Hi support team,
We are considering an inspection process for mass production.
Is it acceptable to use the attached document as a charging IC specification?
BQ25171-Q1_charging_test_250918.xlsx
Dice-K
Hi support team,
Dice-K
Hi Dice-K
This attached circuit is okay, should work for testing.
The NiMH charge profile does not have a battery short circuit feature similar to Li-Ion where current is reduced at low cell voltage.
With the resistor attached at output BQ25171 will source 125mA and develop 1.5V across the 12 ohm resistor.
