Hi expert,
Currently, we use an 1.8V power rail to supply the LP5562 EN/VCC pin. From the LP5562 datasheet, it seems we should be able to use MCU GPIO to control the EN/VCC pin and this pin draw essentially no current and does not require any decoupling cap, can you confirm if this is ok? And is there any special requirement for the MCU GPIO?
Thank you!
McKenna
