Hello ,
Dear TI support team , I started testing the TPSI31PXQ1EVM evaluation module using low HV input ( 30Volts) to become familiar with the board before going to higher voltages , when i probed V_capacitor ( i used 0.47uF) i observed an exponential curve , however in the datasheet i expected to see a linear ramp since the avg current from the inductor is constant .
- Why do i see an exponential curve instead of ramp ?
- how should i measuring the charging current ( i assume this the same current passing through the shunt resistor or somewhere else ?
thank you for your support !
