Dear Team,
is it possible to use the outputs of the HSS in parallel operation to lower the RDSon?
Thanks!
Dear Team,
Thanks!
Hi Christoph,
Yes, this is a common application. The inputs and outputs should be tied together to be as symmetric as possible, and if the SNS pin will be used, it will only output one channels' current, so it should be doubled to get the total current.
Patrick
