BQ40Z50-R2: Issue with Golden file transfer process
Part Number: BQ40Z50-R2
Other Parts Discussed in Thread: BQ40Z50, BQSTUDIO
Hello support team,
I am using the BQ40z50 interfaced with the ESP32.
I am getting an issue while sending the golden file over I2C. I receive a NACK while sending the SWB command, and the NACK comes after sending 2 bytes.
When I look at the datasheet, the 0x0F register is used to calculate the Remaining Capacity of the battery.
I have a golden image file named "goldenimagefinal.fs". Could you please help validate whether it is for the BQ40z50?
I also referred to the application note for Gauge communication (SLUA801). The provided source in the document will not work with the golden file I have.
Here is a reference example:
SWB: 16 0F 00 40 45 2F 05 C2 28 BF 0C 78 65 40 D5 8A 82 49 00 00 40 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF
(one of the lines from the golden image)
In the attached sample code (SLUA801 - gauge.c), it is looking for 'W' and 'C' followed by a colon. But according to my golden image file, it should instead look for 'SWB'.
I have also attached my code developed for the ESP32 for your reference.
I went through the following support cases:
  1. https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1408533/bq40z50-r2-transferring-bq-fs-file-to-bq40z50-r2?tisearch=e2e-sitesearch&keymatch=BQ40z50%25252520goldeb%25252520image%25252520transfer#
  2. https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1107256/faq-bqstudio-how-do-i-interpret-the-lines-in-a-bq-fs-file-for-use-with-my-smbus-gauge
When I follow the SMBus write block format, I still get a NACK after sending 2 bytes.
Could you please look into this and share the C code developed for the BQ40z50 to send the golden image?
;Go To ROM Mode
SWB: 16 44 00 0F
X: 1000
;Clear Tokens by poking 00 to both locations
;Set Address to 0x0000
SWW: 16 09 00 00
;Read Value at address 0x0000
;SCW: 16 0B
;Clear bit 3 and write value to address 0
;dataUpdate = (dataRead & 0xff) | 0x8;Instead setting hardcoded value that works
SWW: 16 0A 02 00
;Set Address to 0x0002
SWW: 16 09 02 00
;Write Value 00 to 0x0002
SWW: 16 0A 00 00
SWW: 16 00 00 00
SWW: 16 1A DE 83
SWW: 16 06 00 00
X: 250
SWW: 16 00 80 00
SWW: 16 1A DE 83
SWW: 16 06 80 00
X: 250
;Set Field Updater tokens by poking 08 to 0000 and B8 to 0002
SWW: 16 09 00 00
;SCW: 16 0B
;Set bit 3 and write value to address 0
;dataUpdate = (dataRead & 0xff) | 0x8; Instead setting hardcoded value that works
SWW: 16 0A 0A 00
SWW: 16 09 02 00
;Write Value B8 to 0x0002
SWW: 16 0A B8 00
SWW: 16 00 80 01
SWW: 16 1A DE 83
SWW: 16 06 80 01
X: 250
SWW: 16 09 00 00
;SCW: 16 0B
SWW: 16 0A 02 00
SWW: 16 09 02 00
SWW: 16 0A 00 00
SWW: 16 11 DE 83
X: 400
SWW: 16 07 DE 83
X: 250
X: 3
SWB: 16 0F 20 40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 40 20 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 7A 78 79 30 31 32 33 34
X: 3
SWB: 16 0F 60 40 35 20 01 23 45 67 89 AB CD EF 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1C 1D 1E 1F 20 21 22 23 24
X: 3
SWB: 16 0F 80 40 25 26 20 01 23 45 67 89 AB CD EF 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1C 1D 1E 1F 20 21 22 23
X: 3
SWB: 16 0F A0 40 24 25 26 00 00 67 35 00 00 21 00 01 00 11 54 65 78 61 73 20 49 6E 73 74 72 75 6D 65 6E 74 73 00
X: 3
SWB: 16 0F C0 40 00 00 0A 62 71 34 30 7A 35 30 2D 52 34 00 00 00 00 00 00 00 00 00 00 04 4C 49 4F 4E 00 00 00 00
X: 3
SWB: 16 0F E0 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 41 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 20 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 41 55 00 6A 01 67 00 6D 00 6F 00 42 00 5E 00 52 00 11 00 11 00 10 00 11 00 13 00 14 00 22 00 65 00
X: 3
SWB: 16 0F 60 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 41 55 00 91 01 72 00 76 00 7E 00 5D 00 6D 00 65 00 32 00 31 00 2E 00 32 00 37 00 3B 00 66 00 28 01
X: 3
SWB: 16 0F A0 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 41 55 FF E8 00 42 00 52 00 67 00 41 00 49 00 4F 00 4D 00 4C 00 47 00 4D 00 55 00 5C 00 9D 00 CB 01
X: 3
SWB: 16 0F E0 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 42 55 FF E8 00 42 00 52 00 67 00 41 00 49 00 4F 00 4D 00 4C 00 47 00 4D 00 55 00 5C 00 9D 00 CB 01
X: 3
SWB: 16 0F 20 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 42 FF FF E8 00 42 00 52 00 67 00 41 00 49 00 4F 00 4D 00 4C 00 47 00 4D 00 55 00 5C 00 9D 00 CB 01
X: 3
SWB: 16 0F 60 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 42 FF FF E8 00 42 00 52 00 67 00 41 00 49 00 4F 00 4D 00 4C 00 47 00 4D 00 55 00 5C 00 9D 00 CB 01
X: 3
SWB: 16 0F A0 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 42 FF FF E8 00 42 00 52 00 67 00 41 00 49 00 4F 00 4D 00 4C 00 47 00 4D 00 55 00 5C 00 9D 00 CB 01
X: 3
SWB: 16 0F E0 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 43 FF FF E8 00 42 00 52 00 67 00 41 00 49 00 4F 00 4D 00 4C 00 47 00 4D 00 55 00 5C 00 9D 00 CB 01
X: 3
SWB: 16 0F 20 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 43 4F 00 00 00 00 00 86 29 27 2D A0 0F A0 0F 86 29 03 00 06 4B 10 3B 10 00 00 00 00 88 01 F3 FE 28
X: 3
SWB: 16 0F 60 43 FF 02 00 27 00 43 11 EB FB F2 FC 30 11 C0 18 64 00 E8 03 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 43 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F A0 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 43 00 00 00 00 00 00 00 00 FF 7F FF 7F FF 7F FF 7F 00 00 00 00 00 00 00 00 00 00 80 7F 00 80 7F 80
X: 3
SWB: 16 0F E0 43 80 80 80 80 7F 7F 7F 7F 80 80 80 80 80 80 80 80 7F 7F 7F 7F 7F 7F 7F 7F 80 7F 00 80 7F 80 80 80
X: 3
SWB: 16 0F 00 44 80 80 7F 7F 7F 7F 80 80 80 80 80 80 80 80 7F 7F 7F 7F 7F 7F 7F 7F 80 7F 00 80 7F 80 80 80 80 80
X: 3
SWB: 16 0F 20 44 7F 7F 7F 7F 80 80 80 80 80 80 80 80 7F 7F 7F 7F 7F 7F 7F 7F 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 60 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F A0 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F E0 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 20 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 60 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F A0 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 45 48 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F E0 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 46 00 00 00 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 20 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 60 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F A0 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F E0 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 47 00 28 23 38 FF 70 FE 00 00 00 64 5A 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 20 47 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 47 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 60 47 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 47 A0 0F 68 10 68 10 A0 0F 04 10 84 00 60 01 08 01 BC 07 A4 0F B0 0B BC 07 A4 0F B0 0B F4 03 BC 07
X: 3
SWB: 16 0F A0 47 D8 05 CC 09 88 11 C0 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 47 48 02 03 40 00 00 41 00 00 42 C0 7F 43 C0 7F 48 00 00 49 00 00 4A C0 7F 4B C0 7F 50 00 00 51 00
X: 3
SWB: 16 0F E0 47 00 52 C0 7F 53 C0 7F 58 00 00 59 00 00 5A C0 7F 5B C0 7F 60 00 00 61 00 00 62 C0 7F 63 C0 7F 68
X: 3
SWB: 16 0F 00 48 00 00 69 00 00 6A C0 7F 6B C0 7F 70 00 00 71 00 00 72 C0 7F 73 C0 7F 78 00 00 79 00 00 7A C0 7F
X: 3
SWB: 16 0F 20 48 7B C0 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 48 05 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 60 48 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 48 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F A0 48 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 48 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 48 FF FF FF FF A0 70 17 30 11 74 0E FF FF FF FF B8 54 0B B8 0B 05 68 10 04 10 64 5F 80 0C E4 0C 06
X: 3
SWB: 16 0F 00 49 08 68 10 04 10 64 5F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 49 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 C4 09 02 8C
X: 3
SWB: 16 0F 40 49 18 00 09 14 54 0B 68 10 68 10 68 10 68 10 10 02 3C 04 10 04 10 04 10 04 10 04 10 FF FF 98 08 06
X: 3
SWB: 16 0F 60 49 60 78 05 38 E8 03 38 B0 04 70 4C 04 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 04
X: 3
SWB: 16 0F 80 49 0D D0 58 18 00 00 58 18 0C D4 C6 4A C2 B4 2B 6E 7C 03 48 01 A3 FD 75 F6 58 12 B7 2D B7 2D 00 00
X: 3
SWB: 16 0F A0 49 00 00 86 D4 C6 4A C2 B4 2B 6E 7C 03 48 01 A3 FD 75 F6 58 12 B7 2D B7 2D 00 00 00 00 EF 40 40 40
X: 3
SWB: 16 0F C0 49 40 0A 0A 40 40 40 03 09 04 00 01 58 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F E0 49 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 4A 74 57 7E 10 34 10 F6 0F E1 0F D0 0F CB 0F C6 0F C4 0F C1 0F BC 0F B7 0F AC 0F A4 0F 92 0F 87 0F
X: 3
SWB: 16 0F 20 4A 5B 0F 4F 0F 36 0F 2C 0F 27 0F 1F 0F 1C 0F 15 0F 10 0F 08 0F 02 0F F3 0E E7 0E D3 0E C2 0E 99 0E
X: 3
SWB: 16 0F 40 4A 70 0E 43 0E 0B 0E E7 0D D0 0D B8 0D 72 0D BF 0C C2 0A D0 0F FB 0E 6A F6 EA FB 7A 00 5E 01 F2 01
X: 3
SWB: 16 0F 60 4A 55 01 24 01 25 01 8E 01 61 03 08 05 A6 06 E3 07 95 08 4E 08 96 08 55 04 16 05 20 04 CC 02 51 03
X: 3
SWB: 16 0F 80 4A 7D 02 9A 02 5A 02 CE 01 3B 00 9D 00 20 FF C4 FD 3B FB 67 FD 01 FE E2 FD 38 00 29 00 6F 00 EC FE
X: 3
SWB: 16 0F A0 4A E2 F5 89 F4 3A F6 CB FF D0 FF C8 FF B1 FF E3 FF DF FF F1 FF EE FF E9 FF EF FF D3 FF DA FF DC FF
X: 3
SWB: 16 0F C0 4A F0 FF B7 FF 80 FF 71 FF 6E FF 9A FF 7A FF 92 FF 8E FF 7B FF 7D FF 6F FF 77 FF 64 FF 3A FF 4B FF
X: 3
SWB: 16 0F E0 4A 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 20 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 4B F4 01 1E 58 02 50 46 0A 00 32 02 1E 03 0F 20 03 02 0F 04 04 76 FE 54 E7 0A 32 00 64 00 50 46 50
X: 3
SWB: 16 0F 60 4B 46 0A 3C 0C 10 0B 00 00 19 C0 55 5A 03 37 00 01 00 14 00 05 00 14 00 23 03 08 07 25 5A 0A 3C 60
X: 3
SWB: 16 0F 80 4B 05 82 C8 00 2C 01 C8 00 48 0D 0F 2C 01 F0 0A 28 C8 00 00 00 32 00 08 07 1E F4 01 FA 00 20 1C E8
X: 3
SWB: 16 0F A0 4B 03 E8 03 0A 00 50 46 64 00 80 43 90 01 0A C8 00 88 13 50 32 00 00 00 C8 00 0A 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 4B 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F E0 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 4C 00 00 00 00 AC 0D 1E 1E 00 00 00 04 00 20 00 00 00 00 00 00 96 00 AF 00 0A 05 00 00 00 00 00 00
X: 3
SWB: 16 0F 20 4C 00 00 00 00 16 EA 04 0A 0A AC 0D D6 06 0A 01 08 D6 06 0A C4 09 00 00 02 18 B8 0B 0A 00 05 DE 0A
X: 3
SWB: 16 0F 40 4C 6E 0C 05 14 00 0A 14 A0 05 1E 00 3C 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 60 4C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 4C D0 00 00 02 00 04 64 00 10 04 0A 00 14 28 3C 50 0A 00 14 28 3C 50 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F A0 4C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 4C 2C 01 B0 01 0A 00 81 00 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F E0 4C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 4D 03 0A 00 1E 32 03 0A 10 0B 3C 0C B8 0B 10 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 20 4D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 4D 02 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 60 4D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 4D E0 2E B0 22 E8 1C 5A 0A 8C 0C 8C 00 80 0C E4 0C 00 05 68 10 04 10 64 5F 80 0C E4 0C 06 08 68 10
X: 3
SWB: 16 0F A0 4D 04 10 64 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 4D 01 00 6F 01 02 02 03 50 46 00 00 50 5F 3C 64 00 3C 0F 64 00 28 00 14 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F E0 4D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 4E FE D0 F7 01 5A 00 07 03 00 00 00 00 00 00 00 00 00 E8 03 96 00 64 00 14 64 64 01 03 0C 05 3C AC
X: 3
SWB: 16 0F 20 4E 0D D0 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 4E 00 00 7E 05 00 00 C2 0C 02 E4 0C 02 80 0C 02 E4 0C 68 10 68 10 68 10 68 10 68 10 02 5E 10 5E 10
X: 3
SWB: 16 0F 60 4E 5E 10 5E 10 5E 10 00 0A 0F 80 0C 06 1C 0C 03 9C FF 05 1C F3 06 B8 F2 03 00 00 05 00 0A 0F 00 0A
X: 3
SWB: 16 0F 80 4E 05 0F 00 0A 05 0F 00 0A 05 0F D2 0C 02 A0 0C 04 0D 02 D2 0C CC 0D 02 36 0D 96 00 02 32 00 AC 0A
X: 3
SWB: 16 0F A0 4E 02 DE 0A AC 0A 02 DE 0A 0A D0 07 08 07 08 07 02 00 C4 09 D0 07 F0 D2 02 00 04 10 FF FF 5A F4 01
X: 3
SWB: 16 0F C0 4E 1E 0C FE F4 01 02 64 00 02 32 00 02 0A 00 02 00 00 00 00 98 08 05 94 11 05 10 27 05 F0 D8 05 36
X: 3
SWB: 16 0F E0 4E 0D 05 68 0D 05 94 0E 05 B8 08 05 C8 00 C8 00 96 00 02 78 00 14 02 AC 0D 0A 00 F4 01 05 64 00 74
X: 3
SWB: 16 0F 00 4F 0E 32 00 C8 00 05 2C 01 90 01 02 00 00 02 05 00 05 FB FF 05 05 00 05 64 02 05 64 05 08 05 05 00
X: 3
SWB: 16 0F 20 4F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 4F 00 00 00 AC 0A 0A 00 24 0B 0A 00 74 0B 0A 00 A6 0B 0A 00 D8 0B 0A 00 D2 0C 0A 00 58 00 2C 00 C4
X: 3
SWB: 16 0F 60 4F 09 54 0B 10 0E A0 0F 00 32 4B 01 32 00 5F 38 22 0A 00 0A 96 00 50 70 44 28 00 14 5E 01 3C A8 66
X: 3
SWB: 16 0F 80 4F 46 00 28 01 0A A0 0C 68 10 2C 01 19 00 B8 0B 94 11 D0 07 94 11 64 00 90 01 40 00 4B 00 36 10 28
X: 3
SWB: 16 0F A0 4F FE FF 00 00 01 00 01 00 05 C0 0D 68 10 0C 02 00 20 1C 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F C0 4F 01 00 00 00 01 00 03 70 F4 77 77 E7 64 98 08 FA 00 3C 00 32 00 2D 00 01 3C A6 0B 00 00 00 00 00
X: 3
SWB: 16 0F E0 4F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 50 00 00 0A 5F 5A 50 32 14 0A 05 05 48 0A 0A 00 AC 0A 0A 00 24 0B 0A 00 74 0B 0A 00 A6 0B 0A 00 D8
X: 3
SWB: 16 0F 20 50 0B 0A 00 D2 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 60 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 50 15 55 74 0E 5A A0 0F 10 27 5A 68 10 33 0C CC 10 33 0C E0 01 32 00 D0 02 64 00 90 06 96 00 40 0B
X: 3
SWB: 16 0F A0 50 C8 00 80 16 2C 01 68 10 65 0C F0 00 32 00 E0 01 64 00 A0 05 96 00 70 08 C8 00 60 09 2C 01 04 10
X: 3
SWB: 16 0F C0 50 97 0C 18 00 32 00 78 00 64 00 50 01 C8 00 E0 01 FA 00 D0 02 2C 01 0A 00 97 0C 10 27 3C 0F 0A 00
X: 3
SWB: 16 0F E0 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 00 51 18 FC E8 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 20 51 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 40 51 B0 00 FE 00 22 0B 02 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 60 51 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
X: 3
SWB: 16 0F 80 51 0A 1E 01 03 07 0F 1F 3F 7F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 51 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 51 1A 00 E0 51 CF 4E 70 02 04 00 E4 52 CF 4E 70 02 02 00 0C 53 CF 4E 70 02 32 00 20 53 42 4E 68 02
X: 3
SWB: 16 0F E0 51 00 12 0F 05 D3 4E D5 4E 79 02 01 13 0D 05 D6 4E D8 4E 7A 02 84 13 DE 61 DF 4E E1 4E 7B 02 84 13
X: 3
SWB: 16 0F 00 52 EF 61 E2 4E E4 4E 7C 02 8C 13 D5 61 03 4F 05 4F 7D 02 8B 13 D5 61 FA 4E FC 4E 7E 02 11 12 FB 04
X: 3
SWB: 16 0F 20 52 11 4F 13 4F 7F 02 10 13 FB 04 0E 4F 10 4F 80 02 16 7D 1E 00 80 00 1E 4F 81 02 14 0E BF 00 00 00
X: 3
SWB: 16 0F 40 52 17 4F BF 00 15 0E BE 00 00 00 1A 4F BE 00 02 13 FB 04 D9 4E DB 4E 82 02 03 12 FB 04 DC 4E DE 4E
X: 3
SWB: 16 0F 60 52 83 02 1C 12 49 05 E8 4E EA 4E 84 02 1D 12 4B 05 E8 4E EA 4E 85 02 1E 12 4D 05 E8 4E EA 4E 86 02
X: 3
SWB: 16 0F 80 52 1F 12 4F 05 E8 4E EA 4E 87 02 17 6D 1E 00 40 00 00 00 00 00 06 13 27 05 E5 4E E7 4E 88 02 93 13
X: 3
SWB: 16 0F A0 52 90 65 14 4F 16 4F 89 02 0D 0E 61 02 00 00 7E 4E 61 02 0E 0E 62 02 00 00 82 4E 62 02 0F 0E 63 02
X: 3
SWB: 16 0F C0 52 00 00 86 4E 63 02 05 0E 64 02 00 00 66 4E 64 02 12 0E 65 02 00 00 7B 4E 65 02 1B 0E 78 02 00 00
X: 3
SWB: 16 0F E0 52 1C 4F 78 02 0A 12 4E 43 0B 4F 0D 4F 8A 02 88 03 88 65 F2 4E 00 00 00 00 88 1B 80 65 F4 4E F5 4E
X: 3
SWB: 16 0F 00 53 8B 02 87 13 63 65 EF 4E F1 4E 8C 02 C9 03 50 65 3B 65 00 00 00 00 C9 13 50 65 26 65 0A 4F 8D 02
X: 3
SWB: 16 0F 20 53 00 12 0F 05 46 4E 48 4E 8E 02 00 83 0F 05 49 4E 00 00 00 00 0D 13 29 05 8F 4E 91 4E 8F 02 0D 82
X: 3
SWB: 16 0F 40 53 29 05 92 4E 00 00 00 00 0C 13 29 05 8A 4E 8C 4E 90 02 0C 82 29 05 8D 4E 00 00 00 00 41 13 0D 05
X: 3
SWB: 16 0F 60 53 17 61 5B 4E 91 02 41 82 0D 05 23 61 00 00 00 00 02 13 FB 04 69 4E 6B 4E 92 02 02 92 FB 04 6F 4E
X: 3
SWB: 16 0F 80 53 71 4E 93 02 04 12 FB 04 72 4E 74 4E 94 02 04 93 FB 04 78 4E 7A 4E 95 02 06 6E 1E 00 08 00 00 00
X: 3
SWB: 16 0F A0 53 61 02 08 6E 1E 00 04 00 00 00 62 02 0A 6E 1E 00 03 00 00 00 63 02 07 0E 61 02 00 00 7E 4E 61 02
X: 3
SWB: 16 0F C0 53 09 0E 62 02 00 00 82 4E 62 02 0B 0E 63 02 00 00 86 4E 63 02 06 91 00 00 00 00 80 4E 96 02 08 91
X: 3
SWB: 16 0F E0 53 00 00 00 00 84 4E 97 02 0A 91 00 00 00 00 88 4E 98 02 07 FD C4 4F 04 00 81 4E 99 02 09 FD C4 4F
X: 3
SWB: 16 0F 00 54 04 00 85 4E 9A 02 0B FD C4 4F 04 00 89 4E 9B 02 0E 12 AF 00 4C 4E 4E 4E 9E 02 0E 83 AF 00 4F 4E
X: 3
SWB: 16 0F 20 54 00 00 00 00 8F 13 3D 61 99 4E 9B 4E 9F 02 8F 82 3D 61 9C 4E 00 00 00 00 03 13 FB 04 6C 4E 6E 4E
X: 3
SWB: 16 0F 40 54 A0 02 03 92 FB 04 6F 4E 71 4E A1 02 05 12 FB 04 75 4E 77 4E A2 02 05 93 FB 04 78 4E 7A 4E A3 02
X: 3
SWB: 16 0F 60 54 10 13 27 05 94 4E 96 4E A4 02 10 82 27 05 97 4E 00 00 00 00 11 0B C0 00 A8 4E 00 00 00 00 11 8F
X: 3
SWB: 16 0F 80 54 C0 00 00 00 00 00 00 00 97 13 2F 61 C3 4E C5 4E A5 02 17 92 FB 04 C6 4E C8 4E A6 02 58 13 09 05
X: 3
SWB: 16 0F A0 54 DA 66 C0 4E A7 02 58 82 09 05 F0 66 00 00 00 00 99 13 2F 61 C9 4E CB 4E A8 02 19 92 FB 04 CC 4E
X: 3
SWB: 16 0F C0 54 CE 4E A9 02 1A 12 2B 05 9E 4E A0 4E AA 02 1A 83 2B 05 A1 4E 00 00 00 00 1B 12 2B 05 A3 4E A5 4E
X: 3
SWB: 16 0F E0 54 AB 02 1B 83 2B 05 A6 4E 00 00 00 00 1C 0E 64 02 00 00 66 4E 64 02 1C FD C4 4F 04 00 68 4E 9C 02
X: 3
SWB: 16 0F 00 55 1D 0E 65 02 00 00 7B 4E 65 02 1D FD C4 4F 04 00 7D 4E 9D 02 FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 55 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 55 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 55 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 55 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 55 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 55 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 55 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 00 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 56 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 00 57 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 57 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 57 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 57 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 57 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 57 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 57 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 57 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 00 58 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 58 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 58 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 58 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 58 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 58 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 58 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 58 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 00 59 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 59 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 59 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 59 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 59 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 59 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 59 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 59 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 00 5A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 5A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 5A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 5A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 5A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 5A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 5A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 5A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 00 5B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 5B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 5B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 5B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 5B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 5B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 5B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 5B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 00 5C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 5C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 5C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 5C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 5C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 5C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 5C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 5C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 00 5D FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 5D FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 5D FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 5D FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 5D FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 5D FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 5D FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 5D FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 00 5E FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 5E FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 5E FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 5E FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 5E FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F A0 5E FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F C0 5E FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 5E FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 00 5F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 20 5F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 40 5F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 60 5F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F 80 5F 00 00 7E 05 00 00 C2 0C 02 E4 0C 02 80 0C 02 E4 0C 68 10 68 10 68 10 68 10 68 10 02 5E 10 5E 10
X: 3
SWB: 16 0F A0 5F 5E 10 5E 10 5E 10 00 0A 0F 80 0C 06 1C 0C 03 9C FF 05 1C F3 06 B8 F2 03 00 00 05 00 0A 0F 00 0A
X: 3
SWB: 16 0F C0 5F FF FF FF FF 06 04 00 00 F8 FB FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 0F E0 5F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SCW: 16 14 D8 DB
SWB: 16 05 00 00 19 00 0D 00 10 00 13 00 16 00 9B 21 D6 9B 3A D5 9B A3 D5 9B 4F D5 9B E5 D5 FC 60 20 00 0A F6 08
X: 3
SWB: 16 05 20 00 9F F9 49 9F 69 D6 A6 20 90 1C 34 25 F5 04 9F 53 00 24 00 01 25 00 01 26 14 55 9F 62 00 24 F5 04
X: 3
SWB: 16 05 40 00 25 F5 04 9F 62 00 9F C6 CA 9F 52 49 99 CB 70 50 00 EC 94 F6 40 ED 40 87 F5 9A 40 80 50 00 EE 96
X: 3
SWB: 16 05 60 00 EC 94 EC 55 87 F4 9A 98 08 98 0F 98 15 98 1C 98 23 22 9A 38 24 00 0A 63 04 FD 22 31 15 24 83 09
X: 3
SWB: 16 05 80 00 73 FD 22 AC 00 24 0E 09 63 04 FD 22 F0 46 24 FD 08 63 04 FD 22 76 22 24 DD 08 73 FD 3F 24 93 80
X: 3
SWB: 16 05 A0 00 60 FE F0 00 21 02 00 9F 64 C8 2F 9A 32 21 0E 00 9F 54 C8 26 90 80 60 01 F1 83 21 02 00 9F 8D C8
X: 3
SWB: 16 05 C0 00 72 9F B3 C2 A6 2A DA 00 88 0F 9F 77 C4 21 00 7F 9F 08 C4 21 08 00 9F 64 C8 A6 A3 C3 7F 72 9F BA
X: 3
SWB: 16 05 E0 00 C1 E6 AA 2E 90 06 21 04 00 9F 64 C8 E6 AA 10 93 C5 9F D9 44 99 C0 E4 94 07 A3 07 40 A1 00 08 84
X: 3
SWB: 16 05 00 01 13 A4 08 00 A6 42 24 19 4F 43 00 9C 47 D3 00 84 03 A4 08 01 A6 42 24 18 4F 43 00 9C 47 D3 00 84
X: 3
SWB: 16 05 20 01 0A A1 02 BF 90 05 B2 82 A3 BF 20 A6 42 24 1B 4F 43 00 9C 47 D3 00 84 0A A1 02 BE 90 05 B2 82 A3
X: 3
SWB: 16 05 40 01 BE 20 9A 3F A1 02 BE 24 1A 4F E0 52 00 88 08 B2 92 A3 BE 20 9F F2 C0 2F 9A 3F 9F 5D C0 A6 23 D2
X: 3
SWB: 16 05 60 01 00 84 10 A1 02 BF 24 17 4F E0 52 00 88 05 B2 92 A3 BF 20 A6 32 2F 9A 3F A1 00 08 90 06 9F 59 01
X: 3
SWB: 16 05 80 01 A4 08 00 2F 9A 3F A4 BE 00 21 C6 4F 9F 2C C1 2F 9A 24 29 4C 02 00 A1 00 F2 C0 02 90 03 32 98 1E
X: 3
SWB: 16 05 A0 01 24 F7 04 01 02 EA E1 88 12 01 12 EA E1 88 0C A1 02 AB E9 09 B3 70 32 B4 74 98 03 22 01 00 A6 42
X: 3
SWB: 16 05 C0 01 9A 3D 3F 9F 19 CB F6 15 9F EE CA D2 00 84 04 F9 50 90 12 9F 5E C6 ED C1 90 0B 24 68 02 60 01 F1
X: 3
SWB: 16 05 E0 01 0F 60 02 F3 F2 2F 2D 9A 9B 6D BF 9A 9B 2A C5 9A 24 C0 4F 43 04 C2 3F E7 38 40 A6 03 B3 12 9A 3D
X: 3
SWB: 16 05 00 02 A6 24 24 29 4C 43 23 D3 08 94 04 63 08 98 06 D3 00 84 02 63 01 A6 3A 7B 20 81 51 E8 25 42 40 73
X: 3
SWB: 16 05 20 02 D4 02 90 06 D4 03 84 04 E9 61 E9 91 2D 9A 3D 3E 3F A7 04 24 00 40 06 0E A1 04 EA CC 04 84 05 24
X: 3
SWB: 16 05 40 02 00 41 06 01 CC 02 90 04 31 32 98 3C A6 30 A6 14 A6 15 9C 52 11 C0 12 C2 25 00 40 F4 26 52 F6 61
X: 3
SWB: 16 05 60 02 A6 30 A6 14 A6 15 9C 52 F6 16 F6 27 01 50 A6 30 A6 14 A6 15 9C 52 3A 39 F6 61 F6 72 9C 4C AC 3A
X: 3
SWB: 16 05 80 02 39 01 C4 02 C6 9C 41 AC AC 2F 2E 2D 9A C2 F1 24 00 4C 40 09 C0 01 90 04 E6 12 02 9A E6 12 04 9A
X: 3
SWB: 16 05 A0 02 A2 A0 3F A1 0A AA E6 AA 01 90 03 9F 8D 02 E6 AA 02 90 03 E6 12 02 E6 AA 04 90 03 E6 12 01 2F A0
X: 3
SWB: 16 05 C0 02 0A 9A 24 00 4C 40 10 C0 40 90 51 E4 80 1D 90 4C 24 29 4C 42 0E 73 24 67 05 F4 51 14 80 3E 24 73
X: 3
SWB: 16 05 E0 02 01 F4 93 00 13 00 A1 00 AB C0 40 84 05 22 10 0E 98 03 22 3C 00 24 29 4C 42 0F 90 18 EA 53 80 27
X: 3
SWB: 16 05 00 03 EA C3 24 73 01 13 00 24 71 01 F4 92 00 12 00 73 E9 52 80 13 24 DF 01 60 01 F1 02 9A 24 73 01 31
X: 3
SWB: 16 05 20 03 11 00 24 71 01 11 00 9A 24 C0 4F 42 04 C2 03 B2 92 9A 3D 3F E9 65 62 03 9F FF 01 E9 05 64 20 21
X: 3
SWB: 16 05 40 03 06 20 9F 11 C4 64 22 21 08 22 9F 11 C4 62 02 9F FF C3 CA 20 84 03 E6 1A 01 64 20 21 06 00 9F 11
X: 3
SWB: 16 05 60 03 C4 64 22 21 08 02 9F 11 C4 F6 51 2F 2D 9A 3D 3F 25 77 01 24 C0 4F 42 04 CA 24 D0 24 90 03 31 98
X: 3
SWB: 16 05 80 03 05 01 40 9F 32 03 11 40 24 DF 01 46 00 A1 02 83 CE 40 90 89 C2 BF A3 83 20 0A 19 90 1A E4 92 1B
X: 3
SWB: 16 05 A0 03 A3 1B 20 D2 EF 94 10 A4 1B 00 EA 81 19 19 FB 84 06 A6 62 C2 BF 52 00 62 01 9F FF 01 24 77 01 F4
X: 3
SWB: 16 05 C0 03 C9 00 84 10 24 C0 4F 40 05 C0 01 84 07 24 DF 01 60 BF F0 00 24 00 4C 44 10 CC 04 90 2E 25 DF 01
X: 3
SWB: 16 05 E0 03 40 41 C0 20 90 25 A1 00 18 90 20 24 F7 04 01 12 24 29 4C F4 E1 10 80 10 E4 92 1C A3 1C 20 D2 01
X: 3
SWB: 16 05 00 04 94 09 60 BF F0 40 98 03 A4 1C 00 CC 08 90 50 A1 00 82 84 4B 24 DF 01 60 BF F0 00 98 42 CA 40 90
