Hello team,
What is switching frequency accuracy of LM5145 when we set as 1MHz?
Can we expect it is about +/-5% because datasheet spec table says it in case of 400kHz setting(Rrt=25kohm).
Hello team,
Hi Sato San,
Yes - +/-5% is a good estimate. We validate only for 400kHz as you pointed out - however, I do not expect the frequency variance to be much different for 1MHz. Hence, you can consider +/-5% here.
Also, the frequency variance will also depend on the accuracy of the Rt resistor. (1% accuracy resistor is recommended here).
Taru
