Hi team,
Regarding the BQ34210-Q1, we have some design questions:
1. As shown in the figure below, is it recommended to place the BQ34210-Q1's GND pin at terminal A or terminal B? If it is placed at terminal B, is there a possibility that a negative voltage will be generated on the SRN pin during system discharge, potentially damaging the device?
2. Regarding the sense resistor, the datasheet states that it supports values from 5mΩ to 20Ω. How does the IC identify the external sense resistor size? Are there any registers for writing data related to the sense resistor size?
Please answer these questions. Thank you.
BR,
Ethan
