Other Parts Discussed in Thread: BQ2002
Hi team,
Since the BQ25172 uses a timer-based charging method, we believe there may be concerns about overcharging.
Given that the minimum safety timer duration is 4 hours, the maximum charge current that can be set would be around 0.25C.
Would it be correct to assume that at this level, the risk of overcharging is extremely low?
We understand that there is also a protection feature via VOUT_OVP, but during normal voltage rise, the voltage reaches 1.70V, which we believe already indicates an overcharged state.
Kyohei
