Could you provide TPS62A02AEVM-197 Altium designer files?
Thanks in advance.
Thanks in advance.
Hello Elder,
thanks for reaching out in E2E.
May I know why you need the TPS62A02AEVM-197 Altium designer files?
For a guideline and a layout example for implementing an optimized layout in your customized design you can refer to section 8.4 of the TPS62A02A datasheet.
The layout of the TPS62A02AEVM-197 is depicted in section 3 of the EVM User's guide. but this layout contains EVM specific traces, such as VIN and VOUT sense lines for efficiency measurement, which might not be required for your customized design.
Please let me know why you need the EVM design files.
Andreas.
To save time, using the schematics and PCB objects from a proven solution instead of creating my own or having to check those from third parties (including Altium's vault).
Elder,
thanks a lot for your feedback.
I found out that it is not allowed to share the Altium design files.
I would be happy to support you in your design process with schematic and layout review.
Andreas.
Andreas, thanks for taking the time to trying to solve this issue. I have seen several requests for design files along the years being granted, including some of mine. We are not talking about rocket science or extremely sensitive trade secrets, but resources that make TI's customers life easier when using TI's components.
Hello Elder,
I checked again and I'm not allowed to send the Altium files.
Andreas.
