the datasheet doesnt state an expected value for silicon and firmware. What are the values that can be expected?
Is there a document stating the actual values? Maybe an errata or pcn?
Thank you in advance.
BR Joerg
BR Joerg
Hello Joerg,
I will get back to you about this tomorrow, 9/12.
Anagha
Hello Joerg,
Can you please clarify what you mean by expected value? I am assuming you are referring to the firmware and silicon version.
At this moment, we can only provide the reference code, which can be found on TI.com's product page for TPS23861: TPS23861 data sheet, product information and support | TI.com
There is only one version of silicon for TPS23861. Please let me know if there are any follow-up questions.
Anagha
Hi Anagha,
we have just started to work with the device. To check if we are talking to the right device, we read out silicon and hardware with cmd code 0x41 and 0x43. Both registers have some variable bits. So what Iam looking for is a table with available sw revision numbers that can be ecpected. For silicon rev. its only 11100001?
BR Joerg
Hi Joerg,
Let me check on this internally. I will get back to you within the next 2 days.
Thank you for your patience,
Anagha
Hi Joerg,
Thank you for the clarification.
These are our register reads for 41h and 43h. Is the value you are reading for 43h 0b00001?
Anagha
Hi Joerg,
There should only be one silicon revision for TPS23861 so what you are reading is correct.
I believe the latest version of firmware revised for the 861 device is 0x3. Let me double check and get back to you regarding this.
Anagha
Hi Joerg,
Thank you for your patience. Looks like both 0x1 and 0x2 are valid firmware versions for the device. Additionally, these are the only 2 firmware revisions, so both values in the screenshot below are valid reads for register 0x41.
Hope this helps. Let me know if there are any further questions.
Anagha
