UCC256404: Feedback loop oscillation
Part Number: UCC256404
LLC Converter feedback loop not stable.docx
Pls see the Document for system details and Problam statement.
My CV Loop is fully stable but in CC Loop , whole system oscillates at 2.6Khz . Can someone suggest right approach to handle the situation as Both CC and CV loop are co existing in system with seamless transition.
    Your inquiry has been received and will be reviewed in the order that it was received.
    I think the way you have your current loop setup it may be fighting your voltage loop.
    The following link will bring you to a reference design for an off-line battery charger that uses an LLC for the step-down converter.  The converter uses constant current constant voltage feedback loops on page 2 of the schematic.  This feedback is proven and I believe if you use this feedback methodology/circuitry your control loops will be stable and will not fight each other.  https://www.ti.com/lit/df/tidmd32a/tidmd32a.pdf
    The following link will bring you to an application note that describes how to design for constant current, constant voltage using a similar control mythology as used in the above reference design.  This information should help you compensate your constant voltage constant current voltage and current loops.  https://www.ti.com/document-viewer/lit/html/slla619
    I would also recommend using a network analyzer to compensate both the current loop and voltage loop.  To ensure that your design has greater than 45 degree of margin and greater than 3 dB of gain margin.