X: 3
SWB: 16 05 20 04 12 A1 02 1B 90 04 B2 82 98 0E A6 62 E6 12 40 52 00 98 08 24 29 4C 42 22 A3 1B 20 34 1C 19 62 01
X: 3
SWB: 16 05 40 04 9F FF 01 24 77 01 F4 C9 00 84 11 24 29 4C 01 20 19 19 A4 1B 00 24 DF 01 60 40 F1 00 A4 1C 00 A4
X: 3
SWB: 16 05 60 04 18 00 2F 2D 9A 3D A2 C0 3F 25 75 01 24 C0 4F 42 04 CA 64 D0 44 90 0C 31 11 40 24 DF 01 60 DF F0
X: 3
SWB: 16 05 80 04 03 98 07 01 40 9F 32 03 11 40 24 DF 01 4C 03 25 75 01 E6 AC 20 90 17 F8 40 84 27 24 F7 04 01 12
X: 3
SWB: 16 05 A0 04 24 29 4C F4 E1 10 80 1A A6 C2 C2 DF 98 0F 62 01 9F FF 01 F4 C9 40 84 0A A6 C2 E6 12 20 24 DF 01
X: 3
SWB: 16 05 C0 04 52 03 2F A0 0C 2D 9A 3D A2 C0 3F A6 2C D2 00 90 32 25 F7 04 01 52 24 29 4C F4 E1 10 88 25 01 44
X: 3
SWB: 16 05 E0 04 30 E8 E1 8C 1E 72 9F C3 C4 A6 C3 72 9F CD 41 9F 99 50 9F 08 C8 9F 6E 5A 9F E3 C9 9F 15 C3 62 FF
X: 3
SWB: 16 05 00 05 9F 51 CF 2F A0 0C 2D 9A 3D A2 C0 3F A1 00 AB C0 02 84 A9 24 00 4C 4C 11 E6 AC 04 90 9F 64 10 21
X: 3
SWB: 16 05 20 05 06 10 9F 11 C4 E6 AC 10 84 08 64 11 21 08 11 9F 11 C4 62 02 9F FF C3 A6 2A 7B BB BB BA EA BB BB
X: 3
SWB: 16 05 40 05 BA EA BB BB BA EA BB BB BA EA E6 4A 01 E6 0A 01 64 10 21 06 00 9F 11 C4 64 11 21 08 01 9F 11 C4
X: 3
SWB: 16 05 60 05 E6 AC 08 90 0A 72 E6 5A 00 84 02 62 01 A6 2A E6 5A 00 90 2F E6 AC 20 90 13 A1 06 17 77 24 29 4C
X: 3
SWB: 16 05 80 05 44 06 75 42 05 73 E9 22 EA E3 8C 1A E4 92 17 A3 17 20 24 29 4C E0 52 05 94 13 24 DF 01 60 80 F1
X: 3
SWB: 16 05 A0 05 03 98 0A A4 17 00 24 DF 01 60 7F F0 03 24 DF 01 40 03 E7 08 02 A6 12 9F C7 04 98 07 24 DF 01 60
X: 3
SWB: 16 05 C0 05 7F F0 03 2F A0 0C 2D 9A 3D 3F 24 00 4C 40 10 C0 02 90 2C 25 29 4C 24 F7 04 01 18 F4 E1 4A 88 1F
X: 3
SWB: 16 05 E0 05 24 F4 03 01 00 F4 E1 4C 88 15 24 67 05 F8 14 84 0E A1 00 CF C0 01 90 07 24 DF 01 60 40 F1 03 24
X: 3
SWB: 16 05 00 06 DF 01 40 02 C0 01 84 06 40 03 C0 40 90 1B A1 06 22 24 29 4C 44 1D 75 A6 62 73 E9 E2 88 04 64 01
X: 3
SWB: 16 05 20 06 98 0B B6 92 A3 22 20 98 03 A4 22 00 74 24 DF 01 40 01 C0 10 90 05 25 30 4C 98 03 25 2B 4C 24 F7
X: 3
SWB: 16 05 40 06 04 01 18 24 DF 01 F4 E1 40 8C 1C 60 04 F1 01 A1 02 16 E0 52 42 88 07 B2 92 A3 16 20 98 10 E4 60
X: 3
SWB: 16 05 60 06 AB 88 0B 64 01 98 07 60 FB F0 01 A4 16 00 A6 42 9F C7 04 2F 2D 9A 3F A1 00 13 90 04 63 04 98 01
X: 3
SWB: 16 05 80 06 73 9F A8 19 66 08 9C 4E 24 63 05 03 01 A6 70 A6 18 A6 19 EB C1 EC D2 2F 9A 3F 24 C0 4F 40 05 C0
X: 3
SWB: 16 05 A0 06 02 90 0A A1 00 09 D0 02 84 03 A4 09 04 E4 92 09 A3 09 20 D2 04 94 03 A4 09 00 A1 02 09 84 04 62
X: 3
SWB: 16 05 C0 06 E5 98 1A D2 01 84 04 62 10 98 12 D2 02 84 04 62 31 98 0A D2 03 90 04 62 73 98 02 62 52 A1 00 13
X: 3
SWB: 16 05 E0 06 90 04 63 04 98 02 63 02 9F A8 19 66 08 9C 4E F6 13 A1 04 09 F6 31 9F BE 18 2F 9A 3F 32 21 59 05
X: 3
SWB: 16 05 00 07 9F 83 CA 32 21 5B 05 9F 83 CA 32 21 5D 05 9F 83 CA 32 21 5F 05 9F 83 CA 32 21 FB 04 9F 83 CA 2F
X: 3
SWB: 16 05 20 07 9A 3F F6 14 F8 01 84 01 33 F6 41 9C 3B 2F 9A 3D 3F 25 F7 04 33 02 6E 21 1D 01 9C 3B 33 02 46 21
X: 3
SWB: 16 05 40 07 19 01 9C 3B 33 02 54 21 21 01 9C 3B 2F 2D 9A 3F A4 20 00 9F FB 06 32 21 FD 04 9F 83 CA 32 21 25
X: 3
SWB: 16 05 60 07 05 9F 83 CA 9F 2F 07 2F 9A 3D A2 C0 3F 24 F7 04 02 04 A1 06 1D 24 C0 4F F4 E2 13 80 07 31 19 10
X: 3
SWB: 16 05 80 07 6C 01 98 4A F4 B1 11 E9 E2 8C 07 31 19 10 6C FF 98 3C D6 FF 84 1B EA B1 F4 E1 15 8C 4D F5 91 10
X: 3
SWB: 16 05 A0 07 19 10 B3 B3 B2 E2 B3 B3 B2 E2 E0 52 17 88 47 98 39 D6 01 84 35 F4 E2 15 8C 30 F5 91 10 19 10 B3
X: 3
SWB: 16 05 C0 07 B3 B2 E2 B3 B3 B2 E2 E0 52 18 88 2A 98 1C BC 56 90 18 25 F7 04 02 6C 21 25 05 9F 83 CA 02 44 21
X: 3
SWB: 16 05 E0 07 FD 04 9F 83 CA 9F 2F 07 A6 C6 A3 1D 60 D6 01 84 08 A4 7F 00 98 03 7C 99 D9 2F A0 0C 2D 9A 3F 24
X: 3
SWB: 16 05 00 08 00 40 00 08 38 00 06 38 9C 46 AC 9F A6 CE 20 00 80 E9 C0 84 03 21 01 80 2F 9A 3D 3E 3F A7 02 A6
X: 3
SWB: 16 05 20 08 2A 7B ED 66 F6 64 20 7B 01 E8 24 01 0E 9F 2E 02 9F FE 07 11 C0 F6 12 F6 61 20 39 05 E8 21 9F 83
X: 3
SWB: 16 05 40 08 CA ED 61 E9 61 20 BC 49 E8 25 46 41 77 02 C0 20 35 01 E8 21 9C 3B AA 2F 2E 2D 9A 3D 3E 3F A7 01
X: 3
SWB: 16 05 60 08 A6 2A A1 00 21 90 04 62 04 98 01 72 52 C0 24 DF 01 E0 60 01 80 06 40 03 C0 08 90 07 42 C0 E6 12
X: 3
SWB: 16 05 80 08 08 52 C0 43 C0 A6 A2 E6 22 E8 9F A8 19 24 63 05 F4 C9 00 F4 D2 02 A6 AC 7D EE 65 20 7D 01 E8 25
X: 3
SWB: 16 05 A0 08 20 80 00 E8 21 30 E8 32 DD 00 8C 14 D5 00 84 16 D4 7F 8C 0C D4 7F 84 0E D3 FF 84 0A D2 00 90 06
X: 3
SWB: 16 05 C0 08 21 00 FF 22 7F 00 66 08 9C 4E 11 40 40 C0 C0 08 90 10 9F 65 BF EE 65 20 7B 01 E8 25 66 08 9C 4E
X: 3
SWB: 16 05 E0 08 11 4E EE 64 20 7D 01 E8 24 01 00 B3 60 80 01 31 A9 2F 2E 2D 9A 3D 3E 3F A7 0D 24 00 40 00 00 10
X: 3
SWB: 16 05 00 09 C3 84 08 21 48 01 9F BD C6 11 C3 9F 28 03 32 33 12 C5 13 C7 98 9E 42 C2 9F 5B 08 F6 15 02 C3 9C
X: 3
SWB: 16 05 20 09 43 F4 21 C5 F4 3A C7 11 C5 12 C7 F6 52 01 C3 9F 6A CE F6 15 42 C2 9F 1A 08 4C C2 7D EE 63 13 C9
X: 3
SWB: 16 05 40 09 F6 52 F6 31 20 51 05 E8 21 9F 83 CA 44 C2 F6 51 9F E9 9D 11 C0 04 C9 20 31 05 E8 24 14 CB F6 12
X: 3
SWB: 16 05 60 09 F6 41 9F 83 CA EE 65 ED 65 20 BC 49 E8 26 46 81 77 02 C0 F6 51 20 25 01 E8 21 9F 21 07 73 42 C2
X: 3
SWB: 16 05 80 09 9F 2D 69 F6 13 04 CB 02 00 F6 51 20 9B 01 E8 21 9F B9 CB 73 42 C2 9F 2D 69 02 C9 20 39 05 E8 22
X: 3
SWB: 16 05 A0 09 12 C9 F6 13 F6 24 02 00 F6 51 20 AB 01 E8 21 9F B9 CB 42 C2 B2 89 59 C2 D2 00 87 5A 63 01 9F 2D
X: 3
SWB: 16 05 C0 09 69 F6 13 24 9A 03 02 00 21 BB 01 9F B9 CB 98 0A 42 C2 9F 5B 08 E0 92 C2 52 C2 43 C2 D3 03 97 F0
X: 3
SWB: 16 05 E0 09 01 C5 02 C7 9F DA CE F6 12 21 41 05 9F 83 CA 24 BC 49 46 07 77 24 31 05 02 10 21 4D 01 9F 21 07
X: 3
SWB: 16 05 00 0A A5 0D 2F 2E 2D 9A 3D 3F A7 04 24 63 05 01 00 02 02 11 C0 12 C2 24 C0 4F 05 0F 24 96 05 40 00 84
X: 3
SWB: 16 05 20 0A 01 35 21 EF 00 9F A8 19 3A 39 F6 52 F6 81 E6 22 04 B3 D3 9C 3C 66 04 F6 82 E6 24 04 B5 D5 21 63
X: 3
SWB: 16 05 40 0A 05 9F 5B CA AC AC 2F 2D 9A 3F B3 60 80 01 31 9F 69 CF 2F 9A 3D 3F A1 02 12 84 08 A4 12 01 9F 06
X: 3
SWB: 16 05 60 0A 0A 98 87 D2 03 90 04 D2 01 84 45 24 00 40 01 02 84 06 21 5E 01 9F BD C6 F6 15 A1 00 12 D0 03 84
X: 3
SWB: 16 05 80 0A 05 A4 12 00 98 03 A4 12 02 62 EC 9F 76 06 24 7B 01 11 0A F6 52 9F 49 0A F6 12 21 45 05 9F 83 CA
X: 3
SWB: 16 05 A0 0A 24 BC 49 46 05 77 24 31 05 02 14 21 49 01 98 37 24 00 40 01 04 84 06 21 5C 01 9F BD C6 F6 15 A4
X: 3
SWB: 16 05 C0 0A 12 03 62 ED 9F 76 06 24 7B 01 11 0C F6 52 9F 49 0A F6 12 21 43 05 9F 83 CA 24 BC 49 46 06 77 24
X: 3
SWB: 16 05 E0 0A 31 05 02 12 21 45 01 9F 21 07 2F 2D 9A A2 A0 3F 24 C0 4F 40 05 C0 02 90 25 6A 07 9F 48 4F D2 00
X: 3
SWB: 16 05 00 0B 90 0A BA 8A 9F A7 41 E6 5A 00 87 EF 9F 90 41 9F F5 4F D2 00 84 08 24 78 02 E0 92 00 52 00 2F A0
X: 3
SWB: 16 05 20 0B 0A 9A A2 A0 3F 24 C0 4F 4A 05 E6 0A 02 E6 5A 00 90 03 9F 75 4F 24 96 05 40 00 90 08 24 DF 01 E0
X: 3
SWB: 16 05 40 0B 60 01 80 1C A4 13 01 A4 12 00 9F 54 0A 9F 54 0A 9F 99 06 E6 5A 00 84 0B 9F 99 06 9F 99 06 98 03
X: 3
SWB: 16 05 60 0B A4 13 00 9F 99 06 9F 99 06 72 9F 44 C3 9F F5 08 9F 54 0A A1 02 21 9F 44 C3 9F E0 BF 9F ED 0A 2F
X: 3
SWB: 16 05 80 0B A0 0A 9A A2 A0 3F FC 60 24 59 05 4A 09 74 21 62 05 9F 79 CA FC 50 A6 A2 2F A0 0A 9A 3D 3E 3F A7
X: 3
SWB: 16 05 A0 0B 08 09 23 0A 25 11 C4 12 C6 24 DF 01 E0 60 01 80 09 24 00 4C 40 11 C0 01 90 E6 01 C4 02 C6 9D 27
X: 3
SWB: 16 05 C0 0B D9 9C 3A 24 C6 49 4A 02 7B 0A 0C 0B 0E ED E1 8C 5E 3B 3A 01 C8 02 CA 9C 40 AC F6 23 F6 12 19 0C
X: 3
SWB: 16 05 E0 0B 1B 0E F5 91 0A 19 0A 24 C6 49 07 03 EF C1 88 04 31 32 98 4D F7 00 42 F7 00 00 F6 21 F6 32 9C 46
X: 3
SWB: 16 05 00 0C AC F6 15 F6 26 F6 71 32 9C 53 3A 39 F6 51 F6 62 9C 4C AC 9D 27 D9 9C 3A 24 C6 49 4A 01 7B ED E1
X: 3
SWB: 16 05 20 0C 8C 04 31 32 98 04 09 0C 0A 0E 33 1B 0A 98 0C 3B 3A 01 C8 02 CA 9C 40 AC 34 1C 0A 33 34 1B 0C 1C
X: 3
SWB: 16 05 40 0C 0E 24 00 40 00 0C 38 00 0A 38 9C 46 AC 11 C0 12 C2 25 BF 01 4D 44 3A 39 F6 51 9F 83 D6 44 44 E5
X: 3
SWB: 16 05 60 0C C4 D4 21 61 05 9F 79 CA 01 C4 02 C6 9F A5 9A AC 24 DF 01 D2 00 90 06 60 10 F1 00 98 04 60 EF F0
X: 3
SWB: 16 05 80 0C 00 9F 0F 57 39 76 01 C2 02 C4 9F 0E 81 FC 60 24 59 05 44 08 E0 24 09 21 62 05 9F 79 CA FC 50 AA
X: 3
SWB: 16 05 A0 0C A8 2F 2E 2D 9A 3D A2 C0 3F A1 0A EA 7B 24 00 41 4C 00 E6 AC 02 90 26 E6 AA 02 84 24 A1 02 20 73
X: 3
SWB: 16 05 C0 0C E9 64 20 59 05 E8 24 01 00 9C 3A 24 C0 4F F4 E1 11 94 0A E4 60 AB 88 05 E6 AC 04 84 03 74 98 02
X: 3
SWB: 16 05 E0 0C 64 01 BB B3 BA E2 B3 B3 B2 E2 E6 42 01 C2 01 B2 54 90 0F D4 00 90 05 21 08 0C 98 03 21 0C 0C 9F
X: 3
SWB: 16 05 00 0D 0C C0 2F A0 0C 2D 9A 3D 3F 9F 18 C5 24 7B 01 11 00 9F 2E 02 19 23 1A 25 9F FE 07 F6 13 A1 02 20
X: 3
SWB: 16 05 20 0D A6 2A 7B 20 02 00 E8 E5 94 03 72 98 02 B2 92 A3 20 20 24 DF 01 E0 60 01 88 05 32 D2 00 84 03 22
X: 3
SWB: 16 05 40 0D 01 00 A3 1F 40 73 E9 61 F6 32 20 59 05 E8 21 9F 83 CA 9F A5 0C 9F 9C 0B 2F 2D 9A 3D 3E 3F 24 59
X: 3
SWB: 16 05 60 0D 05 05 02 A6 B0 A6 1C A6 1D 01 00 A6 30 A6 14 A6 15 E9 25 EA 36 01 04 A6 30 A6 14 A6 15 E9 25 EA
X: 3
SWB: 16 05 80 0D 36 01 06 A6 30 A6 14 A6 15 E9 25 EA 36 E6 ED 00 88 08 20 03 00 E8 25 30 E8 36 66 02 F6 51 F6 62
X: 3
SWB: 16 05 A0 0D 9C 4E F6 16 9C 3A 24 C6 49 4A 00 7B ED E1 88 01 36 F6 62 21 FB 04 9F 83 CA A1 00 1F 90 1D 24 BC
X: 3
SWB: 16 05 C0 0D 49 46 00 77 24 F7 04 02 04 21 19 01 9C 3B 21 19 01 9C 3D F6 12 21 FD 04 9F 83 CA 2F 2E 2D 9A 3D
X: 3
SWB: 16 05 E0 0D 3E 3F A7 01 24 DF 01 4A 00 A6 A2 C2 01 52 C0 26 79 01 24 C0 4F 40 04 C0 04 90 11 62 03 9F FF 01
X: 3
SWB: 16 05 00 0E 11 80 A6 A2 E6 12 01 24 DF 01 98 20 01 80 9F 32 03 F6 15 11 80 62 01 9F FF 01 ED C1 84 12 24 DF
X: 3
SWB: 16 05 20 0E 01 42 00 E6 12 01 60 BF F2 83 C2 BF 52 00 98 13 62 02 9F FF 01 ED C1 84 0A 24 DF 01 60 FE F0 00
X: 3
SWB: 16 05 40 0E 9F D7 63 24 DF 01 42 00 C2 01 E0 42 C0 A9 2F 2E 2D 9A 3D 3E 3F A7 0D 9F 28 03 52 C8 31 11 C6 24
X: 3
SWB: 16 05 60 0E FF 7F 14 C4 11 C2 98 75 E0 89 C8 59 C8 59 CB 72 52 CC F4 66 CB EE 66 F6 61 20 25 01 E8 21 9C 3D
X: 3
SWB: 16 05 80 0E F6 15 F4 64 CB 14 C9 F6 12 F6 41 20 FF 04 E8 21 9F 83 CA 24 F7 04 F8 04 84 03 36 98 0B F6 61 20
X: 3
SWB: 16 05 A0 0E 35 01 E8 21 9C 3D F6 16 01 C4 ED E1 94 02 15 C4 04 C6 ED E4 88 02 15 C6 01 C2 ED 21 11 C2 F6 62
X: 3
SWB: 16 05 C0 0E 01 C9 20 13 05 E8 21 9F 83 CA F6 52 F6 61 9F B0 CB F6 12 01 C9 20 1B 05 E8 21 9F 83 CA 43 C8 D3
X: 3
SWB: 16 05 E0 0E 00 87 85 02 C4 21 0F 05 9F 83 CA 02 C6 21 0D 05 9F 83 CA 9F 28 03 A6 24 01 C2 75 9C 48 F6 12 21
X: 3
SWB: 16 05 00 0F 11 05 9F 83 CA 21 49 01 9C 3D F6 12 21 09 05 9F 83 CA A4 18 01 21 45 01 9C 3D F6 12 21 07 05 9F
X: 3
SWB: 16 05 20 0F 83 CA 21 4D 01 9C 3D F6 16 F6 12 21 F9 04 9F 83 CA F6 62 24 F7 04 01 04 9F B0 CB 11 C0 F6 12 21
X: 3
SWB: 16 05 40 0F 23 05 9F 83 CA A1 00 1F 90 37 24 BC 49 4A 00 7B A6 A6 A6 B7 F6 62 21 21 01 9F 21 07 21 21 01 9C
X: 3
SWB: 16 05 60 0F 3D F6 12 21 0B 05 9F 83 CA A6 A6 A6 B7 02 C0 21 1D 01 9C 3B 21 1D 01 9C 3D F6 12 21 25 05 9F 83
X: 3
SWB: 16 05 80 0F CA A5 0D 2F 2E 2D 9A 3D 3E 3F A7 16 25 C0 4F 42 40 52 D1 24 F7 04 02 38 12 D2 45 42 55 D0 47 44
X: 3
SWB: 16 05 A0 0F C7 80 25 31 05 34 14 CB 27 FF 7F 76 65 01 36 74 31 11 C6 73 53 C5 40 D1 B5 00 90 3C D6 05 84 04
X: 3
SWB: 16 05 C0 0F 01 D2 98 02 01 56 40 D0 B5 00 90 1A D7 00 90 0D 04 C6 E9 24 14 C6 E0 99 C5 59 C5 98 1B F4 E1 C6
X: 3
SWB: 16 05 E0 0F 94 16 11 C6 98 12 E9 E7 94 02 F6 17 04 CB E9 E4 88 02 11 CB E9 26 B4 94 B6 96 ED 95 ED 95 D6 06
X: 3
SWB: 16 05 00 10 90 04 B5 65 99 B0 D4 00 90 07 F6 61 75 9C 48 F6 16 24 BC 49 4A 08 7B A6 A6 A6 B7 F6 72 21 51 01
X: 3
SWB: 16 05 20 10 9F 21 07 A6 A6 A6 B7 02 CB 21 55 01 9F 21 07 A6 A6 A6 B7 F6 62 21 59 01 9F 21 07 25 C0 4F 40 45
X: 3
SWB: 16 05 40 10 C0 02 90 D9 9F BA 4C D2 00 90 D2 49 41 59 CF 49 43 48 44 E6 08 80 25 08 02 65 01 37 17 C9 21 FF
X: 3
SWB: 16 05 60 10 7F 11 D4 36 74 33 73 53 C2 40 CF B5 00 90 39 A6 90 B5 00 90 1D E6 58 00 90 0E F6 37 F4 27 54 17
X: 3
SWB: 16 05 80 10 C3 E0 9F C2 5F C2 98 22 01 54 11 C3 EB E1 8C 1A 98 16 01 54 07 D4 E9 E7 94 02 11 D4 07 C9 E9 E7
X: 3
SWB: 16 05 A0 10 88 02 11 C9 E9 26 B4 94 13 C3 ED 95 ED 95 20 18 02 ED C0 90 06 B5 65 03 C3 99 AE D4 00 90 07 F6
X: 3
SWB: 16 05 C0 10 61 75 9C 48 F6 16 24 BC 49 4A 08 7B A6 A6 A6 B7 02 D4 21 5D 01 9F 21 07 A6 A6 A6 B7 02 C9 21 61
X: 3
SWB: 16 05 E0 10 01 9F 21 07 A6 A6 A6 B7 F6 62 21 65 01 9F 21 07 21 5D 01 9C 3D F6 12 21 2B 05 9F 83 CA 21 61 01
X: 3
SWB: 16 05 00 11 9C 3D F6 12 21 29 05 9F 83 CA 21 65 01 9C 3D F6 12 21 2D 05 9F 83 CA 6F 01 5F C8 98 30 21 51 01
X: 3
SWB: 16 05 20 11 9C 3D F6 12 21 2B 05 9F 83 CA 21 55 01 9C 3D F6 12 21 29 05 9F 83 CA 21 59 01 9C 3D F6 12 21 2D
X: 3
SWB: 16 05 40 11 05 9F 83 CA 72 52 C8 32 12 C3 75 55 C2 24 C0 4F 42 05 C2 C0 D2 00 84 07 24 F7 04 02 32 98 09 D2
X: 3
SWB: 16 05 60 11 40 84 09 24 F7 04 02 36 F6 41 98 30 26 F7 04 D2 80 84 06 02 B4 F6 61 98 23 07 B2 17 C0 05 19 01
X: 3
SWB: 16 05 80 11 B4 ED C1 9C 3A 11 CD 01 B2 ED C1 9C 3A 02 CD E9 E2 94 04 04 B4 14 C0 02 C0 21 F7 04 9F 83 CA 24
X: 3
SWB: 16 05 A0 11 C0 4F E0 60 04 80 20 49 C5 E6 59 00 90 09 01 C6 A6 94 75 9C 48 11 C6 4E C2 E6 5E 00 90 09 01 C3
X: 3
SWB: 16 05 C0 11 A6 E4 75 9C 48 11 C3 24 BC 49 4A 09 7B A6 A6 A6 B7 02 C6 21 69 01 9F 21 07 A6 A6 A6 B7 02 C3 21
X: 3
SWB: 16 05 E0 11 6D 01 9F 21 07 4F C8 E6 5F 00 90 05 21 6D 01 98 03 21 69 01 9C 3D F6 12 21 27 05 9F 83 CA A5 16
X: 3
SWB: 16 05 00 12 2F 2E 2D 9A 3F 9F 52 0E 9F 87 0F 24 59 05 42 08 9F 54 62 9F 08 05 A1 00 1F 90 8C 9F F9 C2 A3 1E
X: 3
SWB: 16 05 20 12 20 CA 0F 90 03 9F FB 06 24 DF 01 E4 60 1E 80 06 60 20 F1 00 98 04 60 DF F0 00 74 24 F7 04 01 12
X: 3
SWB: 16 05 40 12 24 29 4C F4 E1 10 94 02 64 01 A6 42 9F 46 67 9F C8 65 9F B6 63 24 68 02 40 01 84 0C 40 03 84 08
X: 3
SWB: 16 05 60 12 40 05 84 04 40 07 90 09 24 DF 01 60 08 F1 01 98 07 24 DF 01 60 F7 F0 01 9F EB C6 24 DF 01 D2 00
X: 3
SWB: 16 05 80 12 90 06 60 02 F1 02 98 04 60 FD F0 02 24 DF 01 A1 00 21 90 06 60 10 F1 03 98 04 60 EF F0 03 9F C8
X: 3
SWB: 16 05 A0 12 05 9F 77 01 9F 0D 4A 2F 9A 3F 9F 3F C2 B2 62 65 0E A6 24 21 DF 01 9F 48 CA 2F 9A 3D 3F A6 2A 9F
X: 3
SWB: 16 05 C0 12 F2 33 A6 23 A1 00 AA C0 10 90 2F 24 DF 01 42 00 CA 41 D0 01 84 24 40 03 C0 20 84 1E A1 00 27 90
X: 3
SWB: 16 05 E0 12 09 24 00 4C 40 10 C0 20 90 10 D3 00 84 0C 31 24 29 4C A1 00 22 E0 50 1C 94 03 21 01 00 A6 25 24
X: 3
SWB: 16 05 00 13 C0 4F 44 06 E6 5A 00 90 2B D2 00 84 11 E6 5A 01 90 0C E6 5A 03 84 08 24 F6 04 44 00 98 01 74 73
X: 3
SWB: 16 05 20 13 A6 42 9F 3F C4 A6 24 21 F6 04 9F 79 CA 24 F6 04 4B 00 98 C0 D2 00 84 1D 24 DF 01 E0 60 03 88 15
X: 3
SWB: 16 05 40 13 25 29 4C 24 F7 04 01 18 F4 E1 42 8C 0E A1 00 16 E0 50 44 80 06 C4 FE D5 00 84 3F 24 00 4C 43 09
X: 3
SWB: 16 05 60 13 CB 10 90 09 24 46 02 40 01 C0 10 84 2D CB 08 90 09 24 46 02 40 01 C0 20 84 20 CB 20 90 07 A1 00
X: 3
SWB: 16 05 80 13 CD C0 08 84 15 24 C0 4F 42 04 CA 0C 90 10 CB 40 84 0C 24 DF 01 E0 60 01 80 04 C4 F1 98 10 24 46
X: 3
SWB: 16 05 A0 13 02 40 01 C0 01 90 07 A6 42 9F 8D 02 A6 24 CC 02 90 10 24 F7 04 01 02 24 C0 4F F4 E1 0D 88 03 E6
X: 3
SWB: 16 05 C0 13 14 08 A6 42 9F F0 01 9F A0 02 24 00 4C 40 09 E7 08 40 A6 1A E6 0A 01 A6 A3 9F 00 64 A6 2B A6 A3
X: 3
SWB: 16 05 E0 13 9F E2 64 A6 2A A6 24 21 F6 04 9F 79 CA 63 CF A6 A2 9F 74 C3 24 DF 01 E6 AB 01 84 06 60 20 F1 01
X: 3
SWB: 16 05 00 14 98 04 60 DF F0 01 24 DF 01 E6 AB 06 84 06 60 40 F1 01 98 04 60 BF F0 01 A1 00 1E 90 06 9F D7 C0
X: 3
SWB: 16 05 20 14 A4 1E 00 9F A9 12 2F 2D 9A 3F 62 03 9F BB 12 9F 2F 07 2F 9A 3F E4 92 15 A3 15 20 FC 60 24 C5 01
X: 3
SWB: 16 05 40 14 52 00 A1 02 14 52 01 23 16 00 22 7B 01 21 C7 01 9C 3F FC 50 A1 02 14 24 DF 01 40 02 C0 20 90 0C
X: 3
SWB: 16 05 60 14 D2 02 90 15 A4 14 02 9F 5E C5 98 0A D2 01 90 09 A4 14 01 9F 4E C5 9F A5 0C 2F 9A 3F 9F 77 C4 9F
X: 3
SWB: 16 05 80 14 22 0B 9F 07 0D 9F 34 14 9F 5B 0D 9F DF 0D 9F 04 12 9F 6E 03 9F 65 04 21 00 04 9F 64 C8 2F 9A A2
X: 3
SWB: 16 05 A0 14 A0 3F A6 2A 32 21 01 04 9F 54 C8 9F A5 0C E6 5A 00 90 03 9F 4E C5 2F A0 0A 9A 3D 3E 3F 64 24 21
X: 3
SWB: 16 05 C0 14 9B 01 9C 38 9F 28 03 98 24 B2 82 A6 24 75 EA 64 EA 65 ED 65 20 9B 01 E8 25 F6 46 20 31 05 E8 26
X: 3
SWB: 16 05 E0 14 03 80 13 42 20 39 05 E8 24 03 00 13 52 D2 00 87 D8 25 9B 01 24 F7 04 01 34 11 62 2F 2E 2D 9A 3F
X: 3
SWB: 16 05 00 15 62 01 9F BB 12 9F C1 01 A4 20 03 9F 7B 14 9F BA 14 2F 9A 3F 24 68 02 40 09 84 0C 40 0B 84 08 40
X: 3
SWB: 16 05 20 15 0D 84 04 40 0F 90 08 64 01 21 35 17 9F F7 48 2F 9A 3D 3F 62 80 9F C3 C4 62 01 9F 9F 14 9F DF 0D
X: 3
SWB: 16 05 40 15 25 96 05 E0 80 40 90 16 21 88 46 9F 36 68 40 40 D0 02 90 05 9F FF 14 98 08 9F 29 14 98 03 9F 59
X: 3
SWB: 16 05 60 15 01 A4 1D 00 64 02 21 96 05 9F 79 CA 9F 13 15 72 9F BB 12 9F 7B 14 9F B6 57 9F 69 07 99 EE 3F A1
X: 3
SWB: 16 05 80 15 00 AB C0 02 84 0F 24 00 4C 40 12 C0 10 90 06 21 07 03 9F 08 C4 2F 9A 3F 9F FC C0 2F 9A 3F 9F 0B
X: 3
SWB: 16 05 A0 15 C1 2F 9A 3D 3F 24 80 46 03 10 25 F7 04 24 00 4C E0 60 09 80 04 02 52 98 02 02 42 A1 00 AB C0 01
X: 3
SWB: 16 05 C0 15 90 49 24 00 4C 25 68 02 42 00 E0 02 49 84 15 42 01 E0 02 4B 84 0E 42 02 E0 02 4D 84 07 42 03 E0
X: 3
SWB: 16 05 E0 15 02 4F 90 27 24 00 4C F4 E2 04 8C 09 24 68 02 40 0D C0 03 90 16 A1 00 29 84 11 9F 9D 15 A4 29 01
X: 3
SWB: 16 05 00 16 24 00 4C 42 06 A3 28 20 23 72 36 F6 31 2F 2D 9A 3F A7 12 24 80 46 40 09 84 0C 40 0B 84 08 40 0D
X: 3
SWB: 16 05 20 16 84 04 40 0F 90 22 9F 97 15 64 10 21 68 02 9C 38 64 12 F6 81 9C 38 A4 29 00 60 FD F2 F2 23 12 00
X: 3
SWB: 16 05 40 16 F6 82 21 80 46 9F E3 C5 A5 12 2F 9A 3D 3F A7 19 24 DF 01 01 00 02 02 11 C0 12 C2 23 05 00 22 46
X: 3
SWB: 16 05 60 16 02 F6 81 E6 22 04 B3 D3 9C 3F 0A CD 12 C9 09 CF 11 CB 25 F7 04 23 08 00 22 FF 04 F6 81 E6 22 0D
X: 3
SWB: 16 05 80 16 B3 D3 9C 3F 02 50 12 D5 01 52 11 D7 23 19 00 F6 82 21 92 46 9F E3 C5 A5 19 2F 2D 9A 3D 3E 3F A7
X: 3
SWB: 16 05 A0 16 12 21 80 46 F6 86 25 68 02 98 0F F6 14 40 40 E0 10 00 50 80 EE 96 E9 91 ED 95 20 7A 02 ED C0 87
X: 3
SWB: 16 05 C0 16 EA 9F A3 15 11 D0 60 FD F2 F2 23 12 00 F6 82 21 80 46 9F E3 C5 60 02 F3 F2 A5 12 2F 2E 2D 9A 3F
X: 3
SWB: 16 05 E0 16 A7 16 23 0A 00 22 47 05 F6 84 EC 91 E9 91 9C 3F 9F 52 82 23 08 00 F6 12 F6 81 E6 22 0C B3 D3 9C
X: 3
SWB: 16 05 00 17 3F 24 F7 04 01 04 11 C0 24 5C 03 01 00 11 D4 23 16 00 F6 82 21 AB 46 9F E3 C5 A5 16 2F 9A 3F A7
X: 3
SWB: 16 05 20 17 15 F6 81 9F D1 C2 23 15 00 F6 82 21 C1 46 9F E3 C5 A5 15 2F 9A 3D 3E 3F 62 01 9F BB 12 24 DF 01
X: 3
SWB: 16 05 40 17 60 10 F1 01 A4 29 00 25 00 4C 24 DD 01 01 47 11 00 62 82 9F C3 C4 62 01 9F 9F 14 24 80 46 40 09
X: 3
SWB: 16 05 60 17 84 1E 40 0B 84 1A 40 0D 84 16 40 0F 84 12 9F 63 50 9F FC 4B 9F 4C 16 9F DF 16 9F 1E 17 9F 9C 16
X: 3
SWB: 16 05 80 17 60 02 F3 F2 9F 4F 07 25 68 02 26 DD 01 98 74 72 9F BB 12 9F 9C 16 9F 7B 14 A1 00 1F 90 5F 9F D9
X: 3
SWB: 16 05 A0 17 4A 24 00 4C 40 06 90 16 9F F3 C0 D2 00 90 0F A1 02 28 90 07 B2 82 A3 28 20 98 03 9F 97 15 A1 00
X: 3
SWB: 16 05 C0 17 AB C0 02 84 38 24 00 4C 40 12 C0 10 90 2F 24 80 46 F8 10 90 28 62 07 9F FF C3 A6 24 A6 25 01 80
X: 3
SWB: 16 05 E0 17 84 07 24 00 4C F8 07 84 0B E9 81 11 80 A6 53 E6 13 44 98 04 A6 43 C3 BB 62 07 9F 08 C4 9F B6 57
X: 3
SWB: 16 05 00 18 9F 69 07 40 49 87 88 40 4B 87 84 40 4D 87 80 40 4F 87 7C 60 FD F2 F2 24 DF 01 60 EF F0 01 64 01
X: 3
SWB: 16 05 20 18 21 31 15 9F F7 48 2F 2E 2D 9A 3F 62 02 9F 17 C8 9F 22 0B 62 02 9F 20 C8 2F 9A 3D 3E 3F 24 C0 4D
X: 3
SWB: 16 05 40 18 40 00 C0 20 90 04 01 0E 19 D1 72 9F 9F 14 35 26 DF 01 21 01 00 9F 8D C8 72 9F BB 12 E6 5B 00 90
X: 3
SWB: 16 05 60 18 0D 40 80 C0 40 84 07 A1 00 CF C0 20 90 08 9F 2A 18 24 29 4C 4B 19 9F 04 12 9F B6 57 E6 5B 00 90
X: 3
SWB: 16 05 80 18 02 BB 8B E6 5A 02 8C 05 A1 02 21 98 01 72 9F 44 C3 BA 9A E6 5A 03 94 01 7A 21 00 04 9F 64 C8 99
X: 3
SWB: 16 05 A0 18 B1 63 01 98 04 B3 63 A6 42 B2 84 D2 00 87 F6 24 C0 4F A6 32 E0 02 02 D2 00 90 02 62 01 9A 3D 3E
X: 3
SWB: 16 05 C0 18 3F A7 0B 54 CA 24 63 05 F4 C9 01 11 C2 54 C8 72 52 C9 F4 64 C8 20 7B 01 E8 24 02 C2 12 16 45 CA
X: 3
SWB: 16 05 E0 18 D5 00 84 1C 26 80 49 04 C2 F4 E4 84 88 04 03 86 98 94 02 80 01 C2 9F 6A CE F6 13 F4 23 82 98 86
X: 3
SWB: 16 05 00 19 21 6A 01 9F BD C6 11 C6 21 6C 01 9F BD C6 F6 15 42 CA 9F A1 18 D2 00 90 05 26 A2 49 98 03 26 88
X: 3
SWB: 16 05 20 19 49 02 96 84 02 02 C6 01 98 84 02 F6 51 25 00 80 F6 13 F6 51 F4 C9 C2 9F 0D CF 02 C2 E9 C2 12 C0
X: 3
SWB: 16 05 40 19 01 94 04 92 14 C4 F6 53 E9 C3 F6 42 E9 C2 F6 51 F4 C9 C0 9F 0D CF 03 C4 E9 C3 02 92 01 C0 9F 0D
X: 3
SWB: 16 05 60 19 CF F6 15 66 05 F6 12 F6 61 9F 79 CE F6 13 F6 52 21 00 40 9F 0D CF 66 04 F6 12 F6 61 E6 22 0A B3
X: 3
SWB: 16 05 80 19 D3 9F 79 CE F6 13 01 C8 20 00 40 E8 21 F6 14 44 14 EA 0A 42 CA 73 E9 61 EB 22 20 47 05 E8 21 9F
X: 3
SWB: 16 05 A0 19 83 CA A5 0B 2F 2E 2D 9A 3F 9F BB BF 9F 9A BF 2F 9A 3D B3 60 80 01 31 F6 15 EA E1 94 02 F6 25 24
X: 3
SWB: 16 05 C0 19 00 4C 40 0B C0 01 90 2C 24 46 02 E0 60 01 88 24 A1 00 CD C0 02 84 1D F7 00 00 F7 70 FD F6 21 A6
X: 3
SWB: 16 05 E0 19 30 A6 14 A6 15 9C 45 AC 66 10 9C 4E F6 12 E9 E5 94 02 F6 25 F6 51 2D 9A 24 67 05 E0 60 07 80 04
X: 3
SWB: 16 05 00 1A E9 91 E9 91 9A 3F 24 DF 01 D2 00 90 06 60 80 F1 00 98 04 60 7F F0 00 24 00 4C 43 12 CB 01 90 1D
X: 3
SWB: 16 05 20 1A CB 02 84 09 73 D2 00 84 02 63 01 A6 32 D2 00 84 03 73 98 02 63 44 64 44 62 08 9F 11 C4 2F 9A 3F
X: 3
SWB: 16 05 40 1A 24 DF 01 E0 60 00 88 32 24 67 05 02 18 24 00 4C 40 12 C0 04 90 06 24 94 07 44 09 75 24 F7 04 01
X: 3
SWB: 16 05 60 1A 04 24 67 05 30 E8 E1 94 07 F4 E2 2C 80 0C 98 05 F4 E2 2A 8C 05 62 01 9F 05 1A 2F 9A 3F E4 60 CD
X: 3
SWB: 16 05 80 1A 80 04 64 80 98 01 74 65 80 21 6D 05 9F 48 CA 2F 9A 3D 3F F6 15 24 00 4C 46 0B CE 10 90 19 F9 20
X: 3
SWB: 16 05 A0 1A 84 15 F8 40 90 11 A1 00 CD E7 08 08 A6 12 E6 42 01 73 22 01 00 E9 02 CE 02 90 1D 24 00 4E 40 01
X: 3
SWB: 16 05 C0 1A C0 10 84 14 24 DF 01 40 03 C0 01 84 0B E4 A0 1D 84 06 00 40 EA 50 94 05 F6 51 9F 83 CA 2F 2D 9A
X: 3
SWB: 16 05 E0 1A 3D 3F 24 00 4C 4B 16 4A 17 44 14 45 15 40 12 C0 04 90 06 4B 18 7A 44 19 75 21 91 05 9F 83 CA A6
X: 3
SWB: 16 05 00 1B B4 A6 A5 21 93 05 9F 83 CA 72 9F 05 1A 2F 2D 9A 3D 3E 3F A7 02 9F DC 3C 9F 4E 3C D2 00 84 13 25
X: 3
SWB: 16 05 20 1B 94 07 02 44 21 83 05 9F 83 CA 02 46 21 85 05 9F 83 CA 25 94 07 44 48 75 21 79 05 9F 83 CA 9F 3E
X: 3
SWB: 16 05 40 1B 3C D2 00 84 39 9F 22 42 D2 00 90 09 24 40 51 01 00 02 02 98 04 01 40 02 42 12 C0 25 67 05 02 5C
X: 3
SWB: 16 05 60 1B 9F B1 19 F6 16 02 5E 01 C0 9F B1 19 F6 15 F6 62 21 7F 05 9F 91 1A F6 52 21 81 05 9F 91 1A 9F 37
X: 3
SWB: 16 05 80 1B 88 24 00 4C 40 0B C0 04 90 1C A1 00 CD C0 01 90 15 24 67 05 E0 60 07 88 06 F8 18 90 06 98 07 F8
X: 3
SWB: 16 05 A0 1B 1A 84 03 A4 7F 01 AA 2F 2E 2D 9A 3D 3E 3F A7 07 21 7F 05 9F F8 19 F6 14 01 00 11 C4 21 83 05 9F
X: 3
SWB: 16 05 C0 1B F8 19 F6 14 02 00 12 C0 21 80 4D 9F F8 19 F6 14 01 00 11 C2 24 00 4C 40 0B C0 08 84 0B 66 01 02
X: 3
SWB: 16 05 E0 1B C0 01 C4 9F 71 CB 98 35 05 C0 A6 B0 A6 1C A6 1D F7 00 00 F7 70 FD F6 51 F6 62 9C 45 AC 66 10 9C
X: 3
SWB: 16 05 00 1C 4E 02 C4 E9 E2 94 0F F6 21 22 64 00 9C 43 F6 54 F6 65 9C 4A 98 07 02 C0 01 C4 9F 5C CB A6 24 75
X: 3
SWB: 16 05 20 1C 21 7B 05 9F 91 1A 76 02 C2 01 C4 9F 71 CB F6 12 21 7D 05 9F 91 1A 25 67 05 43 56 42 54 9F B3 95
X: 3
SWB: 16 05 40 1C 40 47 E7 08 02 A6 12 9F D9 98 24 94 07 44 0B 75 21 8F 05 9F 83 CA 01 66 C2 8F C3 35 A6 2D A6 3C
X: 3
SWB: 16 05 60 1C A1 04 CD CC 40 90 03 E6 1D 40 21 67 05 54 C6 9F F8 19 F6 14 01 00 44 C6 E6 AD 40 90 08 F4 E1 C4
X: 3
SWB: 16 05 80 1C 94 03 E6 1C 02 CC 08 90 05 E4 80 1D 90 3A 25 68 02 42 40 CA 0E 84 31 42 42 CA 90 84 2B 42 44 CA
X: 3
SWB: 16 05 A0 1C 81 84 25 40 46 C0 07 84 1F 42 48 CA 06 84 19 24 DF 01 40 00 C0 01 90 10 40 49 84 0C 40 4B 84 08
X: 3
SWB: 16 05 C0 1C 40 4D 84 04 40 4F 90 03 E6 1C 40 CC 02 90 03 E6 1D 20 CC 04 90 05 E4 A0 1D 90 3A 25 68 02 42 40
X: 3
SWB: 16 05 E0 1C CA 31 84 31 42 42 CA E0 84 2B 40 44 C0 01 84 25 40 46 C0 08 84 1F 42 48 CA 09 84 19 24 DF 01 40
X: 3
SWB: 16 05 00 1D 00 C0 01 90 10 40 49 84 0C 40 4B 84 08 40 4D 84 04 40 4F 90 03 E6 1C 08 CC 01 84 15 24 68 02 40
X: 3
SWB: 16 05 20 1D 01 C0 01 84 0C 40 03 C0 40 84 06 40 09 C0 01 90 03 E6 1D 10 24 68 02 40 05 C0 40 90 08 E4 80 1D
X: 3
SWB: 16 05 40 1D 84 03 E6 1C 80 A6 D4 A6 C5 21 8D 05 9F 83 CA AF 2F 2E 2D 9A 3D 3E 3F F6 16 30 E8 E1 8C 05 21 FF
X: 3
SWB: 16 05 60 1D FF 98 59 24 5C 03 05 00 F4 25 2E 30 E8 E5 8C 03 31 98 49 24 97 4F 02 00 F6 20 E9 50 94 03 37 98
X: 3
SWB: 16 05 80 1D 0A F6 17 EA C7 ED 57 94 02 F6 57 F6 61 9C 49 20 02 00 E8 51 8C 04 E9 61 98 10 20 08 00 E8 51 94
X: 3
SWB: 16 05 A0 1D 05 21 0A 00 98 04 E9 91 E9 91 F6 72 9C 44 66 03 9C 4E F6 63 22 3C 00 ED 21 9F 78 CF 2F 2E 2D 9A
X: 3
SWB: 16 05 C0 1D 3D 3E 3F F6 15 F6 26 B3 60 88 05 21 FF FF 98 11 21 7F 05 9F F8 19 F6 14 ED B3 02 00 F6 61 9F 78
X: 3
SWB: 16 05 E0 1D CF 2F 2E 2D 9A 3D A2 D0 3F 25 67 05 40 47 E7 08 02 A6 1D 24 F7 04 01 06 9F 54 1D F6 12 21 8B 05
X: 3
SWB: 16 05 00 1E 9F 83 CA A6 D3 62 02 9F DF 85 22 3C 00 9F C0 1D F6 12 21 87 05 9F 83 CA A6 D3 62 03 9F DF 85 22
X: 3
SWB: 16 05 20 1E 3C 00 9F C0 1D F6 12 21 89 05 9F 83 CA 00 44 F4 50 62 94 05 22 01 01 98 03 22 00 01 21 8E 05 9F
X: 3
SWB: 16 05 40 1E 48 CA 2F A0 0D 2D 9A A2 A0 3E 3F A7 02 24 67 05 40 07 E7 08 02 A6 1A A6 A3 62 02 9F DF 85 11 C0
X: 3
SWB: 16 05 60 1E A6 A3 62 05 9F DF 85 F6 16 E6 5A 00 90 0B 24 F7 04 03 02 22 10 27 9F 0D CF 9F 54 1D F6 12 21 73
X: 3
SWB: 16 05 80 1E 05 9F 83 CA 22 3C 00 F6 61 9F C0 1D F6 12 21 75 05 9F 83 CA 22 10 0E 01 C0 EE 21 9F C0 1D 32 20
X: 3
SWB: 16 05 A0 1E 0A 00 E8 51 94 03 22 01 00 21 77 05 9F 83 CA AA 2F 2E A0 0A 9A 3F 24 80 4C 40 00 C0 04 90 13 24
X: 3
SWB: 16 05 C0 1E F7 04 01 04 24 C0 4F F4 E1 13 94 06 9F BF 44 9F 2C 44 9F 91 44 D2 00 90 03 9F BF 44 2F 9A 3F 24
X: 3
SWB: 16 05 E0 1E 68 02 42 03 CA 30 84 0C 40 05 C0 01 84 06 42 09 CA 50 90 05 22 10 10 98 03 22 00 10 21 8E 05 9F
X: 3
SWB: 16 05 00 1F 48 CA 9F 10 1B 9F AB 1B 9F E5 1D 9F 47 1E 9F 7C 1A 9F B5 1E 9F 3F 1A 2F 9A 3D 3F A7 02 FC 60 E4
X: 3
SWB: 16 05 20 1F 80 27 84 5B 24 40 4D A1 00 82 E0 50 00 94 50 A4 27 02 25 80 48 E0 92 41 52 C0 23 01 00 F6 82 21
X: 3
SWB: 16 05 40 1F 81 48 9F E3 C5 43 40 C3 01 24 40 47 42 08 C2 FE C3 01 B3 12 52 C1 23 01 00 F6 81 E9 92 21 48 47
X: 3
SWB: 16 05 60 1F 9F E3 C5 9F 77 C4 24 DF 01 60 01 F1 02 24 00 4C 40 10 C0 20 84 09 24 29 4C E0 92 1D A3 22 20 FC
X: 3
SWB: 16 05 80 1F 50 AA 2F 2D 9A 3F E4 92 2D A3 2D 20 24 00 4C 40 10 C0 01 90 14 24 DF 01 E0 60 01 80 0C 24 29 4C
X: 3
SWB: 16 05 A0 1F 02 1E 90 05 A1 00 82 84 05 31 19 2B 98 10 D2 3B 94 0F F5 91 2B 19 2B EA 51 80 03 9F 19 27 A4 2D
X: 3
