC REG SWTCHD CAP INV 6SOT23 160
TXS0104ERGYR IC TRNSLTR BIDIRECTIONAL 14VQFN 80
SP330EEY-L IC TXRX RS232/485 24TSSOP 40
SN74AVC1T45DCKR IC TRNSLTR BIDIRECTIONAL SC70-6 40
TPS7A8018DRBT IC REG LINEAR POS ADJ 1A 8SON 40
TUSB1002AIRGET IC TXRX USB 10GBPS 24-VQFN 40
TPD12S520RMNR IC INTERFACE SPECIALIZED 24WQFN 40
TPS62091RGTT IC REG BUCK 3.3V 3A 16QFN 40
TPS62093RGTT IC REG BUCK 1.8V 3A 16QFN 40
TPS62090RGTT IC REG BUCK ADJUSTABLE 3A 16QFN 40
SN74AXC2T245RSWR IC TRANSLTR BIDIRECTIONAL 10UQFN 120
TPS568230RJER Buck Switching Regulator IC Positive Adjustable 0.6V 1 Output 8A 160
TMUX1574RSVR IC SWITCH SPDT X 4 4.5OHM 16UQFN 40
TPS74901DRCR IC REG LINEAR POS ADJ 3A 10VSON 80
TPS74901RGWR IC REG LINEAR POS ADJ 3A 20VQFN 120
  • Hi Satish,
    The only part I support is TPS51200.
    Can you be more specific on the information you need. Are you asking where the TPS51200 manufacturing location is?
    James
  • We need the country of origin information for all the parts listed below.
  • Hi Satish,
    Country of Origin for TPS51200DRCT device is either China, Malaysia, or the Philippines. There are multiple locations.
    I don't have information on the other parts in this list, you will need to make a post for each part separately.
    James
  • Shall I get part with COO Malaysia, or the Philippines
  • Malaysia, or the Philippines
  • Hi Satish,
    Whatever units we have qualified will be used for your product requests. With a large bulk order you might be able to request units from a specific site.
    Otherwise, the units could be from any of those manufacturing sites.
    James
