Hi Andres,
Could you clarify what you mean by internal impedance? Between which pins are you measuring this?
Amy
Hi Andres,
The UCC27324 underwent a product change notification (PCN) over a year ago. The device was requalified, leading to some changes in the electrical characteristics.
Could you please provide images of the topside markings of the packages of the older and newer component so we can confirm the device versions? Once we have those, we will run a quick bench test to determine if what you are seeing is accurate to the PCN.
Annabelle
Andres,
Thank you for the images. I will test the pre- vs post-PCN output resistance and get back to you with the results, hopefully by early next week.
Annabelle
Hi Andres,
Thank you for your patience. Here are the results from bench testing pre- vs post-PCN.
UCC27324 Pre-PCN OUT to GND Resistance |
UCC27324 Post-PCN OUT to GND Resistance |
106.77 kOhm | 1.97 MOhm |
Annabelle
