Other Parts Discussed in Thread: TPS62873
Hello TI Team,
I am using three TPS62873 devices in a stacked application, consisting of one primary and two secondary devices. The datasheet specifies that the SYNC_OUT pin of the secondary device needs to be pulled down to ground with a 47K resistor.
I would like to confirm if this means that the SYNC_OUT pin of *all* secondary devices should be pulled down to ground with a 47K resistor.
Thank you for your clarification.
Xiangling
