Part Number: BQ27546-G1
Other Parts Discussed in Thread: EV2400, BQSTUDIO
I required the drivers for the BQ27546YZFR-G1 Gas-Gauge IC.
Please provide appropriate I2C drivers for the same.
This question has been assigned to the team and will be reviewed when possible.
Thank you,
Alan
TI does not provide I2C drivers as these depend on the exact host controller make/model.
The bq27546 is a gauge with flash memory, hence configuration should be programmed using the .bq.fs for .df.fs file with the Golden Image from bqStudio. These files include all I2C instructions that must be executed in either a production environment or a host uC (in-system) or during testing/development bqStudio + EV2400 + bq27546 EVM.
For further information about the .fs format, see: e2e.ti.com/.../faq-bqstudio-what-is-the-ti-bms-flashstream-file-format
