Hi team,
What is the loop response of LMR60440-Q1?
Customer use it in 12V-5V Fsw=2MHz system and they found that the crossing frequency is 37kHz. This is a bit low.
Did you test the loop response on EVM?
Peter
Hi team,
Peter
Hi Peter,
The loop response depends heavily on the external components used. Can you share the customer schematic?
Niranjan
Hi Peter,
For that schematic RT = 68k, sets the switching frequency around 500k, not 2M. For this the 37kHz crossover frequency seems reasonable.
Niranjan
Hi Niranjan,
Sorry I sent the wrong schematic before, please check the right one.
R2801224-TFT1N7A_TFT_1230150161520-A0_20250722_EP1(V00-C00) Copy.pdf
Peter
Hi Peter,
Here the device is set to be in AUTO mode and the load is light (50 mA written on the schematic). So the device operates in PFM.
PFM is like a hysteretic mode of control and is inherently stable. Loop response is not very meaningful in that case. And the actual switching frequency would also be reduced at light loads. So the reduced crossover frequency is not anything to be concerned about.
Niranjan
Hi Peter,
Let me know if you have any further questions. Otherwise you can close the thread by clicking the resolved button.
Niranjan
Hi Niranjan,
They tested this bode plot in full load, not light load.
Peter
Hi Peter,
Do they have any other capacitors on the 3.3V output rail? Maybe at any downstream components?
Niranjan