SWB: 16 05 C0 1F 00 09 30 90 0E E9 81 19 30 FB 84 07 24 DF 01 60 FD F0 03 A1 02 82 D2 FF 90 05 B2 92 A3 82 20 9F
X: 3
SWB: 16 05 E0 1F 34 7A 9F 2F 9A 9F 35 3C 9F 4F 44 9F F6 00 9F 65 51 9F 8E 3A 9F BA 68 9F BE 26 9F D1 26 9F FE 26
X: 3
SWB: 16 05 00 20 9F C2 02 9F 19 1F F5 83 D1 20 FD FF E8 53 8C 1D 0A 2E EA 91 19 2E 20 0F 0E E8 52 94 13 31 19 2E
X: 3
SWB: 16 05 20 20 1B D1 F9 30 84 0A 21 FF FF 19 D1 98 03 31 19 2E 9F BB 3F 2F 9A 3F A1 02 81 90 05 B2 82 A3 81 20
X: 3
SWB: 16 05 40 20 A1 02 80 90 05 B2 82 A3 80 20 A1 00 81 84 19 22 00 20 21 6E 05 9F 48 CA 24 67 05 42 27 CA DB 90
X: 3
SWB: 16 05 60 20 07 60 03 F3 89 A4 81 0A A1 00 80 84 10 24 67 05 40 07 C0 40 84 07 60 0C F3 89 A4 80 32 24 00 4C
X: 3
SWB: 16 05 80 20 40 0D C0 01 90 08 A1 00 89 90 03 9F 8D C7 2F 9A 3D 3E 3F A7 03 9F 5E C5 9F A5 0C 21 00 04 9F 8D
X: 3
SWB: 16 05 A0 20 C8 31 11 C1 24 00 40 05 10 26 DF 01 98 27 9F 08 C8 21 00 04 9F 8D C8 24 7B 01 00 C1 F4 20 00 10
X: 3
SWB: 16 05 C0 20 C1 9F 49 23 63 01 9F AB 23 D2 00 84 06 40 82 C0 08 90 06 ED 85 F9 50 87 D5 9F 4E C5 9F A5 0C F9
X: 3
SWB: 16 05 E0 20 50 84 32 01 C1 9C 3A 24 C6 49 F4 E1 05 88 26 24 00 41 42 00 E6 12 04 52 C0 23 03 00 F6 82 F6 41
X: 3
SWB: 16 05 00 21 9F E3 C5 24 DF 01 60 02 F1 03 60 F7 F0 02 21 A0 8C 19 30 98 07 24 DF 01 60 02 F1 03 9F 08 C8 AB
X: 3
SWB: 16 05 20 21 2F 2E 2D 9A 3D 3E 3F A7 01 9F 49 23 52 C0 24 31 05 06 16 63 01 9F AB 23 25 DF 01 D2 00 90 2B 42
X: 3
SWB: 16 05 40 21 43 CA 02 84 3A 24 00 41 40 00 C0 01 90 31 FA 30 84 2D 24 29 4C F4 E6 17 8C 25 F4 E6 15 80 20 CA
X: 3
SWB: 16 05 60 21 04 84 1C E0 60 42 88 17 98 06 40 42 C0 08 90 05 9F 90 20 98 0A 42 C0 D2 00 84 04 60 FD F0 43 73
X: 3
SWB: 16 05 80 21 42 C0 9F AB 23 A9 2F 2E 2D 9A A2 A0 3F A6 2A A1 00 2A 84 03 9F DE 1E 21 00 04 9F 8D C8 9F 08 C8
X: 3
SWB: 16 05 A0 21 9F 83 0B E9 09 9F A0 7B A1 02 83 DA 00 88 0E C2 7F A3 83 20 22 8E 03 21 86 03 9F CD 80 9F 7E 52
X: 3
SWB: 16 05 C0 21 9F C5 33 72 A1 00 1F 84 02 62 01 A3 2A 20 D2 00 84 10 9F 85 1F E6 5A 00 84 08 9F 35 20 9F 24 21
X: 3
SWB: 16 05 E0 21 98 02 A6 A2 2F A0 0A 9A 3D 3E 3F 66 06 22 C0 4C 21 67 05 9F 5B CA 66 04 22 80 4D 21 83 05 9F 5B
X: 3
SWB: 16 05 00 22 CA 24 C0 4C 02 06 21 6D 05 9F 83 CA 26 80 4D 02 84 21 F9 04 9F 83 CA 22 40 00 21 8D 05 9F 83 CA
X: 3
SWB: 16 05 20 22 22 72 0B 21 F7 04 9F 83 CA 24 00 4E 44 19 75 21 79 05 9F 83 CA 25 74 44 F8 40 90 0B 24 76 44 F8
X: 3
SWB: 16 05 40 22 00 90 04 F6 52 98 02 F6 62 66 04 21 B4 03 9F 5B CA 9F E0 1A 21 00 04 9F 8D C8 9F 08 C8 2F 2E 2D
X: 3
SWB: 16 05 60 22 9A 3F 24 DF 01 60 80 F1 01 66 01 22 A4 25 21 3A 18 9F 15 49 2F 9A 3D 3E 3F 9F 08 C8 24 95 05 42
X: 3
SWB: 16 05 80 22 00 D2 01 90 3E D2 02 90 03 9F E8 21 72 24 95 05 40 00 D0 02 84 02 62 01 73 9F CD 41 9F 4A 56 72
X: 3
SWB: 16 05 A0 22 24 95 05 40 00 D0 02 84 02 62 01 9F DC 7D 9F 40 3D 9F DE 1E 24 80 4C 40 00 C0 01 90 03 9F BF 44
X: 3
SWB: 16 05 C0 22 9F 2C 44 64 02 21 95 05 9F 79 CA 65 80 A6 54 21 8D 05 9F 48 CA 25 DF 01 60 FE F0 43 9F 08 C8 F6
X: 3
SWB: 16 05 E0 22 56 A1 00 1F 90 0C 9F F4 C9 D2 00 84 05 62 01 9F 51 CF 9F 53 68 D2 00 90 04 62 02 98 0C 40 81 E7
X: 3
SWB: 16 05 00 23 08 04 A6 12 E6 42 01 C2 01 9F 85 60 A6 2A D2 00 90 03 9F E8 79 21 6F 05 9F D2 85 22 BA 03 21 B8
X: 3
SWB: 16 05 20 23 03 9F D4 56 A1 03 7F 72 9F BA 7C D2 00 84 08 E6 5A 00 84 03 9F 9F 50 72 9F 8A 21 D2 00 93 A2 A1
X: 3
SWB: 16 05 40 23 00 1D 87 9D 9F 61 22 99 98 A2 A0 3F 24 00 4C 40 0D E7 08 10 A6 1A E6 0A 03 9F 68 C7 D2 00 90 29
X: 3
SWB: 16 05 60 23 A1 06 32 73 E5 22 6A B3 D3 24 29 4C 44 14 75 EA E1 80 0F 65 E3 24 C0 4C 44 07 21 6E 05 9F 48 CA
X: 3
SWB: 16 05 80 23 98 22 B6 92 A3 32 20 98 03 A4 32 00 24 C0 4F 40 04 C0 08 84 03 31 98 0F 31 24 29 4C A1 00 82 E0
X: 3
SWB: 16 05 A0 23 50 14 80 03 21 01 00 2F A0 0A 9A 3D 3E 3F A7 02 53 C1 24 C0 4F 43 04 53 C0 CB 10 84 08 24 DF 01
X: 3
SWB: 16 05 C0 23 E0 60 02 80 18 24 93 07 40 00 90 11 73 24 29 4C 40 19 84 02 63 01 E6 43 01 A6 3A 98 01 35 D2 00
X: 3
SWB: 16 05 E0 23 84 08 24 DF 01 E0 60 02 80 7D 26 DF 01 40 82 C0 01 84 74 E0 60 83 88 6F 24 F7 04 01 04 9C 3A 24
X: 3
SWB: 16 05 00 24 29 4C F4 E1 12 8C 60 40 80 C0 01 90 06 42 C0 CA 0C 90 54 43 C1 D3 00 84 05 E6 5A 00 90 49 24 68
X: 3
SWB: 16 05 20 24 02 40 09 84 42 40 0B 84 3E 40 0D 84 3A 40 0F 84 36 40 08 C0 7F 84 30 42 0A CA F8 84 2A 40 0C 84
X: 3
SWB: 16 05 40 24 26 40 0E 84 22 42 01 CA C0 84 1C 40 03 C0 0F 84 16 40 00 84 12 40 02 84 0E 42 04 CA 83 84 08 40
X: 3
SWB: 16 05 60 24 06 84 04 62 01 98 0D 72 24 DF 01 E0 60 01 80 04 60 7F F0 02 AA 2F 2E 2D 9A A2 A0 3F A6 2A 9F DF
X: 3
SWB: 16 05 80 24 0D D2 00 90 02 6A 01 9F C5 33 9F 6E 03 9F 65 04 9F 08 05 E6 5A 00 84 0B 9F 49 23 73 9F AB 23 D2
X: 3
SWB: 16 05 A0 24 00 84 16 24 DF 01 60 7F F0 01 60 F7 F0 03 66 01 22 76 22 21 31 15 9F 15 49 2F A0 0A 9A 3D 3E 3F
X: 3
SWB: 16 05 C0 24 A7 04 21 00 0C 9F BA C1 9F 4E C5 24 DF 01 60 08 F1 03 24 00 4C 42 11 C2 02 52 C1 35 36 68 04 58
X: 3
SWB: 16 05 E0 24 C0 98 65 9F 07 0D 9F 5B 0D 49 C1 E6 59 00 90 30 24 F7 04 01 04 9C 3A 24 29 4C F4 E1 12 94 21 42
X: 3
SWB: 16 05 00 25 1A D2 02 94 1B 52 C2 79 59 C3 F4 61 C2 32 9C 53 3A 39 09 23 0A 25 9C 46 AC 19 23 1A 25 9F 9C 0B
X: 3
SWB: 16 05 20 25 72 9F 79 24 08 25 38 08 23 38 F6 51 F6 62 9C 40 AC F6 15 F6 26 F7 80 3E F7 00 00 9C 46 AC 19 23
X: 3
SWB: 16 05 40 25 1A 25 21 0C 00 9F 6F C8 E0 82 C0 52 C0 D2 FF 87 92 24 DF 01 60 F7 F0 03 9F 6E C5 AC 2F 2E 2D 9A
X: 3
SWB: 16 05 60 25 A2 A0 3F 24 00 4C E0 A2 10 E7 28 02 A6 12 E6 F2 02 A3 FC 20 63 0C 24 29 4C 42 1B 9F E0 C1 21 0E
X: 3
SWB: 16 05 80 25 0E 9F BA C1 6A 04 98 0E 21 0C 00 9F 8D C8 C2 04 9F 79 24 9F 9C 0B BA 8A E6 5A FF 87 EB A4 FC 00
X: 3
SWB: 16 05 A0 25 2F A0 0A 9A A2 A0 3E 3F 62 40 9F C3 C4 7A 26 29 4C 24 DF 01 40 01 E7 08 04 A6 12 E6 42 01 C2 01
X: 3
SWB: 16 05 C0 25 9F 85 60 22 BA 03 21 B8 03 9F D4 56 A1 03 7F 62 01 9F BA 7C D2 00 84 03 9F 9F 50 21 01 00 9F 64
X: 3
SWB: 16 05 E0 25 C8 E6 5A 00 84 09 9F BD 24 4A 9A 90 07 98 03 9F 60 25 BA 8A 62 01 9F 8A 21 9F 08 34 99 B3 F6 12
X: 3
SWB: 16 05 00 26 F6 14 E6 29 70 20 FF 0F E8 54 94 16 E6 23 80 20 FF 00 E8 51 94 0C F6 21 E6 23 C0 20 FF 1F E8 51
X: 3
SWB: 16 05 20 26 8C 19 F6 23 20 FF 8F E8 52 94 07 F6 43 24 FF 0F 98 2C B5 60 80 25 24 FF 80 98 23 F6 21 E6 23 FF
X: 3
SWB: 16 05 40 26 20 00 01 E8 51 94 02 72 9A 21 FF 00 EA 01 E9 63 EB 63 EB 63 EB 63 EB 63 E6 27 40 24 FF 5F 1B 03
X: 3
SWB: 16 05 60 26 A1 02 79 84 02 62 20 A3 7C 20 EC 92 EB C2 73 E9 E2 80 03 62 01 9A B8 92 E5 C2 62 A3 7C 20 62 01
X: 3
SWB: 16 05 80 26 9A 3D 0B 77 20 FF 3F E8 53 94 1B A1 04 7C 75 21 FF 5F EA C1 E9 53 8C 0E EB 22 1A 77 25 00 4C 24
X: 3
SWB: 16 05 A0 26 E3 01 42 67 52 00 2D 9A F6 14 01 00 C3 7F 11 00 C5 7F F6 20 E9 C0 90 05 E6 13 80 11 00 9A A1 02
X: 3
SWB: 16 05 C0 26 33 90 0D B2 82 A3 33 20 D2 00 84 04 60 FD F2 83 9A A1 03 83 CB 04 90 25 FC 60 24 E3 01 42 00 90
X: 3
SWB: 16 05 E0 26 06 B2 82 52 00 98 14 C3 FB A3 83 30 09 77 E6 23 C0 20 FF 1F E8 51 8C 03 31 19 77 FC 50 9A 24 E4
X: 3
SWB: 16 05 00 27 01 42 00 90 05 B2 82 52 00 9A 60 FE F2 83 9A 3F 64 40 21 36 00 9C 38 2F 9A 3F A7 02 24 DF 01 60
X: 3
SWB: 16 05 20 27 01 F1 02 24 00 4C 40 10 C0 10 90 25 64 02 F6 81 9C 38 42 C0 24 40 47 43 08 C3 01 E6 12 02 C2 FE
X: 3
SWB: 16 05 40 27 C3 01 B3 12 52 C0 23 02 00 F6 82 21 80 48 9F E3 C5 AA 2F 9A 3D 3F F6 15 D4 40 94 02 64 40 A3 76
X: 3
SWB: 16 05 60 27 40 9F 0F 27 A1 06 76 77 F6 52 21 36 00 9C 3F 2F 2D 9A 3F A7 21 64 21 F6 81 9C 38 A1 06 76 56 C0
X: 3
SWB: 16 05 80 27 77 22 36 00 F6 84 EC 91 9C 3F 23 21 00 F6 82 21 82 40 9F E3 C5 A5 21 2F 9A 3F 66 10 0A 7A 21 80
X: 3
SWB: 16 05 A0 27 00 9C 23 2F 9A 3F 66 1C F6 12 21 90 00 9C 23 2F 9A 3F 21 80 00 9F 72 C6 66 2C 22 36 00 21 80 00
X: 3
SWB: 16 05 C0 27 9F 8A C6 2F 9A 3F 66 1C 22 46 00 21 90 00 9C 23 9F B1 27 2F 9A 3D 3F A7 2C 25 36 00 23 1C 00 F6
X: 3
SWB: 16 05 E0 27 52 F6 81 E6 22 10 B3 D3 9C 3F 66 10 F6 82 21 80 00 9C 23 23 2C 00 F6 82 F6 51 9C 3F 9F B1 27 A5
X: 3
SWB: 16 05 00 28 2C 2F 2D 9A 3D 3F A7 02 24 DF 01 46 01 0A 34 09 77 F6 10 EA C0 85 D4 20 00 02 EA C0 84 15 E4 80
X: 3
SWB: 16 05 20 28 76 84 10 A1 02 36 A3 79 20 D2 40 95 8A A4 79 40 9B B7 29 7A CE 03 D0 03 84 02 6A 01 9F FE 25 D2
X: 3
SWB: 16 05 40 28 00 90 27 E6 5A 00 85 6F 09 03 A1 06 76 E4 56 7C 8D 65 E4 60 78 80 06 77 22 36 00 98 AA 20 C0 51
X: 3
SWB: 16 05 60 28 E9 50 95 53 77 22 36 00 98 BB 09 77 20 37 00 E9 C0 84 1D A1 00 76 D0 10 84 CC 64 10 21 36 00 9C
X: 3
SWB: 16 05 80 28 35 9F C5 27 31 19 77 A4 76 14 9F 0F 27 9B B7 29 20 35 00 E9 C0 84 0D A1 00 76 D0 1C 84 A8 9F D5
X: 3
SWB: 16 05 A0 28 27 9B B7 29 20 7B 00 E9 C0 84 18 A1 00 76 D0 20 8C 94 E6 5A 00 90 07 A1 00 83 C0 01 90 88 9F 72
X: 3
SWB: 16 05 C0 28 27 98 F4 20 79 00 E9 C0 84 41 A1 00 76 D0 02 84 75 25 94 07 02 44 A1 02 36 73 9F 94 CB 19 37 02
X: 3
SWB: 16 05 E0 28 46 A1 02 36 73 9F 94 CB 19 39 24 00 4E 40 01 C0 10 90 0B 22 98 07 21 37 00 9F CD 80 98 B9 23 04
X: 3
SWB: 16 05 00 29 00 22 37 00 21 86 03 9C 3F 98 AC 20 9D 00 E9 C0 84 18 A1 00 76 D0 02 84 2D 09 36 11 C0 23 02 00
X: 3
SWB: 16 05 20 29 F6 82 21 02 51 9F E3 C5 98 8D 20 9E 00 E9 C0 84 15 A1 00 76 D0 02 84 0E 09 36 11 C0 23 02 00 F6
X: 3
SWB: 16 05 40 29 82 21 00 51 99 DF A1 00 83 C0 02 90 6A 74 E6 5A 00 84 02 64 01 20 B0 00 E9 C0 84 0F A1 00 76 D0
X: 3
SWB: 16 05 60 29 0A 84 54 21 36 00 9F 1F 5B 98 4C 20 B2 00 E9 C0 84 0F A1 00 76 D0 1E 84 3E 21 36 00 9F A8 5A 98
X: 3
SWB: 16 05 80 29 36 20 08 30 E9 C0 84 19 A1 00 76 D0 02 84 28 A1 05 37 74 A1 02 36 73 E9 22 21 2F 05 9F 83 CA 98
X: 3
SWB: 16 05 A0 29 16 20 8B 00 E9 C0 84 0F A1 00 76 D0 03 84 08 0A 37 A1 02 36 9F 13 4D FA 77 84 2D A1 00 76 D0 14
X: 3
SWB: 16 05 C0 29 84 26 20 37 00 F5 C0 34 90 09 24 00 4C 40 0F C0 04 84 0A 21 4A 00 19 7A 9F 99 27 98 05 21 FE FF
X: 3
SWB: 16 05 E0 29 19 7A 60 20 F3 83 98 03 9F 0F 27 AA 2F 2D 9A 3D 3E 3F A7 03 A6 2C 7D 21 04 00 EE 01 11 C1 FB 84
X: 3
SWB: 16 05 00 2A 04 09 77 19 34 0D 34 A4 76 02 20 00 02 ED C0 84 0C A1 03 79 A3 36 30 A4 37 40 9B D2 2D F6 51 9F
X: 3
SWB: 16 05 20 2A FE 25 D2 00 90 08 A1 04 7C 09 03 9B 6B 2C F6 51 20 7F 0F E8 21 20 01 00 E8 51 8C 08 64 18 21 C5
X: 3
SWB: 16 05 40 2A 01 9B 6B 2C 20 FF 00 E8 55 94 03 9B 71 2C E6 5A 6E 8C 8D E6 5A 60 80 03 9B 5B 2C E6 5A 50 91 4A
X: 3
SWB: 16 05 60 2A E6 5A 50 8C 36 E6 5A 05 8C 19 E6 5A 04 80 03 9B D2 2D E6 5A 02 91 18 E6 5A 02 8D 07 E6 5A 01 85
X: 3
SWB: 16 05 80 2A F0 98 FA E6 5A 09 8C 0B E6 5A 07 80 03 9B D2 2D 9B 98 2B E6 5A 35 85 D9 9B 9E 2B E6 5A 55 91 7C
X: 3
SWB: 16 05 A0 2A E6 5A 55 8C 17 E6 5A 52 91 32 E6 5A 52 81 14 E6 5A 53 91 41 E6 5A 54 85 B8 9B 12 2C E6 5A 58 91
X: 3
SWB: 16 05 C0 2A 77 E6 5A 58 8C 0D E6 5A 56 91 58 E6 5A 57 85 A1 9B 31 2C E6 5A 5A 91 6C E6 5A 5E 85 94 9B 4B 2C
X: 3
SWB: 16 05 E0 2A E6 5A 7E 84 03 9B 65 2D E6 5A 7E 8C 39 E6 5A 78 8C 1F E6 5A 73 80 03 9B 21 2D E6 5A 70 91 94 E6
X: 3
SWB: 16 05 00 2B 5A 70 81 62 E6 5A 71 91 A8 E6 5A 72 85 63 9B ED 2C E6 5A 7B 91 91 E6 5A 7D 84 03 9B 2E 2D E6 5A
X: 3
SWB: 16 05 20 2B 7A 85 4E 9B 9D 2C E6 5A 9E 84 03 9B 9A 2D E6 5A 9E 8C 1D E6 5A 87 84 03 9B 88 2D E6 5A 87 8C 08
X: 3
SWB: 16 05 40 2B E6 5A 81 81 2C 9B 6F 2D E6 5A 9D 85 24 9B 93 2D E6 5A B2 84 03 9B B6 2D E6 5A B2 8C 10 E6 5A 9F
X: 3
SWB: 16 05 60 2B 84 03 9B A6 2D E6 5A B0 85 07 9B AE 2D E6 5A F1 84 03 9B C1 2D E6 5A F2 84 F7 9B C6 2D 21 00 45
X: 3
SWB: 16 05 80 2B 9B D0 2D 9F CC CA A3 36 20 A4 37 00 9B D2 2D 21 36 00 9F 99 3A 9B BC 2D 9F 90 9C 9B D0 2D A4 76
X: 3
SWB: 16 05 A0 2B 1C 21 36 00 9F A5 27 9B D2 2D A4 76 04 24 68 02 43 00 A3 36 30 42 02 A3 37 20 43 04 A3 38 30 42
X: 3
SWB: 16 05 C0 2B 06 98 49 A4 76 04 24 68 02 43 01 A3 36 30 42 03 A3 37 20 43 05 A3 38 30 42 07 98 30 A4 76 04 24
X: 3
SWB: 16 05 E0 2B 68 02 43 08 A3 36 30 42 0A A3 37 20 43 0C A3 38 30 42 0E 98 17 A4 76 04 24 68 02 43 09 A3 36 30
X: 3
SWB: 16 05 00 2C 42 0B A3 37 20 43 0D A3 38 30 42 0F A3 39 20 9B D2 2D 9F A9 12 64 04 21 DF 01 98 4F 64 05 21 46
X: 3
SWB: 16 05 20 2C 02 98 48 A4 76 04 09 CD 19 36 09 CF 19 38 9B D2 2D 64 02 21 AA 00 98 33 A4 76 15 21 36 00 9F D1
X: 3
SWB: 16 05 40 2C C2 9B D2 2D 64 02 21 F4 03 98 20 A4 76 04 24 00 46 01 0B 19 36 31 19 38 9B D2 2D 22 36 00 A6 A2
X: 3
SWB: 16 05 60 2C E6 22 A0 9B 6A 2D 64 04 21 40 48 9F 54 27 9B D2 2D 31 19 34 F8 C1 90 04 72 9B D4 2D E6 AC 08 84
X: 3
SWB: 16 05 80 2C 12 A4 76 14 24 DF 01 40 02 C0 04 85 45 9F 0F 27 9B D2 2D 24 40 40 44 00 21 41 40 99 CE 24 40 40
X: 3
SWB: 16 05 A0 2C 44 21 21 62 40 99 C4 24 82 40 44 00 21 83 40 99 BA A4 76 20 9F 0F 27 23 08 00 22 FF 04 21 36 00
X: 3
SWB: 16 05 C0 2C 9C 3F 25 F7 04 01 50 19 3E 01 52 19 40 23 08 00 22 13 05 21 42 00 9C 3F 23 08 00 22 1B 05 21 4A
X: 3
SWB: 16 05 E0 2C 00 9C 3F 01 6C 19 52 01 6E 19 54 98 E5 A4 76 1A 9F 0F 27 23 0A 00 22 47 05 21 36 00 9C 3F 25 F7
X: 3
SWB: 16 05 00 2D 04 01 40 19 40 01 70 19 42 24 9A 03 01 00 19 44 01 78 19 46 23 08 00 22 51 05 21 48 00 9C 3F 98
X: 3
SWB: 16 05 20 2D B1 22 36 00 A6 A2 E6 22 8D 9F 22 99 98 8E A4 76 12 9F 0F 27 9F 28 03 52 C0 98 1D E0 83 C0 53 C0
X: 3
SWB: 16 05 40 2D A6 3C 7D A6 32 9F 0E 9B EE 65 20 36 00 E8 25 11 40 42 C0 9F 2F 9B 11 48 42 C0 D2 00 87 DD 9F 22
X: 3
SWB: 16 05 60 2D 9B 19 46 98 6D 22 36 00 62 0F 9F 18 4C 98 4D 24 C0 4F 40 05 C0 02 90 5A 9F 0F 27 22 36 00 A6 A2
X: 3
SWB: 16 05 80 2D E6 22 7F 9F F9 4D 98 34 9F 0F 27 21 36 00 9F BF 4D 98 29 24 00 51 01 02 98 05 24 00 51 01 00 19
X: 3
SWB: 16 05 A0 2D 36 A4 76 02 98 2C 21 36 00 9F 4E 9A 98 0E 21 36 00 9F 63 5A 98 06 21 36 00 9F 58 5A A3 76 20 98
X: 3
SWB: 16 05 C0 2D 11 21 40 47 98 03 21 44 47 9F F8 19 F6 14 01 00 19 36 62 01 AB 2F 2E 2D 9A 3D 3E 3F A7 1C F6 16
X: 3
SWB: 16 05 E0 2D 24 DF 01 4A 01 E6 0A 03 F6 81 9F A5 27 E6 5A 03 84 63 66 01 F6 82 F6 61 9F CC 68 D2 00 90 0C 24
X: 3
SWB: 16 05 00 2E DF 01 42 01 C2 FC E6 12 02 98 74 25 00 4C 40 4F C0 08 90 1F 66 09 F6 82 E6 24 08 B5 D5 F6 61 9F
X: 3
SWB: 16 05 20 2E CC 68 D2 00 90 0D 60 04 F3 83 24 E3 01 42 67 52 00 98 4E 66 0A F6 82 E6 24 18 B5 D5 F6 61 9F CC
X: 3
SWB: 16 05 40 2E 68 D2 00 90 27 25 00 4C 24 E4 01 42 68 52 00 60 01 F3 83 98 2C E6 5A 02 84 12 66 02 F6 82 E6 24
X: 3
SWB: 16 05 60 2E 04 B5 D5 F6 61 9F CC 68 D2 00 84 09 F6 61 9F FB 68 D2 00 90 0E 24 DF 01 42 01 C2 FC E6 12 01 52
X: 3
SWB: 16 05 80 2E 01 62 01 A5 1C 2F 2E 2D 9A 3D 3E 3F A7 20 F6 16 F6 81 E6 22 04 B3 D3 9F A5 27 21 0C 27 11 C0 21
X: 3
SWB: 16 05 A0 2E 3D 04 11 C2 66 04 F6 82 F6 61 9F CC 68 D2 00 84 03 7B 98 06 60 40 F3 83 6B 01 01 D0 11 C0 01 D2
X: 3
SWB: 16 05 C0 2E 11 C2 66 06 F6 82 F6 61 9F CC 68 D2 00 90 05 9F 0E 65 6B 01 01 D4 11 C0 01 D6 11 C2 66 07 F6 82
X: 3
SWB: 16 05 E0 2E F6 61 9F CC 68 D2 00 90 05 9F 3B 56 6B 01 01 D8 11 C0 01 DA 11 C2 66 08 F6 82 F6 61 9F CC 68 D2
X: 3
SWB: 16 05 00 2F 00 90 0E 60 02 F3 83 24 00 4C 43 26 A3 33 30 6B 01 21 10 00 11 C0 11 C2 66 03 F6 82 F6 61 9F CC
X: 3
SWB: 16 05 20 2F 68 D2 00 90 10 24 40 47 40 08 C0 01 90 04 6A 01 98 04 9F 19 27 7A 21 F0 00 11 C0 11 C2 66 05 F6
X: 3
SWB: 16 05 40 2F 82 F6 61 9F CC 68 D2 00 84 05 E6 5A 00 90 0C 9F 61 3C D2 00 90 03 9F 19 27 6B 01 A6 B2 A5 20 2F
X: 3
SWB: 16 05 60 2F 2E 2D 9A A2 A0 3F A6 2A 9F E5 60 A1 00 AA C0 10 84 24 E6 AA 07 90 1F 72 9F A0 02 24 00 4C 40 09
X: 3
SWB: 16 05 80 2F E7 08 40 A6 13 C3 01 9F E2 64 A6 2A 9F D7 C0 63 0F A6 A2 9F 74 C3 2F A0 0A 9A 3D A2 C0 3F F6 15
X: 3
SWB: 16 05 A0 2F 7C 24 DF 01 42 01 CA 03 D0 01 84 02 6C 01 24 DF 01 60 CF F0 02 E6 5C 00 90 24 20 33 00 ED C0 90
X: 3
SWB: 16 05 C0 2F 07 20 00 0F ED C0 84 08 9F E7 CE 9F 3E CC 98 0E 20 35 00 ED C0 90 4B 20 37 00 ED C0 90 44 20 80
X: 3
SWB: 16 05 E0 2F F0 ED C0 91 C9 F6 51 20 7F 0F E8 21 20 01 00 E8 51 8C 1D E4 60 AB 80 35 24 DF 01 42 02 E6 12 10
X: 3
SWB: 16 05 00 30 52 02 20 82 F0 ED C0 84 19 E6 12 20 52 02 98 12 F6 51 9F FE 25 D2 00 90 0D E6 5C 00 84 04 BB 60
X: 3
SWB: 16 05 20 30 88 0B 1D 77 98 E2 20 FF 00 E8 55 8D 98 E6 5A 27 91 22 E6 5A 27 8C 53 E6 5A 1F 90 F0 E6 5A 1F 8C
X: 3
SWB: 16 05 40 30 27 E6 5A 12 90 CF E6 5A 12 8C 0C E6 5A 10 90 92 E6 5A 11 85 70 98 B5 E6 5A 1D 91 11 E6 5A 1D 8C
X: 3
SWB: 16 05 60 30 C6 E6 5A 13 85 5F 98 B6 E6 5A 23 90 D3 E6 5A 23 8C 0C E6 5A 21 90 BF E6 5A 21 8C BF 98 B3 E6 5A
X: 3
SWB: 16 05 80 30 25 90 C7 E6 5A 25 8C C7 98 BB E6 5A 2F 91 11 E6 5A 2F 8C 22 E6 5A 2B 90 E5 E6 5A 2B 8C 0C E6 5A
X: 3
SWB: 16 05 A0 30 29 90 C0 E6 5A 29 8C C0 98 B4 E6 5A 2D 90 AA E6 5A 2D 8C E7 98 DC E6 5A 79 90 F6 E6 5A 79 8C 11
X: 3
SWB: 16 05 C0 30 E6 5A 41 90 50 E6 5A 42 90 4E E6 5A 30 84 F6 98 D4 E6 5A 99 90 E7 E6 5A F0 90 23 E6 5A 98 84 E5
X: 3
SWB: 16 05 E0 30 98 D6 24 40 47 40 08 C0 01 84 13 24 DF 01 40 02 C0 01 90 11 24 29 4C 43 1D A3 22 30 98 07 9F 61
X: 3
SWB: 16 05 00 31 3C D2 00 90 03 9F 19 27 62 01 98 BA 24 DF 01 60 80 F1 02 99 F3 9F E7 CE 72 9F 51 CF 99 EA 24 DF
X: 3
SWB: 16 05 20 31 01 60 08 F1 02 99 E1 21 01 00 98 94 21 02 00 98 8F 21 04 00 98 8A 21 08 00 98 85 21 10 00 98 80
X: 3
SWB: 16 05 40 31 21 20 00 98 7B 21 40 00 98 76 21 80 00 98 71 21 00 01 98 6C 21 00 02 98 67 21 00 80 98 62 9F 8E
X: 3
SWB: 16 05 60 31 55 99 A5 9F 10 16 99 A0 9F AE 4A 99 9B 9F F3 C0 D2 00 90 05 9F 97 15 99 8F 9F 9D 15 99 8A 24 80
X: 3
SWB: 16 05 80 31 4C 40 00 E7 08 04 A6 12 9F DE C6 62 3F 9F F4 C6 99 76 60 80 F3 97 9F BF 44 99 6D 9F 19 50 99 68
X: 3
SWB: 16 05 A0 31 21 00 40 98 1B 9F CD 60 9F FD CA 9F 89 36 31 98 03 21 79 00 19 77 99 50 21 00 08 98 03 21 00 04
X: 3
SWB: 16 05 C0 31 9F 63 2F 99 43 72 2F A0 0C 2D 9A 3D 3F F6 15 9F 5E C6 11 40 2F 2D 9A 3D 3F F6 15 66 20 22 14 55
X: 3
SWB: 16 05 E0 31 21 80 49 9C 34 11 40 24 A3 40 02 00 F6 51 9F A8 26 2F 2D 9A 3D 3F F6 15 66 20 22 A7 40 21 19 40
X: 3
SWB: 16 05 00 32 9C 34 66 A0 22 14 55 21 A9 40 9C 34 11 40 24 A3 40 02 04 F6 51 9F A8 26 2F 2D 9A 3D 3F F6 15 9F
X: 3
SWB: 16 05 20 32 83 9C 11 40 24 A3 40 02 02 F6 51 9F A8 26 2F 2D 9A 3F F6 12 20 A7 23 E9 C0 84 0D 60 BF F2 83 24
X: 3
SWB: 16 05 40 32 DF 01 60 BF F0 00 98 3C E6 22 63 B3 C3 20 01 00 E8 51 94 43 20 B0 00 EA C0 90 3C 20 B2 00 EA C0
X: 3
SWB: 16 05 60 32 90 35 20 8B 00 EA C0 84 0B 24 C0 4F 40 05 C0 02 90 12 98 23 20 08 30 EA C0 84 09 24 C0 4F 40 00
X: 3
SWB: 16 05 80 32 C0 20 84 13 A1 00 83 C0 04 90 10 F6 21 E6 23 C0 20 FF 1F E8 51 8C 04 1A 77 98 D4 CD FF 84 CD A6
X: 3
SWB: 16 05 A0 32 43 D4 0A 94 39 A6 42 E6 22 B0 D2 37 94 30 A6 42 E6 22 66 D2 05 94 27 D4 8A 84 0B 24 C0 4F 40 05
X: 3
SWB: 16 05 C0 32 C0 02 84 22 98 A6 D4 9D 90 14 D4 9E 90 10 D4 B0 90 0C D4 B2 90 08 D4 F1 90 04 D4 F2 84 80 D3 07
X: 3
SWB: 16 05 E0 32 84 04 0A 77 1A 36 A6 34 75 1A 77 20 04 00 EA C0 84 08 21 36 00 9F CB 31 98 75 20 05 00 EA C0 84
X: 3
SWB: 16 05 00 33 08 21 36 00 9F D7 31 98 66 20 08 00 EA C0 84 08 21 36 00 9F 1B 32 98 57 20 09 00 EA C0 84 08 21
X: 3
SWB: 16 05 20 33 36 00 9F F4 31 98 48 D3 8A 84 05 9F 39 4D 98 3F D3 9A 84 0C 9F 64 9A 24 DF 01 60 EF F0 00 98 2F
X: 3
SWB: 16 05 40 33 D3 9C 84 05 A4 DC 00 98 26 D3 9B 84 05 A4 DC 01 98 1D 20 0A 00 EA C0 84 16 9F A3 33 98 11 D4 43
X: 3
SWB: 16 05 60 33 84 06 60 80 F3 83 98 07 D4 10 90 03 9F 21 69 2F 9A 3D 3F 0D 34 F6 51 9F D9 2D D2 00 84 22 F6 51
X: 3
SWB: 16 05 80 33 9F 89 2E D2 00 84 19 24 DF 01 42 01 CA 03 D0 03 90 09 F6 51 9F 9A 2F D2 00 84 05 F6 51 9F 31 32
X: 3
SWB: 16 05 A0 33 2F 2D 9A 3D 24 DF 01 60 04 F1 03 25 E5 01 24 80 51 42 00 73 E9 61 E9 61 11 40 42 01 73 E9 61 E9
X: 3
SWB: 16 05 C0 33 61 11 42 2D 9A 24 DF 01 40 03 C0 04 90 23 24 E5 01 01 00 90 04 E9 81 11 00 24 E5 01 01 02 90 05
X: 3
SWB: 16 05 E0 33 E9 81 11 02 9A 24 DF 01 E0 60 01 88 04 60 FB F0 03 9A 24 E5 01 F8 00 90 02 31 9A 24 DF 01 40 03
X: 3
SWB: 16 05 00 34 E7 08 40 A6 12 C2 01 9A 3D 3F 9F 68 C7 D2 00 84 18 25 DF 01 42 43 CA 04 90 0F 24 E5 01 F8 02 84
X: 3
SWB: 16 05 20 34 08 C2 FB 52 43 72 9F BB 12 2F 2D 9A A2 A0 3F A7 02 A6 23 74 24 DF 01 42 01 CA 03 D0 03 84 02 64
X: 3
SWB: 16 05 40 34 01 D3 70 84 11 D4 00 84 04 64 20 98 01 74 21 40 40 9F D8 3A 98 F7 D3 44 84 03 72 98 DD D3 48 84
X: 3
SWB: 16 05 60 34 0A 9C 10 9F 20 41 73 9C 09 98 E2 D3 49 84 16 31 11 C0 9C 10 F6 81 9C 0C A6 2A D2 02 84 D9 01 C0
X: 3
SWB: 16 05 80 34 9F BC 40 98 D2 D3 4A 84 07 22 91 05 62 4A 98 90 D3 4B 84 07 22 93 05 62 4B 98 85 D3 4F 84 07 22
X: 3
SWB: 16 05 A0 34 8F 05 62 4F 98 7A D3 59 84 07 22 BE 03 62 59 98 6F D3 5A 84 07 22 BC 03 62 5A 98 64 D3 5B 84 07
X: 3
SWB: 16 05 C0 34 72 9F 38 A1 74 98 13 D3 5C 84 04 62 01 98 06 D3 5D 84 0C 62 02 9F 38 A1 64 01 9F 25 3B 98 6E D3
X: 3
SWB: 16 05 E0 34 5E 84 07 22 C2 03 62 5E 98 36 D3 5F 84 07 22 C0 03 62 5F 98 2B D3 68 84 07 22 C4 03 62 68 98 20
X: 3
SWB: 16 05 00 35 D3 69 84 07 22 C6 03 62 69 98 15 A6 32 E6 22 30 D2 14 8C 11 A6 34 75 EA 62 20 28 02 E8 22 A6 32
X: 3
SWB: 16 05 20 35 9F 6E 3B 98 28 D4 00 84 28 A6 32 E6 22 B0 D2 37 8C 0D A3 34 30 A4 35 00 62 05 9F CA 35 98 0E A6
X: 3
SWB: 16 05 40 35 32 E6 22 C0 D2 03 8C 09 A6 32 9F A1 3A A6 2A 98 06 9C 11 A4 01 03 7A A6 A2 AA 2F A0 0A 9A 3D 3F
X: 3
SWB: 16 05 60 35 0A 77 F6 21 E6 23 FF 20 00 01 E8 51 8C 07 A4 79 20 6A 01 98 0B 20 37 00 EA C0 90 03 31 19 77 7A
X: 3
SWB: 16 05 80 35 72 9F EF 29 9F 7C 3A D2 00 90 09 21 36 00 9F 99 3A A3 76 20 9C 10 23 36 00 64 20 21 76 00 9C 0D
X: 3
SWB: 16 05 A0 35 A6 2B D2 02 84 1F A1 02 76 D2 14 84 05 31 19 77 98 0C E6 5A 00 90 07 D2 20 90 03 A4 76 00 09 77
X: 3
SWB: 16 05 C0 35 19 34 9F 04 28 A6 B2 2F 2D 9A A2 A0 3F A7 01 A6 2A 9F EF 29 D2 00 84 08 9C 11 A4 01 03 7A 98 5A
X: 3
SWB: 16 05 E0 35 9C 10 E6 AA 01 90 11 A1 02 76 52 C0 22 36 00 9C 0A A6 2A 22 36 00 98 16 A1 02 76 E6 22 02 52 C0
X: 3
SWB: 16 05 00 36 23 34 00 64 42 F6 81 9C 0D A6 2A 22 34 00 E6 5A 02 84 1A 40 C0 D0 01 94 21 9F 71 33 42 C0 D2 02
X: 3
SWB: 16 05 20 36 94 18 E6 22 FE A3 76 20 9F 04 28 98 0D 42 C0 9F 35 3A E6 5A 01 84 03 9F 81 26 A6 A2 A9 2F A0 0A
X: 3
SWB: 16 05 40 36 9A A2 A0 3F A7 02 24 DF 01 01 00 11 C0 A1 00 7D 90 08 A4 7D 00 21 A5 FF 11 C0 9C 10 F6 81 9C 0C
X: 3
SWB: 16 05 60 36 A6 2A D2 02 84 13 02 C0 EA 81 20 01 00 E8 51 8C 03 A4 7D 01 1A 34 9F 71 33 01 C0 9F 2E 3A A6 A2
X: 3
SWB: 16 05 80 36 AA 2F A0 0A 9A 9B 38 C7 9A 3F 9F EE CA 24 DF 01 D2 00 90 06 60 03 F1 01 98 09 42 01 C2 FC E6 12
X: 3
SWB: 16 05 A0 36 01 52 01 2F 9A 3F D2 19 90 28 D2 19 8C 0A D2 17 90 10 D2 18 84 11 98 12 D2 1A 90 1B D2 1C 8C 07
X: 3
SWB: 16 05 C0 36 98 1A 21 80 43 98 1D 31 98 1A 21 80 4D 9F F8 19 98 12 21 84 4D 98 0D 21 C8 4C 98 08 73 E9 61 20
X: 3
SWB: 16 05 E0 36 73 40 E8 21 2F 9A 3F A6 24 D2 0E 8C 1D D2 0C 88 5D D2 04 90 3F D2 04 8C 0A D2 01 90 28 D2 00 90
X: 3
SWB: 16 05 00 37 21 98 27 73 D4 07 94 34 98 3B D2 13 8C 07 73 D4 11 88 50 98 43 D2 15 94 53 D2 16 84 05 21 8D 05
X: 3
SWB: 16 05 20 37 98 52 31 98 4F 21 67 05 98 0D 73 E9 61 20 67 05 E8 21 98 40 21 6F 05 9F F8 19 98 38 E9 61 20 69
X: 3
SWB: 16 05 40 37 05 E8 21 98 2F E9 61 20 E7 04 E8 21 98 26 73 E9 61 20 61 05 E8 21 98 1C E9 61 E9 61 20 43 05 E8
X: 3
SWB: 16 05 60 37 21 99 D4 E9 61 20 65 05 E8 21 98 08 73 E9 61 20 3D 07 E8 21 2F 9A 3D 3F 24 00 4C 44 24 E5 B2 40
X: 3
SWB: 16 05 80 37 E0 52 25 84 08 D4 00 90 04 D4 FF 84 02 64 16 63 02 A6 42 9F 48 C7 25 00 4C 40 4D E7 08 10 A6 13
X: 3
SWB: 16 05 A0 37 C3 03 B3 63 72 9F 73 C7 40 4D E7 08 20 A6 1A E6 0A 01 A6 A2 9F 95 C7 24 DF 01 42 02 C2 BF E7 A8
X: 3
SWB: 16 05 C0 37 40 C0 40 B0 12 52 02 2F 2D 9A 3D 3F 24 00 4C 4A 0D E6 AA 01 90 7A 9F 68 C7 D2 00 84 6F 24 67 05
X: 3
SWB: 16 05 E0 37 01 26 22 0F 00 E9 12 A1 0B 00 A1 06 89 CE 01 90 16 A4 00 01 E6 AA 04 90 03 A4 00 03 21 10 16 9C
X: 3
SWB: 16 05 00 38 06 60 FE F2 89 98 40 A4 00 01 E6 AA 02 90 03 A4 00 03 CE 02 90 0B 21 12 16 9C 06 60 FD F2 89 98
X: 3
SWB: 16 05 20 38 26 CE 04 90 10 24 65 07 02 00 21 12 14 9C 06 60 FB F2 89 98 12 CE 08 90 0E 24 65 07 02 02 21 12
X: 3
SWB: 16 05 40 38 15 9C 06 60 F7 F2 89 A3 00 B0 98 04 60 F0 F2 89 9F 19 C7 2F 2D 9A 3F D2 21 90 11 D2 22 90 13 D2
X: 3
SWB: 16 05 60 38 20 90 03 72 98 13 74 21 AD 40 98 0A 74 21 C2 40 98 04 74 21 D7 40 9F D8 3A 2F 9A 3F A7 02 E4 80
X: 3
SWB: 16 05 80 38 27 84 14 A4 27 00 64 02 F6 81 9C 38 23 02 00 F6 82 21 80 48 9F E3 C5 AA 2F 9A 3D 3E 3F A7 01 9F
X: 3
SWB: 16 05 A0 38 76 37 9F 89 36 25 80 48 40 40 C0 02 90 18 24 40 4D 42 01 40 41 E0 50 01 80 04 D2 00 84 05 A4 27
X: 3
SWB: 16 05 C0 38 01 98 03 9F 7B 38 24 00 4C 4B 0D E6 0B 80 65 0F A1 04 7E 21 8D 05 9F 48 CA 9F CA 37 A1 02 00 E6
X: 3
SWB: 16 05 E0 38 5B 00 90 05 E6 12 40 98 02 C2 BF A3 00 20 62 01 9F 20 C8 F6 81 9C 16 A6 2A 62 01 9F 17 C8 60 40
X: 3
SWB: 16 05 00 39 F3 00 A4 01 00 E6 5A 02 84 EB 24 DF 01 60 7F F0 02 43 C0 D3 22 8C 14 D3 20 88 44 D3 16 8C 06 D3
X: 3
SWB: 16 05 20 39 00 84 26 98 1F D3 1C 8C 62 98 29 D3 2F 90 41 D3 2F 8C 06 D3 23 84 54 98 2D A6 32 E6 22 C4 D2 03
X: 3
SWB: 16 05 40 39 8C 49 98 31 9F 41 36 98 47 A6 32 9F E6 36 F6 12 42 C0 98 32 A6 32 9F A5 36 74 9F 25 3B 98 31 A6
X: 3
SWB: 16 05 60 39 32 9F 56 38 98 2A A4 79 20 62 09 9F CA 35 98 20 9F 5E 35 98 1B A6 3C 7D 22 3F 00 EE C2 EA 62 20
X: 3
SWB: 16 05 80 39 FF 04 E8 22 A6 32 9F 6E 3B 98 05 A6 32 9F 2C 34 A6 23 D2 00 90 0C A4 7E 00 24 DF 01 60 FB F0 02
X: 3
SWB: 16 05 A0 39 98 0D A1 02 01 A3 7E 20 D2 00 84 03 A4 7E 08 42 C0 9F 3F 3A A1 02 83 CA 20 90 58 C2 DF A3 83 20
X: 3
SWB: 16 05 C0 39 24 DF 01 60 04 F1 02 31 19 77 64 14 21 36 00 9C 35 22 36 00 09 7A 9C 2F 22 36 00 09 7A 9C 2F 64
X: 3
SWB: 16 05 E0 39 14 21 36 00 9C 35 09 7A 20 00 40 E9 50 94 24 64 10 9C 38 98 1E 9F 21 C7 D2 00 90 20 A1 00 83 C0
X: 3
SWB: 16 05 00 3A 10 90 09 0A 86 A1 02 88 9C 0F 98 04 09 86 9C 0E A4 7E 00 9F 46 61 A4 82 00 9F 7B 38 A1 02 83 CA
X: 3
SWB: 16 05 20 3A 08 92 AB C2 F7 A3 83 20 9F 06 C6 9B CE 38 60 EF F2 83 19 86 9A 60 10 F3 83 1A 86 A3 88 20 9A A1
X: 3
SWB: 16 05 40 3A 00 85 84 03 A4 84 00 D3 00 84 2D A1 03 01 D3 06 90 04 D3 04 84 22 D2 20 84 07 E4 80 84 84 19 98
X: 3
SWB: 16 05 60 3A 0D D2 22 84 13 A1 02 84 90 04 D2 02 84 0A A4 85 04 E4 92 84 A3 84 20 9A A4 84 00 9A A1 00 85 84
X: 3
SWB: 16 05 80 3A 02 72 9A 72 A1 00 84 D0 03 84 02 62 01 9A A1 02 85 90 05 B2 82 A3 85 20 9A 3F 9F 2A CB 62 0B 2F
X: 3
SWB: 16 05 A0 3A 9A A2 A0 3F A6 2A 9C 10 E6 5A 42 90 1D E6 5A 42 8C 0C E6 5A 40 90 1B E6 5A 41 84 07 98 08 E6 5A
X: 3
SWB: 16 05 C0 3A 43 90 0B 72 98 0E 9C 2B 98 0A 9C 2C 98 06 9C 2D 98 02 9C 2A 2F A0 0A 9A 3D A2 C0 3F F6 15 A6 4C
X: 3
SWB: 16 05 E0 3A 9C 10 E6 5C 00 84 0A ED 92 42 40 9C 0A A6 2C 98 26 E0 94 40 F6 51 9F 54 27 23 37 00 A6 C4 21 36
X: 3
SWB: 16 05 00 3B 00 9C 0D A6 2C D2 02 84 0E A1 06 36 77 EB 93 22 36 00 F6 51 9F E3 C5 ED 92 42 40 9F 35 3A A6 C2
X: 3
SWB: 16 05 20 3B 2F A0 0C 2D 9A A2 A0 3E 3F A7 02 F6 16 A6 4A 9C 10 02 80 12 C0 E6 5A 00 84 13 24 DF 01 42 01 CA
X: 3
SWB: 16 05 40 3B 03 D0 03 84 08 F6 21 9C 09 A6 2A 98 14 F6 81 9C 0C A6 2A D2 02 84 0A 23 02 00 F6 82 F6 61 9F E3
X: 3
SWB: 16 05 60 3B C5 01 C0 9F 2E 3A A6 A2 AA 2F 2E A0 0A 9A 3D 3E 3F A7 02 A6 2A F6 26 9C 10 01 80 11 C0 E6 5A 03
X: 3
