Hi, can you please share the gold plating thickness on the leads of PN TPS7A4501DCQR?
Hi Andrew,
This document addresses your question and contains other relevant information.
Sarah
Thanks, Sarah. Does the gold plating thickness specified in this document also apply to NiPdAu leads? The 50-225 micro-inches stated in the document seems a bit high for this plating configuration.
Andrew
Hi Andrew,
Apologies, I had assumed you were discussing the TPS7A4501-SP which is a space grade hermetic part with NiAu plating. TPS7A4501DCQR is not rated or qualified for use in the radiation environment of space.
For that class of parts, this document would apply.
Sarah
