Other Parts Discussed in Thread: TPS26750
We originally intended to develop the firmware burning for the EPPROM of the PD TPS25751 chip on the RG650 side. Then it was found that according to the documentation, the firmware must already be present in the EPPROM before the RG650 module can be used to burn the firmware to the EPPROM on the PD chip. we need consult TI. 1. If the EPPROM is not burned, can the EPPROM connected to the PD chip be burned by connecting the main control to the PD chip? If there is a solution, are there any drivers or applications related to the linux system?