SWB: 16 05 80 3B 84 0E 24 00 4C 40 0D C0 01 84 05 E6 13 60 11 C0 A1 00 7F 90 0C A6 A2 E6 22 F3 D2 02 8C 03 31 11
X: 3
SWB: 16 05 A0 3B C0 24 DF 01 42 01 CA 03 D0 03 84 17 E6 5A 4A 90 12 E6 5A 4B 90 0D E6 5A 04 94 08 01 C0 9C 09 A6
X: 3
SWB: 16 05 C0 3B 2B 98 66 F6 81 9C 0C A6 2B D2 02 84 3B E6 5A 03 90 10 E6 5A 03 80 28 A6 A2 E6 22 B6 D2 01 8C 1F
X: 3
SWB: 16 05 E0 3B 98 19 24 DF 01 42 01 CA 03 D0 03 84 12 44 80 75 01 C0 72 C3 E3 E9 12 12 C0 98 04 72 9F 05 1A 02
X: 3
SWB: 16 05 00 3C C0 F6 61 9F 83 CA 98 04 D2 00 90 1D E6 5A 03 84 18 42 C1 CA 20 90 07 A4 81 3C 60 FC F2 89 CA 40
X: 3
SWB: 16 05 20 3C 90 07 A4 80 32 60 F3 F2 89 01 C0 9F 2E 3A A6 B2 AA 2F 2E 2D 9A 09 8A 90 04 E9 81 19 8A 9A A1 00
X: 3
SWB: 16 05 40 3C 8D 84 02 31 9A 24 00 4D E0 B2 00 C2 01 9A A1 00 8D 84 02 31 9A 24 00 4D E0 A2 00 C2 01 E6 42 01
X: 3
SWB: 16 05 60 3C 9A 3F A7 09 72 52 C8 24 00 4D 42 03 90 28 FA 8A 84 24 73 24 67 05 F4 51 14 80 1B 62 01 52 C8 23
X: 3
SWB: 16 05 80 3C 08 00 22 7F 05 F6 81 9C 3F 23 09 00 F6 82 21 40 47 9F E3 C5 98 18 23 01 00 F6 82 E6 24 08 B5 D5
X: 3
SWB: 16 05 A0 3C 21 48 47 9F E3 C5 72 24 00 4D 40 03 84 02 62 01 A5 09 2F 9A 3D 3F 21 86 03 9F F8 19 F6 14 05 00
X: 3
SWB: 16 05 C0 3C 21 8E 03 9F F8 19 F6 14 02 00 30 E8 E5 8C 03 72 98 07 66 01 F6 51 9F 71 CB 2F 2D 9A 3D 3E 3F A1
X: 3
SWB: 16 05 E0 3C 00 8D 90 34 26 00 4D F8 81 84 18 9F B4 3C A6 2A 7B A1 0E 8C 7F F6 51 EF C1 9C 3A 4A 85 ED E1 80
X: 3
SWB: 16 05 00 3D 09 98 04 FA 8A 84 03 A4 8D 00 A1 00 8D 84 09 22 83 05 21 7F 05 9F CD 80 9F 4E 3C D2 00 90 0B 66
X: 3
SWB: 16 05 20 3D 04 22 44 47 21 83 05 9F 5B CA 9F 3E 3C D2 00 90 0B 66 04 22 40 47 21 7F 05 9F 5B CA 2F 2E 2D 9A
X: 3
SWB: 16 05 40 3D 3D 3F A7 01 24 40 47 42 08 CA 01 90 5D C2 FE 52 C0 23 01 00 F6 82 21 48 47 9F E3 C5 9F B4 3C A6
X: 3
SWB: 16 05 60 3D 2E A3 8C 20 24 F7 04 03 16 02 18 24 00 4D 48 04 F6 31 EA C1 A6 8A 7B ED E1 94 05 E6 58 00 84 2A
X: 3
SWB: 16 05 80 3D 24 F7 04 01 00 24 00 4D F4 E1 07 80 1D F4 E1 09 8C 18 F4 E2 0B 80 13 F4 E3 0D 8C 0E 01 01 84 05
X: 3
SWB: 16 05 A0 3D E0 5E 06 94 05 19 8A A4 8D 01 A9 2F 2D 9A 24 DF 01 42 01 CA 03 D0 03 90 03 62 0F 9A 24 00 4C 43
X: 3
SWB: 16 05 C0 3D 1A CB 01 84 04 62 0E 98 02 62 0F CB 02 84 02 C2 FD CB 04 84 02 C2 FB CB 08 84 02 C2 F7 9A 3D A2
X: 3
SWB: 16 05 E0 3D C0 A6 2B A6 4C 7A 22 10 01 98 26 A6 B8 79 23 03 00 EC 03 20 01 00 E8 E3 94 04 B4 A2 98 06 F9 30
X: 3
SWB: 16 05 00 3E 84 04 B5 A2 B2 03 B4 64 B5 65 E7 B8 40 A6 1B BA 9A BC 5A 83 D6 A6 32 A0 0C 2D 9A A6 25 D2 00 84
X: 3
SWB: 16 05 20 3E 04 21 01 00 9A 21 01 00 74 98 04 E9 61 B4 94 B5 54 83 F8 9A 73 E9 64 20 00 4C E8 24 42 1C C2 0F
X: 3
SWB: 16 05 40 3E D2 00 84 07 24 67 05 02 06 98 8F D2 01 84 07 24 67 05 02 26 98 84 D2 02 84 07 24 DF 01 02 00 98
X: 3
SWB: 16 05 60 3E 79 D2 03 84 07 24 DF 01 02 02 98 6E D2 04 84 07 24 46 02 42 02 98 25 D2 05 84 08 24 46 02 44 00
X: 3
SWB: 16 05 80 3E 75 98 57 D2 06 84 04 0A CD 98 4F D2 07 84 04 0A CF 98 47 D2 08 84 0D 24 68 02 42 03 73 A6 25 74
X: 3
SWB: 16 05 A0 3E 42 01 98 34 D2 09 84 0D 24 68 02 42 07 73 A6 25 74 42 05 98 23 D2 0B 84 0D 24 68 02 42 0B 73 A6
X: 3
SWB: 16 05 C0 3E 25 74 42 09 98 12 D2 0C 90 03 32 98 0D 24 68 02 42 0F 73 A6 25 74 42 0D E9 12 F6 21 9A A2 A0 3E
X: 3
SWB: 16 05 E0 3E 3F A7 02 52 C0 73 53 C1 F4 66 C0 20 00 4C E8 26 43 9C C3 0F D3 0A 84 16 24 68 02 40 01 84 27 40
X: 3
SWB: 16 05 00 3F 03 84 23 40 05 84 1F 31 40 07 90 30 98 18 D3 0D 84 19 24 68 02 40 09 84 0D 40 0B 84 09 40 0D 84
X: 3
SWB: 16 05 20 3F 05 31 40 0F 90 16 21 01 00 98 11 9F 34 3E A6 2A 40 9C E7 08 10 A6 12 9F 1B 3E BA 02 F4 64 C0 20
X: 3
SWB: 16 05 40 3F 00 4C E8 24 40 1D C0 01 90 09 73 D2 00 84 02 63 01 A6 32 AA 2F 2E A0 0A 9A 3F A6 26 A6 37 A1 00
X: 3
SWB: 16 05 60 3F AB C0 02 84 32 24 00 4C 40 12 C0 08 90 29 D5 00 90 04 65 08 98 02 65 07 D4 00 90 03 72 98 05 E7
X: 3
SWB: 16 05 80 3F 68 10 A6 02 E5 13 62 D7 00 90 04 A6 34 98 03 A6 34 73 A6 52 9F 11 C4 2F 9A 3F D2 00 84 06 65 01
X: 3
SWB: 16 05 A0 3F 62 01 98 12 D2 01 90 04 D2 02 84 03 75 98 07 D2 03 84 06 75 62 04 9F 59 3F 2F 9A 3D 3E 3F A7 0F
X: 3
SWB: 16 05 C0 3F 64 04 F6 81 9C 38 64 04 F6 81 E6 22 04 B3 D3 9C 38 36 EE 65 20 00 4C E8 25 E0 60 5D 80 29 E0 B3
X: 3
SWB: 16 05 E0 3F 5D C3 03 A6 C2 53 CA 9F DD 3E 43 CA D2 00 90 04 F6 84 98 0D 40 5D C0 10 84 0D 24 04 00 F6 80 E8
X: 3
SWB: 16 05 00 40 24 EE 24 B3 92 52 00 EE 96 20 04 00 EE C0 87 C2 36 EE 64 20 00 4C E8 24 E0 60 1D 80 53 E0 B2 1D
X: 3
SWB: 16 05 20 40 C2 03 73 32 A6 2A 7B ED 97 24 04 00 F6 80 E8 24 EA 24 46 00 77 F6 70 EB C0 84 03 73 98 1D F6 84
X: 3
SWB: 16 05 40 40 EA 24 49 00 59 C8 78 58 C9 F6 70 F4 C8 C8 84 02 63 01 EA 92 20 04 00 EA C0 87 CE EE 64 20 00 4C
X: 3
SWB: 16 05 60 40 E8 24 40 1D E7 08 08 A6 14 C4 01 13 CB 9F 99 3F EE 96 20 04 00 EE C0 87 98 A5 0F 2F 2E 2D 9A 3D
X: 3
SWB: 16 05 80 40 3F A1 00 AB C0 02 84 31 24 00 4C 40 12 C0 08 90 28 35 ED 64 20 00 4C E8 24 E0 60 1D 80 12 40 1D
X: 3
SWB: 16 05 A0 40 E7 08 08 A6 14 E0 B2 1D C4 01 73 C2 03 9F 99 3F ED 95 20 04 00 ED C0 87 D9 2F 2D 9A 3D 3E 3F A7
X: 3
SWB: 16 05 C0 40 02 F6 16 A1 00 AB C0 02 84 51 24 00 4C 40 12 C0 08 90 48 9F AE 3D B2 B2 E7 28 10 A6 03 B2 13 53
X: 3
SWB: 16 05 E0 40 C1 BD B7 BC E6 B7 B7 B6 E6 64 03 A6 62 9F DE 3D 52 C0 9F AE 3D CA 01 90 04 6B 11 98 01 7B 64 01
X: 3
SWB: 16 05 00 41 A6 B3 A6 C2 9F DE 3D A6 2A 44 C1 43 C0 62 07 9F 11 C4 A6 B4 A6 A3 62 08 9F 11 C4 AA 2F 2E 2D 9A
X: 3
SWB: 16 05 20 41 3D 3F A1 00 AB C0 02 84 3C 24 00 4C 40 12 C0 08 90 33 9F AE 3D B2 BB CA 01 90 03 E6 1B 10 A6 B4
X: 3
SWB: 16 05 40 41 A6 B3 62 06 9F 11 C4 62 02 9F FF C3 E5 0A 2B A6 B4 21 06 00 9F 11 C4 BA 62 C2 07 E6 AA 10 90 06
X: 3
SWB: 16 05 60 41 E6 12 01 98 01 72 2F 2D 9A 3D 24 64 80 21 FF 00 11 00 25 62 80 21 18 00 11 40 24 90 80 63 FE 53
X: 3
SWB: 16 05 80 41 00 24 68 80 72 52 00 01 40 E6 12 01 11 40 2D 9A 24 62 80 31 11 00 9A 3F 24 92 80 60 FE F0 00 21
X: 3
SWB: 16 05 A0 41 10 00 9F 64 C8 2F 9A 3F 9F 69 41 FC 60 24 90 80 62 FE 52 00 60 01 F1 02 21 10 00 9F 8D C8 2F 9A
X: 3
SWB: 16 05 C0 41 F6 14 42 00 D2 FF 90 04 B2 92 52 00 9A A2 A0 3F A7 04 A6 2A 24 40 48 02 00 03 02 12 C0 13 C2 D3
X: 3
SWB: 16 05 E0 41 00 90 04 F6 81 98 28 9F E9 C7 D2 00 84 07 9F 95 C4 D2 00 90 09 F6 81 E6 22 03 B3 D3 98 11 E6 5A
X: 3
SWB: 16 05 00 42 00 90 06 F6 83 EB 91 98 06 F6 82 EA 91 E9 91 9F C0 41 23 04 00 F6 82 21 40 48 9F E3 C5 AC 2F A0
X: 3
SWB: 16 05 20 42 0A 9A 3D 3F 24 67 05 40 07 E7 08 02 A6 14 24 00 4C 40 0B C0 20 90 91 A1 00 CE C0 01 90 3A 24 E9
X: 3
SWB: 16 05 40 42 01 E0 92 00 52 00 24 68 02 40 00 C0 01 84 16 40 02 C0 40 84 10 24 F7 04 E0 60 05 80 08 24 40 51
X: 3
SWB: 16 05 60 42 E0 52 07 80 6B 22 98 07 21 40 51 9F CD 80 A1 02 CE C2 FE A3 CE 20 98 48 E4 A0 1D 84 43 25 40 51
X: 3
SWB: 16 05 80 42 24 F7 04 01 18 F4 E1 44 88 36 24 94 07 D4 00 84 09 01 00 F4 E1 40 8C 09 98 26 01 02 F4 E1 42 94
X: 3
SWB: 16 05 A0 42 1F 25 E9 01 42 40 24 40 51 E0 52 06 88 04 B2 92 98 0A A1 02 CE E6 12 01 A3 CE 20 72 52 40 98 10
X: 3
SWB: 16 05 C0 42 24 E9 01 72 52 00 98 08 A1 02 CE C2 FE A3 CE 20 A1 02 CE C2 01 2F 2D 9A 3D 25 68 02 40 41 C0 01
X: 3
SWB: 16 05 E0 42 90 22 24 80 4C 42 01 CA 01 90 10 40 49 84 15 40 4B 84 11 40 4D 84 0D 40 4F 84 09 B2 B2 E6 42 01
X: 3
SWB: 16 05 00 43 C2 01 98 01 72 2D 9A 3D E4 60 97 80 04 6A 64 98 12 25 67 05 24 80 4C 40 00 C0 08 84 04 4A 54 98
X: 3
SWB: 16 05 20 43 02 4A 56 A4 95 00 A4 96 00 24 67 05 4B 26 E6 0B 40 E6 5B 00 84 05 24 8A 4C 98 03 24 90 4C 47 05
X: 3
SWB: 16 05 40 43 E5 E0 7A 80 1C ED 0A A6 72 E9 09 E6 22 64 B3 D3 E5 73 30 B2 E2 E9 E2 8C 03 A4 96 10 A4 95 1F 98
X: 3
SWB: 16 05 60 43 84 46 04 E5 E0 6A 80 1B ED 09 EB 0A A6 76 EB 0B EB 22 E5 75 50 B4 E4 EA E1 8C 03 A4 96 08 A4 95
X: 3
SWB: 16 05 80 43 0F 98 62 47 03 E5 E0 7A 80 1B ED 09 A6 74 EA 0A EB 0B EB 22 E5 75 50 B4 E4 EA E1 8C 03 A4 96 04
X: 3
SWB: 16 05 A0 43 A4 95 07 98 40 46 02 E5 E0 6A 80 1B ED 09 EB 0A A6 76 EB 0B EB 22 E5 75 50 B4 E4 EA E1 8C 03 A4
X: 3
SWB: 16 05 C0 43 96 02 A4 95 03 98 1E 44 01 E5 E0 4A 80 17 ED 09 EA 0A EB 0B EB 22 E5 75 50 B4 E4 EA E1 8C 03 A4
X: 3
SWB: 16 05 E0 43 96 01 A4 95 01 E0 EA 00 8C 04 60 80 F3 95 24 80 4C 40 01 C0 04 90 0B A1 00 96 90 06 E4 B2 95 A3
X: 3
SWB: 16 05 00 44 95 20 24 67 05 40 27 C0 02 90 0D 24 80 4C 40 00 C0 02 90 04 60 80 F3 95 E6 5B 00 84 04 60 40 F3
X: 3
SWB: 16 05 20 44 95 2D 9A E4 B2 AB E6 42 01 C2 01 9A 24 80 4C 40 00 C0 04 90 19 40 01 C0 08 90 13 A1 00 CD C0 02
X: 3
SWB: 16 05 40 44 90 0C 43 09 62 0F E7 31 20 24 EA 01 11 00 9A 3D 25 EA 01 02 40 90 33 E4 A0 1D 90 14 24 F7 04 01
X: 3
SWB: 16 05 60 44 12 24 29 4C F4 E1 10 80 07 A1 00 CD C0 02 84 08 24 EA 01 31 11 00 98 15 F5 91 8E 19 8E 20 3B 00
X: 3
SWB: 16 05 80 44 E8 51 94 0B EA 81 11 40 98 02 12 40 31 19 8E 2D 9A 24 EA 01 03 00 84 03 74 98 11 74 63 0F 24 80
X: 3
SWB: 16 05 A0 44 4C 42 09 E7 21 30 E9 53 8C 02 64 01 A6 42 9A 3F 24 92 80 60 F7 F0 00 21 80 00 9F 64 C8 2F 9A 3F
X: 3
SWB: 16 05 C0 44 FC 60 A1 02 97 CA 40 84 0C E6 12 10 A3 97 20 21 00 01 9F 64 C8 FC 50 2F 9A 3F A1 02 97 E6 12 20
X: 3
SWB: 16 05 E0 44 A3 97 20 CA 40 84 06 21 00 01 9F 64 C8 2F 9A A2 A0 3F A6 2A 24 80 4C 40 00 E7 08 04 A6 12 9F DE
X: 3
SWB: 16 05 00 45 C6 A6 A2 C2 3F 9F EF C6 2F A0 0A 9A 3F A6 24 75 A1 03 94 C0 03 B2 50 84 09 A1 02 95 E6 42 01 A3
X: 3
SWB: 16 05 20 45 95 20 E7 38 40 A6 16 A6 62 73 73 C2 03 F6 10 EA C0 84 09 A1 02 95 E6 42 02 A3 95 20 E7 68 40 A6
X: 3
SWB: 16 05 40 45 12 73 73 C2 03 E9 C2 84 09 A1 02 95 E6 42 04 A3 95 20 A1 02 95 9F EF 44 2F 9A 3F 32 21 80 01 9F
X: 3
SWB: 16 05 60 45 54 C8 72 9F EF 44 64 10 21 06 10 9F 11 C4 64 11 21 08 11 9F 11 C4 64 10 21 09 10 9F 11 C4 60 7F
X: 3
SWB: 16 05 80 45 F2 97 2F 9A 3D 3E 3F 20 10 00 E8 51 8C 05 25 01 00 98 0B E7 28 10 A6 1A 7B E7 38 10 E8 15 26 90
X: 3
SWB: 16 05 A0 45 80 ED 85 FC 60 62 F7 52 80 60 08 F1 82 21 80 00 9F 8D C8 F9 50 87 EA 2F 2E 2D 9A 3F 64 01 A6 23
X: 3
SWB: 16 05 C0 45 62 09 9F 11 C4 21 10 10 9F BA C1 2F 9A A2 A0 3F A6 2A 62 75 E7 A2 20 E5 C2 5A B2 B2 B5 22 E7 28
X: 3
SWB: 16 05 E0 45 20 A6 15 62 0B E7 51 20 E5 F2 A2 64 AB E7 21 40 B3 B6 E7 A1 40 B3 B4 B4 62 B4 22 E5 C4 2A D5 00
X: 3
SWB: 16 05 00 46 84 0C A6 42 73 E9 61 E9 61 E6 12 30 98 0C D5 01 84 0F E7 48 10 A6 02 E6 12 0C B6 12 A3 94 20 98
X: 3
SWB: 16 05 20 46 14 A6 62 73 E9 61 E9 61 E7 48 10 A6 04 B2 14 E6 14 03 A3 94 40 A4 95 00 62 01 9F 0C 45 24 80 4C
X: 3
SWB: 16 05 40 46 42 08 E7 28 04 A6 02 A4 90 00 A3 91 20 98 5B 62 03 9F 0C 45 21 E0 01 9F 84 45 62 02 9F 0C 45 21
X: 3
SWB: 16 05 60 46 E0 01 9F 84 45 62 02 9F 0C 45 21 A0 05 9F 84 45 62 02 9F 0C 45 21 E0 01 9F 84 45 62 02 9F 0C 45
X: 3
SWB: 16 05 80 46 21 E0 01 9F 84 45 A1 02 97 E6 EA 00 88 06 CA 20 90 0E 98 1A C2 DF A3 97 20 72 9F BB 45 E6 1A 80
X: 3
SWB: 16 05 A0 46 22 20 0D 09 90 9F 61 CF 19 90 FA 90 87 A1 2F A0 0A 9A 3F 60 BF F2 97 9F BB 45 21 00 01 9F 8D C8
X: 3
SWB: 16 05 C0 46 60 40 F3 97 21 00 10 9F BA C1 2F 9A 3D 3F 62 02 9F FF C3 A6 2A 7B BB BB BA EA BB BB BA EA BB BB
X: 3
SWB: 16 05 E0 46 BA EA BB BB BA EA E6 4A 01 A6 A2 C2 01 2F 2D 9A 3D 3E 3F A7 04 9F 5A 45 9F CC 46 D2 00 90 05 62
X: 3
SWB: 16 05 00 47 01 9F B2 46 21 20 00 9F 84 45 9F CC 46 D2 00 87 E7 9F B2 46 A1 00 97 C0 10 84 14 21 20 00 9F 84
X: 3
SWB: 16 05 20 47 45 9F CC 46 D2 00 93 D0 9F 23 44 D2 00 87 C9 9F D8 42 D2 00 87 C2 60 DF F2 97 62 01 9F BB 45 24
X: 3
SWB: 16 05 40 47 68 02 40 09 84 0C 40 0B 84 08 40 0D 84 04 40 0F 90 0B 24 80 4C 42 00 CA 30 D0 20 90 10 24 80 4C
X: 3
SWB: 16 05 60 47 42 08 B2 62 A4 90 00 A3 91 20 9F 07 43 A4 94 01 98 25 E5 02 BA 9F EF 44 24 80 4C F4 65 06 F6 52
X: 3
SWB: 16 05 80 47 09 90 9F 61 CF 19 90 F6 51 9F 84 45 A1 02 94 B2 62 E6 12 01 A3 94 20 A1 0B 94 A1 0A 95 A6 A2 C2
X: 3
SWB: 16 05 A0 47 3F E5 E0 B2 80 07 9F D8 42 D2 00 93 C5 31 19 92 A4 94 00 24 80 4C 4D 00 A6 DC E6 0C 04 98 88 A1
X: 3
SWB: 16 05 C0 47 03 95 24 80 4C 40 01 C0 04 90 13 A1 04 96 90 0E 05 02 A6 32 C2 3F E5 43 42 A3 95 30 98 39 DB 00
X: 3
SWB: 16 05 E0 47 88 10 24 80 4C 05 02 90 2E A1 00 94 90 29 C3 C0 98 25 53 C0 79 59 C1 CB 40 90 1A 24 80 4C 05 04
X: 3
SWB: 16 05 00 48 90 15 A1 00 94 90 10 01 C0 73 C2 3F E5 73 30 B2 E2 A6 23 98 02 0D 90 A1 02 94 E6 42 01 A3 94 20
X: 3
SWB: 16 05 20 48 A6 32 9F EF 44 F6 51 9F 84 45 F6 52 09 90 9F 61 CF 19 90 F6 51 F5 21 92 19 92 20 E8 03 E8 51 94
X: 3
SWB: 16 05 40 48 06 9F 07 43 31 19 92 E6 5C 00 90 07 A1 00 95 C0 40 84 0B FA 90 84 07 24 EA 01 F8 00 90 07 9F D8
X: 3
SWB: 16 05 60 48 42 D2 00 93 5A A6 D2 C2 30 D2 30 90 0F D2 20 90 0B D2 10 84 50 A1 00 97 C0 20 84 49 24 68 02 40
X: 3
SWB: 16 05 80 48 09 84 12 40 0B 84 0E 40 0D 84 0A 40 0F 84 06 72 9F CD 45 98 30 7C 25 01 01 5C C2 79 59 C3 F4 64
X: 3
SWB: 16 05 A0 48 C2 20 68 02 E8 24 40 09 BA 00 90 05 A6 B2 9F CD 45 E6 5A 80 84 06 BC 9C 6A 01 98 02 BA 6A BB 9B
X: 3
SWB: 16 05 C0 48 E6 5B 21 87 D4 60 6F F2 97 72 9F EF 44 9B F8 46 3F 72 9F C3 C4 72 9F 88 BF 21 10 10 9F BA C1 31
X: 3
SWB: 16 05 E0 48 9F E3 C3 24 95 80 62 FE 52 00 24 91 80 52 00 73 B2 92 9F A9 C7 2F 9A 3D 3F F6 15 FC 60 21 96 05
X: 3
SWB: 16 05 00 49 9F 79 CA 9F D0 48 62 02 9F 20 C8 F6 52 62 01 9F 57 C9 2F 2D 9A 3D A2 D0 3F A7 02 F6 15 12 C0 A6
X: 3
SWB: 16 05 20 49 6D FC 60 A6 64 21 96 05 9F 79 CA A6 D4 21 95 05 9F 79 CA 9F D0 48 A4 FC 00 62 0A 9F 20 C8 F6 52
X: 3
SWB: 16 05 40 49 62 01 9F 57 C9 02 C0 62 04 9F 57 C9 AA 2F A0 0D 2D 9A 3F 24 DF 01 60 01 F1 03 24 00 0C 40 00 D0
X: 3
SWB: 16 05 60 49 AA 84 17 24 08 0C 40 00 D0 55 84 0E 9F E9 C7 D2 00 84 07 9F 95 C4 D2 00 90 03 9F E3 C9 24 00 0C
X: 3
SWB: 16 05 80 49 62 AA 52 00 24 08 0C 62 55 52 00 9F 0E CA 9F CB C6 9F 2D C8 9F 3A 5A A1 02 AB E6 12 80 A3 AB 20
X: 3
SWB: 16 05 A0 49 33 32 31 9F E3 C5 9F CD 60 9F 85 01 9F D0 48 9F 97 15 9F 41 C5 21 06 00 9F 08 C4 21 07 07 9F 08
X: 3
SWB: 16 05 C0 49 C4 21 08 07 9F 08 C4 64 7F 21 09 00 9F 11 C4 9F 7E 15 9F 7F 40 24 96 05 40 00 90 07 64 02 F6 41
X: 3
SWB: 16 05 E0 49 9F 79 CA 24 95 05 40 00 90 07 64 02 F6 41 9F 79 CA 9F 3D C9 21 01 00 2F 9A 3F 21 26 01 9F AF C6
X: 3
SWB: 16 05 00 4A D2 07 90 07 D2 FC 90 03 9F 3E CC 2F 9A 3D 3E E4 60 AA 80 77 A1 04 98 75 EA 66 EE 66 EE 66 20 EC
X: 3
SWB: 16 05 20 4A 01 E8 26 25 68 02 E0 A2 80 E0 02 41 90 37 EA 91 22 03 00 9C 48 A3 98 40 A6 42 73 E9 64 EC 64 EC
X: 3
SWB: 16 05 40 4A 64 20 EC 01 E8 24 25 68 02 42 41 52 00 43 43 53 01 42 45 52 02 43 47 53 03 25 80 43 01 40 11 06
X: 3
SWB: 16 05 60 4A 31 11 04 98 0D EE 96 ED 95 ED 95 20 70 02 ED C0 87 B4 A1 02 98 73 E9 64 EC 64 EC 64 20 EC 01 E8
X: 3
SWB: 16 05 80 4A 24 01 04 E9 A0 90 04 E9 91 11 04 2E 2D 9A 24 40 46 72 40 18 84 0C 40 19 84 08 40 1A 84 04 40 1B
X: 3
SWB: 16 05 A0 4A 90 0B B2 92 20 08 00 E8 24 D2 03 87 E5 9A 3F A4 98 00 24 04 02 31 11 00 64 18 21 EC 01 9C 38 23
X: 3
SWB: 16 05 C0 4A 18 00 22 EC 01 21 40 46 9F E3 C5 23 18 00 22 EC 01 21 58 46 9F E3 C5 2F 9A 3D 3E 3F A7 02 E4 B2
X: 3
SWB: 16 05 E0 4A F2 C2 01 52 C1 E4 60 AA 80 CC 9F 8E 4A 52 C0 D2 02 8C C3 D2 00 90 2B 73 E9 64 EC 64 EC 64 20 38
X: 3
SWB: 16 05 00 4B 46 E8 24 25 68 02 40 18 E0 50 49 84 15 40 19 E0 50 4B 84 0E 40 1A E0 50 4D 84 07 40 1B E0 50 4F
X: 3
SWB: 16 05 20 4B 90 87 60 FD F2 F2 4C C0 7D EE 65 ED 65 ED 65 23 01 00 22 71 02 F6 51 20 58 46 E8 21 9F E3 C5 23
X: 3
SWB: 16 05 40 4B 01 00 22 73 02 F6 51 20 59 46 E8 21 9F E3 C5 23 01 00 22 75 02 F6 51 20 5A 46 E8 21 9F E3 C5 23
X: 3
SWB: 16 05 60 4B 01 00 22 77 02 F6 51 20 5B 46 E8 21 9F E3 C5 43 C0 D3 00 90 10 F6 51 23 02 00 22 04 02 20 54 46
X: 3
SWB: 16 05 80 4B E8 21 9F E3 C5 EE 61 E9 61 E9 61 23 02 00 22 80 43 20 5E 46 E8 21 9F E3 C5 42 C1 D2 00 90 04 60
X: 3
SWB: 16 05 A0 4B 02 F3 F2 24 04 02 31 98 0B 24 04 02 01 00 E9 A0 90 04 E9 91 11 00 AA 2F 2E 2D 9A 3D 3E 3F A7 02
X: 3
SWB: 16 05 C0 4B 11 C0 37 A1 0C 98 7D EE 91 EF 21 22 03 00 9C 48 A6 4A 7B ED 62 EA 62 EA 62 23 08 00 20 EC 01 E8
X: 3
SWB: 16 05 E0 4B 22 01 C0 9C 3F EF 97 01 C0 E6 22 08 B3 D3 11 C0 20 03 00 EF C0 87 CC AA 2F 2E 2D 9A 3F A7 18 E4
X: 3
SWB: 16 05 00 4C 60 AA 80 10 F6 81 9F BB 4B 23 18 00 F6 82 21 40 46 9F E3 C5 A5 18 2F 9A A6 26 F6 24 D2 00 84 0D
X: 3
SWB: 16 05 20 4C 23 1A 00 22 97 05 F6 41 9C 3F 62 1A 9A D2 01 84 0D 23 14 00 22 4B 06 F6 41 9C 3F 62 14 9A D2 02
X: 3
SWB: 16 05 40 4C 84 0D 23 04 00 22 5F 06 F6 41 9C 3F 62 04 9A D2 03 84 08 23 20 00 22 0B 06 98 28 D2 04 84 08 23
X: 3
SWB: 16 05 60 4C 20 00 22 2B 06 98 1C E6 22 FB D2 06 8C 1C A6 64 75 EA 62 EA 62 EA 62 EA 62 EA 62 23 20 00 20 E3
X: 3
SWB: 16 05 80 4C 05 E8 22 F6 41 9C 3F 62 20 9A A6 62 E6 22 F4 D2 02 8C 14 62 1E E7 62 20 23 1E 00 20 49 04 E8 22
X: 3
SWB: 16 05 A0 4C F6 41 9C 3F 62 1E 9A D6 0F 90 02 72 9A 23 20 00 22 63 06 F6 41 9C 3F 62 20 9A 3D 72 25 C0 47 24
X: 3
SWB: 16 05 C0 4C 06 02 40 00 E0 50 42 88 02 62 01 2D 9A 3D 25 06 02 D2 00 90 03 72 98 0C 42 40 24 C0 47 E0 52 02
X: 3
SWB: 16 05 E0 4C 88 04 B2 92 52 40 2D 9A 3D 3E 3F A7 01 52 C0 A6 3B F6 26 7A 98 0F F6 62 A6 B3 42 C0 9F F2 AA D2
X: 3
SWB: 16 05 00 4D 01 90 0B BA 9A 24 C0 47 E0 5A 01 83 E9 72 A9 2F 2E 2D 9A 3F A6 23 24 C0 47 42 00 9F E8 4C 2F 9A
X: 3
SWB: 16 05 20 4D 3F D2 00 90 05 22 A6 5C 98 03 22 19 EB 63 C4 24 C0 47 42 00 9F E8 4C 2F 9A 3D 3E 3F A7 01 72 9F
X: 3
SWB: 16 05 40 4D 20 4D D2 00 90 60 25 C0 47 22 00 80 63 20 42 40 9F E8 4C D2 00 90 4F F6 56 42 40 52 C0 02 44 43
X: 3
SWB: 16 05 60 4D 43 42 C0 9F E8 4C D2 00 90 3C 02 47 43 46 42 80 9F E8 4C D2 00 90 2F 02 4A 43 49 42 80 9F E8 4C
X: 3
SWB: 16 05 80 4D D2 00 90 22 02 4D 43 4C 42 80 9F E8 4C D2 00 90 15 20 0C 00 E8 25 20 20 48 ED C0 87 C0 98 0D 62
X: 3
SWB: 16 05 A0 4D 01 9F 20 4D 98 01 72 A9 2F 2E 2D 9A 22 FC FF 63 30 24 C0 47 42 00 9F E8 4C D2 00 93 E9 99 E0 23
X: 3
SWB: 16 05 C0 4D 12 00 22 1A 02 9C 3F 62 12 9A 3D 3E 3F A7 01 52 C0 A6 3B F6 26 7A 98 13 F6 62 A6 B3 42 C0 9F 82
X: 3
SWB: 16 05 E0 4D AA DA 00 80 04 62 01 98 0B BA 9A 24 C0 47 E0 5A 01 83 E5 72 A9 2F 2E 2D 9A 3D 3E 3F A7 09 A6 23
X: 3
SWB: 16 05 00 4E F6 26 D2 00 90 07 D2 04 84 2A E6 23 7C F6 62 E6 24 12 B5 D5 12 C2 98 12 B3 9A F6 62 24 C0 47 42
X: 3
SWB: 16 05 20 4E 00 9F CA 4D EE 96 EE 96 A6 A3 00 C2 EE C0 87 E8 62 12 98 E4 D2 01 84 5B F6 25 63 20 24 C0 47 42
X: 3
SWB: 16 05 40 4E 00 52 C4 B3 94 54 C1 F6 52 42 C4 9F CA 4D ED 95 ED 95 45 C1 D5 24 90 04 A6 53 99 E7 F6 62 E6 24
X: 3
SWB: 16 05 60 4E 08 B5 D5 63 30 24 C0 47 42 00 9F CA 4D 20 0A 00 E8 26 63 38 24 C0 47 4B 00 B3 9A F6 62 A6 B2 9F
X: 3
SWB: 16 05 80 4E CA 4D EE 96 EE 96 E6 5A 3B 84 04 62 10 98 89 A6 A3 99 E6 E6 22 FE D2 01 8C 53 D3 03 84 04 66 60
X: 3
SWB: 16 05 A0 4E 98 02 66 40 F6 65 24 C0 47 42 00 52 C5 F6 62 E6 24 20 B5 D5 12 C6 98 30 43 C0 B3 95 55 C0 F6 52
X: 3
SWB: 16 05 C0 4E EE 22 42 C5 56 C8 9F CA 4D EE 96 EE 96 46 C8 20 08 00 EE C0 87 E2 20 08 00 E8 25 00 C6 ED C0 84
X: 3
SWB: 16 05 E0 4E 04 62 20 98 33 E6 26 08 A6 63 36 99 CD D3 05 90 03 72 98 24 25 C0 47 63 C4 42 40 9F CA 4D EE 96
X: 3
SWB: 16 05 00 4F EE 96 F6 62 63 FE 42 40 9F CA 4D EE 92 EA 92 63 FF 42 40 9F CA 4D 62 06 A5 09 2F 2E 2D 9A 3D 3E
X: 3
SWB: 16 05 20 4F 3F 73 25 08 02 24 C0 47 4D 00 B3 9C F6 52 A6 D2 9F CA 4D ED 95 ED 95 E6 5C 09 90 08 D2 00 90 04
X: 3
SWB: 16 05 40 4F A6 C3 99 E6 2F 2E 2D 9A 3D 3F A7 02 25 07 02 40 40 90 1C F6 82 63 30 24 C0 47 42 00 9F CA 4D 52
X: 3
SWB: 16 05 60 4F 40 D2 00 90 0A 01 C0 B3 B3 B2 E2 C2 01 98 02 62 01 AA 2F 2D 9A 3D 3E 3F A7 02 25 07 02 72 52 40
X: 3
SWB: 16 05 80 4F 26 C0 47 F6 82 73 42 80 9F CA 4D D2 00 90 26 F8 C0 84 05 9F 39 4D 98 1B 72 9F 20 4D D2 00 90 15
X: 3
SWB: 16 05 A0 4F 22 FC FF 63 30 42 80 9F E8 4C D2 00 90 07 62 01 9F 20 4D 52 40 AA 2F 2E 2D 9A 3D 3F 25 08 02 01
X: 3
SWB: 16 05 C0 4F 40 B3 B3 B2 E2 B3 B3 B2 E2 B3 B3 B2 E2 CB 10 90 06 E9 A1 C3 0F E9 B1 23 E8 03 22 71 02 9F 0D CF
X: 3
SWB: 16 05 E0 4F 20 AC 0A E8 21 11 52 ED 95 ED 95 20 1A 02 ED C0 87 CD 2F 2D 9A 3D 3F 25 07 02 40 40 90 0C 9F 1E
X: 3
SWB: 16 05 00 50 4F 52 40 D2 00 90 03 9F BA 4F 24 07 02 4A 00 A6 A2 9F CD 4C A6 A2 2F 2D 9A 24 00 50 42 02 A3 9B
X: 3
SWB: 16 05 20 50 20 9A 3F F6 24 CE 20 90 07 F4 E1 00 94 0E 98 05 F4 E1 00 88 07 F6 12 F6 41 9F 83 CA 2F 9A 3D 3F
X: 3
SWB: 16 05 40 50 A6 2A 7B ED 65 ED 65 20 0B 06 E8 25 F4 92 40 F6 51 9F 83 CA 24 80 43 02 00 ED 91 E9 91 9F 83 CA
X: 3
SWB: 16 05 60 50 2F 2D 9A 3F A1 00 AA C0 20 90 2C 23 CE 01 22 C0 43 21 97 05 9F 4A CE FB 90 1D A4 9B 00 31 19 99
X: 3
SWB: 16 05 80 50 24 63 07 F4 92 00 F6 41 9F 83 CA 23 CE 01 22 97 05 21 C0 43 9F E3 C5 2F 9A 3F 9F 63 50 2F 9A 3F
X: 3
SWB: 16 05 A0 50 24 00 50 A1 00 9B E0 50 02 80 03 9F 63 50 2F 9A 3D 3E 3F A7 03 9F 28 03 52 C2 21 FF 7F 11 C0 36
X: 3
SWB: 16 05 C0 50 98 3A E0 83 C2 53 C2 A6 3E 7F EF 64 EC 64 20 4F 06 E8 24 01 00 02 02 24 10 0E 35 9C 4B D5 00 84
X: 3
SWB: 16 05 E0 50 08 D4 00 84 04 D3 7F 94 03 21 FF 7F F6 13 E9 E6 88 02 F6 16 01 C0 EB E1 94 02 13 C0 43 C2 D3 00
X: 3
SWB: 16 05 00 51 87 C0 02 C0 F6 61 AB 2F 2E 2D 9A A2 A0 3F A6 2A 9F B0 50 A6 A4 75 9C 48 2F A0 0A 9A A2 A0 3F A6
X: 3
SWB: 16 05 20 51 2A 9F B0 50 EA C1 A6 A4 75 9C 48 2F A0 0A 9A 3F A7 04 F6 14 21 01 00 32 11 C0 12 C2 A1 00 AB C0
X: 3
SWB: 16 05 40 51 40 90 08 21 10 0E 32 11 C0 12 C2 00 00 F4 20 C0 10 C0 00 02 F4 38 C2 10 C2 66 04 F6 82 F6 41 9F
X: 3
SWB: 16 05 60 51 5B CA AC 2F 9A 3D 3E 3F A7 02 A1 00 AA C0 20 90 BA 21 5F 06 9F 2F 51 66 04 65 07 A1 04 9E 21 0B
X: 3
SWB: 16 05 80 51 50 9F 2D 57 A3 9E 20 9F 46 CB D2 07 8C 2D 24 94 07 45 09 25 00 50 74 E0 55 43 88 08 B4 94 ED 95
X: 3
SWB: 16 05 A0 51 D4 07 87 F3 73 E9 61 E9 61 E9 61 B4 22 B3 D3 E9 61 E9 61 20 63 06 E8 21 9F 2F 51 A1 02 1D A1 00
X: 3
SWB: 16 05 C0 51 9C E4 50 1D 90 08 A4 9D 00 A3 9C 20 98 10 A1 02 9D 24 00 50 E0 52 0A 88 05 B2 92 A3 9D 20 A1 00
X: 3
SWB: 16 05 E0 51 21 90 32 62 04 52 C1 63 08 53 C0 36 E0 82 C1 52 C1 43 C0 E4 03 21 90 0F A6 2A 7B ED 61 E9 61 20
X: 3
SWB: 16 05 00 52 4F 06 E8 21 9F 2F 51 E0 B2 C0 52 C0 EE 96 20 04 00 EE C0 87 D7 0A 99 EA 91 19 99 20 0F 0E E8 52
X: 3
SWB: 16 05 20 52 94 09 31 19 99 E4 92 9B A3 9B 20 AA 2F 2E 2D 9A 3F F6 24 A6 6E DE 00 80 05 20 54 F5 E8 21 E6 22
X: 3
SWB: 16 05 40 52 05 B3 D3 22 0A 00 9C 48 F6 12 E6 AE 20 90 15 20 7E 00 E8 E1 94 04 64 7F 98 1D 42 00 E9 09 E9 E2
X: 3
SWB: 16 05 60 52 94 1A 98 13 20 81 FF E8 E1 88 04 64 80 98 08 42 00 E9 09 E9 E2 88 05 F6 41 9F 79 CA 2F 9A 3D 3E
X: 3
SWB: 16 05 80 52 3F A7 0F A1 00 AA C0 20 84 03 9B 88 55 24 00 50 A1 00 9B E0 50 02 80 03 9B 88 55 9F 28 03 52 C6
X: 3
SWB: 16 05 A0 52 98 30 E0 82 C6 52 C6 A6 2C 7D EE 65 F6 54 20 F7 04 E8 24 14 C9 66 20 F6 52 20 97 05 E8 22 01 08
X: 3
SWB: 16 05 C0 52 9F 22 50 76 F6 52 20 9F 05 E8 22 04 C9 01 08 9F 22 50 25 F7 04 49 C6 E6 59 00 87 C6 66 20 22 A7
X: 3
SWB: 16 05 E0 52 05 01 56 F4 C9 58 9F 22 50 66 20 22 A9 05 01 44 9F 22 50 76 22 AB 05 01 44 9F 22 50 76 22 AD 05
X: 3
SWB: 16 05 00 53 01 46 9F 22 50 76 22 AF 05 01 6E 9F 22 50 24 00 50 A1 00 9D E0 50 0A 81 11 A1 02 9C D2 FF 84 02
X: 3
SWB: 16 05 20 53 62 02 52 C7 72 52 C8 01 C7 22 1E 00 9C 42 F6 15 26 F7 04 66 20 F6 12 20 B1 05 E8 22 01 80 9F 30
X: 3
SWB: 16 05 40 53 52 76 F6 52 20 B2 05 E8 22 01 80 9F 30 52 66 A0 F6 52 20 B3 05 E8 22 01 B2 F4 C9 B4 9F 30 52 66
X: 3
SWB: 16 05 60 53 20 F6 52 20 B4 05 E8 22 24 31 05 01 16 9F 30 52 F4 91 C7 22 1E 00 9C 42 76 F6 12 20 97 05 E8 22
X: 3
SWB: 16 05 80 53 24 31 05 01 16 9F 30 52 66 20 F6 52 20 B6 05 E8 22 01 B0 9F 30 52 69 04 59 C1 31 11 C2 98 35 E0
X: 3
SWB: 16 05 A0 53 83 C1 53 C1 A6 3C 7D 01 C7 22 1E 00 9C 42 EE 21 11 CB EE 65 20 33 05 E8 25 66 20 F6 12 20 B7 05
X: 3
SWB: 16 05 C0 53 E8 22 01 56 9F 30 52 76 02 CB 20 BB 05 E8 22 01 56 9F 30 52 F4 94 C2 14 C2 20 05 00 EC C0 87 BF
X: 3
SWB: 16 05 E0 53 69 08 59 C0 31 11 C4 98 35 E0 83 C0 53 C0 A6 3C 7D 01 C7 22 1E 00 9C 42 EE 21 11 CD EE 65 20 0A
X: 3
SWB: 16 05 00 54 02 E8 25 66 20 F6 12 20 BF 05 E8 22 01 52 9F 30 52 76 02 CD 20 C7 05 E8 22 01 52 9F 30 52 F4 94
X: 3
SWB: 16 05 20 54 C4 14 C4 20 09 00 EC C0 87 BF A1 04 9F 24 68 02 45 01 A3 9F 50 A1 02 A0 43 03 A3 A0 30 B2 A2 E5
X: 3
SWB: 16 05 40 54 0B 32 A1 02 A1 43 05 A3 A1 30 B2 A2 E5 0C 32 B4 A4 B5 04 A6 4A CC 01 84 05 E6 AB 40 90 05 62 01
X: 3
SWB: 16 05 60 54 9F 3E 50 E6 AA 02 90 04 72 9F 3E 50 E6 AA 04 90 05 62 04 9F 3E 50 E6 AA 08 90 05 62 05 9F 3E 50
X: 3
SWB: 16 05 80 54 E6 AA 10 90 05 62 02 9F 3E 50 E6 AA 20 90 05 62 03 9F 3E 50 E6 AA C0 90 05 62 06 9F 3E 50 A6 BA
X: 3
SWB: 16 05 A0 54 E6 AB 03 90 05 62 08 9F 3E 50 E6 AA 0C 90 05 62 07 9F 3E 50 E6 AA 10 90 05 62 09 9F 3E 50 E6 AA
X: 3
SWB: 16 05 C0 54 20 90 05 62 0A 9F 3E 50 E6 AC 01 90 05 62 0B 9F 3E 50 A1 02 A2 24 46 02 E0 60 01 80 0F CA 08 84
X: 3
SWB: 16 05 E0 54 05 62 0C 9F 3E 50 60 08 F3 A2 98 05 C2 F7 A3 A2 20 A1 02 A2 A1 00 CF C0 04 84 07 C2 FB A3 A2 20
X: 3
SWB: 16 05 00 55 98 0F CA 04 84 0B E6 12 04 A3 A2 20 62 0F 9F 3E 50 E4 B3 A2 C3 01 A1 00 D0 E7 08 40 A6 12 C2 01
X: 3
SWB: 16 05 20 55 B2 53 90 16 E6 43 01 A1 02 A2 C2 FD B3 60 C0 02 B0 12 A3 A2 20 62 0E 9F 3E 50 A1 04 A2 A6 43 C3
X: 3
SWB: 16 05 40 55 01 E4 B2 D0 C2 01 B2 53 90 13 E6 43 01 A6 42 C2 FE C3 01 B3 12 A3 A2 20 62 0D 9F 3E 50 24 4B 06
X: 3
SWB: 16 05 60 55 02 00 90 19 24 B4 03 01 00 EA E1 80 10 24 4D 06 02 00 90 09 24 B6 03 01 00 EA E1 88 0B 66 04 22
X: 3
SWB: 16 05 80 55 B4 03 21 4B 06 9F 5B CA A5 0F 2F 2E 2D 9A 3D A2 C0 3F 9F F4 C9 A6 2C 22 CE 01 21 97 05 9C 39 24
X: 3
SWB: 16 05 A0 55 97 05 21 FF 7F 11 0E 11 0C 11 0A 11 08 24 ED 05 27 03 00 98 57 EF 87 63 80 53 00 53 03 62 7F 52
X: 3
SWB: 16 05 C0 55 01 11 04 67 04 B7 87 F6 71 22 1E 00 9C 42 F6 15 20 97 05 E8 25 B7 2A BB DB 63 80 53 60 62 7F 52
X: 3
SWB: 16 05 E0 55 64 D7 00 87 E0 67 08 B7 87 F6 71 22 1E 00 9C 42 F6 15 20 97 05 E8 25 B7 2A BB DB 63 80 53 68 62
X: 3
SWB: 16 05 00 56 7F 52 70 D7 00 87 E0 20 E2 FF E8 24 F9 70 87 A5 E6 5C 00 90 0C FC 60 9F CC C9 24 A0 07 11 00 FC
X: 3
SWB: 16 05 20 56 50 24 00 50 43 02 A3 9B 30 A1 00 AB C0 40 90 06 21 00 40 9F E5 60 2F A0 0C 2D 9A 3F 24 00 50 40
X: 3
SWB: 16 05 40 56 00 C0 01 90 03 9F 8E 55 2F 9A 3F 24 63 07 F8 00 84 0C 23 CE 01 22 C0 43 21 97 05 9F 2C CA 64 03
X: 3
SWB: 16 05 60 56 21 9F 00 9C 38 A4 A2 00 A4 9E 04 2F 9A 3D 3E F6 12 24 40 4F 40 00 C0 08 90 4F 25 F7 04 01 40 24
X: 3
SWB: 16 05 80 56 85 4F F4 E1 00 80 29 01 56 24 87 4F F4 E1 00 80 1F 26 30 02 01 80 24 89 4F F4 51 00 80 18 25 32
X: 3
SWB: 16 05 A0 56 02 24 8B 4F 00 00 F4 20 40 10 40 31 11 80 98 06 24 30 02 31 11 00 24 8D 4F 01 00 24 32 02 F4 CA
X: 3
SWB: 16 05 C0 56 00 E9 E2 88 0A F6 12 98 06 24 30 02 31 11 00 F6 21 2E 2D 9A 3D 3E F6 15 F6 26 24 69 07 01 08 11
X: 3
SWB: 16 05 E0 56 40 24 97 4F 01 00 11 80 2E 2D 9A 24 46 02 62 01 52 01 52 03 52 04 9A 3D F6 15 31 98 0C B4 84 A6
X: 3
SWB: 16 05 00 57 46 77 EB 64 ED 24 F4 21 00 D4 00 87 F0 2D 9A 24 46 02 40 02 C0 08 84 02 31 9A 24 4B 02 01 0C E6
X: 3
SWB: 16 05 20 57 22 03 B3 D3 B3 B3 B2 E2 B3 B3 B2 E2 9A 3D 3E 3F A7 01 F6 15 A6 4C A6 5D 56 C0 A6 42 9F 46 CB 24
X: 3
