Other Parts Discussed in Thread: BQ24650, BQ24610
I'm starting a new design that will require two separate battery charging circuits. Both circuits will be powered from 15 watt wireless receiver circuits
The first circuit will be powered from the 5 volt 15 watt maximum output of a wireless charger receiver circuit. It will be used to charge a single 18650 cell.
The second circuit will be powered from the 12 volt 15 watt maximum output of a second wireless charger receiver circuit. It will be used to charge four 18650 cells in series.
Since there are so many potential solutions, I wanted to ask for any recommendations for battery charging ICs before starting the design. (The BQ24810 is only a placeholder for this post; I haven't begun to research different potential solutions at this point.
Thanks in advance for any suggestions as to components that are well suited to these applications.
Mark
