Hi team
Since the behavior of pin FMA of the TPS7B63-Q1 when PGADJ = OPEN was not described, I checked it on an actual device.
The conclusion was that the voltage was always at GND level, and the waveform appeared to be pulled down internally by the IC.
However, even after looking at the datasheet, I could not understand why this waveform appeared.
Please explain why PGADJ is at GND level voltage when it is OPEN.
Saito