SWB: 16 05 40 57 F7 04 07 00 D2 00 84 07 02 40 23 00 80 98 2D A6 24 75 B2 5D 84 12 EA 64 EC 64 ED 24 20 FC FF E8
X: 3
SWB: 16 05 60 57 24 03 00 22 FF 7F 98 14 EA 64 EC 64 ED 24 20 FC FF E8 24 03 00 20 04 00 E8 24 02 00 E0 52 C0 88
X: 3
SWB: 16 05 80 57 0C 73 E9 64 EC 64 ED 24 F4 22 02 98 14 E0 52 C0 94 0F 73 E9 61 E9 61 E9 25 20 FC FF E8 25 F4 CB
X: 3
SWB: 16 05 A0 57 42 EB E7 88 04 BC BC 98 06 EA E7 94 02 BC 6C A6 C2 A9 2F 2E 2D 9A 3D 3E 3F A7 02 24 46 02 40 00
X: 3
SWB: 16 05 C0 57 84 04 62 08 52 00 24 46 02 4C 00 40 01 C0 0F 84 03 9F EB 56 25 46 02 48 41 A6 82 C2 80 52 C1 66
X: 3
SWB: 16 05 E0 57 03 65 06 A6 C4 21 43 4F 9F 2D 57 52 C0 A1 03 1D D3 01 84 06 40 41 C0 10 90 26 42 C0 CA 41 84 0D
X: 3
SWB: 16 05 00 58 24 40 4F 40 01 C0 10 84 0A CA 20 90 06 60 10 F1 C1 98 18 D3 01 90 09 24 46 02 40 01 C0 20 90 0B
X: 3
SWB: 16 05 20 58 48 C0 E6 A8 41 90 04 60 20 F1 C1 42 C0 CA 03 90 05 A4 A9 00 98 1E CA 04 90 05 A4 A9 01 98 15 CA
X: 3
SWB: 16 05 40 58 08 90 05 A4 A9 04 98 0C CA 10 90 05 A4 A9 02 98 03 A4 A9 03 24 F7 04 05 18 26 46 02 40 81 C0 01
X: 3
SWB: 16 05 60 58 84 08 24 40 4F F4 E5 1F 8C 1D 9F EB 56 24 40 4F F4 E5 21 95 25 24 46 02 42 03 B2 62 52 03 42 04
X: 3
SWB: 16 05 80 58 B2 62 52 04 9B 9A 59 42 84 CA 02 90 06 42 28 73 33 98 19 44 29 75 CA 04 90 09 46 28 77 A6 42 A6
X: 3
SWB: 16 05 A0 58 53 98 09 A6 42 A6 53 F6 13 21 FF 7F 24 94 07 44 09 75 E9 E2 94 09 24 46 02 42 04 B2 62 98 20 E4
X: 3
SWB: 16 05 C0 58 80 1D 90 1D 24 40 4F 42 2A 73 F6 34 E9 C4 F6 41 B9 60 80 01 31 E9 E2 88 08 24 46 02 E0 B2 04 52
X: 3
SWB: 16 05 E0 58 04 25 F7 04 03 56 24 40 4F 42 02 C2 03 D2 01 84 04 03 58 98 06 D2 02 84 02 03 5A 24 46 02 42 03
X: 3
SWB: 16 05 00 59 CA 02 90 09 24 40 4F 02 21 01 23 98 12 24 40 4F CA 04 90 06 02 23 01 25 98 05 02 25 21 FF 7F E9
X: 3
SWB: 16 05 20 59 E3 94 09 24 46 02 42 03 B2 62 98 19 E4 80 1D 90 16 24 40 4F 42 27 73 F6 24 E9 C4 EC E3 88 08 24
X: 3
SWB: 16 05 40 59 46 02 E0 B2 03 52 03 24 40 4F 40 00 C0 04 90 0A 24 46 02 42 C1 E0 12 04 98 48 E0 60 01 80 3B 24
X: 3
SWB: 16 05 60 59 46 02 E4 80 1D 90 1F 42 03 CA 08 90 06 40 04 C0 02 84 0D CA 02 90 23 24 46 02 40 04 C0 08 90 1A
X: 3
SWB: 16 05 80 59 60 04 F1 C1 98 1E 43 03 42 04 B2 53 94 07 E0 13 C1 53 C1 98 0F E0 12 C1 98 08 24 46 02 42 C1 E0
X: 3
SWB: 16 05 A0 59 12 03 52 C1 48 C1 E6 A8 31 84 0B A1 00 CD C0 08 90 04 60 40 F1 C1 FC 60 24 46 02 42 C1 52 01 42
X: 3
SWB: 16 05 C0 59 C0 52 00 FC 50 AA 2F 2E 2D 9A 3D 3E 3F A7 04 11 C2 24 40 4F 40 00 C0 02 90 52 26 F7 04 05 82 24
X: 3
SWB: 16 05 E0 59 65 07 F4 E5 02 88 45 01 92 11 C0 E9 E5 88 3D 01 84 24 A9 4F F4 E1 00 94 33 24 AB 4F 01 00 9F FD
X: 3
SWB: 16 05 00 5A 9A 02 C0 ED C2 E9 E2 94 0F 24 AB 4F 01 00 9F FD 9A F4 21 C2 11 C2 98 0B 01 92 F4 C9 82 02 C2 E9
X: 3
SWB: 16 05 20 5A 22 12 C2 24 46 02 60 04 F1 02 98 07 24 46 02 60 FB F0 02 01 C2 AC 2F 2E 2D 9A 3F 66 28 22 80 47
X: 3
SWB: 16 05 40 5A 21 69 07 9F 5B CA 24 69 07 01 00 9F FD 9A F6 12 21 67 07 9F 83 CA 2F 9A 23 1E 00 22 73 07 9C 3F
X: 3
SWB: 16 05 60 5A 62 1E 9A 23 0A 00 22 69 07 9C 3F 62 0A 9A 3F 23 28 00 22 69 07 21 80 47 9F E3 C5 2F 9A 3D 3F 24
X: 3
SWB: 16 05 80 5A 38 02 01 00 90 04 E9 81 11 00 24 36 02 01 00 90 14 E9 81 11 00 FB 84 0D 9F 6E 5A 25 B0 4F 24 38
X: 3
SWB: 16 05 A0 5A 02 01 40 11 00 2F 2D 9A 3D 3E 3F A7 01 F6 16 54 C0 D4 00 84 09 24 40 4F 40 01 C0 40 90 5C 24 38
X: 3
SWB: 16 05 C0 5A 02 F8 00 84 55 24 95 4F 07 00 24 93 4F 03 00 F6 65 74 01 40 EF E1 80 42 EB E1 8C 3E B4 94 D4 0F
X: 3
SWB: 16 05 E0 5A 90 06 ED 95 ED 95 99 EA 66 1E F6 62 21 73 07 9F 5B CA 42 C0 D2 00 84 17 24 AE 4F 01 00 24 36 02
X: 3
SWB: 16 05 00 5B 11 00 FB 84 15 25 B0 4F 24 38 02 01 40 11 00 23 1E 00 F6 62 21 8A 47 9F E3 C5 A9 2F 2E 2D 9A 3D
X: 3
SWB: 16 05 20 5B 3E 3F A7 01 F6 16 54 C0 D4 00 84 09 24 40 4F 40 01 C0 20 90 5C 24 38 02 F8 00 84 55 24 91 4F 07
X: 3
SWB: 16 05 40 5B 00 24 8F 4F 03 00 F6 65 74 01 40 EF E1 80 42 EB E1 8C 3E B4 94 D4 05 90 06 ED 95 ED 95 99 EA 66
X: 3
SWB: 16 05 60 5B 0A F6 62 21 69 07 9F 5B CA 42 C0 D2 00 84 17 24 AE 4F 01 00 24 36 02 11 00 FB 84 15 25 B0 4F 24
X: 3
SWB: 16 05 80 5B 38 02 01 40 11 00 23 0A 00 F6 62 21 80 47 9F E3 C5 A9 2F 2E 2D 9A 3D 3E 3F A7 02 F6 15 F6 26 A1
X: 3
SWB: 16 05 A0 5B 00 AB C0 40 90 05 21 10 0E 98 03 21 01 00 F6 14 F4 24 40 14 40 A6 6E 7F F6 71 22 10 0E 9C 42 E9
X: 3
SWB: 16 05 C0 5B 54 80 20 02 80 EA A1 EF 51 94 06 EF 22 12 C0 98 05 21 FF FF 11 C0 31 11 40 23 02 00 F6 82 F6 61
X: 3
SWB: 16 05 E0 5B 9F E3 C5 AA 2F 2E 2D 9A 3F 24 83 4F 42 00 73 24 80 43 F4 51 00 8C 0E 24 84 4F 46 00 22 C0 45 21
X: 3
SWB: 16 05 00 5C 34 02 9F 96 5B 2F 9A 3D 3E 3F A7 0A F6 17 54 C5 24 40 4F 42 00 CA C0 D0 C0 90 A5 43 01 CB 02 84
X: 3
SWB: 16 05 20 5C 08 DA 00 88 04 CB 01 84 97 A6 24 C4 40 54 C4 D4 00 84 1C 24 C0 45 02 00 12 C0 24 80 43 02 00 12
X: 3
SWB: 16 05 40 5C C2 25 7B 4F 77 C2 80 52 C6 C3 01 53 C7 98 06 CB 01 93 E0 98 6B 45 C6 D5 00 90 0B 04 C2 F4 54 40
X: 3
SWB: 16 05 60 5C 80 04 66 01 98 24 49 C7 E6 59 00 90 0B 01 C0 F4 51 43 80 04 66 03 98 12 43 C4 D3 00 90 2D 24 94
X: 3
SWB: 16 05 80 5C 07 40 0B E0 50 42 8C 23 66 02 49 C5 E6 59 00 90 15 4C 47 7D F6 72 21 64 00 EE C1 13 C8 9F 94 CB
X: 3
SWB: 16 05 A0 5C F6 17 03 C8 98 06 F4 CF 45 98 01 76 D7 00 84 02 A6 67 20 F8 FF E8 25 20 63 4F ED C0 87 97 98 01
X: 3
SWB: 16 05 C0 5C 77 24 46 02 42 02 C2 3F E7 78 40 C0 C0 B0 12 52 02 F6 71 A5 0A 2F 2E 2D 9A 3D 3E 3F 26 40 4F 05
X: 3
SWB: 16 05 E0 5C 9B 24 46 02 42 01 9F 46 CB B2 87 A1 02 A9 73 22 03 00 9C 42 B7 22 B3 D3 E9 64 20 69 07 E8 24 01
X: 3
SWB: 16 05 00 5D 0A ED E1 80 25 40 80 C0 01 90 0B F6 12 24 94 07 42 0B 73 9F 94 CB 24 40 4F 40 00 C0 20 90 05 64
X: 3
SWB: 16 05 20 5D 01 9F 07 5C ED E1 88 02 F6 51 2F 2E 2D 9A 3F A1 02 A9 73 E9 64 20 69 07 E8 24 74 01 00 9F 07 5C
X: 3
SWB: 16 05 40 5D 9F 6D 56 9F 42 A6 9F 8F A6 2F 9A 3D 3E 3F F6 15 F6 27 A6 67 62 06 E7 66 20 20 3A 02 E8 26 A6 62
X: 3
SWB: 16 05 60 5D 73 E9 64 20 A4 4F E8 24 02 00 D6 00 84 15 24 40 4F 40 02 C0 04 90 0C F6 21 24 A8 4F 44 00 75 9C
X: 3
SWB: 16 05 80 5D 42 F6 12 00 80 EF C0 90 0F 17 80 15 82 F9 50 90 03 31 98 02 F6 21 11 84 01 84 EA E1 88 17 E9 91
X: 3
SWB: 16 05 A0 5D 11 84 24 46 02 D7 00 84 06 60 01 F1 02 98 17 60 02 F1 02 98 11 24 46 02 D7 00 84 06 60 FE F0 02
X: 3
SWB: 16 05 C0 5D 98 04 60 FD F0 02 05 82 F6 23 02 80 ED C2 01 84 9F 0D CF ED 21 2F 2E 2D 9A 3D 3E 3F A7 03 F6 16
X: 3
SWB: 16 05 E0 5D 24 40 4F 40 00 C0 10 90 77 24 40 43 01 04 11 C1 9F 28 03 52 C0 25 F7 04 04 46 1C A3 F6 61 44 C0
X: 3
SWB: 16 05 00 5E 75 9C 48 F6 42 03 56 E9 C3 F6 31 9F 18 9E A6 30 A6 14 A6 15 19 A5 1A A7 24 AD 4F 4A 00 7B 3A 39
X: 3
SWB: 16 05 20 5E 22 00 01 ED C2 21 2C 02 9C 3C 21 2C 02 9C 3D F6 14 AC B3 60 80 01 34 F6 41 44 C0 75 9C 42 F4 E1
X: 3
SWB: 16 05 40 5E C1 94 06 01 C1 9C 48 F6 14 F6 41 44 C0 75 9C 42 23 E8 03 0A A3 04 C1 E9 C4 F6 41 9F 0D CF E9 26
X: 3
SWB: 16 05 60 5E F6 61 AB 2F 2E 2D 9A 3D 3E 3F A6 2A 21 30 02 9F 47 CC 9F 1C A8 9F 42 A7 9F E8 5B E6 5A 02 90 0E
X: 3
SWB: 16 05 80 5E E6 5A 01 84 6F 24 46 02 42 01 CA 30 84 66 24 46 02 42 01 CA 01 90 07 24 40 4F 01 1B 98 0E CA 40
X: 3
SWB: 16 05 A0 5E 90 07 24 40 4F 01 1D 98 03 9F D9 5C 25 65 07 76 F6 12 01 40 9F 4B 5D F6 16 9F 2E 5D 9F FD 9A 9F
X: 3
SWB: 16 05 C0 5E CA 59 66 01 F6 12 01 42 9F 4B 5D E4 80 1D 84 03 9F D9 5D 24 40 4F 40 01 C0 08 90 14 24 F7 04 F4
X: 3
SWB: 16 05 E0 5E E1 02 88 0C 24 65 07 05 02 ED E1 88 03 36 98 06 F6 15 98 02 36 35 F6 62 21 65 07 9F 83 CA F6 52
X: 3
SWB: 16 05 00 5F 21 67 07 9F 83 CA 2F 2E 2D 9A 3D 3E 3F A7 01 52 C0 64 11 21 4B 02 9C 38 26 4B 02 24 BF 01 01 03
X: 3
SWB: 16 05 20 5F 11 82 24 9F 4F 4A 00 7B ED 65 ED 65 15 8C 43 C0 53 80 D3 01 94 09 62 01 52 81 24 46 02 98 0F 24
X: 3
SWB: 16 05 40 5F 46 02 43 C0 D3 01 84 06 60 08 F1 02 98 04 60 F7 F0 02 A9 2F 2E 2D 9A 3D 3E 3F A7 05 24 4B 02 42
X: 3
SWB: 16 05 60 5F 10 52 C0 40 01 85 08 24 46 02 60 7F F0 01 9F 2E 5D F6 12 24 40 4F 40 01 C0 04 90 05 24 9D 4F 02
X: 3
SWB: 16 05 80 5F 00 24 9B 4F 01 00 24 F7 04 F4 21 16 EA E1 80 AC 24 9F 4F 43 00 53 C1 76 56 C2 42 C0 52 C3 56 C4
X: 3
SWB: 16 05 A0 5F F4 65 C3 20 4B 02 E8 25 26 BF 01 24 4B 02 01 83 F4 C9 02 11 44 64 04 21 4F 02 9F F7 56 F6 15 76
X: 3
SWB: 16 05 C0 5F 47 C1 22 10 0E 9F 0D CF 24 97 4F 03 00 24 65 07 02 00 30 E8 E2 94 06 EA E3 94 02 F6 23 EB E1 88
X: 3
SWB: 16 05 E0 5F 5B 24 4B 02 F4 86 0C 16 0C F4 64 C1 EC 64 B9 BF B8 EE BF BF BE EE F6 61 F6 72 9C 49 F9 20 84 6F
X: 3
SWB: 16 05 00 60 43 C0 D3 00 84 04 F6 47 EE C7 F4 64 C3 20 4B 02 E8 24 01 04 24 A2 4F F4 E1 00 94 20 76 A6 E7 22
X: 3
SWB: 16 05 20 60 40 38 9F 0D CF F6 12 24 4B 02 01 0E 46 C0 D6 00 90 10 EA C1 24 A0 4F F4 E1 00 88 06 72 9F 0A 5F
X: 3
SWB: 16 05 40 60 98 2D 26 4B 02 E0 92 90 52 90 12 8E 24 BF 01 01 03 11 82 F8 8C 84 18 24 99 4F F4 E5 00 8C 03 72
X: 3
SWB: 16 05 60 60 98 03 E0 92 80 9F 0A 5F 24 4B 02 42 01 98 01 72 AD 2F 2E 2D 9A 3F 24 2C 02 31 32 11 00 12 02 72
X: 3
SWB: 16 05 80 60 9F 0A 5F 2F 9A 3D 3F A1 00 1F 90 06 9F 67 5E 9F 7D 5A E4 80 1D 90 20 9F 75 60 25 46 02 60 F7 F0
X: 3
SWB: 16 05 A0 60 42 24 30 02 31 11 00 24 32 02 11 00 E4 A0 1D 84 18 60 7F F0 41 98 12 9F 57 5F D2 00 90 0B 24 46
X: 3
SWB: 16 05 C0 60 02 60 80 F1 01 62 01 98 01 72 2F 2D 9A 24 40 49 01 00 C2 F8 C3 0F 19 AA FB 84 09 A1 02 AB E6 12
X: 3
SWB: 16 05 E0 60 80 A3 AB 20 9A 3F A7 02 F6 13 F5 43 AA 21 FF CF EB 01 11 C0 CA 10 90 07 21 F8 CF EB 01 11 C0 01
X: 3
SWB: 16 05 00 61 C0 19 AA C2 F8 C3 0F 11 C0 23 02 00 F6 82 21 40 49 9F E3 C5 AA 2F 9A A1 02 A9 73 E9 61 20 51 4E
X: 3
SWB: 16 05 20 61 E8 21 9A A1 02 A9 73 E9 61 20 5C 4E E8 21 9A 3D 25 65 07 24 F7 04 01 04 F4 C9 40 2D 9A 24 F7 04
X: 3
SWB: 16 05 40 61 01 32 F4 C9 34 9A A4 C0 00 9A 3D 24 40 4E 40 00 C0 02 90 26 24 68 02 40 01 C0 01 90 1D 25 66 02
X: 3
SWB: 16 05 60 61 D2 00 90 11 42 40 24 42 4E E0 52 09 88 12 B2 92 52 40 72 98 0D 72 52 40 98 08 24 66 02 72 52 00
X: 3
SWB: 16 05 80 61 62 01 2D 9A 3D D4 00 84 27 A6 24 75 F6 25 20 61 02 E8 25 46 40 90 19 F6 24 20 5C 02 E8 24 E0 92
X: 3
SWB: 16 05 A0 61 00 52 00 B3 52 80 14 B6 82 52 40 72 52 00 98 0B A6 2A 7B 20 5C 02 E8 25 72 52 40 2D 9A 3D B5 03
X: 3
SWB: 16 05 C0 61 84 11 B5 04 90 0D A6 2A 7B 20 61 02 E8 25 E0 92 40 52 40 2D 9A 24 F7 04 01 16 F4 C9 18 9A F6 14
X: 3
SWB: 16 05 E0 61 E4 80 1D 90 04 62 80 52 01 24 F7 04 01 32 9A F6 14 E4 80 1D 84 04 62 80 52 01 24 F7 04 01 32 9A
X: 3
SWB: 16 05 00 62 E4 92 AC A3 AC 20 24 1D 4F 43 00 9C 47 D3 00 84 0B 24 78 02 42 00 90 04 B2 82 52 00 9A 3D 25 C0
X: 3
SWB: 16 05 20 62 4F 40 40 B2 00 84 03 74 98 26 24 CF 4E 03 1E E0 02 42 90 02 03 1C 74 A6 32 73 E9 64 20 47 05 E8
X: 3
SWB: 16 05 40 62 24 F6 31 F4 21 00 24 31 05 F4 E1 16 88 02 64 01 A6 42 2D 9A 3D A6 25 25 68 02 44 45 CC 40 90 38
X: 3
SWB: 16 05 60 62 24 C0 4F 40 04 C0 04 90 73 E4 A0 1D 84 07 E9 09 F5 21 B3 98 01 31 19 B3 F5 B1 B3 25 A9 4E F4 E1
X: 3
SWB: 16 05 80 62 52 88 0A 24 94 07 40 09 E0 50 54 88 4F A6 42 C2 BF 24 68 02 52 05 98 41 24 42 4E 40 02 C0 40 90
X: 3
SWB: 16 05 A0 62 3B 24 94 07 40 09 D0 63 94 2B E9 09 F5 21 B3 19 B3 30 E8 E1 94 04 60 40 F1 44 24 A9 4E F4 E1 10
X: 3
SWB: 16 05 C0 62 94 1A 24 68 02 A6 42 E6 12 40 52 05 60 BF F0 04 31 19 B3 98 07 60 BF F0 44 33 1B B3 E4 A0 1D 90
X: 3
SWB: 16 05 E0 62 07 31 19 B5 19 B7 98 48 FA BB 90 20 A6 52 E9 09 0B B5 E9 C3 1B B5 24 A9 4E F4 E3 06 80 0E 24 68
X: 3
SWB: 16 05 00 63 02 60 F3 F0 04 60 F3 F0 05 31 19 BB FA B9 90 20 A6 52 E9 09 0A B7 E9 C2 1A B7 24 A9 4E F4 E2 0E
X: 3
SWB: 16 05 20 63 80 0E 24 68 02 60 CF F0 04 60 CF F0 05 33 1B B9 24 67 02 40 00 84 0C A1 00 CD C0 02 90 05 31 19
X: 3
SWB: 16 05 40 63 B9 19 BB E4 B2 CD C2 01 24 67 02 52 00 2D 9A 3D 3E 3F A6 2E F6 25 F6 36 24 42 4E 40 02 B2 00 90
X: 3
SWB: 16 05 60 63 51 24 68 02 40 05 B2 00 84 48 24 F7 04 01 04 F4 E1 82 88 12 F8 40 90 0E A6 E2 73 E9 61 24 68 02
X: 3
SWB: 16 05 80 63 A6 20 F1 04 98 2C F4 E1 80 8C 04 F8 40 90 23 F4 91 40 11 40 F4 51 84 80 0A 24 68 02 A6 E2 E0 12
X: 3
SWB: 16 05 A0 63 05 52 05 24 68 02 A6 E2 73 E9 61 B2 A2 E0 02 04 52 04 2F 2E 2D 9A 3F 24 46 02 40 01 C0 01 90 0A
X: 3
SWB: 16 05 C0 63 23 A9 4E 22 BB 00 62 04 98 08 23 B1 4E 22 B9 00 62 10 9F 4F 63 2F 9A 24 68 02 60 43 F0 00 60 F5
X: 3
SWB: 16 05 E0 63 F0 02 60 83 F0 04 60 CF F0 06 60 43 F0 01 60 F5 F0 03 60 83 F0 05 60 CF F0 07 31 19 BB 19 B9 9A
X: 3
SWB: 16 05 00 64 3D A6 26 24 68 02 40 09 84 14 40 0B 84 10 40 0D 84 0C 40 0F 84 08 32 24 93 07 40 00 84 03 22 01
X: 3
SWB: 16 05 20 64 00 D3 00 90 0A 67 EC 6B 93 65 01 6A D7 98 07 67 4C 6B 03 75 6A D6 D4 00 84 1B 24 68 02 42 01 CA
X: 3
SWB: 16 05 40 64 F1 84 12 40 03 B7 00 84 0C 40 05 B5 00 84 06 42 07 CA 28 90 06 C6 FE D4 00 84 1B 24 68 02 42 01
X: 3
SWB: 16 05 60 64 CA 0E 84 12 40 03 BB 00 84 0C 40 05 BA 00 84 06 42 07 CA 17 90 02 C6 F1 24 40 4E 40 00 C0 08 90
X: 3
SWB: 16 05 80 64 5A A1 00 BD 84 55 24 68 02 40 08 84 10 40 0A 84 0C 40 0C 84 08 40 0E 84 04 63 01 98 03 C6 F0 73
X: 3
SWB: 16 05 A0 64 24 68 02 44 00 CC F1 84 10 E0 07 02 84 0B E0 05 04 84 06 42 06 CA 28 90 03 C6 FE 73 CC 0E 84 13
X: 3
SWB: 16 05 C0 64 24 68 02 E0 0B 02 84 0B E0 0A 04 84 06 42 06 CA 17 90 04 C6 F1 98 07 D3 00 90 03 A4 BD 01 A6 62
X: 3
SWB: 16 05 E0 64 2D 9A 3F 9F 00 64 A6 24 CA 0F 90 1E 24 F7 04 03 04 EB B1 24 C0 4F F4 E1 11 80 07 C4 F1 E6 14 02
X: 3
SWB: 16 05 00 65 98 08 F4 E3 13 80 03 E6 14 01 A6 42 2F 9A A1 00 AA C0 40 90 10 24 CF 4E 40 03 C0 02 90 07 24 68
X: 3
SWB: 16 05 20 65 02 60 02 F1 0F 9A 3F 24 40 43 02 00 24 CF 4E 01 37 9F 94 CB 19 AD 21 AD 00 2F 9A 3F 24 40 43 02
X: 3
SWB: 16 05 40 65 00 24 CF 4E 01 39 9F 94 CB 19 AD 21 AD 00 2F 9A 3D 3F 9F 06 82 F6 15 9F D1 81 F6 52 E9 C2 F6 21
X: 3
SWB: 16 05 60 65 2F 2D 9A 3F 9F 28 03 A6 24 21 46 43 9F 21 CE 24 46 43 04 08 F6 43 22 E8 03 EC C1 9F 78 CF 2F 9A
X: 3
SWB: 16 05 80 65 3F 62 02 9F 1C 51 2F 9A 3F 62 02 9F 0B 51 2F 9A 3F 24 F7 04 01 04 9C 3A 2F 9A 3D 3F 24 F7 04 25
X: 3
SWB: 16 05 A0 65 CF 4E 01 16 F4 E1 67 80 18 01 04 9C 3A F4 E1 69 88 0F 09 B1 F4 51 6E 80 04 62 01 98 08 E9 91 98
X: 3
SWB: 16 05 C0 65 01 31 19 B1 72 2F 2D 9A 3D A2 C0 3F A7 04 9F 22 C1 A6 2C A1 00 F2 C0 01 90 07 24 68 02 60 04 F1
X: 3
SWB: 16 05 E0 65 0F 9F 69 68 9F 00 62 A1 00 AA C0 40 90 E6 64 04 F6 81 9C 38 24 93 07 E0 80 00 84 07 42 C0 E6 12
X: 3
SWB: 16 05 00 66 01 52 C0 24 F7 04 25 CF 4E 01 16 F4 E1 70 80 07 01 04 F4 E1 72 88 07 42 C0 E6 12 10 52 C0 9F 9A
X: 3
SWB: 16 05 20 66 65 D2 00 84 07 42 C0 E6 12 20 52 C0 A6 C3 E6 AC 01 90 07 42 C0 E6 12 40 52 C0 CB 06 90 07 42 C0
X: 3
SWB: 16 05 40 66 E6 12 80 52 C0 9F F3 C0 D2 00 90 07 42 C1 E6 12 01 52 C1 21 02 01 9F 1D 62 D2 00 84 07 42 C1 E6
X: 3
SWB: 16 05 60 66 12 20 52 C1 21 04 02 9F 1D 62 D2 00 84 07 42 C1 E6 12 40 52 C1 21 08 03 9F 1D 62 D2 00 84 07 42
X: 3
SWB: 16 05 80 66 C1 E6 12 80 52 C1 21 10 04 9F 1D 62 D2 00 84 07 42 C2 E6 12 01 52 C2 E4 60 1E 88 07 42 C2 E6 12
X: 3
SWB: 16 05 A0 66 08 52 C2 F6 82 21 C0 51 9F CF D0 24 46 43 02 0A 24 91 07 F6 20 F4 C8 00 90 0C F6 41 9F 83 CA 32
X: 3
SWB: 16 05 C0 66 21 C8 51 9F CF D0 9F AE 81 D2 00 90 07 32 21 D0 51 9F CF D0 AC 2F A0 0C 2D 9A 3F 24 A9 4E 01 15
X: 3
SWB: 16 05 E0 66 9F FD 9A 24 65 07 F4 21 02 19 AD 21 AD 00 2F 9A 3D 3F 24 A9 4E 01 18 9F FD 9A F6 15 19 AD 9F 2E
X: 3
SWB: 16 05 00 67 5D 9F FD 9A E9 25 1D AD 21 AD 00 2F 2D 9A 3D 3F 24 F7 04 05 18 9F 28 03 98 13 B2 82 A6 24 75 EA
X: 3
SWB: 16 05 20 67 64 20 F7 04 E8 24 F6 50 F4 C8 08 90 04 D2 00 87 E9 24 F7 04 A6 26 02 32 01 04 9F 84 95 F6 52 E9
X: 3
SWB: 16 05 40 67 C2 1A AF 2F 2D 9A 3D 3E 3F A7 07 A6 2A 64 07 F6 81 9C 38 42 C0 43 C5 E4 80 1D 84 0A E6 12 04 52
X: 3
SWB: 16 05 60 67 C0 E6 13 10 98 08 E6 12 10 52 C0 E6 13 04 53 C5 A6 A2 9F 4A 61 D2 00 84 0E 42 C0 E6 12 02 52 C0
X: 3
SWB: 16 05 80 67 42 C3 E6 12 02 52 C3 E4 80 1D 84 07 24 65 07 F8 02 84 07 42 C4 E6 12 50 52 C4 24 46 02 40 01 C0
X: 3
SWB: 16 05 A0 67 01 84 09 42 C5 E6 12 01 52 C5 98 0E 42 C1 E6 12 01 52 C1 42 C3 E6 12 10 52 C3 25 68 02 44 41 26
X: 3
SWB: 16 05 C0 67 42 4E C4 40 43 BD 72 9F 84 61 44 43 C4 01 24 83 4E 43 00 62 01 9F 84 61 44 43 C4 04 24 87 4E 43
X: 3
SWB: 16 05 E0 67 00 62 02 9F 84 61 44 41 E0 14 40 C4 02 43 A5 62 03 9F 84 61 44 41 E0 14 40 C4 30 43 BA 62 04 9F
X: 3
SWB: 16 05 00 68 84 61 9F 0E 67 4D 41 F6 82 21 D8 51 9F CF D0 65 02 44 41 A6 D3 62 03 9F BD 61 65 30 44 41 A6 D3
X: 3
SWB: 16 05 20 68 62 04 9F BD 61 40 45 C0 02 84 06 E4 92 C0 A3 C0 20 AF 2F 2E 2D 9A 3F 23 08 00 F6 12 21 70 02 9C
X: 3
SWB: 16 05 40 68 3F 24 CF 4E E0 60 02 80 05 9F 1B C2 98 03 9F 2A C2 2F 9A 24 40 4E 40 00 C0 04 84 02 72 9A 72 24
X: 3
SWB: 16 05 60 68 93 07 40 00 84 02 62 01 9A 3E 3F A7 02 F6 86 24 40 4E 40 00 C0 01 84 04 64 02 98 34 24 93 07 40
X: 3
SWB: 16 05 80 68 00 84 33 72 52 81 62 13 A2 20 62 01 A2 20 3E F7 AC 02 24 F7 04 03 18 22 D5 4E 21 D3 4E 9F A4 CF
X: 3
SWB: 16 05 A0 68 AE 40 81 84 09 24 68 02 40 09 C0 01 90 08 64 01 21 93 07 9F 79 CA AA 2F 2E 9A A1 02 C2 90 0C B2
X: 3
SWB: 16 05 C0 68 82 A3 C2 20 D2 00 84 03 A4 C1 00 9A F6 24 A1 04 C1 B6 54 84 0E A4 C1 00 F4 C9 02 84 17 A4 C2 00
X: 3
SWB: 16 05 E0 68 62 01 9A A1 00 C2 84 11 D4 00 84 0D F4 C9 00 84 08 A3 C1 60 A4 C2 04 72 9A 72 9A 3F A7 04 24 94
X: 3
SWB: 16 05 00 69 07 02 00 24 80 43 F4 42 00 23 F2 A6 EA 43 13 C0 20 CE 35 E8 42 12 C2 66 FE F6 82 9F CC 68 AC 2F
X: 3
SWB: 16 05 20 69 9A A1 00 C1 84 06 A4 C1 FF A4 C2 04 9A 3D A6 2A 7B 20 84 04 E8 25 E0 A0 51 84 0B D3 00 84 07 24
X: 3
SWB: 16 05 40 69 40 4B 01 16 98 05 24 40 4B 01 14 2D 9A 3D A1 00 1F 90 44 25 68 04 24 F7 04 01 04 A6 30 A6 14 A6
X: 3
SWB: 16 05 60 69 15 F4 21 40 F4 3A 42 11 40 12 42 01 2C A6 30 A6 14 A6 15 F4 21 44 F4 3A 46 11 44 12 46 02 06 01
X: 3
SWB: 16 05 80 69 54 EA E1 94 02 12 54 24 F7 04 02 2E 24 68 04 01 16 EA E1 94 02 12 16 2D 9A 3D 3E 3F A7 02 F6 15
X: 3
SWB: 16 05 A0 69 F6 26 13 C0 F6 34 07 00 F6 71 A6 30 A6 14 A6 15 9C 52 3A 39 F6 51 F6 62 9C 54 AC DA 00 8C 24 04
X: 3
SWB: 16 05 C0 69 C0 07 02 F6 71 A6 30 A6 14 A6 15 9C 52 3A 39 F6 51 F6 62 9C 54 AC DA 00 80 09 F6 51 F6 62 9D 27
X: 3
SWB: 16 05 E0 69 D9 F6 17 F6 71 AA 2F 2E 2D 9A 24 40 4B F4 E1 22 94 03 74 98 08 74 F4 E1 24 80 02 64 01 A6 42 9A
X: 3
SWB: 16 05 00 6A 3F 9F 28 03 98 11 B2 82 A6 24 75 EA 64 20 84 04 E8 24 23 E8 03 13 00 24 84 04 D2 00 87 E8 E0 80
X: 3
SWB: 16 05 20 6A 08 84 03 77 57 08 2F 9A A2 A0 3F 9F 28 03 A6 2A 24 F7 04 01 14 A6 A4 75 9C 48 F6 17 98 21 BA 8A
X: 3
SWB: 16 05 40 6A A6 A4 75 EA 61 F6 14 20 51 05 E8 24 F6 73 F4 CB 00 F6 14 20 68 04 E8 24 F4 E3 08 94 02 13 08 E6
X: 3
SWB: 16 05 60 6A 5A 00 87 DA 2F A0 0A 9A 3F 9F 28 03 A6 27 6E 7F 98 19 B7 87 A6 72 73 22 03 00 9C 42 F6 14 20 04
X: 3
SWB: 16 05 80 6A 04 E8 24 42 00 B2 5E 94 02 A6 2E D7 00 87 E3 24 A7 03 E0 5E 00 94 39 24 40 4B 02 00 33 24 9E 03
X: 3
SWB: 16 05 A0 6A 42 03 B7 52 80 2A B7 52 84 1A 42 02 B6 52 80 20 B6 52 84 10 42 01 B5 52 80 16 B5 52 84 06 42 00
X: 3
SWB: 16 05 C0 6A B4 52 80 0C 24 A7 03 5E 00 24 68 04 60 04 F1 13 24 68 04 42 13 CA 0C D0 04 90 03 72 98 06 C2 FB
X: 3
SWB: 16 05 E0 6A 52 13 62 01 2F 9A 3D 3F 24 00 4E 40 01 C0 20 84 99 9F 28 03 A6 26 31 98 0F B6 86 A6 64 75 EA 64
X: 3
SWB: 16 05 00 6B 20 68 04 E8 24 F4 21 08 D6 00 87 ED B3 60 80 01 31 25 68 04 4E 52 90 0D 04 50 EC C1 A6 E4 75 9C
X: 3
SWB: 16 05 20 6B 48 E9 24 14 50 25 68 04 BE 92 52 52 02 50 24 46 43 07 1B 24 B9 4B 03 00 F6 31 EF 21 E9 E2 8C 08
X: 3
SWB: 16 05 40 6B F6 71 EB C1 E9 E2 88 02 11 50 24 B7 4B 02 00 90 0B 24 68 04 01 10 EA E1 94 02 12 10 24 B5 4B 02
X: 3
SWB: 16 05 60 6B 00 B5 60 88 0B 24 68 04 01 10 EA E1 88 02 12 10 9F 28 03 98 11 B2 82 A6 24 75 EA 64 20 68 04 E8
X: 3
SWB: 16 05 80 6B 24 23 01 80 13 08 D2 00 87 EB 2F 2D 9A 3D A2 C0 3F A7 20 9F 28 03 A6 2C 98 39 BC 8C A6 C2 9F 39
X: 3
SWB: 16 05 A0 6B 9D F6 15 43 41 40 40 D0 55 84 28 B3 82 D2 FD 8C 22 D3 05 90 1E 23 20 00 F6 52 E6 25 01 F6 81 9C
X: 3
SWB: 16 05 C0 6B 3F 62 FF 52 C1 62 55 52 C0 23 20 00 F6 82 F6 51 9F E3 C5 E6 5C 00 87 C2 A5 20 2F A0 0C 2D 9A 3D
X: 3
SWB: 16 05 E0 6B F6 15 24 9E 03 42 00 E0 12 01 E0 12 02 E0 12 03 D2 00 90 09 D4 00 84 0A E4 A0 1D 90 05 22 67 43
X: 3
SWB: 16 05 00 6C 98 03 22 7C 04 23 04 00 F6 51 9C 3F 2D 9A 3D 3E 3F A7 02 F6 16 24 9E 03 07 00 42 02 52 C0 42 03
X: 3
SWB: 16 05 20 6C 52 C1 E5 12 FE E0 12 C0 E0 12 C1 D2 00 90 2D D4 00 84 05 E4 A0 1D 84 24 24 68 04 01 04 02 06 A6
X: 3
SWB: 16 05 40 6C E8 A6 F9 05 C0 9C 4A 11 82 24 68 04 01 00 02 02 A6 E8 A6 F9 05 C0 9C 4A 11 80 98 0A 23 04 00 22
X: 3
SWB: 16 05 60 6C 5D 43 F6 61 9C 3F AA 2F 2E 2D 9A 3D 3E 3F A7 08 25 48 04 00 50 38 00 4E 38 01 46 02 48 9C 41 AC
X: 3
SWB: 16 05 80 6C 3A 39 9C 46 AC F6 16 F6 27 F7 80 40 F7 00 00 01 4A 02 4C 9C 46 AC 03 4A 04 4C 3C 3B 9C 46 AC 3A
X: 3
SWB: 16 05 A0 6C 39 F6 61 F6 72 9C 40 AC 9C 3E 11 C0 12 C2 00 50 38 00 4E 38 01 46 02 48 9C 40 AC F6 15 F6 26 7E
X: 3
SWB: 16 05 C0 6C 01 C0 02 C2 3A 39 F6 51 F6 62 9C 40 AC 11 C4 12 C6 02 C0 03 C2 3B 3A F6 51 F6 62 9C 41 AC F6 15
X: 3
SWB: 16 05 E0 6C F6 26 24 9F 4B 01 00 A6 30 A6 14 A6 15 9C 52 3A 39 F6 51 F6 62 9C 46 AC 3A 39 01 C8 02 CA 9C 54
X: 3
SWB: 16 05 00 6D AC DA 00 88 02 6E 01 A6 E2 A8 2F 2E 2D 9A 3D 3E 3F A7 1C 9F 6B 6C D2 00 91 27 24 48 04 01 06 02
X: 3
SWB: 16 05 20 6D 08 11 D8 12 DA 01 0E 02 10 11 CC 12 CE 01 0A 02 0C 11 C8 12 CA 01 CC 02 CE 3A 39 01 DC 02 DE 9C
X: 3
SWB: 16 05 40 6D 46 AC F6 15 F6 26 02 C8 03 CA 3B 3A 01 CC 02 CE 9C 46 AC 3A 39 F6 51 F6 62 9C 41 AC 11 D0 12 D2
X: 3
SWB: 16 05 60 6D 24 48 04 03 12 04 14 13 C4 14 C6 24 48 04 01 16 02 18 11 C0 12 C2 3A 39 01 DC 02 DE 9C 46 AC F6
X: 3
SWB: 16 05 80 6D 15 F6 26 01 C4 02 C6 3A 39 01 CC 02 CE 9C 46 AC 3A 39 F6 51 F6 62 9C 41 AC 03 D0 04 D2 3C 3B 9C
X: 3
SWB: 16 05 A0 6D 4C AC 11 D4 12 D6 F7 00 00 F7 00 00 01 D8 02 DA 9C 54 AC DA 00 94 8A F7 80 3F F7 00 00 01 D8 02
X: 3
SWB: 16 05 C0 6D DA 9C 54 AC DA 00 88 79 01 C4 02 C6 3A 39 01 D0 02 D2 9C 46 AC F6 15 F6 26 02 C0 03 C2 3B 3A 01
X: 3
SWB: 16 05 E0 6D CC 02 CE 9C 46 AC 3A 39 F6 51 F6 62 9C 41 AC 03 D0 04 D2 3C 3B 9C 4C AC F6 15 F6 26 01 D4 02 D6
X: 3
SWB: 16 05 00 6E 3A 39 31 22 80 3F 9C 41 AC 3A 39 F6 51 F6 62 9C 4C AC F7 80 43 F7 00 00 9C 46 AC 23 A1 4B 9F 99
X: 3
SWB: 16 05 20 6E 69 24 48 04 11 1A 01 D4 02 D6 9F F8 D7 3A 39 31 22 61 C3 9C 4C AC 23 A5 4B 9F 99 69 24 48 04 11
X: 3
SWB: 16 05 40 6E 1C A5 1C 2F 2E 2D 9A 3F A7 0E 24 40 4B 02 00 33 24 9E 03 42 03 B7 52 80 51 B7 52 84 1A 42 02 B6
X: 3
SWB: 16 05 60 6E 52 80 47 B6 52 84 10 42 01 B5 52 80 3D B5 52 84 06 42 00 B4 52 80 33 64 01 F6 81 9F 0E 6C 24 68
X: 3
SWB: 16 05 80 6E 04 01 10 11 C4 9F 0E 6D 24 48 04 01 1A 02 1C 11 C6 12 C8 64 01 F6 81 E6 22 0A B3 D3 9F DF 6B 23
X: 3
SWB: 16 05 A0 6E 0E 00 F6 82 21 5D 43 9F E3 C5 A5 0E 2F 9A 3D A2 C0 3F A6 2C D2 0E 94 03 74 98 1B A6 36 24 5C 03
X: 3
SWB: 16 05 C0 6E 02 00 21 24 04 9F 5E 9C F6 15 A6 C2 9F AE 9F 74 E9 E5 80 02 64 01 A6 42 2F A0 0C 2D 9A 3D 3E 3F
X: 3
SWB: 16 05 E0 6E A7 03 F6 16 12 C0 56 C2 62 03 E7 25 60 20 04 04 E8 25 D7 00 90 14 24 00 4E 40 02 C0 04 84 16 24
X: 3
SWB: 16 05 00 6F 46 43 42 0C CA 03 D0 02 84 0B 43 C2 42 40 9F AE 6E D2 00 90 5D A1 02 CF CA 14 D0 10 84 54 24 46
X: 3
SWB: 16 05 20 6F 43 40 0C C0 03 90 4B 44 40 D4 0E 8C 45 24 40 4B 42 10 73 F4 E1 80 8C 1F A6 42 9F AE 9F F6 12 F6
X: 3
SWB: 16 05 40 6F 61 9F B2 CD 04 C0 11 00 30 E8 E1 94 04 6A 01 98 19 60 04 F3 CF 98 12 42 C2 73 E9 64 20 04 04 E8
X: 3
SWB: 16 05 60 6F 24 31 11 30 E0 92 40 52 40 7A 64 0E F6 61 9C 38 98 01 7A A6 A2 AB 2F 2E 2D 9A 3D 3F 25 68 04 62
X: 3
SWB: 16 05 80 6F 01 52 5B 24 9E 03 31 32 11 00 12 02 60 EF F2 CD A1 00 CF E7 08 40 A6 13 E6 43 01 C3 01 A1 02 D0
X: 3
SWB: 16 05 A0 6F C2 FE C3 01 B3 12 A3 D0 20 64 1C F6 51 9C 38 24 46 43 02 1B 12 50 01 17 02 19 11 54 12 56 2F 2D
X: 3
SWB: 16 05 C0 6F 9A 3D 3E 3F A7 0A 11 C4 F6 25 26 40 4B 03 8E 34 A6 30 A6 14 A6 15 11 C0 12 C2 3C 3B 01 C4 02 C6
X: 3
SWB: 16 05 E0 6F 13 CA 14 CC 9C 45 AC F6 16 F6 27 03 C6 04 C8 21 E8 03 32 EB C1 EC D2 3A 39 F6 51 A6 30 A6 14 A6
X: 3
SWB: 16 05 00 70 15 9C 45 AC EE 21 EF 32 24 E8 03 35 9C 4A F6 16 24 40 43 02 00 24 40 4B 42 11 73 9F 94 CB F6 14
X: 3
SWB: 16 05 20 70 A6 90 A6 1A A6 1B F4 24 C0 F4 3D C2 F6 62 A6 50 A6 16 A6 17 E5 E0 B7 8C 18 BB 57 84 18 BA 56 8C
X: 3
SWB: 16 05 40 70 10 BA 56 84 10 B9 55 8C 08 B9 55 84 08 B8 54 94 04 F6 41 98 0C 02 C4 E9 C2 F6 21 EE E2 88 02 F6
X: 3
SWB: 16 05 60 70 61 A5 0A 2F 2E 2D 9A 3D 3E 3F A7 25 11 E0 54 E4 A6 42 9F 39 9D F6 14 40 01 D0 05 84 07 F6 16 E6
X: 3
SWB: 16 05 80 70 2D 01 98 07 42 E4 9F 4C 9D F6 16 23 20 00 F6 62 F6 81 9C 3F A1 00 CF C0 04 84 E2 62 03 40 E4 E7
X: 3
SWB: 16 05 A0 70 25 00 20 04 04 E8 25 42 40 73 E9 91 E9 64 EE 24 01 00 11 E2 24 46 43 4C 0C E6 AC 03 D0 02 84 07
X: 3
SWB: 16 05 C0 70 02 E0 9F C1 6F 11 E0 46 E4 02 E2 F6 81 E6 22 20 B3 D3 9F 9B 83 D2 00 90 A0 02 E0 42 40 73 E9 91
X: 3
SWB: 16 05 E0 70 E9 64 F6 80 E8 24 12 00 40 40 A2 00 03 E3 F6 81 E6 22 03 B3 D3 9F 23 9E A9 40 41 84 13 40 40 A2
X: 3
SWB: 16 05 00 71 00 03 E3 02 E1 F6 81 E6 22 03 B3 D3 9F 5F 9E A9 E6 AC 04 90 68 40 42 90 07 E6 AC 0B D0 02 90 5D
X: 3
SWB: 16 05 20 71 44 E4 F6 81 9F 6C A0 E0 92 40 52 40 63 01 53 41 53 42 4C E4 7D 03 E0 EE 61 F6 14 20 04 04 E8 24
X: 3
SWB: 16 05 40 71 13 30 24 84 04 E0 80 08 84 0D F6 15 EC 25 02 E2 01 40 9F 0D CF 11 40 77 24 40 4B 4A 13 7B F6 61
X: 3
SWB: 16 05 60 71 22 03 00 9C 42 F6 14 20 04 04 E8 24 42 00 73 E9 81 E9 C5 84 09 67 01 98 05 60 04 F3 CF 77 A6 72
X: 3
SWB: 16 05 80 71 A5 25 2F 2E 2D 9A 3D 3E 3F A7 05 11 C2 54 C4 9F 28 03 24 68 04 60 F7 F0 13 A6 2C 6D 01 98 38 BC
X: 3
SWB: 16 05 A0 71 8C 31 11 C0 A6 CA 7B ED 61 E9 61 E9 61 E9 61 47 C4 A6 C6 F6 82 F4 21 C2 9F DD 6E D2 00 90 16 A6
X: 3
SWB: 16 05 C0 71 C4 01 C0 9F 67 70 D2 00 90 04 A6 D0 F3 DA 24 68 04 60 08 F1 13 BD 6D E6 5C 00 87 C3 AD 2F 2E 2D
X: 3
SWB: 16 05 E0 71 9A 3D 3E 3F A7 14 24 00 4E E0 60 00 80 09 24 46 43 40 0C C0 08 90 09 24 00 4E 40 01 C0 01 90 DA
X: 3
SWB: 16 05 00 72 24 46 43 42 0C CA 07 D0 06 84 CF A1 00 CF C0 08 90 C8 26 5C 03 40 A3 84 C1 01 91 9F E0 AB 11 CF
X: 3
SWB: 16 05 20 72 01 8F 9C 3A F6 12 25 40 4B 42 7D 73 9F A7 CB F6 10 F4 50 CF 94 A4 9F 4C AC D2 00 90 9D 23 0D 00
X: 3
SWB: 16 05 40 72 22 46 43 F6 81 9C 3F 9F 28 03 52 D3 98 5E E0 8B D3 5B D3 A6 B6 24 5C 03 02 0F 21 2C 04 9F 5E 9C
X: 3
SWB: 16 05 60 72 11 CD 22 00 40 25 40 4B 42 6B 73 9F 94 CB 02 CD E9 52 94 38 4C D3 7D F6 64 20 5C 03 E8 24 40 24
X: 3
SWB: 16 05 80 72 E0 50 6C 80 27 24 46 43 40 0C E7 08 20 A6 1A E6 0A 01 EE 61 E9 61 20 6F 03 E8 21 9C 3D A6 A5 44
X: 3
SWB: 16 05 A0 72 D3 9F 73 AE EE 64 F6 80 E8 24 11 00 49 D3 E6 59 00 87 9B 66 0D 22 46 43 F6 81 9F 49 CE FB 90 1A
X: 3
SWB: 16 05 C0 72 26 5C 03 01 8F 30 E8 E1 94 10 F6 81 9F ED AC D2 00 90 07 6A 01 5A A3 A4 DB 03 A5 14 2F 2E 2D 9A
X: 3
SWB: 16 05 E0 72 3D 3E 3F A7 02 F6 15 9F 47 6E A1 00 CD E7 08 08 A6 14 C4 01 F6 51 9F 86 71 9F E1 71 62 05 9F F6
