TPS23755: 802.3at Type2 POE+ 25.5W
Part Number: TPS23755
Other Parts Discussed in Thread: TPS23731, TPS23734, TPS23754, TPS23756, TPS23751, TPS23752, TPS2378, TPS2379
Does TI have PD can support 802.3at Type2 POE+    25.5W solution? thanks!
Jeff
  • Hi Jeff,
    Thanks for reaching out.
    For 25.5W 802.3at Type2 PD, we have following recommendations:
    1. TPS23731/4 (PD + PWM controller), newest:
    • Compliance to IEEE 802.3bt and 802.3at
    • 0.3-Ohm typ. hotswap
    • TPS23731 supports flyback; TPS23734 supports flyback/ACF (both have internal error amplifier, can be configured to low side SW Buck converter)
    • Support primary side regulation (no need for OPTO feedback)
    • Support auto maintain power signature
    • Programmable frequency dithering for EMI
    • Support soft-stop
    • Support adapter priority
    • VSON45 (7mm x 5mm)
    2. TPS23754/6 (PD + PWM controller):
    • Compliance to IEEE 802.3at
    • 0.5-Ohm typ. hotswap
    • TPS23754 has 15-V Vc UVLO; TPS23756 has 9-V Vc UVLO(used for low-voltage DC adapter case).
    • Both support flyback/ACF-active clamping forward (no internal error amplifier for both)
    • Support adapter priority & low voltage PD input
    • HTSSOP20 (6.5mm x 4.4mm)
    3. TPS23751/2 (PD + PWM controller):
    • Flyback with secondary side regulation only (no internal error amplifier)
    • Sleep mode (disable DC/DC, TPS23752 only) and high efficiency light load mode (automatically reduce switching frequency at light load)
    • TPS23751: TSSOP16 (5mm x 4.4mm)
    • TPS23752: TSSOP20 (6.5mm x 4.4mm)
    4. TPS2378/9 (PD only):
    • TPS2378 has adapter higher priority, TPS2379 has gate pin to drive an external hotswap
    • HSOP8 (4.89mm x 3.9mm)
    Please let me know for any questions.
    Zhining
  • Hi Zhining,
    Got it, thank you!
  • TI USA is on holiday today, please expect delays in response
