TPS53830A: [IMC] Jitter check
Part Number: TPS53830A
Hi Expert,
This is for Dell server project IMC.
1.8V rail jitter result as below, transient test is passed for 1k~10K by frequency sweeping.
Could you help to see if this Jitter result is okay or not? If not, how to improve?
PMIC_TI 0411 (002).pdf
Allen
  • Hi Allen,
    The jitter shouldn't be an issue.
    The main way we've found to reduce the jitter would be to raise your RAMP compensation setting to a higher value but this involves unlocking the PMIC Vendor region registers and might cause a difference in performance so it's not recommended if you're already passing transient tests with the current setting.
    James