X: 3
SWB: 16 05 00 73 A0 60 DF F2 CD 24 48 04 F4 61 1C 11 C0 9F 28 03 A6 2A 26 9A 03 98 17 BA 8A A6 A6 24 5C 03 02 00
X: 3
SWB: 16 05 20 73 21 24 04 9F 5E 9C 77 A6 A6 02 80 9F F7 9F E6 5A 00 87 E4 74 24 A2 03 01 00 9F CE 9E 24 C0 4F 4E
X: 3
SWB: 16 05 40 73 17 7F E9 27 24 9E 03 01 00 02 02 F6 75 36 B5 5D 8C 18 B5 5D 84 1D B4 5C 8C 10 B4 5C 84 15 B3 5B
X: 3
SWB: 16 05 60 73 8C 08 B3 5B 84 0D B2 5E 94 09 E9 C7 24 A2 03 17 00 98 06 24 A2 03 31 11 00 24 A4 03 01 00 F4 51
X: 3
SWB: 16 05 80 73 C0 94 04 01 C0 11 00 AA 2F 2E 2D 9A 3D A2 C0 3F A7 02 9F 28 03 A6 2C 98 4A BC 8C A6 C2 9F 0E 9B
X: 3
SWB: 16 05 A0 73 9F CB 82 A6 CA 7B D2 00 90 28 F6 51 20 C3 00 E8 21 11 C0 F6 14 42 00 24 B2 4B E0 52 00 80 0B 20
X: 3
SWB: 16 05 C0 73 84 04 E8 25 69 FF 59 51 98 19 B2 92 04 C0 52 00 98 11 F6 54 20 C3 00 E8 24 72 52 00 20 84 04 E8
X: 3
SWB: 16 05 E0 73 25 52 51 E6 5C 00 87 B1 AA 2F A0 0C 2D 9A 3D 3F F6 15 A6 46 24 5C 03 02 00 21 24 04 9F 5E 9C 24
X: 3
SWB: 16 05 00 74 9A 03 02 00 9F 93 9B 74 ED C1 24 40 4B F4 E1 19 94 02 64 01 A6 42 2F 2D 9A 3D 3F A7 02 F6 15 A6
X: 3
SWB: 16 05 20 74 46 24 5C 03 02 00 21 24 04 9F 5E 9C 11 C0 F6 81 9F 5F 9D B2 92 52 40 73 53 41 AA 2F 2D 9A 3D 3E
X: 3
SWB: 16 05 40 74 3F F6 15 9F 28 03 A6 2C 6D 7F 98 22 BC 8C 64 0E F6 51 9C 38 64 03 E7 C1 40 A6 C4 20 04 04 E8 21
X: 3
SWB: 16 05 60 74 9F 19 74 B2 5D 94 02 A6 2D 20 10 00 E8 25 E6 5C 00 87 D9 24 A7 03 5D 00 2F 2E 2D 9A 3D 3E 3F A7
X: 3
SWB: 16 05 80 74 17 11 D4 54 D6 A1 00 CF E7 08 40 A6 13 E6 43 01 C3 01 A1 02 D0 C2 FE C3 01 B3 12 A3 D0 20 54 C8
X: 3
SWB: 16 05 A0 74 A6 42 9F 2F 9B 11 C6 9F 22 9B 11 C4 42 D6 9F 0E 9B 11 C2 F6 82 EA 91 E9 91 9F 24 9C 11 CE 30 E8
X: 3
SWB: 16 05 C0 74 E1 8C 05 75 55 CD 98 BD E0 A2 C7 E7 28 02 A6 12 E6 42 01 52 CD D2 00 90 AC 05 C6 26 40 4B 24 80
X: 3
SWB: 16 05 E0 74 4D 02 00 01 AD 9F 94 CB E9 B1 E9 E5 94 97 46 D6 25 5C 03 02 4F 21 2C 04 9F 5E 9C F6 15 22 00 40
X: 3
SWB: 16 05 00 75 42 AA 73 9F 94 CB E9 55 94 7B 24 5C 03 05 0F 24 80 4D 02 00 42 BB 73 9F 94 CB E9 E5 80 67 66 01
X: 3
SWB: 16 05 20 75 45 C8 44 BB 01 CE 9F 7E AC D2 00 90 58 01 C4 9F EA 69 D2 00 90 4F 4A D6 7B ED 64 20 04 04 E8 24
X: 3
SWB: 16 05 40 75 02 CE F4 CA 28 24 5C 03 01 0F 9F 96 9C F6 12 F6 54 20 5C 03 E8 24 42 24 D2 FF 90 04 B2 92 52 24
X: 3
SWB: 16 05 60 75 ED 64 EC 64 20 5C 03 E8 24 F8 14 84 04 12 14 98 14 42 D6 73 E9 61 E9 61 24 40 4B 46 29 77 20 6F
X: 3
SWB: 16 05 80 75 03 E8 21 9C 3B 24 C0 4F F4 B1 15 24 F7 04 F4 E1 06 95 61 44 D6 01 C2 9F EE 73 D2 00 84 16 01 C6
X: 3
SWB: 16 05 A0 75 9C 3A F6 14 25 80 4D 01 40 25 40 4B 02 47 9C 48 E9 E4 95 40 26 68 04 40 9B 84 20 24 F7 04 01 99
X: 3
SWB: 16 05 C0 75 F4 C9 06 9C 3A F6 15 23 64 00 02 99 24 40 4B 42 18 73 9F 0D CF 9C 3A E9 E5 89 19 46 D6 24 5C 03
X: 3
SWB: 16 05 E0 75 02 00 21 24 04 9F 5E 9C 05 D4 11 4E 05 C6 06 C2 02 C4 9F 93 9B F6 52 F6 63 E9 C3 F6 31 9F 18 9E
X: 3
SWB: 16 05 00 76 11 D0 9C 3A 20 FF 7F E9 C0 84 04 60 04 F3 CF 47 D6 57 CB 78 58 CC 25 84 04 04 CB ED 24 40 11 90
X: 3
SWB: 16 05 20 76 49 77 46 D6 02 C4 04 D4 01 0E 9F F7 9F F6 13 22 E8 03 01 D0 9F 0D CF B3 60 80 0A 60 04 F3 CF 69
X: 3
SWB: 16 05 40 76 02 59 48 98 25 40 48 84 04 64 01 54 48 F4 64 CB 20 84 04 E8 24 11 00 05 D4 05 4E 15 09 24 00 4E
X: 3
SWB: 16 05 60 76 40 00 C0 40 90 04 60 01 F3 DB 04 D4 04 0E 14 C9 01 CB 22 03 00 9C 42 F6 15 20 04 04 E8 25 E0 82
X: 3
SWB: 16 05 80 76 40 9F AE 9F 11 D2 42 40 9F AE 9F F6 16 E0 82 40 9F AE 9F F6 62 E9 C2 24 40 4B 42 09 73 9F 94 CB
X: 3
SWB: 16 05 A0 76 02 C9 F4 CA D2 E9 E2 80 4B 05 D4 05 4E 15 C0 F6 81 9F 5F 9D 05 C0 A6 24 01 C4 9F C2 9D F6 52 9F
X: 3
SWB: 16 05 C0 76 BE 9C E9 B2 01 C4 9F DF 9F F6 15 F6 26 01 D0 A6 30 A6 14 A6 15 9C 52 3E 3D 9C 46 AC 9D 27 D9 F4
X: 3
SWB: 16 05 E0 76 64 CB 20 04 04 E8 24 11 30 F6 13 04 D4 02 0E F6 41 9F 1A CD 24 84 04 40 08 D0 02 84 50 24 00 4E
X: 3
SWB: 16 05 00 77 40 00 C0 40 90 47 4C D6 7D F6 64 20 84 04 E8 24 40 11 90 39 49 CD E6 59 00 90 32 EE 65 F6 54 20
X: 3
SWB: 16 05 20 77 46 43 E8 24 02 00 24 5C 03 F4 B1 00 9F 96 9C 20 04 04 E8 25 F4 21 CE B3 60 80 01 31 11 60 A4 DB
X: 3
SWB: 16 05 40 77 03 EE 64 20 84 04 E8 24 25 E8 03 15 00 A5 17 2F 2E 2D 9A 3D 3E 3F A7 08 D2 00 90 1C 64 1A 21 48
X: 3
SWB: 16 05 60 77 04 9C 38 24 9A 03 25 5C 03 01 00 F4 C9 7C 24 48 04 11 00 9F 94 8F 98 25 24 48 04 05 02 06 04 24
X: 3
SWB: 16 05 80 77 F7 04 02 04 24 44 04 01 02 9F 86 83 A6 30 A6 14 A6 15 ED 21 EE 32 24 48 04 11 02 12 04 24 A6 03
X: 3
SWB: 16 05 A0 77 40 00 84 E6 A1 00 1F 90 E1 25 9A 03 24 5C 03 07 40 F4 CF 3C F6 71 A6 30 A6 14 A6 15 11 C4 12 C6
X: 3
SWB: 16 05 C0 77 24 48 04 01 02 02 04 24 E1 00 35 9C 4A F6 12 A6 50 A6 16 A6 17 12 C0 13 C2 03 C4 04 C6 3C 3B 01
X: 3
SWB: 16 05 E0 77 C4 02 C6 9C 45 AC 9C 52 3A 39 24 48 04 01 12 02 14 9C 40 AC 24 48 04 11 12 12 14 05 00 A6 B0 A6
X: 3
SWB: 16 05 00 78 1C A6 1D 3E 3D 01 C8 02 CA 9C 45 AC 9C 52 3A 39 24 48 04 01 16 02 18 9C 40 AC 24 48 04 11 16 12
X: 3
SWB: 16 05 20 78 18 01 C0 02 C2 3A 39 01 C4 02 C6 9C 45 AC 9C 52 3A 39 24 48 04 01 06 02 08 9C 40 AC 24 48 04 11
X: 3
SWB: 16 05 40 78 06 12 08 3E 3D 01 C4 02 C6 9C 45 AC 9C 52 3A 39 24 48 04 01 0A 02 0C 9C 40 AC 24 48 04 11 0A 12
X: 3
SWB: 16 05 60 78 0C 3E 3D F6 51 F6 62 9C 45 AC 9C 52 3A 39 24 48 04 01 0E 02 10 9C 40 AC 24 48 04 11 0E 12 10 31
X: 3
SWB: 16 05 80 78 32 11 02 12 04 17 00 9F 94 8F A8 2F 2E 2D 9A 3D A2 C0 3F A7 02 11 C0 9F 4D 69 9F 8C 73 A1 00 1F
X: 3
SWB: 16 05 A0 78 90 B3 25 F6 03 02 40 24 82 4B 01 00 EA 51 94 04 EA 91 11 40 24 40 4B 02 00 33 24 9E 03 42 03 B7
X: 3
SWB: 16 05 C0 78 52 80 63 B7 52 84 1A 42 02 B6 52 80 59 B6 52 84 10 42 01 B5 52 80 4F B5 52 84 06 42 00 B4 52 80
X: 3
SWB: 16 05 E0 78 45 05 C0 20 40 00 E8 25 E0 92 40 52 40 24 40 4B E0 52 02 80 31 72 52 40 9F 28 03 A6 2C 98 15 BC
X: 3
SWB: 16 05 00 79 8C A6 CA 7B ED 61 E9 61 E9 61 E9 61 A6 C4 F4 21 C0 9F 7C 74 E6 5C 00 87 E6 25 68 04 24 F7 04 01
X: 3
SWB: 16 05 20 79 06 11 59 73 53 5B 74 01 C0 9F 86 71 9F 28 6A 9F 68 6A D2 00 90 10 60 01 F3 DB 60 40 F3 D4 9F E6
X: 3
SWB: 16 05 40 79 6A 9F 0E 6D 98 0B 9F FF 92 D2 00 90 04 60 20 F3 CD 72 9F 53 77 AA 2F A0 0C 2D 9A 3D 3F F6 15 20
X: 3
SWB: 16 05 60 79 40 00 E8 25 72 52 40 20 C0 FF E8 25 24 F6 03 31 11 00 9F 7A 6F 62 01 9F 53 77 F6 51 9F 3E 74 2F
X: 3
SWB: 16 05 80 79 2D 9A FC 60 24 BF 01 21 FF 7F 11 04 21 FF FF 22 FF 7F 11 00 12 02 31 32 19 D6 1A D8 FC 50 9A 3D
X: 3
SWB: 16 05 A0 79 24 00 4E 42 04 C2 60 D2 40 84 07 24 F7 04 01 34 98 0D 24 F7 04 D2 00 84 04 01 32 98 02 01 36 25
X: 3
SWB: 16 05 C0 79 5C 03 24 9A 03 11 00 F4 E1 7C 88 02 11 7C 2D 9A 24 00 4E 40 08 84 07 A1 02 D0 C2 F7 98 06 A1 02
X: 3
SWB: 16 05 E0 79 D0 E6 12 08 A3 D0 20 9A 3F 9F 3D AB 24 5C 03 31 11 38 A4 DB 03 9F 80 94 A1 02 D5 E6 12 08 A3 D5
X: 3
SWB: 16 05 00 7A 20 24 00 4E 40 00 C0 02 90 13 66 04 22 8E 03 21 86 03 9F 5B CA 22 8E 03 F6 21 9F CD 80 24 80 4D
X: 3
SWB: 16 05 20 7A 42 09 CA 04 90 04 60 02 F3 CD CA 08 90 04 60 08 F3 CD 2F 9A 3D 3F 25 5C 03 24 9E 03 F4 90 00 10
X: 3
SWB: 16 05 40 7A 00 30 F4 38 02 10 02 F4 90 46 10 46 30 F4 38 48 10 48 24 A6 03 E0 92 00 52 00 E4 A0 D3 90 13 21
X: 3
SWB: 16 05 60 7A A2 03 9F 47 CC 24 A4 03 01 00 90 0C E9 81 11 00 98 06 21 A4 03 9F 47 CC 24 A6 03 42 00 D2 E0 94
X: 3
SWB: 16 05 80 7A 37 E6 22 1F 52 00 21 6D 03 9F 47 CC 21 60 03 9F 47 CC 21 84 03 9F 47 CC 24 5C 03 01 04 9F E0 AB
X: 3
SWB: 16 05 A0 7A F6 15 24 80 4D 02 00 24 40 4B 42 0A 73 9F 94 CB E9 55 80 04 60 04 F3 CF 2F 2D 9A 3D 3E 3F A7 02
X: 3
SWB: 16 05 C0 7A F6 16 09 D6 0A D8 24 10 27 35 9C 4A 11 C0 9F 4A 83 F6 62 9C 43 F5 21 D6 F5 32 D8 19 D6 1A D8 24
X: 3
SWB: 16 05 E0 7A 10 27 35 9C 4A F4 C9 C0 AA 2F 2E 2D 9A 3F A7 01 24 46 43 44 0C A1 00 AA E7 08 20 A6 13 C3 01 E7
X: 3
SWB: 16 05 00 7B 48 40 A6 12 C2 01 B3 52 84 03 72 98 1A A6 42 C2 FB E7 38 04 C0 04 B0 12 52 C0 23 01 00 F6 82 21
X: 3
SWB: 16 05 20 7B 52 43 9F E3 C5 62 01 A9 2F 9A 3F 60 40 F3 CD 9F ED 7A 9F D0 79 2F 9A 3D 3E 3F A7 02 24 00 4E 40
X: 3
SWB: 16 05 40 7B 00 C0 01 90 07 24 94 07 02 04 98 05 24 80 4D 02 00 25 80 4D 42 46 73 9F 94 CB F6 16 02 40 42 47
X: 3
SWB: 16 05 60 7B 73 9F 94 CB F6 12 EE E1 88 02 F6 62 24 5C 03 01 36 EA E1 80 22 20 09 00 E8 E2 94 1B EA C1 11 36
X: 3
SWB: 16 05 80 7B 24 80 43 01 00 E9 A0 90 0E E9 91 11 C0 23 02 00 F6 82 F6 41 9F E3 C5 72 9F 9A 94 AA 2F 2E 2D 9A
X: 3
SWB: 16 05 A0 7B 3D 3E 3F F6 15 9F BB 7A F6 16 24 5C 03 01 0F ED C1 11 0F 01 00 ED C1 11 00 01 02 EE C1 11 02 01
X: 3
SWB: 16 05 C0 7B 38 ED C1 11 38 01 3A ED C1 11 3A BB 60 80 06 01 36 ED C1 11 36 24 FC 03 F6 51 F4 21 00 11 00 24
X: 3
SWB: 16 05 E0 7B FE 03 F6 61 F4 21 00 11 00 72 9F 0F 98 A1 00 D0 C0 40 84 21 F6 51 24 5C 03 F4 21 2A 11 2A E4 80
X: 3
SWB: 16 05 00 7C 1D 84 0A 9F BB 7A 24 5C 03 11 2C 98 08 24 5C 03 F4 26 2C 16 2C 9F 17 7F 24 00 4E 40 02 C0 40 90
X: 3
SWB: 16 05 20 7C 1D 24 FA 03 02 00 30 E8 E2 94 13 23 10 27 24 94 07 01 00 9F 0D CF F6 12 21 96 07 9F 83 CA 9F 37
X: 3
SWB: 16 05 40 7C 7B 2F 2E 2D 9A 3F A6 24 A1 03 D3 84 0B 24 3B 03 42 00 B4 52 90 02 54 00 E4 53 1D 90 5B D3 01 90
X: 3
SWB: 16 05 60 7C 06 D3 FF 84 1F 98 09 9F 60 AB 60 40 F3 CD 98 06 21 AD 02 9F E0 72 64 01 21 AD 02 9F 19 BA 21 3C
X: 3
SWB: 16 05 80 7C 03 9F D4 BB A1 02 1D D2 01 90 04 D2 FF 84 23 9F D0 79 21 AD 02 9F F7 B3 A4 21 00 E4 80 1D 84 09
X: 3
SWB: 16 05 A0 7C 60 BF F2 CD 9F C7 AB 98 06 21 AD 02 9F 5B 79 A4 DB 03 A1 02 1D A3 D3 20 2F 9A 3D A2 C0 3F A6 2A
X: 3
SWB: 16 05 C0 7C A6 3C 9F 9F 79 9F ED 7A D2 00 90 1F 60 02 F3 D4 24 A2 03 21 FF FF 11 00 A1 00 AA E7 08 20 A6 14
X: 3
SWB: 16 05 E0 7C C4 01 21 AD 02 9F D9 BA A4 DB 03 A6 A2 9F 45 7C A1 02 D3 84 1D A1 00 1F 90 2B 24 3B 03 44 00 21
X: 3
SWB: 16 05 00 7D AD 02 9F 86 B5 A6 A6 22 AD 02 21 3C 03 9F C1 BE 98 13 D2 01 84 05 9F 7D AB 98 0A D2 FF 84 06 21
X: 3
SWB: 16 05 20 7D AD 02 9F 8F 78 24 84 04 40 08 D0 02 84 0B E4 A0 D3 84 06 60 80 F3 CF 98 04 60 7F F2 CF 9F A4 91
X: 3
SWB: 16 05 40 7D D2 00 90 03 A4 DB 07 9F F8 8E 24 00 4E 40 02 C0 40 90 10 E4 80 D3 84 0B A1 02 DB 90 02 62 01 A6
X: 3
SWB: 16 05 60 7D 2A 98 01 7A 9F 80 94 A6 2B E6 5A 00 90 22 24 5C 03 07 2C 01 34 E9 E7 88 17 02 2A 03 32 EB E2 88
X: 3
SWB: 16 05 80 7D 0F EA C3 22 10 27 EF C1 9F 0D CF 24 F8 03 11 00 A1 02 D4 CA 20 84 10 CA 40 90 05 9F 51 90 98 07
X: 3
SWB: 16 05 A0 7D CA 04 90 03 9F F9 82 A1 00 1F 90 09 60 DF F2 D4 A6 C2 9F C9 A2 A1 00 1F 90 03 9F 8C 81 24 94 07
X: 3
SWB: 16 05 C0 7D 40 09 90 05 E4 80 D3 84 08 A1 02 D5 C2 FE A3 D5 20 60 FD F2 D4 A6 B2 2F A0 0C 2D 9A 3F A4 DB 03
X: 3
SWB: 16 05 E0 7D 9F 9F 79 24 A2 03 21 FF FF 11 00 9F 2A 7B 74 21 AD 02 9F D9 BA 72 9F 9A 94 9F 8D 6B 9F 80 94 9F
X: 3
SWB: 16 05 00 7E 94 8F A1 02 D4 C2 9E E6 12 41 A3 D4 20 2F 9A F6 14 12 0A EB E2 94 02 F6 32 13 0C B5 60 80 01 32
X: 3
SWB: 16 05 20 7E 12 04 21 FF FF 22 FF 7F 11 00 12 02 31 22 80 3F 11 06 12 08 9A 3D 3E 3F A7 02 F6 17 12 C0 E4 60
X: 3
SWB: 16 05 40 7E C7 88 0A A6 30 A6 14 A6 15 9C 52 98 05 09 C8 32 9C 53 F6 15 F6 26 F7 00 00 F7 00 00 9C 54 AC DA
X: 3
SWB: 16 05 60 7E 00 94 18 BF 60 88 14 F4 CF C0 F6 71 A6 30 A6 14 A6 15 9C 52 3E 3D 9C 4C AC 98 02 31 32 3A 39 31
X: 3
SWB: 16 05 80 7E 22 80 3F 9C 41 AC AA 2F 2E 2D 9A 3D 3F F6 15 F6 21 02 4C F4 CA 44 9F 35 7E 11 46 12 48 2F 2D 9A
X: 3
SWB: 16 05 A0 7E 3D 3F F6 15 F6 21 02 44 9F 35 7E E4 60 C7 80 09 3A 39 31 22 80 3F 9C 41 AC 11 46 12 48 2F 2D 9A
X: 3
SWB: 16 05 C0 7E 3F F6 14 E4 60 C7 88 10 30 E8 E2 94 04 EB E2 80 07 F6 41 9F 0F 7E 98 04 01 04 11 0A 2F 9A 3D 3E
X: 3
SWB: 16 05 E0 7E 3F F6 15 FC 60 26 40 03 02 8A 9F 83 CA 02 8C F6 51 E6 22 04 B3 D3 9F 83 CA 26 4E 03 02 8A ED 91
X: 3
SWB: 16 05 00 7F E9 91 9F 83 CA 02 8C F6 51 E6 22 06 B3 D3 9F 83 CA FC 50 2F 2E 2D 9A 3D 3F FC 60 25 5C 03 03 72
X: 3
SWB: 16 05 20 7F 02 6A 21 40 03 9F C0 7E 03 74 02 6C 21 4E 03 9F C0 7E FC 50 24 00 4E 40 01 C0 10 90 08 21 94 07
X: 3
SWB: 16 05 40 7F 9F DE 7E 98 16 66 04 22 86 03 21 94 07 9F 5B CA 66 04 22 8E 03 21 98 07 9F 5B CA 2F 2D 9A 3D 3F
X: 3
SWB: 16 05 60 7F F6 15 03 C4 04 C6 D4 01 90 05 E4 60 C7 88 11 00 48 38 00 46 38 F6 31 F6 42 9C 46 AC F6 13 F6 24
X: 3
SWB: 16 05 80 7F 3C 3B F6 51 9F 83 D6 02 4C AC 01 44 EA 51 94 02 12 44 2F 2D 9A 3D 3E 3F A7 02 F6 16 12 C0 F6 35
X: 3
SWB: 16 05 A0 7F A1 02 C7 D2 01 84 0C F6 32 F4 CA C0 F6 61 9F 8B 7E 98 2D D2 F6 84 22 24 00 4E 40 01 C0 08 90 04
X: 3
SWB: 16 05 C0 7F 02 C0 98 10 02 8C 01 84 9F 96 9C F6 52 9F AF 9C F6 53 F6 12 F6 61 9F 0F 7E 02 C0 F6 61 9F A0 7E
X: 3
SWB: 16 05 E0 7F AA 2F 2E 2D 9A 3D 3F A6 27 FC 60 D2 01 84 0E A1 02 C7 E6 22 02 D2 01 8C 08 FC 50 98 CD D2 02 90
X: 3
SWB: 16 05 00 80 14 A1 00 D5 C0 01 90 0D E4 80 C7 90 08 24 00 4E 44 17 75 67 04 F9 20 90 17 D7 03 90 04 66 FE 98
X: 3
SWB: 16 05 20 80 02 66 FF E4 56 C7 84 3F 09 C8 EA 51 8C 39 98 1D A1 00 1D 84 1B D7 01 90 07 A1 00 C7 D0 F6 84 10
X: 3
SWB: 16 05 40 80 24 00 4E 42 01 CA 48 90 07 02 11 66 F6 72 98 19 76 A1 02 20 73 E9 64 20 59 05 E8 24 01 00 30 E8
X: 3
SWB: 16 05 60 80 E1 97 EA 66 01 99 E6 62 01 E4 56 C7 84 0C D2 00 84 08 D7 02 90 04 D7 01 84 4E A3 C7 60 1A C8 D6
X: 3
SWB: 16 05 80 80 FF 84 15 24 40 03 02 0C F6 23 F6 41 9F 95 7F 24 4E 03 02 0C F6 23 98 15 D6 FE 84 15 24 40 03 03
X: 3
SWB: 16 05 A0 80 0C 32 F6 41 9F 95 7F 24 4E 03 03 0C 32 F6 41 98 14 25 5C 03 03 72 02 6A 21 40 03 9F 95 7F 03 74
X: 3
SWB: 16 05 C0 80 02 6C 21 4E 03 9F 95 7F FC 50 2F 2D 9A 3D 3E 3F F6 16 F6 25 FC 60 03 40 02 80 21 40 03 9F 0F 7E
X: 3
SWB: 16 05 E0 80 03 42 02 82 21 4E 03 9F 0F 7E A4 C7 00 32 62 02 9F E5 7F FC 50 9F 17 7F 24 94 07 03 04 22 10 27
X: 3
SWB: 16 05 00 81 01 06 9F 0D CF 24 FA 03 11 00 2F 2E 2D 9A 3D 3E 3F A7 01 F6 15 F6 26 56 C0 07 C7 F7 00 00 F7 00
X: 3
SWB: 16 05 20 81 00 9C 54 AC DA 00 8C 01 37 42 C0 D2 00 84 18 F9 70 90 0F 24 00 4E 40 04 C0 02 90 06 F6 72 62 03
X: 3
SWB: 16 05 40 81 98 02 72 32 9F E5 7F FC 60 3E 3D 44 C4 21 40 03 9F 5E 7F 9F 4A 83 AC 44 C0 D4 01 84 03 21 10 27
X: 3
SWB: 16 05 60 81 A6 30 A6 14 A6 15 9C 52 3A 39 F6 51 F6 62 9C 46 AC F7 1C 46 F7 00 40 9C 4C AC 3A 39 44 C4 21 4E
X: 3
SWB: 16 05 80 81 03 9F 5E 7F FC 50 AC A9 2F 2E 2D 9A 3F FC 60 E4 60 C7 80 16 FA C8 90 12 F7 00 00 66 01 31 22 80
X: 3
SWB: 16 05 A0 81 4F 9F 0E 81 F5 81 C8 19 C8 AA FC 50 2F 9A 3F 9F 28 03 A1 04 DA 63 01 98 0D B2 82 A6 40 B3 00 84
X: 3
SWB: 16 05 C0 81 03 72 98 0B B3 63 D2 00 87 EF A4 DA 00 62 01 2F 9A 3D A2 C0 3F 9F 28 03 A6 2C 25 FF 7F 98 1B BC
X: 3
SWB: 16 05 E0 81 8C A6 C2 9F 4C 9D 24 40 4B 4E 13 7F EF 92 EA 64 E9 24 01 00 E9 E5 94 02 F6 15 E6 5C 00 87 E0 F6
X: 3
SWB: 16 05 00 82 51 2F A0 0C 2D 9A 3D A2 C0 3F 9F 28 03 A6 2C 25 00 80 98 1B BC 8C A6 C2 9F 4C 9D 24 40 4B 4E 13
X: 3
SWB: 16 05 20 82 7F EF 92 EA 64 E9 24 01 00 E9 E5 88 02 F6 15 E6 5C 00 87 E0 F6 51 2F A0 0C 2D 9A 24 00 4E 42 06
X: 3
SWB: 16 05 40 82 D2 03 8C 01 72 9A 24 48 04 02 1A 9C 43 66 08 9C 4E 9A 21 24 04 9A 24 00 4E 40 00 E7 08 08 A6 12
X: 3
SWB: 16 05 60 82 C2 01 24 00 4A 43 01 CB F0 90 05 E7 38 10 A6 13 D3 04 90 01 72 9A 3D F6 13 A6 42 73 E9 65 20 84
X: 3
SWB: 16 05 80 82 04 E8 25 01 40 24 00 4E E0 60 01 80 05 F4 E3 49 80 09 24 00 4E 40 00 C0 40 84 03 21 E8 03 24 AE
X: 3
SWB: 16 05 A0 82 4B 02 00 EA E1 88 02 F6 21 24 B0 4B 02 00 EA E1 94 02 F6 21 2D 9A 3F 24 5C 03 01 2A 30 E8 E1 8C
X: 3
SWB: 16 05 C0 82 03 31 98 05 02 32 9F 5C CB 2F 9A 3D 3F F6 15 9F 28 03 A6 24 24 88 4B 01 00 75 9C 48 24 8B 4B F4
X: 3
SWB: 16 05 E0 82 21 00 E9 E5 80 0C 9F B6 82 73 24 AD 4B E0 52 00 8C 02 63 01 A6 32 2F 2D 9A 3F 23 04 00 22 B4 03
X: 3
SWB: 16 05 00 83 21 6B 43 9F E3 C5 60 FB F2 D4 2F 9A 3F EA B3 22 10 0E 9F 0D CF 2F 9A 3D 3F 77 EB 64 E9 24 05 04
X: 3
SWB: 16 05 20 83 23 E8 03 01 0C 9F 0D CF ED 21 B3 60 80 01 31 2F 2D 9A 3D 3F F6 14 05 00 23 E8 03 01 02 9F 0D CF
X: 3
SWB: 16 05 40 83 ED 21 B3 60 80 01 31 2F 2D 9A 3F 24 5C 03 E0 60 2D 80 07 24 88 4B 01 00 98 2A E4 80 1D 84 20 24
X: 3
SWB: 16 05 60 83 00 4E 40 02 C0 40 90 0A 24 F8 03 01 00 30 E8 E1 8C 12 24 46 43 02 17 21 44 04 9F 32 83 98 05 24
X: 3
SWB: 16 05 80 83 31 05 01 10 2F 9A 3D 3F F6 25 23 E8 03 9F 0D CF 23 10 27 F6 52 9F 0D CF 2F 2D 9A 3D A2 C0 3F A7
X: 3
SWB: 16 05 A0 83 06 11 C2 12 C4 24 46 43 42 0C CA 03 D0 02 84 AB 62 03 E7 65 20 20 10 04 E8 25 42 42 B2 93 53 42
X: 3
SWB: 16 05 C0 83 D2 00 84 07 21 10 27 11 40 98 0B 24 40 4B E0 53 0D 80 03 73 53 42 04 40 14 C0 03 C4 04 C2 02 00
X: 3
SWB: 16 05 E0 83 01 C0 9F 0D CF 11 40 04 C2 E0 60 01 80 0A 64 0C 21 10 04 9C 38 7A 98 65 22 E8 03 9C 48 F6 12 24
X: 3
SWB: 16 05 00 84 40 4B 46 0B A6 62 73 E9 52 8C 08 42 0C F6 10 EA 50 94 48 24 00 4E 40 00 C0 04 84 03 7A 98 33 24
X: 3
SWB: 16 05 20 84 40 4B 4C 0C A6 C2 73 E9 52 80 02 A6 6C 01 C0 22 E8 03 9C 48 F6 13 02 C4 A6 C2 73 9F 0D CF 04 C2
X: 3
SWB: 16 05 40 84 11 00 A6 C2 73 22 E8 03 9C 42 11 40 60 04 F3 CF 6A 01 64 0C 21 10 04 9C 38 98 02 6A 01 A6 A2 AE
X: 3
SWB: 16 05 60 84 2F A0 0C 2D 9A 3F 24 00 4E 40 04 C0 10 90 2C A1 00 D4 C0 10 84 25 24 84 04 40 08 90 1E 24 48 04
X: 3
SWB: 16 05 80 84 F4 61 1C 24 A4 03 04 00 E9 54 80 03 31 98 0F F6 13 22 00 04 EC C1 9F 78 CF 98 03 21 00 04 2F 9A
X: 3
SWB: 16 05 A0 84 3D 3E 3F A7 0A 11 C4 F6 35 A1 00 D4 C0 08 90 09 24 46 43 01 29 07 2B 98 07 24 48 04 01 1A 07 1C
X: 3
SWB: 16 05 C0 84 9C 43 66 08 9C 4E 24 48 04 F4 21 1E 11 C0 F6 51 32 9C 53 F6 15 F6 26 E6 4D 80 F6 71 A6 30 A6 14
X: 3
SWB: 16 05 E0 84 A6 15 9C 52 3A 39 F6 51 F6 62 9C 4C AC 9F 27 D7 F6 15 F6 26 01 C4 F4 C9 C0 11 C4 A6 30 A6 14 A6
X: 3
SWB: 16 05 00 85 15 9C 52 3E 3D 9C 46 AC 11 C6 12 C8 9F 65 84 F6 16 25 00 04 F6 53 F6 52 E9 C2 24 9A 03 01 00 9F
X: 3
SWB: 16 05 20 85 0D CF 11 C2 01 C6 02 C8 9D 27 D9 F6 53 F6 62 F4 21 C0 9F 0D CF F4 21 C2 A5 0A 2F 2E 2D 9A 3D 3E
X: 3
SWB: 16 05 40 85 3F A7 07 11 C1 35 F6 14 15 02 9F 28 03 52 C0 98 75 E0 8B C0 5B C0 24 92 4B 01 00 A6 30 A6 14 A6
X: 3
SWB: 16 05 60 85 15 9C 52 F6 15 F6 26 42 C0 9F DA 9D 3A 39 F6 51 F6 62 9C 46 AC 9D 27 D9 4C C0 7D EE 65 F4 25 C1
X: 3
SWB: 16 05 80 85 07 4C E9 C7 11 4C 30 E8 E7 94 2D A6 30 A6 14 A6 15 9C 52 11 C3 12 C5 F6 71 A6 30 A6 14 A6 15 9C
X: 3
SWB: 16 05 A0 85 52 3A 39 01 D1 02 D3 9C 46 AC 3A 39 01 C7 02 C9 9C 40 AC 9D 27 D9 11 4C EE 64 F4 24 C1 05 C1 00
X: 3
SWB: 16 05 C0 85 42 F4 20 0C 10 42 4B C0 E6 5B 00 87 84 AF 2F 2E 2D 9A 3F 66 04 F6 12 21 B0 03 9F 5B CA 2F 9A 3D
X: 3
SWB: 16 05 E0 85 A2 C0 3F A7 04 A6 3C D2 00 84 09 24 46 43 01 17 02 19 98 70 D2 01 84 08 74 F6 81 9F 0E 6C 98 70
X: 3
SWB: 16 05 00 86 D2 02 84 12 25 F7 04 02 42 01 44 9F B0 CB 11 C2 02 44 12 C0 98 5A D2 03 84 10 25 F7 04 02 42 01
X: 3
SWB: 16 05 20 86 46 9F B0 CB 11 C2 01 46 98 2B D2 04 84 17 24 80 4D 01 00 22 FB FF 9C 48 11 C0 01 02 22 FB FF 9C
X: 3
SWB: 16 05 40 86 48 11 C2 98 2B D2 05 84 10 24 B2 03 02 00 12 C2 24 B0 03 01 00 11 C0 98 17 D2 06 84 0D 24 00 4E
X: 3
SWB: 16 05 60 86 01 09 02 0B 11 C0 12 C2 98 06 74 F6 81 9F DF 6B E6 5C 00 90 04 01 C2 98 02 01 C0 AC 2F A0 0C 2D
X: 3
SWB: 16 05 80 86 9A 3D 3F F6 15 24 88 4B 01 00 11 46 24 8D 4B 03 00 13 48 A1 00 D4 C0 08 90 0A 24 B5 4B F4 21 00
X: 3
SWB: 16 05 A0 86 11 46 98 30 D4 00 90 33 24 68 04 02 10 F4 22 46 12 46 A1 00 DB C0 04 84 1B 24 F7 04 01 14 EA E1
X: 3
SWB: 16 05 C0 86 80 0B 9F B6 82 24 AD 4B E0 52 00 8C 07 24 00 4E 42 07 98 12 24 00 4E 42 06 98 0B 24 46 43 F4 21
X: 3
SWB: 16 05 E0 86 1B 11 46 9F 3B 82 A1 00 D0 E7 08 20 A6 13 C3 01 9F DF 85 11 44 25 5C 03 24 48 04 01 7C 11 1E 2F
X: 3
SWB: 16 05 00 87 2D 9A 3D 3E 3F A7 0A F6 15 F6 24 02 04 B5 60 88 03 31 98 D7 A1 00 D0 C0 08 90 C9 01 42 11 C8 30
X: 3
SWB: 16 05 20 87 E8 E1 94 B6 03 40 A6 70 A6 18 A6 19 13 C4 14 C6 9C 43 9C 52 F6 15 F6 26 01 C4 02 C6 3A 39 01 C8
X: 3
SWB: 16 05 40 87 02 CA 9C 45 AC 9C 52 3A 39 F6 51 F6 62 9C 4C AC F7 20 42 F7 00 00 9C 46 AC F6 15 F6 26 F7 80 BF
X: 3
SWB: 16 05 60 87 F7 00 00 9C 54 AC DA 00 94 7E F7 80 3F F7 00 00 F6 51 F6 62 9C 40 AC 9C 3E 11 C0 12 C2 F7 00 00
X: 3
SWB: 16 05 80 87 F7 F4 01 01 C8 02 CA 9C 45 AC 9C 52 F6 15 F6 26 01 C8 A6 30 A6 14 A6 15 9C 52 3A 39 F6 51 F6 62
X: 3
SWB: 16 05 A0 87 9C 4C AC F6 15 F6 26 02 C0 03 C2 3B 3A 31 22 80 3F 9C 41 AC 3A 39 F6 51 F6 62 9C 46 AC F6 15 F6
X: 3
SWB: 16 05 C0 87 26 F7 FF 46 F7 00 FE 9C 54 AC DA 00 88 1A F6 51 F6 62 E6 45 80 9D 27 D9 98 11 03 40 21 10 27 9F
X: 3
SWB: 16 05 E0 87 0D CF 98 07 F6 21 98 03 21 01 80 A5 0A 2F 2E 2D 9A 3F EB C2 9F AF 9C 2F 9A 3D 3E 3F A7 03 11 C1
X: 3
SWB: 16 05 00 88 F6 26 9F 28 03 25 FF 7F 98 1E 03 80 EE 96 EE 96 04 C1 01 00 EC 92 EA 92 12 C1 22 00 40 9F F1 87
X: 3
SWB: 16 05 20 88 E9 E5 94 02 F6 15 42 C0 B2 85 55 C0 D2 00 87 DA F6 51 AB 2F 2E 2D 9A 3F 22 24 04 21 46 43 9F F9
X: 3
SWB: 16 05 40 88 87 24 5C 03 F6 12 F4 CA 00 21 F4 03 9F 83 CA 2F 9A 3D 3E 3F A7 05 11 C3 12 C1 9F 28 03 26 04 04
X: 3
SWB: 16 05 60 88 25 FF 7F 98 22 04 C3 01 00 EC 92 EA 92 12 C3 04 C1 03 00 02 9E 9F F1 87 E9 E5 94 02 F6 15 F4 91
X: 3
SWB: 16 05 80 88 C1 E9 91 11 C1 42 C0 B2 83 53 C0 EE 96 EE 96 D2 00 87 D2 F6 51 AD 2F 2E 2D 9A 3D A2 C0 3F A7 06
X: 3
SWB: 16 05 A0 88 11 C2 12 C4 9F 28 03 A6 2C 21 00 80 11 C0 98 2A BC 8C A6 C6 24 5C 03 02 00 21 24 04 9F 5E 9C F6
X: 3
SWB: 16 05 C0 88 15 A6 C6 02 C4 01 C2 9F 5E 9C F6 52 E9 C2 F4 E2 C0 94 07 19 CA A3 CC C0 12 C0 E6 5C 00 87 D1 AE
X: 3
SWB: 16 05 E0 88 2F A0 0C 2D 9A 3D 3E 3F A7 0B 11 C5 12 C7 13 C9 64 04 01 D1 9C 38 9F 28 03 52 C2 98 5D E0 82 C2
X: 3
SWB: 16 05 00 89 52 C2 A6 26 02 C7 01 C5 9F 5E 9C 11 C0 4C C2 7D 02 C9 9F 93 9B EE 65 F4 25 D1 11 44 04 D1 02 00
X: 3
SWB: 16 05 20 89 E9 22 12 00 77 46 C2 02 C9 01 C0 9F F7 9F 11 C3 11 4C 49 D3 E6 59 00 90 13 44 C2 01 C0 9F 76 82
X: 3
SWB: 16 05 40 89 23 E8 03 F6 12 01 C3 9F 0D CF 11 4C EE 64 F4 24 D1 05 D1 00 42 F4 20 0C 10 42 4B C2 E6 5B 00 87
X: 3
SWB: 16 05 60 89 9C A5 0B 2F 2E 2D 9A 3D 3E 3F A7 4A 24 42 00 F6 80 E8 24 11 00 25 44 00 F6 80 E8 25 12 40 26 46
X: 3
SWB: 16 05 80 89 00 F6 80 E8 26 56 80 24 47 00 F6 80 E8 24 57 00 64 0D F6 81 9C 38 24 46 43 02 08 24 8F 4B 42 00
X: 3
SWB: 16 05 A0 89 73 9F A7 CB 11 EF 25 42 00 F6 80 E8 25 05 40 05 40 15 F1 26 47 00 F6 80 E8 26 4D 80 A2 D0 F6 81
X: 3
SWB: 16 05 C0 89 E6 22 0E B3 D3 39 24 47 00 F6 80 E8 24 03 00 02 F4 25 45 00 F6 80 E8 25 05 40 01 4A 9F E5 88 26
X: 3
SWB: 16 05 E0 89 49 00 F6 80 E8 26 44 80 24 A2 03 01 00 9F CE 9E F6 17 AB 24 46 00 F6 80 E8 24 49 00 E6 59 00 84
X: 3
SWB: 16 05 00 8A 37 E4 A0 D3 84 32 E9 61 11 C7 24 9E 03 4B 00 47 01 4A 02 46 03 32 B6 55 8C 18 B6 55 84 1A BA 54
X: 3
SWB: 16 05 20 8A 8C 10 BA 54 84 12 B7 53 8C 08 B7 53 84 0A BB 52 94 06 A6 B2 A6 73 11 C7 02 C7 EF 61 F6 10 EA 50
X: 3
SWB: 16 05 40 8A 94 33 F6 21 32 9C 53 F6 15 F6 26 E6 4D 80 F6 71 32 9C 53 3A 39 F6 51 F6 62 9C 4C AC 9F 27 D7 3A
X: 3
SWB: 16 05 60 8A 39 31 22 80 3F 9C 41 AC 3A 39 F6 81 E6 22 11 B3 D3 9F 3E 85 AC 01 CF 9F 66 9F 11 EB 11 CF 25 42
X: 3
SWB: 16 05 80 8A 00 F6 80 E8 25 02 40 F6 81 E6 22 0D B3 D3 9F 02 87 11 FB 26 42 00 F6 80 E8 26 20 01 80 E9 C0 84
X: 3
SWB: 16 05 A0 8A 03 9B 68 8E 24 42 00 F6 80 E8 24 04 00 01 00 F4 E1 02 80 03 9B 68 8E 9F 28 03 A6 2A 36 16 F7 21
X: 3
SWB: 16 05 C0 8A FF 7F 11 F5 F6 86 20 0D 00 E8 26 98 19 BA 8A A6 A6 02 FB F6 61 9F 17 83 02 F5 E9 E2 94 02 11 F5
X: 3
SWB: 16 05 E0 8A 04 F7 E9 24 14 F7 E6 5A 00 87 E2 02 F7 01 F5 25 42 00 F6 80 E8 25 26 42 00 F6 80 E8 26 06 80 F4
X: 3
SWB: 16 05 00 8B E2 86 8C 03 9B 68 8E 24 00 4E 4C 01 25 41 00 F6 80 E8 25 A6 C2 C2 02 52 40 D2 00 90 13 05 F5 24
X: 3
SWB: 16 05 20 8B 42 00 F6 80 E8 24 04 00 F4 E5 08 8C 03 9B 68 8E 9F 28 03 73 24 9B 4B 02 00 9C 42 24 88 4B F4 21
X: 3
SWB: 16 05 40 8B 00 11 E5 24 00 4E 4B 04 A6 B2 C2 08 52 FE 24 44 00 F6 80 E8 24 04 00 14 E9 79 59 FD 4A FD E6 5A
X: 3
SWB: 16 05 60 8B 00 84 77 26 98 4B 43 80 42 C0 B2 53 8C 04 68 01 98 03 E5 C8 23 25 42 00 F6 80 E8 25 06 40 07 82
X: 3
SWB: 16 05 80 8B F4 CF F1 01 F7 F4 E1 E5 80 1E F6 71 02 EF 9C 48 25 48 00 F6 80 E8 25 58 40 74 26 49 00 F6 80 E8
X: 3
SWB: 16 05 A0 8B 26 54 80 F4 51 40 80 32 25 3F 00 F6 80 E8 25 58 40 72 26 40 00 F6 80 E8 26 52 80 EF 81 F4 21 40
X: 3
SWB: 16 05 C0 8B 02 40 9C 48 11 EF 30 E8 E1 8C 0B 63 01 53 FD 22 01 00 12 EF 98 04 65 01 55 FD 04 EF F4 24 F1 14
X: 3
SWB: 16 05 E0 8B ED 25 42 00 F6 80 E8 25 05 40 01 42 E9 E4 94 02 11 ED 06 ED F4 CE F1 16 EF E0 92 C0 52 C0 02 FB
X: 3
SWB: 16 05 00 8C F6 61 9F 0C 83 11 E7 4D FE E6 5D 00 90 11 01 C5 24 48 04 F4 51 1C 94 07 05 F7 F4 E5 E5 80 09 02
X: 3
SWB: 16 05 20 8C FB 01 EB 9F 86 83 11 CB 03 E7 02 CB 01 E9 9F A0 84 11 E3 26 47 00 F6 80 E8 26 4D 80 A2 D0 21 0E
X: 3
SWB: 16 05 40 8C 00 F6 80 E8 21 39 03 E6 02 F0 24 45 00 F6 80 E8 24 04 00 01 0A 9F E5 88 25 49 00 F6 80 E8 25 44
X: 3
SWB: 16 05 60 8C 40 26 A2 03 01 80 9F CE 9E 11 E4 03 CA E9 61 AB F6 10 EB 50 94 38 02 E7 F6 31 9F 31 9D 32 9C 53
X: 3
SWB: 16 05 80 8C F6 15 F6 26 E6 4D 80 01 E1 32 9C 53 3A 39 F6 51 F6 62 9C 4C AC 9F 27 D7 3A 39 31 22 80 3F 9C 41
X: 3
SWB: 16 05 A0 8C AC 3A 39 F6 81 E6 22 11 B3 D3 9F 3E 85 AC 01 CF 9F 66 9F 11 CF 24 42 00 F6 80 E8 24 02 00 F6 81
X: 3
SWB: 16 05 C0 8C E6 22 0D B3 D3 9F 02 87 11 F9 25 42 00 F6 80 E8 25 9F 28 03 A6 2C 35 21 FF 7F 11 F3 98 1A BC 8C
X: 3
SWB: 16 05 E0 8C A6 C6 02 F9 F6 81 E6 22 0D B3 D3 9F 17 83 02 F3 E9 E2 94 02 11 F3 E9 25 E6 5C 00 87 E1 F6 56 F4
X: 3
SWB: 16 05 00 8D CE F7 16 C9 20 01 80 F4 C8 F9 90 1E 01 F7 ED C1 B3 60 80 02 E9 B1 20 FF 07 E8 E1 8C 0D E9 61 E9
X: 3
SWB: 16 05 20 8D 61 E9 61 E9 61 F4 E1 F7 94 19 45 FD D5 00 84 13 04 EF 20 01 00 E8 E4 94 0A E5 79 90 B8 E8 14 EF
X: 3
SWB: 16 05 40 8D 9B 63 8B 02 E7 01 C5 9F 31 9D 11 C5 02 E7 01 C7 9F 31 9D 11 C7 20 01 80 F4 C8 F9 84 12 06 F1 25
X: 3
SWB: 16 05 60 8D 42 00 F6 80 E8 25 05 40 F4 CE 40 16 42 98 87 24 42 00 F6 80 E8 24 04 00 01 06 E9 E5 8C 27 F6 63
X: 3
SWB: 16 05 80 8D 02 EF F4 C9 F7 9F 0D CF F6 12 05 F1 E9 25 26 42 00 F6 80 E8 26 06 80 F4 CD 80 15 82 01 F7 F4 21
X: 3
SWB: 16 05 A0 8D 86 11 F7 98 3E 24 41 00 F6 80 E8 24 49 00 E6 59 00 90 46 26 42 00 F6 80 E8 26 06 80 01 88 02 F3
X: 3
SWB: 16 05 C0 8D E9 E2 8C 35 F6 23 F4 CB F5 02 EF F4 C9 F5 9F 0D CF F6 12 04 F1 E9 24 F4 CC 80 14 82 05 F5 F4 25
X: 3
SWB: 16 05 E0 8D 88 F6 51 E5 73 30 B2 E2 9C 43 03 C1 04 C3 E9 23 EA 34 13 C1 14 C3 7C 98 51 E5 73 B0 BA E2 02 F7
X: 3
SWB: 16 05 00 8E E5 75 50 B4 E4 EA 21 02 EF 9C 43 03 C1 04 C3 E9 23 EA 34 13 C1 14 C3 26 42 00 F6 80 E8 26 06 80
X: 3
SWB: 16 05 20 8E 01 82 02 ED E9 E2 80 09 F4 C9 80 11 82 6C 01 98 19 06 CF 16 EB 01 F9 11 FB 15 F7 02 F3 12 F5 04
X: 3
SWB: 16 05 40 8E ED 14 F1 05 E3 15 E9 9B 5C 8B 01 C1 02 C3 24 10 27 35 9C 4A 24 42 00 F6 80 E8 24 04 00 11 04 25
X: 3
SWB: 16 05 60 8E 42 00 F6 80 E8 25 98 10 31 26 42 00 F6 80 E8 26 06 80 11 84 11 82 6C 01 A6 C2 A5 4A 2F 2E 2D 9A
X: 3
SWB: 16 05 80 8E 3D 3E 3F A7 0D 11 C7 12 C9 13 CB 9F 28 03 52 C4 31 11 C2 36 98 48 E0 83 C4 53 C4 A6 36 02 C9 01
X: 3
SWB: 16 05 A0 8E C7 9F 5E 9C F6 15 02 CB 9F 93 9B 11 C5 77 46 C4 02 CB F6 51 9F F7 9F 11 C0 44 D5 D4 00 90 15 44
