Team,
Are there any sequence requirements for the external bias VCCX? If the 5V supply comes after the output voltage is ready, is it okay to switchover automatically? Thanks!
Sam Ting
Team,
Sam Ting
Hi Sam,
No problem if the 5V external supply is applied after VOUT is in regulation. The main concern is the external bias supply coming up before VIN is applied, as there is a diode path from VCC to VIN that can conduct.
Tim
Tim,
Thanks! I see the description on datasheet. "If an external supply is connected to VCCX to power the LM5148, VIN must be greater than the external bias voltage during all conditions to avoid damage to the controller."
Sam Ting