X: 3
SWB: 16 05 C0 8E C4 F6 51 9F 76 82 23 E8 03 F6 12 01 C0 9F 0D CF E9 26 98 03 F4 26 C0 04 C2 F4 24 C5 14 C2 49 C4
X: 3
SWB: 16 05 E0 8E E6 59 00 87 B1 F6 61 9F 66 9F 02 C2 04 D3 12 00 11 02 A5 0D 2F 2E 2D 9A 3D 3E 3F A7 08 F6 86 24
X: 3
SWB: 16 05 00 8F 00 4E 40 04 C0 04 90 87 A1 00 D3 90 82 02 21 33 24 9E 03 42 03 B7 52 80 76 B7 52 84 1A 42 02 B6
X: 3
SWB: 16 05 20 8F 52 80 6C B6 52 84 10 42 01 B5 52 80 62 B5 52 84 06 42 00 B4 52 80 58 25 9A 03 62 01 A2 20 3E 03
X: 3
SWB: 16 05 40 8F 40 24 5C 03 02 00 21 24 04 9F 80 8E 24 F7 04 02 06 01 82 9F 86 83 9F 46 82 02 40 E9 C2 24 5C 03
X: 3
SWB: 16 05 60 8F 12 3C 24 00 4E AB 05 21 15 84 31 11 86 25 9E 03 40 40 E0 50 21 84 18 42 41 E0 52 85 84 11 42 42
X: 3
SWB: 16 05 80 8F E0 52 86 84 0A 42 43 E0 52 87 84 03 A4 DB 03 A8 2F 2E 2D 9A 3F 62 01 A2 20 F7 44 04 24 9A 03 03
X: 3
SWB: 16 05 A0 8F 00 24 5C 03 02 00 21 24 04 9F 80 8E AB 2F 9A 3D 3E 3F A7 07 31 11 C4 24 9A 03 01 00 11 C2 31 11
X: 3
SWB: 16 05 C0 8F C0 9F 28 03 52 C6 26 3C 04 98 0F 01 80 EE 96 EE 96 02 C2 9F 93 9B E9 25 15 C0 43 C6 B3 82 52 C6
X: 3
SWB: 16 05 E0 8F 05 C0 D3 00 87 E5 9F 28 03 A6 24 F6 51 75 9C 48 11 C0 73 53 C6 F6 81 9F 24 9C AF 2F 2E 2D 9A 3D
X: 3
SWB: 16 05 00 90 3E 3F A7 07 F6 16 12 C2 24 46 43 01 15 11 C4 9F 28 03 52 C6 98 32 B2 82 A6 2A 7B ED 64 20 46 43
X: 3
SWB: 16 05 20 90 E8 24 02 0D 12 C0 A1 00 D4 C0 08 90 0E 24 B8 03 04 00 14 C0 24 BA 03 04 00 14 C4 52 C6 F6 81 9F
X: 3
SWB: 16 05 40 90 24 9C ED 64 EE 24 11 00 42 C6 87 CA AF 2F 2E 2D 9A 3D 3F A7 14 60 08 F3 D4 22 A6 0B F6 81 9F FF
X: 3
SWB: 16 05 60 90 8F F6 80 10 D2 31 11 C8 F6 82 21 46 43 9F F9 87 11 CA 74 F6 81 E6 22 08 B3 D3 9F 81 86 24 C0 4B
X: 3
SWB: 16 05 80 90 25 80 4D A1 00 D0 C0 08 90 0A 46 00 77 22 0A 00 01 42 98 08 46 00 77 22 0A 00 01 40 9F 0D CF E9
X: 3
SWB: 16 05 A0 90 B1 11 CC 24 48 04 21 A6 0B 11 1E 60 10 F3 D4 23 01 00 F6 12 F6 81 E6 22 08 B3 D3 9F 67 89 A1 06
X: 3
SWB: 16 05 C0 90 D4 C6 E7 A3 D4 60 24 00 4E E0 60 04 80 1E 02 CA 24 46 43 F4 E2 25 94 14 01 CC F4 E1 27 94 0D F4
X: 3
SWB: 16 05 E0 90 E2 08 8C 08 A6 62 E6 12 04 A3 D4 20 02 CA 21 B4 03 9F 83 CA 02 CC 21 B6 03 9F 83 CA 60 BF F2 D4
X: 3
SWB: 16 05 00 91 A5 14 2F 2D 9A A2 A0 3F A7 0C E4 80 1D 84 07 A1 00 D5 C0 08 90 07 A1 00 D4 C0 01 84 0B 24 9A 03
X: 3
SWB: 16 05 20 91 02 00 21 3C 04 9F FF 8F 74 F6 81 9F 81 86 21 3C 04 11 CA 32 12 C0 F6 12 21 46 43 9F 51 88 11 C2
X: 3
SWB: 16 05 40 91 B3 60 88 03 7A 98 0B 22 24 04 12 CA E9 B1 11 C2 6A 01 23 01 01 24 9A 03 02 00 F6 81 9F 67 89 D2
X: 3
SWB: 16 05 60 91 00 84 09 24 00 4E 40 02 C0 02 84 0A A1 02 D5 C2 FB A3 D5 20 98 10 A1 02 D5 E6 12 04 A3 D5 20 02
X: 3
SWB: 16 05 80 91 C2 01 CA 9F 9A 88 01 C4 24 5C 03 11 30 02 C2 12 2E E6 5A 00 90 08 E9 B1 11 30 EA B1 11 2E A5 0C
X: 3
SWB: 16 05 A0 91 2F A0 0A 9A 3D 3F 24 9C 03 25 9A 03 01 40 F4 C9 00 9C 3A 74 24 B3 4B F4 E1 00 94 02 64 01 A6 42
X: 3
SWB: 16 05 C0 91 2F 2D 9A 3D 3E 3F A7 06 F6 16 12 C4 E4 A0 1D 84 37 30 E8 E1 8C 45 24 00 4E 40 00 C0 40 90 29 40
X: 3
SWB: 16 05 E0 91 01 C0 04 90 23 9F 28 03 73 98 15 B2 82 A6 2A 7B 20 84 04 E8 25 E0 A0 51 90 06 63 FF 53 51 63 01
X: 3
SWB: 16 05 00 92 D2 00 87 E7 D3 00 84 F2 F9 60 84 0F 24 00 4E 01 0D 24 5C 03 F4 21 2A B3 60 88 CD 24 00 4E F4 CE
X: 3
SWB: 16 05 20 92 0D 16 C0 01 C4 F4 C9 0F 11 C2 66 04 F6 82 21 FC 03 9F 5B CA 25 5C 03 A1 00 D5 C0 04 84 14 01 6E
X: 3
SWB: 16 05 40 92 F4 21 C0 F4 21 40 11 C0 01 70 F4 21 C2 F4 21 42 98 2D 9F 28 03 A6 24 21 3C 04 9F 21 CE F6 13 0A
X: 3
SWB: 16 05 60 92 CA 24 46 43 01 08 9F F1 87 11 C0 03 6E 02 70 9F 0D CF 02 C0 24 00 4E F4 CA 0D 12 C0 F4 C9 0F 11
X: 3
SWB: 16 05 80 92 C2 E0 60 C1 80 03 31 11 C0 E0 60 C3 80 03 34 14 C2 66 04 F6 82 21 00 04 9F 5B CA 62 01 9F 0F 98
X: 3
SWB: 16 05 A0 92 A1 00 D0 C0 40 84 41 66 04 22 00 04 21 8E 03 9F 5B CA 66 04 22 FC 03 21 86 03 9F 5B CA 24 00 4E
X: 3
SWB: 16 05 C0 92 40 04 C0 01 90 1C 24 5C 03 01 2A 30 E8 E1 8C 12 24 94 07 40 09 D0 01 94 09 A1 02 D5 E6 12 01 A3
X: 3
SWB: 16 05 E0 92 D5 20 32 62 01 9F E5 7F A1 02 D4 CA 03 D0 01 90 09 22 8E 03 21 86 03 9F CD 80 AE 2F 2E 2D 9A 3D
X: 3
SWB: 16 05 00 93 3E 3F A7 0C 26 F7 04 01 98 11 C4 9F 28 03 A6 27 24 88 4B 07 00 25 00 4E 02 53 12 CA 01 55 11 C8
X: 3
SWB: 16 05 20 93 24 8D 4B 02 00 12 C6 40 44 C0 01 90 56 04 82 A6 72 73 02 CA 9C 42 EF 21 E9 E4 94 11 40 41 C0 02
X: 3
SWB: 16 05 40 93 90 14 F6 21 F4 21 C6 02 C4 E9 E2 8C 09 A1 02 D5 E6 12 01 A3 D5 20 A6 72 73 02 C8 9C 42 F6 72 E9
X: 3
SWB: 16 05 60 93 C2 EA E4 94 14 24 00 4E 40 01 C0 02 90 52 01 C6 F4 C9 C8 02 C4 E9 E2 8C 47 A1 02 D5 C2 FE A3 D5
X: 3
SWB: 16 05 80 93 20 98 26 01 82 EF E1 94 0D 40 41 C0 02 90 2B 01 98 F4 E1 C6 8C 24 25 68 04 42 58 24 8A 4B E0 52
X: 3
SWB: 16 05 A0 93 00 88 06 B2 92 52 58 98 17 64 04 F6 81 9C 38 01 C0 02 C2 9F C3 91 62 01 98 07 24 68 04 75 55 18
X: 3
SWB: 16 05 C0 93 72 A5 0C 2F 2E 2D 9A 3D 3F A7 0C 60 20 F3 D4 25 9A 03 24 9C 03 01 40 11 00 E4 A0 D3 90 03 32 98
X: 3
SWB: 16 05 E0 93 1A 73 24 9E 03 42 00 E0 12 01 E0 12 02 E0 12 03 D2 00 84 02 63 01 E6 43 01 A6 34 F6 81 9F 81 86
X: 3
SWB: 16 05 00 94 21 24 04 11 CA F6 12 21 46 43 9F F9 87 11 C2 25 5C 03 01 40 11 C0 23 00 01 24 9C 03 02 00 F6 81
X: 3
SWB: 16 05 20 94 9F 67 89 02 C2 30 E8 E2 94 08 F4 22 40 01 CA 9F 9A 88 A1 06 CC 24 5C 03 02 00 21 24 04 9F 5E 9C
X: 3
SWB: 16 05 40 94 0A CA 90 0D EA E1 94 09 24 00 4E 40 02 C0 02 84 06 05 C2 03 C4 98 16 F6 13 24 46 43 01 08 9F F1
X: 3
SWB: 16 05 60 94 87 F6 15 24 88 4B 02 00 9F B0 CB F6 13 F6 32 F6 51 9F C3 91 24 5C 03 63 01 53 0E A5 0C 2F 2D 9A
X: 3
SWB: 16 05 80 94 3F A1 02 DB 84 03 72 98 0F CA 02 90 03 9F 05 91 9F C7 93 A4 DB 00 62 01 2F 9A 3D 3E 3F A7 02 A6
X: 3
SWB: 16 05 A0 94 23 72 52 C0 24 46 43 42 0C CA 03 D0 02 90 04 62 01 52 C0 D3 00 90 15 9F A2 9E 25 00 4E D2 00 90
X: 3
SWB: 16 05 C0 94 07 44 5A 72 52 C0 98 9D 44 5B 98 99 25 00 4E 42 5D 52 C1 24 5C 03 01 28 32 3A 39 42 C5 73 9C 45
X: 3
SWB: 16 05 E0 94 AC F6 16 F6 27 F7 00 00 F7 80 0C 42 5C 73 32 9C 45 AC F6 13 F6 24 F6 61 F6 72 F6 45 F6 34 9C 4B
X: 3
SWB: 16 05 00 95 D5 00 84 0C D4 00 84 08 D3 00 84 04 D2 64 94 04 6C 64 98 02 A6 2C 23 64 00 44 C1 75 25 46 43 24
X: 3
SWB: 16 05 20 95 80 43 01 00 F4 C9 4A 9F 78 CF A6 CA 7B ED 51 94 0D 20 64 00 E8 51 94 04 6C 64 98 02 A6 2C 42 C0
X: 3
SWB: 16 05 40 95 D2 00 84 0A 24 00 4E A6 C4 E0 24 1A 98 17 25 00 4E 24 46 43 42 0C CA 03 D0 01 84 07 A6 C4 E0 24
X: 3
SWB: 16 05 60 95 5B 98 02 44 59 24 00 4E E0 54 18 80 06 60 80 F3 CD 98 04 60 7F F2 CD 21 9C 07 9F 79 CA 42 C0 AA
X: 3
SWB: 16 05 80 95 2F 2E 2D 9A 3D A2 D0 3F A7 02 11 C0 F6 25 A6 6D 24 5C 03 02 00 21 24 04 9F 5E 9C 77 A6 D6 F6 52
X: 3
SWB: 16 05 A0 95 9F F7 9F 23 E8 03 F6 12 01 C0 9F 0D CF AA 2F A0 0D 2D 9A 3D 3F A6 2B A6 3A A6 24 21 9D 07 9F 79
X: 3
SWB: 16 05 C0 95 CA A6 A4 21 9E 07 9F 79 CA 24 F7 04 01 16 24 80 4D 45 08 DD 00 88 05 E0 5B 23 94 0C CD 20 90 0E
X: 3
SWB: 16 05 E0 95 24 80 4D F4 E1 20 8C 06 60 F7 F2 CD 98 1C CD 40 90 08 24 80 4D E0 5B 22 88 0C CD 10 90 0C 24 80
X: 3
SWB: 16 05 00 96 4D F4 E1 1E 80 04 60 08 F3 CD 24 80 4D 44 0A DC 00 88 05 E0 5B 17 94 0C CC 20 90 0E 24 80 4D F4
X: 3
SWB: 16 05 20 96 E1 14 8C 06 60 FD F2 CD 98 1C CC 40 90 08 24 80 4D E0 5B 16 88 0C CC 10 90 0C 24 80 4D F4 E1 12
X: 3
SWB: 16 05 40 96 80 04 60 02 F3 CD 24 F7 04 01 18 CD 08 90 08 24 80 4D E0 5B 1D 88 0C CD 02 90 0E 24 80 4D F4 E1
X: 3
SWB: 16 05 60 96 1A 80 06 60 FB F2 CD 98 1C CD 04 90 08 24 80 4D E0 5B 1C 94 0C CD 01 90 0C 24 80 4D F4 E1 18 8C
X: 3
SWB: 16 05 80 96 04 60 04 F3 CD CC 08 90 08 24 80 4D E0 5B 11 88 0C CC 02 90 0E 24 80 4D F4 E1 0E 80 06 60 FE F2
X: 3
SWB: 16 05 A0 96 CD 98 1C CC 04 90 08 24 80 4D E0 5B 10 94 0C CC 01 90 0C 24 80 4D F4 E1 0C 8C 04 60 01 F3 CD 2F
X: 3
SWB: 16 05 C0 96 2D 9A 3D 3E 3F A7 06 12 C0 24 99 04 05 04 ED E1 94 02 F6 51 24 99 04 11 04 30 E8 E5 94 A0 F4 C9
X: 3
SWB: 16 05 E0 96 C0 A6 30 A6 14 A6 15 9C 52 F7 48 43 F7 00 00 9C 46 AC F6 16 F6 27 F6 51 F4 C9 C0 A6 30 A6 14 A6
X: 3
SWB: 16 05 00 97 15 9C 52 3A 39 F6 61 F6 72 9C 4C AC F7 3B 45 F7 00 80 9C 40 AC F7 A0 C1 F7 00 00 9C 46 AC F7 6A
X: 3
SWB: 16 05 20 97 47 F7 00 60 9C 40 AC F7 84 45 F7 00 08 9C 40 AC 9C 3E F7 A0 40 F7 00 00 9C 46 AC F7 A2 43 F7 00
X: 3
SWB: 16 05 40 97 80 9C 41 AC 24 99 04 05 00 06 02 F7 48 C2 F7 00 00 9C 4C AC 3E 3D 9C 46 AC F7 A0 40 F7 00 00 9C
X: 3
SWB: 16 05 60 97 4C AC 11 C2 12 C4 3A 39 F6 51 F6 62 9C 54 AC DA 00 94 04 05 C2 06 C4 24 99 04 15 00 16 02 24 99
X: 3
SWB: 16 05 80 97 04 01 00 02 02 AE 2F 2E 2D 9A 3D 3E 3F A7 0A F7 C8 42 F7 00 00 9C 4C AC 11 C2 12 C4 25 5C 03 07
X: 3
SWB: 16 05 A0 97 40 F4 27 6E 06 42 F4 26 70 3A 39 31 22 80 3F 9C 41 AC 11 C6 12 C8 F6 71 A6 30 A6 14 A6 15 9C 52
X: 3
SWB: 16 05 C0 97 3A 39 01 C6 02 C8 9C 46 AC 03 C6 04 C8 3C 3B 9C 4C AC 9D 27 D9 11 C0 11 6A F6 61 A6 30 A6 14 A6
X: 3
SWB: 16 05 E0 97 15 9C 52 3A 39 01 C6 02 C8 9C 46 AC 03 C6 04 C8 3C 3B 9C 4C AC 9D 27 D9 11 6C F4 27 C0 17 72 E9
X: 3
SWB: 16 05 00 98 26 16 74 32 62 01 9F E5 7F A5 0A 2F 2E 2D 9A 3D 3E 3F A7 04 D2 00 90 16 24 FC 03 01 00 24 99 04
X: 3
SWB: 16 05 20 98 30 E8 E1 8C 06 62 01 52 06 98 03 73 53 06 24 F7 04 06 02 24 88 4B 01 00 11 C2 24 00 4E 01 1F 9F
X: 3
SWB: 16 05 40 98 FD 9A 11 C0 24 00 4E 40 05 C0 02 90 0A E4 A0 1D 84 05 F4 E6 C2 8C 10 A1 02 D0 C2 BF A3 D0 20 24
X: 3
SWB: 16 05 60 98 99 04 31 11 04 98 5C A1 02 D0 CA 40 84 44 9F B6 82 25 99 04 73 32 9C 53 11 40 12 42 16 44 40 46
X: 3
SWB: 16 05 80 98 90 08 A1 02 D0 E6 12 40 98 36 F4 E6 C0 88 34 66 01 24 00 04 02 00 24 FC 03 01 00 9F 71 CB 24 00
X: 3
SWB: 16 05 A0 98 4E 43 1E B2 53 94 1C A1 02 D0 E6 12 40 A3 D0 20 98 22 F4 E6 C0 94 0C 24 99 04 40 06 84 05 C2 BF
X: 3
SWB: 16 05 C0 98 A3 D0 20 A1 00 D0 C0 40 90 0A 02 C2 F6 61 9F C2 96 9F 8A 97 AC 2F 2E 2D 9A 3D 3E 3F 25 80 4D 26
X: 3
SWB: 16 05 E0 98 00 4E D2 00 90 13 24 B6 03 01 00 02 42 E0 60 84 80 1E 24 46 43 03 27 98 11 24 B4 03 01 00 02 40
X: 3
SWB: 16 05 00 99 E0 60 84 80 0B 24 46 43 03 25 EA E3 80 02 F6 32 FB 90 0B 9F 5C CB A6 24 21 9F 07 9F 79 CA 2F 2E
X: 3
SWB: 16 05 20 99 2D 9A 3D 3F F6 25 D2 00 84 2F 23 0C 00 22 86 03 F6 51 9C 3F 24 9C 03 01 00 11 4C 24 5C 03 01 3C
X: 3
SWB: 16 05 40 99 11 4E 23 08 00 22 84 04 F6 51 E6 22 10 B3 D3 9C 3F 23 08 00 22 34 04 98 58 D2 01 84 61 24 A7 03
X: 3
SWB: 16 05 60 99 43 00 53 40 24 46 43 42 0C 52 41 24 04 04 43 00 53 42 42 03 52 43 43 06 53 44 42 09 52 45 24 9E
X: 3
SWB: 16 05 80 99 03 01 00 02 02 11 46 66 10 9C 4F 11 48 23 08 00 22 24 04 F6 51 E6 22 0A B3 D3 9C 3F 23 06 00 22
X: 3
SWB: 16 05 A0 99 5C 03 F6 51 E6 22 12 B3 D3 9C 3F 23 08 00 22 3C 04 F6 51 E6 22 18 B3 D3 9C 3F 62 20 98 6E D2 02
X: 3
SWB: 16 05 C0 99 84 3F 23 08 00 22 46 43 F6 51 9C 3F 23 08 00 22 2C 04 F6 51 E6 22 08 B3 D3 9C 3F 23 04 00 22 6B
X: 3
SWB: 16 05 E0 99 03 F6 51 E6 22 10 B3 D3 9C 3F 23 04 00 22 62 04 F6 51 E6 22 14 B3 D3 9C 3F 23 08 00 22 1C 04 99
X: 3
SWB: 16 05 00 9A B0 D2 03 84 07 F6 21 9F 51 BC 98 20 D2 04 84 0E 23 04 00 22 B4 03 F6 51 9C 3F 62 04 98 0E D2 05
X: 3
SWB: 16 05 20 9A 90 03 72 98 07 F6 21 9F DE 7E 62 08 2F 2D 9A A1 00 DC 84 19 A1 02 AB CA 0C 90 12 FC 60 24 A0 04
X: 3
SWB: 16 05 40 9A F4 90 00 10 00 30 F4 38 02 10 02 FC 50 9A 3D F6 15 24 A0 04 01 00 02 02 11 40 12 42 02 08 12 44
X: 3
SWB: 16 05 60 9A 62 06 2D 9A 3F FC 60 64 0A 21 A0 04 9C 38 FC 50 2F 9A 3D 3F F6 15 FC 60 01 44 E6 23 80 11 44 42
X: 3
SWB: 16 05 80 9A 43 E6 22 80 52 43 00 C6 38 00 C6 38 F6 51 9F 83 D6 01 44 E6 23 80 11 44 42 43 E6 22 80 52 43 FC
X: 3
SWB: 16 05 A0 9A 50 AC 2F 2D 9A 3D 3E 3F F6 15 F6 26 A1 00 AB E7 08 20 A6 1E E6 0E 01 F7 00 00 F7 00 00 9C 54 AC
X: 3
SWB: 16 05 C0 9A DA 00 80 04 A6 E2 98 0A A1 00 AB E7 08 40 A6 12 C2 01 A1 00 DC 84 0D D2 00 90 09 3E 3D 21 A4 04
X: 3
SWB: 16 05 E0 9A 9F 72 9A AC 24 A0 04 02 08 24 00 51 F4 E2 00 80 06 72 F4 E2 02 94 02 62 01 2F 2E 2D 9A 3D 3F F6
X: 3
SWB: 16 05 00 9B 15 9F 28 03 A6 24 F6 51 75 9C 42 2F 2D 9A 3F FC 60 73 E9 61 E9 61 20 9B 01 E8 21 9F 2B CC FC 50
X: 3
SWB: 16 05 20 9B 2F 9A 3F FC 60 21 BB 01 9F 2B CC FC 50 2F 9A 3F FC 60 73 E9 61 E9 61 20 AB 01 E8 21 9F 2B CC FC
X: 3
SWB: 16 05 40 9B 50 2F 9A 3D 3E A7 02 11 C0 F6 14 01 00 84 03 74 98 09 20 FF 3F E8 E1 94 05 64 27 35 98 0D 22 27
X: 3
SWB: 16 05 60 9B 00 9C 43 F6 15 66 0E 9C 4E A6 24 21 FF 3F ED 01 04 C0 11 00 A6 42 AA 2E 2D 9A 74 24 40 4B 01 26
X: 3
SWB: 16 05 80 9B 24 52 4A F4 21 00 24 F7 04 F4 E1 18 8C 02 64 01 A6 42 9A 3D 3E 3F A7 04 F6 25 11 C0 F6 81 9F 43
X: 3
SWB: 16 05 A0 9B 9B A6 2E 7F EF 66 02 C0 F6 61 20 02 4A E8 21 9F BE 9C 11 C2 02 C0 F6 61 20 56 4A E8 21 9F BE 9C
X: 3
SWB: 16 05 C0 9B F6 52 20 54 F5 E8 22 9C 43 66 0F 20 00 40 E8 21 30 E8 32 9C 4E F4 21 C2 AC 2F 2E 2D 9A 3D 3E 3F
X: 3
SWB: 16 05 E0 9B A7 04 F6 16 F6 25 02 42 9F 93 9B 11 C0 67 01 46 46 02 42 F6 61 9F F7 9F 11 C2 02 44 F6 81 9F 32
X: 3
SWB: 16 05 00 9C 83 F6 12 01 44 30 E8 E1 94 13 03 C0 24 AB 4B 04 00 F6 21 EB C1 EC E1 94 04 F6 42 EB 22 F6 21 AC
X: 3
SWB: 16 05 20 9C 2F 2E 2D 9A 3D 3E 3F F6 16 05 80 F6 12 31 9F DD 9B E9 E5 80 03 31 98 22 05 80 F6 62 21 00 40 9F
X: 3
SWB: 16 05 40 9C DD 9B E9 E5 8C 05 21 00 40 98 0F 3E 00 80 38 23 00 40 32 21 DD 9B 9F 54 CC AC 2F 2E 2D 9A 3D 3F
X: 3
SWB: 16 05 60 9C F6 27 A6 64 75 EA 64 F6 15 EC 25 05 40 20 46 43 E8 24 02 00 F6 71 9F 96 9C ED 21 B3 60 80 01 31
X: 3
SWB: 16 05 80 9C 2F 2D 9A 3F 66 20 22 22 4B 21 00 4A 9C 34 2F 9A 24 00 4A 01 00 9A 3D F6 25 66 0E A6 30 A6 14 A6
X: 3
SWB: 16 05 A0 9C 15 9C 4D F6 54 A6 90 A6 1A A6 1B 9C 4A 2D 9A 9C 43 66 0E 20 00 20 E8 21 30 E8 32 9C 4E 9A 3D 3F
X: 3
SWB: 16 05 C0 9C F6 14 05 00 01 02 ED C1 9F AF 9C ED 21 2F 2D 9A A6 27 A6 36 DD FF 80 18 D5 FF 84 18 D4 FF 80 10
X: 3
SWB: 16 05 E0 9C D4 FF 84 2C D3 80 80 08 D3 80 84 24 D2 00 84 20 21 01 80 9A DD 00 8C 14 D5 00 84 14 D4 00 84 0C
X: 3
SWB: 16 05 00 9D D3 7F 8C 08 D3 7F 84 08 D2 FE 94 04 21 FF 7F 9A A6 74 A6 65 F6 21 9A 3F F6 13 A6 70 A6 18 A6 19
X: 3
SWB: 16 05 20 9D F6 21 A6 30 A6 14 A6 15 EB 21 EC 32 9F D0 9C 2F 9A EA 21 80 03 21 FF FF 9A 73 E9 61 E9 61 E9 61
X: 3
SWB: 16 05 40 9D E9 61 E9 61 E9 61 20 40 41 E8 21 9A 3F 9F 39 9D F6 14 40 00 D0 55 90 03 E6 29 01 F6 41 2F 9A 3D
X: 3
SWB: 16 05 60 9D 3E 3F A7 02 11 C0 F6 14 01 00 84 03 74 98 09 20 FF 3F E8 E1 94 05 64 0E 35 98 37 20 C6 31 E8 E1
X: 3
SWB: 16 05 80 9D 8C 0C 22 09 00 9C 43 F6 15 F6 26 7E 98 19 22 3F 00 9C 43 66 01 20 07 C0 E8 21 20 F3 FF E8 32 9C
X: 3
SWB: 16 05 A0 9D 4E F6 15 F6 26 6E 07 66 0E F6 51 F6 62 9C 4E E5 24 2E 21 FF 3F ED 01 04 C0 11 00 A6 42 AA 2F 2E
X: 3
SWB: 16 05 C0 9D 2D 9A 75 20 A6 0B E8 E1 94 08 EA 61 20 A6 4A E8 21 9A EA 61 20 C4 4A E8 21 9A 73 E9 64 EC 64 20
X: 3
SWB: 16 05 E0 9D AA 04 E8 24 01 00 02 02 9A 3D 3E 3F F6 16 A6 42 73 E9 64 F6 45 20 40 50 E8 25 23 E8 03 20 F7 04
X: 3
SWB: 16 05 00 9E E8 24 02 1C 01 40 9F 0D CF F6 62 E9 C2 F6 21 B5 60 80 01 31 2F 2E 2D 9A 3F F6 23 22 E8 03 9F 0D
X: 3
SWB: 16 05 20 9E CF 2F 9A 3D 3E 3F A7 07 11 C0 12 C2 13 C4 F9 30 84 05 21 01 00 11 C4 E0 98 CD 98 19 A6 8C 7D EE
X: 3
SWB: 16 05 40 9E 65 F4 25 C0 03 C4 02 C2 01 40 58 C6 9F 0D CF 11 40 48 C6 B8 98 E6 58 0E 97 E2 AF 2F 2E 2D 9A 3D
X: 3
SWB: 16 05 60 9E 3E 3F A7 07 11 C0 12 C2 49 CD 13 C4 F9 30 84 05 21 01 00 11 C4 25 40 4B E0 59 52 94 1B 98 1E B9
X: 3
SWB: 16 05 80 9E 89 A6 9C 7D EE 65 F4 25 C0 03 C4 02 C2 01 40 59 C6 9F 0D CF 11 40 49 C6 E6 59 00 87 E2 AF 2F 2E
X: 3
SWB: 16 05 A0 9E 2D 9A A2 A0 3F 9F 28 03 A6 2A 98 17 BA 8A A6 A2 9F 39 9D F6 14 40 00 D0 55 84 08 E0 A0 01 84 03
X: 3
SWB: 16 05 C0 9E 72 98 07 E6 5A 00 87 E4 62 01 2F A0 0A 9A 3D 3E 3F A7 0A 11 C4 A6 4D 24 90 4B 05 00 24 00 4E 42
X: 3
SWB: 16 05 E0 9E 02 CA 20 84 03 35 98 6A DA 00 88 66 9F 28 03 A6 2C 31 32 11 C0 12 C2 98 2B BC 8C A6 CE 7F EF 64
X: 3
SWB: 16 05 00 9F EC 64 20 AA 04 E8 24 02 00 03 02 12 C6 13 C8 3B 3A 01 C4 02 C6 9C 54 AC DA 00 88 08 03 C6 04 C8
X: 3
SWB: 16 05 20 9F 13 C0 14 C2 E6 5C 00 87 D0 F6 51 32 9C 53 03 C0 04 C2 3C 3B 9C 46 AC 9D 2A D9 24 96 4B 05 00 ED
X: 3
SWB: 16 05 40 9F 51 8C 0F 24 94 4B 02 00 F6 15 F6 20 E9 50 94 02 F6 25 E6 5D 00 84 07 F4 55 C4 94 02 05 C4 F6 51
X: 3
SWB: 16 05 60 9F A5 0A 2F 2E 2D 9A 3D 3E 3F A7 01 F6 16 9F 28 03 A6 26 98 19 B6 86 A6 6A 7B ED 64 20 40 50 E8 24
X: 3
SWB: 16 05 80 9F F6 62 01 00 56 C0 9F 17 9D F6 16 46 C0 D6 00 87 E3 F6 61 A9 2F 2E 2D 9A 3D 3F 25 40 43 F6 12 01
X: 3
SWB: 16 05 A0 9F 42 9F 17 9D F6 12 01 44 9F 17 9D 2F 2D 9A 3D 3F D2 07 8C 09 22 09 00 73 9F 96 9C 98 1F 73 E6 22
X: 3
SWB: 16 05 C0 9F F9 B3 C3 66 0E A6 30 A6 14 A6 15 9C 4D 66 01 9C 4D 24 3F 00 35 9C 4A 20 C7 31 E8 21 2F 2D 9A 3F
X: 3
SWB: 16 05 E0 9F 20 5A F4 E8 21 9C 43 9C 52 F7 80 37 F7 00 00 9C 46 AC 9F 27 D7 2F 9A 3D 3E 3F A7 07 11 C0 12 C4
X: 3
SWB: 16 05 00 A0 56 C6 A6 7A F6 81 9F 5F 9D A6 2C D2 00 84 0A E6 5A 00 84 05 31 11 C0 6C 01 42 C6 9F 4C 9D A6 CA
X: 3
SWB: 16 05 20 A0 7B ED 95 ED 65 02 C0 ED 21 9F BE 9C 11 C2 A6 C4 01 C4 9F C2 9D 02 C0 9F BE 9C F6 12 01 C4 9F DF
X: 3
SWB: 16 05 40 A0 9F F6 16 F6 27 4A C6 7B ED 64 EC 64 20 AA 04 E8 24 11 00 12 02 01 C2 A6 30 A6 14 A6 15 9C 52 3F
X: 3
SWB: 16 05 60 A0 3E 9C 46 AC 9D 27 D9 AF 2F 2E 2D 9A 3D 3E 3F A7 03 F6 16 54 C2 A6 42 9F 39 9D F6 15 40 40 D0 55
X: 3
SWB: 16 05 80 A0 84 20 40 41 90 15 62 55 52 81 52 80 42 C2 9F 39 9D 23 20 00 F6 62 9F E3 C5 98 3A 11 C0 E6 2B 01
X: 3
SWB: 16 05 A0 A0 98 05 E6 23 01 11 C0 F6 51 9F 8A C5 66 1E EE 92 EA 92 ED 91 E9 91 9F A2 C5 73 53 81 62 55 52 80
X: 3
SWB: 16 05 C0 A0 66 02 F6 62 F6 51 9F A2 C5 73 53 80 66 02 F6 62 01 C0 9F A2 C5 A1 00 D0 E7 08 40 A6 13 C3 01 E6
X: 3
SWB: 16 05 E0 A0 43 01 A1 02 D0 C2 FB E7 38 04 C0 04 B0 12 A3 D0 20 AB 2F 2E 2D 9A 3D 3F A7 02 A6 2B 62 55 52 C0
X: 3
SWB: 16 05 00 A1 5B C1 9F 28 03 A6 2A 98 26 BA 8A A6 A2 9F 39 9D F6 14 42 01 BB 52 90 17 40 00 D0 55 84 11 D2 55
X: 3
SWB: 16 05 20 A1 90 04 D2 05 84 09 66 02 F6 82 F6 41 9F A2 C5 E6 5A 00 87 D5 AA 2F 2D 9A D2 00 84 04 21 42 43 9A
X: 3
SWB: 16 05 40 A1 D2 01 84 04 21 44 43 9A D2 02 90 02 31 9A 21 01 47 9A 3F 23 64 00 F6 12 24 80 4D 01 00 9F 0D CF
X: 3
SWB: 16 05 60 A1 2F 9A 3D 3F F6 35 E9 C2 F6 21 30 E8 E2 8C 0F 03 C4 22 E8 03 9F 0D CF F6 52 9F 17 9D F6 15 F6 51
X: 3
SWB: 16 05 80 A1 2F 2D 9A 3D 3F A7 0C F6 15 A1 00 D0 E7 08 20 A6 13 C3 01 24 00 4E 42 06 9F DF 85 11 C4 F6 82 F6
X: 3
SWB: 16 05 A0 A1 51 9F 02 87 A5 0C 2F 2D 9A 3D 3E 3F A7 02 12 C0 24 E4 4A 02 00 20 A6 0B E8 E1 94 05 24 E2 4A 02
X: 3
SWB: 16 05 C0 A1 00 9F DF 9F F6 15 F6 26 24 00 47 01 07 A6 30 A6 14 A6 15 9C 52 3E 3D 9C 46 AC 9D 27 D9 F6 15 9F
X: 3
SWB: 16 05 E0 A1 28 03 A6 24 F6 51 75 9C 42 F4 E1 C0 94 02 01 C0 AA 2F 2E 2D 9A 3D 3E 3F A7 12 12 CA 13 CC 11 C0
X: 3
SWB: 16 05 00 A2 F6 81 9F 5F 9D A6 2C 02 C0 24 00 47 42 0C B2 5C 88 04 A6 C2 98 01 32 73 E9 61 20 E6 4A E8 21 9F
X: 3
SWB: 16 05 20 A2 BE 9C 11 C6 A6 CA 7B ED 65 02 C0 F6 51 20 04 4B E8 21 9F BE 9C 11 C4 05 C0 A6 C4 01 CA 9F C2 9D
X: 3
SWB: 16 05 40 A2 F6 52 9F BE 9C 11 C8 E6 5C 00 84 05 31 11 C0 6C 01 01 C0 11 C2 42 D8 9F 4C 9D A6 CA 7B ED 95 ED
X: 3
SWB: 16 05 60 A2 65 02 C2 ED 21 9F BE 9C A6 30 A6 14 A6 15 9C 52 9D 2A D9 F6 12 24 00 47 42 0A 73 9F 94 CB A6 30
X: 3
SWB: 16 05 80 A2 A6 14 A6 15 9C 52 11 CE 12 D0 02 C8 F4 22 C4 01 CA 9F DF 9F F6 15 F6 26 01 C6 A6 30 A6 14 A6 15
X: 3
SWB: 16 05 A0 A2 9C 52 F7 00 38 F7 00 00 9C 46 AC 3A 39 01 D2 02 D4 9C 46 AC 3E 3D 9C 46 AC 9F A6 CE F4 E1 CC 94
X: 3
SWB: 16 05 C0 A2 02 01 CC A5 12 2F 2E 2D 9A 3D 3E 3F A7 56 F6 86 24 51 00 EE 24 52 00 64 38 F6 61 E6 22 14 B3 D3
X: 3
SWB: 16 05 E0 A2 9C 38 24 5C 03 05 00 24 F7 04 01 02 24 52 00 EE 24 11 00 24 94 07 02 06 24 00 47 42 09 73 9F 94
X: 3
SWB: 16 05 00 A3 CB 24 52 00 EE 24 03 00 22 10 27 9F 0D CF E9 25 15 A0 25 00 47 40 40 C0 01 90 0E 24 9A 03 01 00
X: 3
SWB: 16 05 20 A3 25 4C 00 EE 25 11 40 98 0A 9F 22 9B 24 4C 00 EE 24 11 00 72 A2 20 3E 25 4C 00 EE 25 03 40 02 A0
X: 3
SWB: 16 05 40 A3 21 24 04 9F E5 88 25 00 47 02 82 42 4A 73 9F 94 CB 11 82 9F 66 9F 11 82 F6 61 9F 83 A1 11 A2 F6
X: 3
SWB: 16 05 60 A3 12 F6 61 9F 32 83 11 AC 01 82 9F 98 9F 11 82 02 A2 F6 61 9F 32 83 F6 64 20 42 00 E8 24 22 01 80
X: 3
SWB: 16 05 80 A3 12 00 F6 64 20 40 00 E8 24 12 00 F6 64 20 3E 00 E8 24 12 00 12 BC 11 AE 9F 28 03 24 4E 00 EE 24
X: 3
SWB: 16 05 A0 A3 52 00 9B A9 A4 25 4E 00 EE 25 E0 82 40 52 40 24 4F 00 EE 24 52 00 72 25 50 00 EE 25 52 40 24 4F
X: 3
SWB: 16 05 C0 A3 00 EE 24 F4 65 00 F6 64 ED 24 02 0C 24 00 47 42 0A 73 9F 94 CB F6 64 ED 24 11 0C F6 12 24 00 47
X: 3
SWB: 16 05 E0 A3 42 0B 73 9F 94 CB 24 52 00 EE 24 11 00 24 4E 00 EE 24 46 00 02 A0 21 24 04 9F 5E 9C 24 4E 00 EE
X: 3
SWB: 16 05 00 A4 24 49 00 A2 90 24 52 00 EE 24 03 00 24 4C 00 EE 24 02 00 9F F5 A1 F6 62 ED 22 24 54 00 EE 24 12
X: 3
SWB: 16 05 20 A4 00 F6 24 11 30 F6 51 20 40 50 E8 21 24 52 00 EE 24 11 00 24 54 00 EE 24 04 00 02 0C F6 14 01 00
X: 3
SWB: 16 05 40 A4 9F 17 9D F6 64 ED 24 11 0C 24 4E 00 EE 24 46 00 02 A2 F6 61 9F 17 83 F6 62 ED 22 24 54 00 EE 24
X: 3
SWB: 16 05 60 A4 12 00 F6 24 11 24 24 52 00 EE 24 04 00 02 00 24 54 00 EE 24 04 00 01 30 9F 17 9D F6 62 ED 22 24
X: 3
SWB: 16 05 80 A4 54 00 EE 24 12 00 39 03 A2 24 8D 4B 02 00 24 54 00 EE 24 04 00 01 24 9F 62 A1 F6 64 ED 24 11 3C
X: 3
SWB: 16 05 A0 A4 02 B8 01 30 9F 17 9D 11 B8 AB 25 4E 00 EE 25 4B 40 E6 5B 00 86 EF 02 B8 24 00 47 42 0B 73 9F 94
X: 3
SWB: 16 05 C0 A4 CB F6 12 25 4C 00 EE 25 01 40 9F A9 A1 F6 64 20 48 00 E8 24 11 00 01 B8 9F 66 9F 11 B8 9F 98 9F
X: 3
SWB: 16 05 E0 A4 11 BA F6 64 20 48 00 E8 24 01 00 9F 66 9F F6 64 20 4A 00 E8 24 11 00 9F 98 9F 11 9C 00 BA 38 03
X: 3
SWB: 16 05 00 A5 A2 24 00 47 02 01 01 AE 9F 62 A1 F6 64 20 46 00 E8 24 11 00 00 B8 38 03 A2 24 88 4B 02 00 01 AC
X: 3
SWB: 16 05 20 A5 9F 62 A1 F6 64 20 44 00 E8 24 11 00 25 F7 04 23 E8 03 F6 64 20 4A 00 E8 24 02 00 01 44 9F 0D CF
X: 3
SWB: 16 05 40 A5 E9 B2 01 42 9F 17 9D 11 9E AC 24 46 43 40 0C C0 08 90 1D 20 01 80 F4 C8 A2 90 AD 24 94 07 40 09
X: 3
SWB: 16 05 60 A5 90 A6 25 51 00 EE 25 4B 40 E6 5B 00 84 9A 98 07 31 11 9C 11 9E 98 91 64 06 F6 61 E6 22 3C B3 D3
X: 3
SWB: 16 05 80 A5 9F 21 CE 11 98 24 00 47 01 03 9F 52 A1 F6 12 01 98 EA E1 88 02 12 98 05 AE 23 E8 03 02 BA 01 98
X: 3
SWB: 16 05 A0 A5 F4 C9 A2 9F 0D CF F6 52 9F 17 9D F6 15 23 10 27 02 98 9F 0D CF 11 94 03 98 F6 64 20 46 00 E8 24
X: 3
SWB: 16 05 C0 A5 00 00 EB C0 84 04 13 9A 98 10 00 9C 38 24 00 47 02 01 F6 51 9F 62 A1 11 9A AA 24 00 47 01 05 9F
X: 3
SWB: 16 05 E0 A5 52 A1 F6 12 01 9A EA E1 88 02 12 9A 23 E8 03 02 9C 01 9A F4 C9 98 9F 0D CF F6 52 9F 17 9D 23 10
X: 3
SWB: 16 05 00 A6 27 02 9A 9F 0D CF 11 96 66 38 F6 62 E6 24 14 B5 D5 21 BC 03 9F 5B CA A5 56 2F 2E 2D 9A 3D 25 80
X: 3
SWB: 16 05 20 A6 50 40 40 C0 08 90 07 24 F7 04 02 16 98 09 24 94 07 44 09 75 42 49 73 76 E9 E2 80 02 66 01 A6 62
X: 3
SWB: 16 05 40 A6 2D 9A 3D F6 12 24 00 46 42 0A CA 02 90 05 24 DC 50 02 00 CA 01 90 0C 24 46 02 42 02 C2 EF E6 12
X: 3
SWB: 16 05 60 A6 20 98 1D 25 80 50 40 40 C0 01 90 18 24 00 46 01 00 F4 51 47 80 0E 24 46 02 42 02 E6 12 10 C2 DF
X: 3
SWB: 16 05 80 A6 52 02 98 07 24 46 02 60 EF F0 02 F6 21 2D 9A 3D 3E F6 16 24 00 46 40 0A C0 02 84 A1 A1 07 DD DF
X: 3
SWB: 16 05 A0 A6 01 8C 21 A6 72 E9 09 E9 91 22 18 00 9C 42 F6 15 20 90 50 E8 25 24 F7 04 01 32 F4 E1 40 80 05 B7
X: 3
SWB: 16 05 C0 A6 92 A3 DD 20 A1 07 DD 90 25 A6 72 E9 09 22 18 00 9C 42 F6 15 20 80 50 E8 25 24 D6 50 01 50 F4 C9
X: 3
SWB: 16 05 E0 A6 00 24 F7 04 F4 E1 32 94 05 B7 82 A3 DD 20 A1 07 DD 72 22 10 00 98 0C EA 62 EA 62 EA 62 EA 62 EA
X: 3
SWB: 16 05 00 A7 62 B2 92 E5 E0 72 83 EF 24 00 46 04 0B 66 04 F6 21 EC 01 FB 90 1B EB 0C A6 72 E9 09 22 06 00 9C
X: 3
SWB: 16 05 20 A7 42 E9 24 EC 64 EC 64 20 80 50 E8 24 F4 CE 14 98 0C B6 86 D6 FF 90 06 B5 B5 B4 E4 99 D2 F6 61 2E
X: 3
SWB: 16 05 40 A7 2D 9A 3D 3E 3F A7 07 24 80 50 40 00 C0 20 90 A6 24 F7 04 01 32 11 C5 25 BE 50 26 00 40 21 02 00
X: 3
SWB: 16 05 60 A7 11 C2 43 C2 53 C4 01 40 9F 1D A6 D2 00 90 66 01 C5 F4 E1 42 80 5F 42 C4 E9 09 E9 61 24 DE 50 46
X: 3
SWB: 16 05 80 A7 00 F6 12 20 04 46 E8 22 20 BA 04 E8 21 9F 96 5B F4 64 C2 20 00 46 E8 24 05 04 01 C2 22 18 00 9C
X: 3
SWB: 16 05 A0 A7 42 F6 14 20 8E 50 E8 24 62 04 F4 55 14 80 15 24 00 46 F4 16 0D 16 C0 23 02 00 F6 82 21 0D 46 9F
X: 3
SWB: 16 05 C0 A7 E3 C5 98 32 B2 82 20 FC FF E8 24 D2 FF 90 27 BD BD BC EC 99 D5 20 E8 FF E8 25 F4 81 C2 11 C2 20
X: 3
SWB: 16 05 E0 A7 76 50 ED C0 90 10 E7 C8 08 A6 1C A2 D0 7D A9 E7 08 08 E8 16 99 6C E4 80 1D 90 1C 24 00 46 02 0D
X: 3
SWB: 16 05 00 A8 01 0B F6 10 EA C0 90 0F EA 11 11 C0 23 02 00 F6 82 21 0B 46 9F E3 C5 AF 2F 2E 2D 9A 3D 3E 3F A7
X: 3
SWB: 16 05 20 A8 01 25 80 50 40 40 C0 02 90 0B 24 F7 04 06 16 01 42 05 45 98 0C 24 94 07 4C 09 7D 42 41 73 4A 44
X: 3
SWB: 16 05 40 A8 7B E9 E6 88 13 FA DE 90 0F 31 19 DE 23 02 00 22 DE 00 21 00 46 9F E3 C5 ED E6 80 0E 24 DE 50 46
X: 3
SWB: 16 05 60 A8 00 22 00 46 21 DE 00 9F 96 5B 25 80 50 01 4A 9F 1D A6 D2 00 90 18 24 F7 04 01 32 F4 E1 4C 80 0E
X: 3
SWB: 16 05 80 A8 24 DE 50 46 00 22 02 46 21 E0 00 9F 96 5B 24 80 50 42 00 CA 04 90 0D 25 DA 50 24 00 46 00 40 F4
X: 3
SWB: 16 05 A0 A8 50 02 94 1D CA 10 90 32 24 80 50 01 0A 9F 1D A6 D2 00 90 26 24 F7 04 01 32 24 D8 50 F4 E1 00 80
X: 3
SWB: 16 05 C0 A8 19 24 00 46 42 0A CA 01 84 10 E6 12 01 52 C0 23 01 00 F6 82 21 0A 46 9F E3 C5 24 00 46 42 0A CA
X: 3
SWB: 16 05 E0 A8 01 90 19 E4 80 1D 90 14 CA 02 84 10 E6 12 02 52 C0 23 01 00 F6 82 21 0A 46 9F E3 C5 A9 2F 2E 2D
X: 3
SWB: 16 05 00 A9 9A 24 78 80 60 04 F1 00 9A 24 78 80 60 FB F0 00 9A 24 78 80 60 08 F1 00 9A 24 78 80 60 F7 F0 00
X: 3
SWB: 16 05 20 A9 9A 63 10 24 70 80 98 08 D3 00 84 02 72 9A B3 83 42 02 CA 04 93 F2 62 01 9A 9A 3F 24 70 80 60 0C
X: 3
SWB: 16 05 40 A9 F1 05 60 0C F1 08 9F 39 A9 2F 9A 3F 9F 01 A9 9F 11 A9 9F 39 A9 9F 39 A9 9F 19 A9 9F 39 A9 9F 09
X: 3
SWB: 16 05 60 A9 A9 9F 39 A9 2F 9A 3D 3E 3F A7 01 52 C0 6D 08 E6 5D 00 90 24 42 C0 DA 00 80 08 9F 19 A9 9F 39 A9
X: 3
SWB: 16 05 80 A9 98 19 9F 11 A9 9F 39 A9 24 70 80 42 02 CA 08 84 0A 9F 01 A9 6C FE 98 4A 9F 11 A9 9F 01 A9 9F 21
X: 3
SWB: 16 05 A0 A9 A9 D2 00 84 07 9F 11 A9 6C FF 98 36 9F 39 A9 24 70 80 42 02 A6 2A 7B BB B3 BA E2 B3 B3 B2 E2 B3
X: 3
SWB: 16 05 C0 A9 B3 B2 E2 E6 42 01 A6 2C E6 0C 01 9F 39 A9 9F 09 A9 9F 39 A9 BD 8D E6 5D FF 90 07 E0 69 C0 59 C0
X: 3
SWB: 16 05 E0 A9 99 8D A6 C2 A9 2F 2E 2D 9A 3D 3E 3F A7 03 52 C0 12 C1 9F 11 A9 26 08 00 42 C0 D2 00 90 08 E6 5C
X: 3
SWB: 16 05 00 AA 00 84 03 9F 19 A9 9F 39 A9 9F 01 A9 9F 21 A9 D2 00 84 07 9F 11 A9 62 FF 98 39 9F 39 A9 E6 5C 00
X: 3
SWB: 16 05 20 AA 90 1B 24 70 80 42 02 BD 64 A6 2A 7B BB B3 BA E2 B3 B3 B2 E2 B3 B3 B2 E2 C2 01 E5 1D 24 9F 39 A9
X: 3
SWB: 16 05 40 AA 9F 09 A9 9F 39 A9 BC 8C E6 5C FF 87 AB 04 C1 5D 00 62 01 AB 2F 2E 2D 9A 3F DA 00 80 12 9F 19 A9
X: 3
SWB: 16 05 60 AA 9F 39 A9 9F 01 A9 9F 39 A9 9F 39 A9 9F 11 A9 2F 9A 3F 9F 39 A9 24 70 80 60 F3 F0 05 60 0C F1 08
X: 3
SWB: 16 05 80 AA 2F 9A 3D A2 C0 3F A7 04 A6 3B 12 C2 B2 6A FC 60 9F 3A A9 9F 4B A9 A6 A2 9F 66 A9 A6 2C D2 01 84
X: 3
SWB: 16 05 A0 AA 3F A6 B2 9F 66 A9 A6 2C D2 01 84 34 9F 4B A9 A6 A2 E6 12 01 9F 66 A9 A6 2C D2 01 84 23 F6 82 62
X: 3
SWB: 16 05 C0 AA 01 9F E9 A9 A6 2C D2 01 84 16 F6 81 E9 92 72 9F E9 A9 A6 2C 4F C0 7E 4A C1 7B ED 17 04 C2 17 00
X: 3
SWB: 16 05 E0 AA A6 C2 9F 58 AA 9F 71 AA FC 50 A6 C2 AC 2F A0 0C 2D 9A 3D 3E 3F A6 2A A6 3B A6 4D A6 5C FC 60 9F
X: 3
SWB: 16 05 00 AB 3A A9 9F 4B A9 BA 62 9F 66 A9 A6 2A D2 01 84 1D A6 B2 9F 66 A9 A6 2A D2 01 84 12 A6 C2 9F 66 A9
X: 3
SWB: 16 05 20 AB A6 2A DA 00 80 07 A6 D2 9F 66 A9 A6 2A A6 A2 9F 58 AA 9F 71 AA FC 50 A6 A2 2F 2E 2D 9A 3F A7 0A
X: 3
SWB: 16 05 40 AB 23 08 00 22 FF 04 F6 81 9C 3F 24 F7 04 01 04 11 C8 23 0A 00 F6 82 21 53 43 9F E3 C5 A5 0A 2F 9A
X: 3
SWB: 16 05 60 AB 3F A4 21 00 9F 7A 9B D2 00 90 07 9F 56 82 D2 00 90 09 A1 02 D0 E6 12 10 A3 D0 20 2F 9A 3D 3F A1
X: 3
SWB: 16 05 80 AB 00 1F 90 18 25 F6 03 02 40 24 82 4B 01 00 EA 51 94 04 EA 91 11 40 9F 0D BE 9F 94 8F 24 F7 04 05
X: 3
SWB: 16 05 A0 AB 14 9F 28 03 73 24 8B 4B 02 00 9C 42 24 88 4B F4 21 00 E9 E5 94 0E 9F B6 82 24 AD 4B E0 52 00 94
X: 3
SWB: 16 05 C0 AB 03 9F 00 6A 2F 2D 9A 3F 24 9E 03 31 32 11 00 12 02 24 F6 03 32 12 00 60 10 F3 CD 9F C4 BB 2F 9A
X: 3
SWB: 16 05 E0 AB 3D 3E 24 C6 49 44 01 75 33 3B 3A 32 9C 45 AC 9C 52 24 00 40 00 0C 38 00 0A 38 9C 46 AC F7 E0 31
X: 3
SWB: 16 05 00 AC F7 6B F8 9C 46 AC F6 15 F6 26 F7 FF 46 F7 00 FE 9C 54 AC DA 00 80 05 21 FF 7F 98 07 F6 51 F6 62
X: 3
SWB: 16 05 20 AC 9D 27 D9 2E 2D 9A D5 00 84 08 D4 00 84 04 D3 07 94 04 21 FF FF 9A 3A 39 9C 45 AC 66 06 9C 4F F6
X: 3
SWB: 16 05 40 AC 11 84 03 21 01 00 9A F6 12 9C 42 9A 3D 3F 24 80 4D 01 00 A6 30 A6 14 A6 15 3A 39 24 7F 4B 42 00
X: 3
SWB: 16 05 60 AC 73 32 9C 45 AC 66 08 9C 4E F6 15 24 5C 03 01 0F 9C 3A 74 E9 E5 8C 02 64 01 A6 42 2F 2D 9A 3D A2
X: 3
SWB: 16 05 80 AC D0 3F A7 04 11 C2 A6 42 A6 5A A6 6D 22 00 40 73 9F 94 CB 11 C0 7B ED 64 20 04 04 E8 24 01 C2 F4
X: 3
SWB: 16 05 A0 AC C9 28 E6 5D 00 84 02 9C 3A 74 F4 E1 C0 94 02 64 01 A6 42 AC 2F A0 0D 2D 9A 3D 3E 3F A7 02 11 C0
X: 3
SWB: 16 05 C0 AC A6 4D 9F 28 03 A6 2C 98 18 BC 8C A6 CA 7B ED 64 F4 24 C0 76 A6 C5 A6 D4 01 00 9F 7E AC D2 00 90
X: 3
SWB: 16 05 E0 AC 07 E6 5C 00 87 E3 62 01 AA 2F 2E 2D 9A 3D 3E 3F A7 11 11 CD 9F 28 03 52 CA 21 FF 7F 98 90 E0 83
X: 3
SWB: 16 05 00 AD CA 53 CA 24 46 43 40 0C C0 03 90 68 53 CB 79 59 CC F4 64 CB F6 45 20 46 43 E8 25 01 40 11 C6 F4
X: 3
SWB: 16 05 20 AD 24 CD 05 00 24 80 4D 02 00 24 80 4B 42 00 73 9F 94 CB F6 16 24 80 4D 02 00 24 81 4B 42 00 73 9F
X: 3
SWB: 16 05 40 AD 94 CB 30 E8 E5 94 22 02 C6 EE 22 EA E5 8C 0A 02 C6 EE C2 ED E2 88 02 F6 52 F6 25 E9 E2 94 02 F6
X: 3
SWB: 16 05 60 AD 15 F4 64 CB F4 24 CD 15 00 F6 51 F4 C9 C6 9C 3A EE E1 8C DC 49 CA 59 CF 7A 5A D0 F4 64 CF F4 24
X: 3
SWB: 16 05 80 AD CD 01 00 30 E8 E1 94 C8 02 C8 E9 E2 94 02 11 C8 45 CA D5 00 87 68 98 BF 04 CD 42 0C C2 FC E6 12
X: 3
SWB: 16 05 A0 AD 01 52 0C 98 78 05 CD 43 4C C3 FC E6 13 02 53 4C 24 46 43 42 0C CA 03 D0 02 84 07 A6 32 E6 12 08
X: 3
SWB: 16 05 C0 AD 52 4C 24 46 43 40 0C C0 08 84 52 9F 28 03 A6 2D A6 2C 31 32 11 C2 12 C4 98 27 BC 8C A6 C2 9F 4C
X: 3
SWB: 16 05 E0 AD 9D 24 40 4B 4A 13 7B ED 92 EA 64 E9 24 01 00 A6 30 A6 14 A6 15 03 C2 04 C4 E9 23 EA 34 13 C2 14
X: 3
SWB: 16 05 00 AE C4 E6 5C 00 87 D4 01 C2 02 C4 A6 D8 79 35 9C 4A 11 C0 23 02 00 F6 82 21 40 43 9F E3 C5 24 5C 03
X: 3
SWB: 16 05 20 AE 35 15 28 60 FB F2 CF 23 0D 00 02 CD 21 46 43 9F E3 C5 E4 B3 D0 C3 01 E6 43 01 A1 02 D0 C2 FD B3
X: 3
SWB: 16 05 40 AE 60 C0 02 B0 12 A3 D0 20 60 40 F3 D4 62 01 98 01 72 A5 11 2F 2E 2D 9A 72 9F F6 A0 24 80 43 01 00
X: 3
SWB: 16 05 60 AE 05 CD 11 4A 02 C8 12 48 62 01 9F 9A 94 D2 00 87 27 99 32 3D 3E 3F A7 04 F6 16 A6 42 D5 00 90 5D
X: 3
SWB: 16 05 80 AE 32 33 12 C0 13 C2 73 E9 64 20 46 43 E8 24 01 00 11 C1 F6 63 E9 C3 F6 31 9C 3A F6 15 02 C1 24 40
X: 3
SWB: 16 05 A0 AE 4B 42 3E 73 9F 94 CB E9 55 8C 31 9F 4C AC D2 00 90 2A 24 5C 03 01 0F 9C 3A F6 13 24 80 4D 02 00
X: 3
SWB: 16 05 C0 AE 24 7F 4B 42 00 73 9F 0D CF 20 FF 00 E8 51 8C 0C F6 13 F6 62 F6 81 9C 3B 06 C1 98 01 36 F6 61 AC
X: 3
SWB: 16 05 E0 AE 2F 2E 2D 9A 3D 3F F6 15 40 75 90 16 64 19 21 6B 03 9C 38 23 08 00 F6 52 E6 24 3C B5 D5 21 2C 04
X: 3
SWB: 16 05 00 AF 9C 3F 2F 2D 9A 3D 3E 3F A7 17 11 D1 F6 14 40 35 90 EF A1 00 CF C0 08 90 E8 26 5C 03 01 91 9F E0
X: 3
SWB: 16 05 20 AF AB F6 15 24 80 4D 02 00 24 40 4B 42 3D 73 9F A7 CB E9 C5 88 CC 01 8F 9C 3A 11 CD 24 46 43 40 0C
X: 3
SWB: 16 05 40 AF C0 03 90 1A 24 40 4B 44 3B 01 D1 E6 22 3C B3 D3 9F B9 AC D2 00 90 A3 9F 4C AC D2 00 90 9C 60 F7
X: 3
SWB: 16 05 60 AF F2 CF 24 46 43 40 0C C0 03 84 13 24 40 4B 44 3C 01 D1 E6 22 3C B3 D3 9F B9 AC D2 00 90 83 24 5C
X: 3
SWB: 16 05 80 AF 03 01 11 9F E0 AB F6 15 02 CD 24 40 4B 42 3D 73 9F A7 CB E9 C5 88 6A 23 0D 00 22 46 43 F6 81 9C
X: 3
SWB: 16 05 A0 AF 3F 9F 28 03 A6 2C 98 40 BC 8C 24 46 43 4D 0C E6 0D 03 5C CF 79 59 D0 F4 65 CF 01 D1 ED 21 11 D3
X: 3
SWB: 16 05 C0 AF F6 54 20 04 04 E8 24 14 D5 F6 14 01 3C 04 D5 F4 C9 28 9C 3A F6 12 01 CD 9F 96 9C A6 D5 A6 C4 9F
X: 3
SWB: 16 05 E0 AF 73 AE F6 80 E8 25 11 40 E6 5C 00 87 BB F6 81 9F ED AC D2 00 90 04 62 01 98 08 72 04 D1 52 35 98
X: 3
SWB: 16 05 00 B0 01 72 A5 17 2F 2E 2D 9A 3D 3E 3F A7 04 F6 26 E6 22 45 B3 D3 11 C2 01 82 04 C2 11 00 02 C2 E6 24
X: 3
SWB: 16 05 20 B0 BB B5 C5 12 C2 4A 86 7B F6 61 9F 24 9C ED 64 F4 24 C2 11 3C 4A 86 ED 64 05 C2 EC 25 20 04 04 E8
X: 3
SWB: 16 05 40 B0 24 01 7C 11 18 46 86 A6 6A 7B ED 64 F4 24 C2 02 3C 12 C0 A1 00 D4 C0 01 90 1D 24 00 4E 40 03 C0
X: 3
SWB: 16 05 60 B0 01 90 14 24 5C 03 02 00 21 24 04 9F 5E 9C 11 C0 F6 62 9F DD 9B 11 80 F4 91 80 11 80 4A 86 7B F6
X: 3
SWB: 16 05 80 B0 61 9F 24 9C 04 C0 E9 C4 F6 41 9C 3A ED 64 F4 24 C2 20 4E 00 E8 24 11 00 F4 81 80 E9 81 11 80 F6
X: 3
SWB: 16 05 A0 B0 61 9F 24 9C 02 C0 E9 C2 F6 21 9C 3A 4A 86 ED 64 F4 24 C2 20 4E 00 E8 24 F4 E1 00 94 02 11 00 AC
X: 3
SWB: 16 05 C0 B0 2F 2E 2D 9A 3D 3E 3F A7 17 F6 16 23 08 00 22 FF 04 F6 81 E6 22 07 B3 D3 9C 3F 23 08 00 22 13 05
X: 3
SWB: 16 05 E0 B0 F6 81 E6 22 0F B3 D3 9C 3F 24 9A 03 01 00 11 C2 9F 28 03 52 C6 98 1C B2 82 A6 2A 7B ED 64 F6 80
X: 3
SWB: 16 05 00 B1 E8 24 02 07 12 C0 02 0F 12 C4 52 C6 F6 82 F6 61 9F 08 B0 42 C6 87 E0 A5 17 2F 2E 2D 9A 3D 3E 3F
X: 3
SWB: 16 05 20 B1 A7 15 F6 16 54 CC 20 4B 00 E8 26 42 80 73 E9 64 20 40 4B E8 24 01 2F A6 30 A6 14 A6 15 11 C0 12
X: 3
SWB: 16 05 40 B1 C2 20 FA FF E8 26 01 80 20 BB FF E8 26 23 E8 03 24 40 4B 02 35 20 5A F4 E8 21 9F 0D CF 9C 3A F6
X: 3
SWB: 16 05 60 B1 12 A6 50 A6 16 A6 17 F4 22 C0 F4 3B C2 12 C8 13 CA F6 64 20 4D 00 E8 24 40 00 90 82 24 C0 4F 45
X: 3
SWB: 16 05 80 B1 17 55 CD 76 56 CE 34 14 CF 20 47 00 E8 26 01 80 32 20 B9 FF E8 26 F4 21 CD F4 3A CF 25 9E 03 F4
X: 3
SWB: 16 05 A0 B1 21 40 F4 3A 42 9C 53 9C 3E 11 C4 12 C6 01 CD 02 CF F4 21 40 F4 3A 42 9C 53 9C 3E 3A 39 01 C8 02
X: 3
SWB: 16 05 C0 B1 CA 9C 41 AC 11 D1 12 D3 24 40 4B 01 37 A6 30 A6 14 A6 15 9C 52 3A 39 01 D5 02 D7 9C 46 AC F7 80
X: 3
SWB: 16 05 E0 B1 3A F7 00 00 9C 46 AC 9D 27 D9 9C 3A A6 30 A6 14 A6 15 03 C8 04 CA E9 23 EA 34 13 C8 14 CA 42 CC
X: 3
SWB: 16 05 00 B2 73 E9 64 EE 24 20 4E 00 E8 24 01 00 90 0E 32 3A 39 01 CC 02 CE 9C 45 AC 11 C8 12 CA 01 C8 02 CA
X: 3
SWB: 16 05 20 B2 9F 26 AC A5 15 2F 2E 2D 9A 3D 3E 3F A7 0C A6 2E 24 5C 03 01 0A 02 0C 11 C0 12 C2 00 08 38 00 06
X: 3
SWB: 16 05 40 B2 38 24 C6 49 42 01 73 32 9C 45 AC 9C 53 24 00 40 00 08 38 00 06 38 9C 46 AC F7 E1 40 F7 3B 27 9C
X: 3
SWB: 16 05 60 B2 4C AC 9C 51 11 C4 12 C6 24 00 4E 40 02 C0 01 90 24 25 C0 4D 06 42 66 0E 01 C0 02 C2 9C 4D 03 44
X: 3
SWB: 16 05 80 B2 EE 53 94 02 F6 63 F6 34 35 9C 4B F4 21 C4 F4 3A C6 11 C4 12 C6 7F EF 67 F6 74 20 46 43 E8 24 01
X: 3
SWB: 16 05 A0 B2 C4 02 C6 04 00 35 9C 4B 11 C8 12 CA F6 75 20 A8 03 E8 25 66 06 01 40 32 9C 4D 9C 53 9C 3E 9C 51
X: 3
SWB: 16 05 C0 B2 F4 21 C8 F4 3A CA 9F 26 AC 11 40 A5 0C 2F 2E 2D 9A 3D 3E 3F A7 17 11 C9 24 00 4E 40 00 C0 10 90
X: 3
SWB: 16 05 E0 B2 DD 9F 28 03 52 C0 01 C9 E6 22 4C B3 D3 11 D5 98 C7 E0 83 C0 53 C0 A6 34 01 C9 9F 1D B1 F6 15 44
X: 3
SWB: 16 05 00 B3 C0 54 D3 75 55 D4 04 D5 40 00 90 0C F4 64 D3 20 A8 03 E8 24 11 00 98 A0 42 C0 9F 29 B2 46 C0 24
X: 3
SWB: 16 05 20 B3 5C 03 02 00 21 24 04 9F 5E 9C F6 13 F4 62 D3 F6 21 20 A8 03 E8 21 11 CB F6 14 04 00 14 C5 31 11
X: 3
SWB: 16 05 40 B3 C7 15 C1 11 C3 06 C1 07 C3 F4 26 C5 F4 3F C7 A6 C2 BD 12 BE 12 BF 12 D2 00 90 5D 04 C9 EA 24 14
X: 3
SWB: 16 05 60 B3 CD 01 C1 02 C3 3A 39 F6 31 A6 30 A6 14 A6 15 9C 45 AC 11 CF 12 D1 01 C5 02 C7 3A 39 04 D1 01 3C
X: 3
SWB: 16 05 80 B3 A6 30 A6 14 A6 15 9C 45 AC F4 21 CF F4 3A D1 F6 64 F6 75 9C 4B 04 CD 11 3C 01 C5 02 C7 3A 39 01
X: 3
SWB: 16 05 A0 B3 C5 02 C7 9C 45 AC F6 64 F6 75 9C 4B 04 CB 11 00 FB 84 05 21 01 00 11 00 43 C0 D3 00 87 33 23 08
X: 3
SWB: 16 05 C0 B3 00 02 C9 E6 24 3C B5 D5 21 24 04 9C 3F 64 0F 21 5C 03 9C 38 A1 02 D5 E6 12 02 A3 D5 20 64 0C 21
X: 3
SWB: 16 05 E0 B3 04 04 9C 38 24 84 04 40 08 D0 02 84 04 64 01 54 08 A5 17 2F 2E 2D 9A 3D 3E 3F A7 0B F6 16 9F 56
X: 3
SWB: 16 05 00 B4 82 A6 2B 40 BB 84 43 A1 00 CF C0 40 90 3C 9F 28 03 52 C6 F6 61 E6 22 3C B3 D3 11 C7 98 15 A6 A6
X: 3
SWB: 16 05 20 B4 24 5C 03 02 3A 01 C7 9F 5E 9C A6 AE 7F EF 64 EE 24 11 3C 42 C6 B2 8A 5A C6 D2 00 87 E1 F6 61 9F
X: 3
SWB: 16 05 40 B4 05 AF 69 01 59 BB 60 FB F2 CF 40 BB 84 93 A1 00 D5 C0 08 90 8C 24 9A 03 01 00 11 C2 24 46 43 01
X: 3
SWB: 16 05 60 B4 15 11 C4 9F 28 03 52 C6 98 30 53 C9 73 53 CA F4 64 C9 20 46 43 E8 24 01 0D 11 C0 F6 82 F6 61 9F
X: 3
SWB: 16 05 80 B4 08 B0 4A C6 A6 A6 24 5C 03 02 38 21 3C 04 9F 5E 9C A6 A4 75 EA 64 EE 24 11 3C 42 C6 B2 83 53 C6
X: 3
SWB: 16 05 A0 B4 D2 00 87 C6 23 08 00 F6 62 E6 24 3C B5 D5 21 1C 04 9C 3F E6 5B 00 84 09 24 00 4E 40 02 C0 10 90
X: 3
SWB: 16 05 C0 B4 07 F6 61 9F 05 AF 98 03 79 59 B5 62 01 52 BB 60 FB F2 CF 20 4B 00 E8 26 63 02 53 80 20 B5 FF E8
X: 3
SWB: 16 05 E0 B4 26 A1 02 D5 C2 F7 A3 D5 20 40 BB 90 2D F6 61 9F D1 B2 40 B5 90 04 60 08 F3 CF F6 61 9F E4 AE 9F
X: 3
SWB: 16 05 00 B5 82 79 24 C0 4D 42 00 CA 40 84 0F CA 08 84 05 21 1C 04 98 03 21 24 04 9F 47 BD 60 BF F2 CF A5 0B
X: 3
SWB: 16 05 20 B5 2F 2E 2D 9A 3E 3F A7 02 F6 86 22 01 00 12 80 3E 39 23 6E 00 32 21 47 AC 9F 54 CC AC AA 2F 2E 9A
X: 3
SWB: 16 05 40 B5 3D 3F A1 00 CF C0 10 90 39 9F 28 03 24 54 4A 05 00 24 52 4A 07 00 98 16 B2 82 A6 24 75 EA 64 20
X: 3
SWB: 16 05 60 B5 F7 04 E8 24 03 08 ED E3 94 04 EF E3 80 14 D2 00 87 E6 24 9A 03 01 00 9F EA 69 D2 00 90 05 62 01
X: 3
SWB: 16 05 80 B5 98 01 72 2F 2D 9A 3D 3E 3F A7 22 11 D5 54 D7 24 9E 03 42 00 52 DA 43 01 53 DB 44 02 54 DC 45 03
X: 3
SWB: 16 05 A0 B5 55 DD 11 DE 24 40 4B 01 03 32 E0 55 DD 84 19 E0 54 DC 8C 98 E0 54 DC 84 0F E0 53 DB 8C 8E E0 53
X: 3
SWB: 16 05 C0 B5 DB 84 05 E0 52 DA 8C 84 9F 56 82 A6 2A 9F 7A 9B D2 00 90 04 60 80 F3 D4 A1 00 D0 C0 10 90 4B D2
X: 3
SWB: 16 05 E0 B5 00 90 07 E6 5A 00 90 42 98 0A E6 5A 00 90 05 E4 60 D4 88 36 24 00 4E 40 00 C0 08 90 2D 24 A9 4B
X: 3
SWB: 16 05 00 B6 01 00 22 0A 00 9C 44 E0 55 DD 8C 40 E0 55 DD 84 19 E0 54 DC 8C 36 E0 54 DC 84 0F E0 53 DB 8C 2C
X: 3
SWB: 16 05 20 B6 E0 53 DB 84 05 E0 52 DA 8C 22 A1 02 D0 C2 EF A3 D0 20 60 7F F2 D4 04 D5 40 3B 90 06 69 01 59 CD
X: 3
SWB: 16 05 40 B6 98 0D 60 EF F2 CD 62 01 52 CD 98 03 73 53 CD 24 00 4E 40 05 C0 01 91 03 24 F6 03 02 00 90 FC 24
X: 3
SWB: 16 05 60 B6 84 4B 01 00 03 DE E9 53 94 F1 24 86 4B F4 21 00 E9 53 94 95 24 F7 04 01 06 11 C4 02 00 12 C2 9F
X: 3
SWB: 16 05 80 B6 40 B5 04 D5 52 35 9F 28 03 52 C6 21 FF 7F 11 CB 22 00 80 12 C9 6A 0E 98 33 E7 31 A0 E6 22 56 B3
X: 3
SWB: 16 05 A0 B6 D3 32 F4 21 D5 9F B2 CD B3 60 80 02 E9 91 E5 73 30 B2 E2 11 C0 03 CB E9 E3 94 02 11 CB 04 C9 E9
X: 3
SWB: 16 05 C0 B6 E4 88 02 11 C9 F6 82 01 D5 9F 08 B0 42 C6 B2 83 53 C6 D2 00 87 C3 01 D5 E6 22 49 B3 D3 11 D5 01
X: 3
SWB: 16 05 E0 B6 C9 F4 C9 CB 04 D5 11 00 01 D5 E6 22 B7 B3 C3 11 D5 24 F6 03 32 12 00 24 5C 03 12 3A A1 02 CF E6
X: 3
SWB: 16 05 00 B7 12 40 C2 FB A3 CF 20 98 5C 05 DE EA 25 ED 61 E9 61 9F 24 B5 F6 16 24 F6 03 F4 CD 00 24 84 4B F4
X: 3
SWB: 16 05 20 B7 CD 00 ED 61 E9 61 9F 24 B5 E9 C6 9F 28 03 52 C6 98 1F A6 3A 7B ED 64 20 F7 04 E8 24 64 0E E7 31
X: 3
SWB: 16 05 40 B7 40 E6 22 56 B3 D3 F4 63 08 F6 62 F4 21 D5 9F 1A CD 42 C6 B2 83 53 C6 D2 00 87 D7 23 FF 7F 13 CB
X: 3
SWB: 16 05 60 B7 24 00 80 14 C9 49 CD E6 59 00 84 04 76 9B B4 B9 A1 00 21 85 B5 9F 28 03 98 37 A6 C6 77 EB 65 ED
X: 3
SWB: 16 05 80 B7 65 F4 25 D5 EB 64 20 F7 04 E8 24 01 08 A6 30 A6 14 A6 15 F4 21 54 F4 3A 56 11 54 12 56 01 1C A6
X: 3
SWB: 16 05 A0 B7 30 A6 14 A6 15 F4 21 64 F4 3A 66 11 64 12 66 A6 C2 B2 8C D2 00 87 C3 5C C6 04 D5 F4 91 37 11 37
X: 3
SWB: 16 05 C0 B7 25 40 4B F4 C9 5B 85 87 9F 28 03 52 C6 69 01 98 47 A6 36 77 EB 65 ED 65 F4 25 D5 EB 91 E9 64 EC
X: 3
SWB: 16 05 E0 B7 64 F4 24 D5 01 54 02 56 F4 C9 00 F4 D2 02 13 E0 9F 3D CB 24 40 4B 4A 21 7B 36 E5 E0 D5 8C 18 BD
X: 3
SWB: 16 05 00 B8 55 84 17 BC 54 8C 10 BC 54 84 0F BB 53 8C 08 BB 53 84 07 BA 52 94 03 79 59 CE 42 C6 B2 83 53 C6
X: 3
SWB: 16 05 20 B8 D2 00 87 AD 42 CE D2 00 90 06 04 D5 40 34 84 0F 01 DE 04 D5 F4 C9 02 24 40 4B F4 51 1D 80 C3 24
X: 3
SWB: 16 05 40 B8 9A 03 01 00 11 C2 72 04 D5 52 39 9F 40 B5 04 D5 52 35 01 DE 11 02 9F 28 03 52 C6 98 54 53 C7 73
X: 3
SWB: 16 05 60 B8 53 C8 24 40 4B 04 1B 14 D1 31 11 D3 F4 62 C7 EA 62 03 D5 EA 23 13 D8 F6 34 01 14 02 16 04 D1 05
X: 3
SWB: 16 05 80 B8 D3 9C 4A F6 16 11 CF 11 C0 04 D8 01 24 02 26 04 D1 05 D3 9C 4A 11 C4 01 CB EE E1 94 02 16 CB 02
X: 3
SWB: 16 05 A0 B8 C9 F4 E2 CF 88 04 03 CF 13 C9 F6 82 01 D5 9F 08 B0 42 C6 B2 83 53 C6 D2 00 87 A2 01 D5 E6 22 49
X: 3
SWB: 16 05 C0 B8 B3 D3 11 D5 02 C9 F4 CA CB F6 14 12 00 01 D5 E6 22 04 B3 D3 11 D5 62 01 04 D5 52 00 02 D5 E6 24
X: 3
SWB: 16 05 E0 B8 F7 B5 C5 12 D5 F6 24 52 00 02 D5 E6 24 BC B5 C5 12 D5 42 DA F6 24 52 3A 60 BF F2 CF 24 F6 03 32
X: 3
SWB: 16 05 00 B9 12 00 42 CE 04 D5 52 34 F6 45 20 14 00 E8 25 23 10 00 F6 52 01 D5 E6 22 04 B3 D3 9C 3F 64 20 F6
X: 3
SWB: 16 05 20 B9 51 9C 38 31 04 D5 11 37 98 25 04 D5 40 3B 90 1F 01 DE 11 02 73 53 34 64 20 01 D5 E6 22 14 B3 D3
X: 3
SWB: 16 05 40 B9 9C 38 31 04 D5 11 37 A1 02 D5 C2 FD A3 D5 20 05 D5 20 44 00 E8 25 40 40 90 43 42 DA 04 D5 E0 C2
X: 3
SWB: 16 05 60 B9 3A 24 40 4B E0 52 28 80 34 79 59 40 62 01 04 D5 52 3B 01 D5 9F 05 AF D2 00 84 06 04 D5 40 36 90
X: 3
SWB: 16 05 80 B9 0D 72 04 D5 52 36 A4 DB 03 01 D5 9F D1 B2 A1 02 CF C2 BA E6 12 01 A3 CF 20 60 10 F3 CD 01 DE 04
X: 3
SWB: 16 05 A0 B9 D5 F4 C9 02 24 40 4B F4 51 1F 80 04 60 EF F2 CD 04 D5 46 39 01 DE 04 D5 F4 C9 00 24 40 4B F4 51
X: 3
SWB: 16 05 C0 B9 05 80 0E 01 DE 04 D5 11 00 63 01 53 36 60 EF F2 CD 24 9D 4B 01 00 32 E0 55 DD 84 19 E0 54 DC 8C
X: 3
SWB: 16 05 E0 B9 1E E0 54 DC 84 0F E0 53 DB 8C 14 E0 53 DB 84 05 E0 52 DA 8C 0A 25 9A 03 24 5C 03 02 40 12 3C 45
X: 3
SWB: 16 05 00 BA D7 D5 00 90 0A D6 00 90 06 60 20 F3 CF 98 04 60 DF F2 CF A5 22 2F 2E 2D 9A 3D 3E 3F A7 08 11 C4
X: 3
SWB: 16 05 20 BA A6 4A 26 9E 03 01 80 02 82 11 C0 12 C2 60 FE F2 CF 64 8E 01 C4 9C 38 E6 5A 00 90 1F 31 32 11 80
X: 3
SWB: 16 05 40 BA 12 82 A1 00 CF E7 08 10 A6 12 C2 01 04 C4 52 39 60 DF F2 CF 9F 40 B5 04 C4 52 35 A1 02 D3 D2 FF
X: 3
SWB: 16 05 60 BA 84 07 24 C0 4F 42 17 98 0D D2 01 90 04 35 36 98 0F 24 C0 4F 42 18 73 32 05 C0 06 C2 E9 C5 EA D6
X: 3
SWB: 16 05 80 BA 01 C4 E6 22 47 B3 D3 11 C6 24 40 4B 01 39 32 A6 A8 A6 B7 B5 5D 8C 18 B5 5D 84 18 B4 5C 8C 10 B4
X: 3
SWB: 16 05 A0 BA 5C 84 10 B3 5B 8C 08 B3 5B 84 08 B2 5A 94 04 A6 28 A6 37 A6 82 A6 73 04 C6 11 00 24 F6 03 F8 00
X: 3
SWB: 16 05 C0 BA 90 06 60 EF F2 CD 98 04 60 10 F3 CD A1 02 D5 C2 FD A3 D5 20 A8 2F 2E 2D 9A 3D 3E 3F A7 01 F6 16
X: 3
SWB: 16 05 E0 BA 54 C0 25 9A 03 24 5C 03 01 40 11 3C 25 46 43 24 48 04 01 5D 02 5F 11 1A 12 1C 40 4C C0 04 90 10
X: 3
SWB: 16 05 00 BB A1 02 CF E6 12 10 43 C0 D3 00 90 09 C2 FB 98 08 A1 02 CF C2 EF E6 12 04 A3 CF 20 74 F6 61 9F 19
X: 3
SWB: 16 05 20 BB BA 44 C0 54 B5 24 46 43 42 0C CA 0B D0 0A 84 13 D4 00 90 0C 9F 40 B5 D2 00 90 05 21 01 00 98 01
X: 3
SWB: 16 05 40 BB 31 52 B5 F6 61 9F C4 B0 65 01 55 BB 24 5C 03 55 23 F6 61 9F E4 AE 20 4C 00 E8 26 62 01 52 80 20
X: 3
SWB: 16 05 60 BB B4 FF E8 26 A1 00 D4 C0 01 84 0C 20 4B 00 E8 26 52 80 20 B5 FF E8 26 F6 61 9F F7 B3 9F 00 6A 24
X: 3
SWB: 16 05 80 BB 84 04 73 53 08 64 01 F6 61 9F 19 BA 60 40 F3 D4 A9 2F 2E 2D 9A 24 C0 4D 40 00 C0 01 90 24 24 46
X: 3
SWB: 16 05 A0 BB 43 42 0C CA 04 90 1B CA 03 D0 02 84 0B A1 00 CD C0 02 90 04 21 01 00 9A E7 28 20 A6 12 73 73 C2
X: 3
SWB: 16 05 C0 BB 01 9A 31 9A 3D 25 C0 04 24 C0 4D 01 10 11 40 73 53 42 2D 9A 3D 3F F6 15 24 C0 4D 01 07 02 09 11
X: 3
SWB: 16 05 E0 BB 40 12 42 9F C4 BB 2F 2D 9A 3D 3E 24 C0 04 E0 92 02 52 02 25 C0 4D E0 52 56 80 3C 72 52 02 02 00
X: 3
SWB: 16 05 00 BC F6 23 F4 23 52 24 F7 04 01 16 EB E1 8C 06 01 18 EA E1 94 05 24 C0 04 13 00 A1 00 D3 84 19 25 C0
X: 3
SWB: 16 05 20 BC 4D 01 50 26 C0 04 11 80 24 F7 04 02 18 E9 E2 94 06 01 54 EA 21 11 80 24 F7 04 02 18 25 C0 04 01
X: 3
SWB: 16 05 40 BC 40 EA E1 88 09 24 C0 4D 01 14 EA 21 11 40 2E 2D 9A 3D F6 15 23 12 00 22 C3 04 9C 3F A1 02 21 52
X: 3
SWB: 16 05 60 BC 52 62 13 2D 9A 3D 3E 3F A7 14 F6 15 64 0C F6 81 9C 38 72 52 CE 63 08 53 CF F6 51 E6 22 F8 B3 C3
X: 3
SWB: 16 05 80 BC 11 D2 98 64 F8 46 90 57 47 CE 98 2D A6 7E 7F EF 81 22 03 00 9C 42 F6 80 E8 21 11 D0 F6 14 06 00
X: 3
SWB: 16 05 A0 BC 01 46 F4 51 80 94 16 F6 71 9C 42 F6 84 E9 24 16 00 06 D0 4D 82 5D 02 B7 87 D7 00 87 CF A6 72 73
X: 3
SWB: 16 05 C0 BC 22 03 00 9C 42 F6 84 E9 24 01 CC 11 00 A6 72 73 9C 42 F6 84 E9 24 43 CF 53 02 E0 98 CE 58 CE E0
X: 3
SWB: 16 05 E0 BC B9 CF 59 CF ED 85 ED 85 F6 51 E6 22 06 B3 D3 11 CC 00 D2 ED C0 87 8D F6 85 7C 77 98 2A 46 42 B6
X: 3
SWB: 16 05 00 BD B2 B7 02 84 12 A6 64 75 EA 61 B7 02 84 09 B6 17 04 40 F4 81 00 11 00 20 03 00 E8 25 24 C0 4D 40
X: 3
SWB: 16 05 20 BD 00 C0 02 84 07 BC 9C E0 5C CE 83 D1 D7 00 90 0E 24 5C 03 F4 90 0A 10 0A 30 F4 38 0C 10 0C A3 21
X: 3
SWB: 16 05 40 BD 70 A5 14 2F 2E 2D 9A 3D 3E 3F A7 14 11 CE 64 12 21 C3 04 9C 38 9F 95 BB D2 00 90 AB 23 08 00 02
X: 3
SWB: 16 05 60 BD CE 21 CB 04 9C 3F 9F AF 8F 25 C3 04 E6 23 40 11 50 9F 28 03 52 CC 52 CD 98 33 E0 82 CD 52 CD A6
X: 3
SWB: 16 05 80 BD 2C 7D EE 65 04 CE ED 24 14 D2 F6 51 20 46 43 E8 21 11 D0 24 C3 04 03 10 04 D2 F4 CB 00 22 00 40
X: 3
SWB: 16 05 A0 BD F6 14 01 00 9F F1 87 F6 80 E8 25 11 40 49 CD E6 59 00 87 C6 44 CC F6 81 9F 21 CE 11 CA 24 C0 4D
X: 3
SWB: 16 05 C0 BD 07 02 01 04 11 C8 98 38 4C CD 7D EE 65 F6 84 ED 24 01 CA F4 C9 00 F6 14 21 FF FF F6 72 9C 49 20
X: 3
SWB: 16 05 E0 BD C3 04 E8 25 F6 10 EC 50 94 0A F6 41 F6 72 9C 42 11 40 98 05 24 FF FF 14 40 E0 99 CD 59 CD 07 C8
X: 3
SWB: 16 05 00 BE 42 CD E0 52 CC 83 C1 A5 14 2F 2E 2D 9A 3D 3E 3F A7 08 9F B6 82 A6 2B A1 00 CD C0 10 90 98 26 C0
X: 3
SWB: 16 05 20 BE 4D 4A 80 E6 0A 40 E6 5A 00 90 14 9F 95 BB D2 00 90 84 24 F7 04 01 16 F4 C9 18 F4 E1 94 80 77 E4
X: 3
SWB: 16 05 40 BE 80 D3 90 2A 09 D1 E9 A0 84 08 24 C0 4D E0 5B 0C 8C 1C A1 00 21 90 0C 24 C0 4D E0 5B 0D 80 04 E9
X: 3
SWB: 16 05 60 BE A0 90 0B FB 84 50 24 C0 4D E0 5B 0B 94 48 E6 5A 00 84 05 21 C3 04 98 39 64 08 F6 81 9C 38 9F E9
X: 3
SWB: 16 05 80 BE BB 24 C0 04 06 00 6E 04 23 05 00 98 1C BE 8E A6 E4 75 EA 65 F6 54 20 F7 04 E8 24 01 08 EE E1 94
X: 3
SWB: 16 05 A0 BE 08 F6 80 E8 25 EE C1 11 40 EB 83 F9 30 87 DE F6 81 9F 65 BC 98 06 31 19 D1 A4 21 00 A8 2F 2E 2D
X: 3
SWB: 16 05 C0 BE 9A 3D 3E 3F F6 15 F6 26 D6 00 90 0E 24 C0 4D 40 00 C0 20 84 05 A4 21 00 98 87 24 C0 4D 4E 00 E6
X: 3
SWB: 16 05 E0 BE AE 04 90 7D 02 40 03 42 A6 42 B5 12 B6 12 B7 12 D2 00 90 2A EA 81 F6 32 30 E8 D2 11 40 12 42 A6
X: 3
SWB: 16 05 00 BF 26 B3 16 B4 16 B5 16 D6 00 84 53 60 EF F2 CD 64 08 21 C3 04 9C 38 24 C0 04 7C 5C 02 98 40 A1 00
X: 3
SWB: 16 05 20 BF CD C0 10 90 39 E6 AE 40 84 29 F6 64 20 49 00 E8 24 26 C0 4D 42 86 73 F4 E1 00 88 17 E6 AE 10 84
X: 3
SWB: 16 05 40 BF 05 21 1C 04 98 0A A1 00 D5 C0 02 90 14 21 24 04 9F 47 BD 24 C0 4D 01 07 02 09 11 40 12 42 9F 0D
X: 3
SWB: 16 05 60 BF BE 2F 2E 2D 9A 24 30 80 01 05 02 07 9A 3F 24 30 80 01 01 02 03 19 E2 1A E4 24 92 80 60 DF F0 00
X: 3
SWB: 16 05 80 BF 21 00 10 9F 64 C8 2F 9A 3F 63 20 9F 0C C0 9F E0 BF 32 21 00 10 9F 54 C8 2F 9A 3D 3E 3F 25 90 80
X: 3
SWB: 16 05 A0 BF 26 30 80 60 20 F1 42 21 00 10 9F 8D C8 42 80 CA 01 87 F0 09 E2 0A E4 2F 2E 2D 9A 3D 3F A6 2B A6
X: 3
SWB: 16 05 C0 BF 3A 21 10 10 9F 0C C0 A6 B3 62 0C 9F 08 C4 24 90 80 62 DF 52 00 E6 1A 01 24 30 80 5A 00 2F 2D 9A
X: 3
SWB: 16 05 E0 BF 3F 24 92 80 60 DF F0 00 21 00 10 9F 0C C0 24 30 80 42 00 CA 01 87 FA 21 0C E0 9F 08 C4 24 30 80
X: 3
SWB: 16 05 00 C0 72 52 00 24 90 80 62 DF 52 00 2F 9A 3D 3F A6 2A A6 3B 21 00 80 9F 8D C8 BB A3 E4 03 EA BB 0A BA
X: 3
SWB: 16 05 20 C0 13 A3 EA 30 62 0B 9F 08 C4 21 00 80 9F 64 C8 2F 2D 9A 3D 3E 3F A7 01 A6 2A F6 26 42 80 52 C0 A6
X: 3
SWB: 16 05 40 C0 A2 9F 5B C2 7B 43 C0 B2 53 84 04 6B 01 98 07 43 80 A6 A2 9F A6 C3 A6 B2 A9 2F 2E 2D 9A 3D 3E 3F
X: 3
SWB: 16 05 60 C0 A7 03 F5 91 ED 11 C0 21 00 80 9F 8D C8 22 E8 00 62 05 9F 32 C0 52 C2 22 E7 00 62 04 9F 32 C0 A6
X: 3
SWB: 16 05 80 C0 2A 22 E9 00 62 0A 9F 32 C0 A6 2C 22 EA 00 62 0B 9F 32 C0 A6 2D 22 EB 00 62 0E 9F 32 C0 A6 2B 22
X: 3
SWB: 16 05 A0 C0 EC 00 62 0F 9F 32 C0 E0 0A C2 BC 0A BD 0A BB 0A E5 0C 2A 6D 10 F4 95 C0 02 C0 A6 D2 9F 32 C0 B2
X: 3
SWB: 16 05 C0 C0 0C BD 9D 15 C0 E6 5D 15 87 EB 21 00 80 9F 64 C8 A6 C2 AB 2F 2E 2D 9A 3F 21 00 80 9F 8D C8 21 03
X: 3
SWB: 16 05 E0 C0 00 9F A6 C3 21 00 FD 9F A6 C3 21 00 80 9F 64 C8 2F 9A 9A A1 00 EB E7 08 02 A6 12 9A 3F 21 00 80
X: 3
SWB: 16 05 00 C1 9F 1E C3 21 00 80 9F E0 C1 2F 9A 3F 63 80 A6 32 9F E0 C1 63 80 A6 32 9F 1E C3 21 00 80 9F E0 C1
X: 3
SWB: 16 05 20 C1 2F 9A A1 02 E6 A1 03 E8 A3 E6 30 9A 3D 3E 3F F6 15 22 00 80 F6 21 9F 54 C8 21 00 80 9F 8D C8 62
X: 3
SWB: 16 05 40 C1 03 9F 5B C2 62 0B 9F 5B C2 A3 EA 20 62 0F 9F 5B C2 A3 EC 20 F9 50 90 55 ED 96 1D ED A1 03 E8 C3
X: 3
SWB: 16 05 60 C1 3F 42 40 C2 C0 B2 13 A3 E8 30 62 05 9F 5B C2 C2 0F 43 40 C3 C0 B2 13 62 05 9F A6 C3 A4 E7 02 A4
X: 3
SWB: 16 05 80 C1 EB 00 A4 E9 00 21 04 02 9F A6 C3 A1 03 EB 62 0E 9F A6 C3 A1 03 E9 62 0A 9F A6 C3 6A 10 43 80 EE
X: 3
SWB: 16 05 A0 C1 96 A6 A2 9F A6 C3 BA 9A E6 5A 15 87 F0 21 00 80 9F 64 C8 9F D7 C0 2F 2E 2D 9A 3D 3F A6 2A A6 3B
X: 3
SWB: 16 05 C0 C1 21 00 80 9F 8D C8 BB A3 E4 03 E7 BB 0A BA 13 A3 E7 30 62 04 9F A6 C3 21 00 80 9F 64 C8 2F 2D 9A
X: 3
SWB: 16 05 E0 C1 3D 3F A6 2A A6 3B 21 00 80 9F 8D C8 BB A3 E4 03 EC BB 0A BA 13 A3 EC 30 62 0F 9F 08 C4 21 00 80
X: 3
SWB: 16 05 00 C2 9F 64 C8 2F 2D 9A A1 02 EB 73 E7 28 04 A6 12 A2 30 73 A9 E7 08 04 E8 11 C2 01 9A 3F 21 00 40 9F
X: 3
SWB: 16 05 20 C2 1E C3 21 00 40 9F E0 C1 2F 9A 3F 21 40 40 9F E0 C1 21 40 40 9F 1E C3 21 00 40 9F E0 C1 2F 9A A2
X: 3
SWB: 16 05 40 C2 A0 3F 21 00 80 9F 8D C8 62 01 9F 5B C2 A6 2A 21 00 80 9F 64 C8 A6 A2 2F A0 0A 9A 3D 3E 3F A7 01
X: 3
SWB: 16 05 60 C2 52 C0 D2 24 8C 42 36 98 37 42 C0 9F FF C3 A6 2A D3 00 84 27 E6 5B 00 90 1C 42 C0 D2 00 90 04 D2
X: 3
SWB: 16 05 80 C2 03 84 09 E5 12 AC BA 52 84 06 98 20 BC 5A 90 1C BD 9D 9F 43 01 A6 AC 6B 01 98 06 BD 9D 9F 43 01
X: 3
SWB: 16 05 A0 C2 7B 0C ED E0 5D 06 97 C1 62 FF 98 02 A6 A2 A9 2F 2E 2D 9A A2 A0 3F A6 2A 21 00 80 9F 8D C8 A6 A2
X: 3
SWB: 16 05 C0 C2 9F 5B C2 A6 2A 21 00 80 9F 64 C8 A6 A2 2F A0 0A 9A 3D A2 C0 3F F6 15 21 00 80 9F 8D C8 7C A6 C2
X: 3
SWB: 16 05 E0 C2 9F 5B C2 52 40 ED 95 BC 9C E6 5C 15 87 F0 21 00 80 9F 64 C8 2F A0 0C 2D 9A A2 A0 3F 21 00 80 9F
X: 3
SWB: 16 05 00 C3 8D C8 62 03 9F 5B C2 A6 2A 21 00 80 9F 64 C8 A6 A2 2F A0 0A 9A 3F 21 02 02 9F 1E C3 2F 9A 3D 3F
X: 3
SWB: 16 05 20 C3 A6 2A A6 3B 21 00 80 9F 8D C8 BB A3 E4 03 EB BB 0A BA 13 A3 EB 30 62 0E 9F A6 C3 21 00 80 9F 64
X: 3
SWB: 16 05 40 C3 C8 2F 2D 9A A2 A0 3F A6 2A E6 0A 0F 60 0F E4 00 E9 BA 50 90 1B 21 00 80 9F 8D C8 A1 03 E9 C3 F0
X: 3
SWB: 16 05 60 C3 BA 13 A3 E9 30 62 0A 9F A6 C3 21 00 80 9F 64 C8 2F A0 0A 9A 3D 3F A6 3A E5 0B 32 A6 32 E4 02 E8
X: 3
SWB: 16 05 80 C3 B2 5B 90 1F 21 00 80 9F 8D C8 BA A3 E4 03 E8 BB 13 A3 E8 30 A6 30 F3 E6 62 05 9F A6 C3 21 00 80
X: 3
SWB: 16 05 A0 C3 9F 64 C8 2F 2D 9A 3D A2 C0 3F A6 2A A6 3C D2 24 8C 2C 7B 98 22 A6 C3 A6 A2 9F 08 C4 D3 00 84 12
X: 3
SWB: 16 05 C0 C3 E6 5A 03 94 19 A6 A2 9F FF C3 D3 00 84 04 BC 52 90 0C BB 9B 9F 43 01 0C ED E0 5B 06 97 D7 2F A0
X: 3
SWB: 16 05 E0 C3 0C 2D 9A 3D 3F A6 2B A6 3A 21 00 80 9F 8D C8 A6 A3 A6 B2 9F A6 C3 21 00 80 9F 64 C8 2F 2D 9A 3F
X: 3
SWB: 16 05 00 C4 FC 60 9C 31 FC 50 2F 9A 3F FC 60 9C 32 FC 50 2F 9A 3D A2 C0 3F A6 2C A6 3B A6 4A FC 60 9F FF C3
X: 3
SWB: 16 05 20 C4 A6 24 D3 00 84 10 E5 02 AB BA A3 B4 03 B2 13 A6 C2 9F 08 C4 A6 24 FC 50 A6 42 2F A0 0C 2D 9A 3D
X: 3
SWB: 16 05 40 C4 3F A6 2B A6 3A 21 00 80 9F 8D C8 E6 5A 00 84 11 A1 03 E8 C3 C0 A6 B2 C2 0F B3 12 A3 E8 20 A3 E6
X: 3
SWB: 16 05 60 C4 B0 A1 03 E8 62 05 9F A6 C3 21 00 80 9F 64 C8 A1 02 E8 C2 0F 2F 2D 9A 3F 64 80 A1 03 EF 62 09 9F
X: 3
SWB: 16 05 80 C4 11 C4 A1 03 EB E6 13 10 62 0E 9F 08 C4 21 00 7F 9F 08 C4 2F 9A 3D 3F A1 00 EF C0 10 90 05 21 01
X: 3
SWB: 16 05 A0 C4 00 98 1D 62 03 9F 5B C2 A6 2A 7B BB BB BA EA BB BB BA EA BB BB BA EA BB BB BA EA 21 01 00 ED 01
X: 3
SWB: 16 05 C0 C4 2F 2D 9A 3D 3F A6 2B A1 0A EF 62 03 9F 5B C2 BA 12 C2 10 A6 B3 C3 C0 B3 12 A3 EF 20 64 80 21 09
X: 3
SWB: 16 05 E0 C4 00 9F 11 C4 21 00 80 9F BA C1 21 03 EF 9F 08 C4 21 00 7F 9F 08 C4 63 03 A6 B2 9F E0 C1 A1 00 EF
X: 3
SWB: 16 05 00 C5 C0 40 90 07 63 80 A6 32 9F BA C1 64 80 A1 03 EF 62 09 9F 11 C4 2F 2D 9A 3F 24 92 80 60 10 F1 00
X: 3
SWB: 16 05 20 C5 21 00 08 9F 8D C8 09 F0 2F 9A 3F 24 40 80 01 01 19 F0 24 92 80 60 EF F0 00 21 00 08 9F 64 C8 2F
X: 3
SWB: 16 05 40 C5 9A 3F 9F 6E C5 32 21 00 08 9F 54 C8 2F 9A 3F 21 01 03 9F 0C C0 24 40 80 62 01 52 00 2F 9A 3F 21
X: 3
SWB: 16 05 60 C5 03 03 9F 0C C0 24 40 80 62 01 52 00 2F 9A 3D 3F 25 90 80 60 EF F0 42 21 00 03 9F 0C C0 24 40 80
X: 3
SWB: 16 05 80 C5 72 52 00 62 EF 52 40 2F 2D 9A 3D 3F F6 15 9F 91 01 D2 00 90 0A 9F 44 C6 F6 51 9C 28 9F 17 C6 2F
X: 3
SWB: 16 05 A0 C5 2D 9A 3D 3E 3F A7 01 F6 16 F6 25 56 C0 9F 91 01 D2 00 90 24 9F 44 C6 46 C0 F6 52 F6 61 9F F5 D1
X: 3
SWB: 16 05 C0 C5 46 C0 F6 52 F6 61 9F 49 CE FB 90 09 46 C0 F6 52 F6 61 9F 6F C6 9F 17 C6 A9 2F 2E 2D 9A 3D 3F 05
X: 3
SWB: 16 05 E0 C5 C4 98 05 3D 3F 25 80 5F 39 3A 3B 9F 91 01 D2 00 90 0D 9F 44 C6 2B 2A 29 1D FE 2F 2D 9B A3 D3 21
X: 3
SWB: 16 05 00 C6 00 00 AE 2F 2D 9A 3F A1 00 F3 90 09 A4 F3 00 21 00 40 9F 64 C8 2F 9A 3F A1 00 F3 84 06 21 00 40
X: 3
SWB: 16 05 20 C6 9F 64 C8 2F 9A 3F A1 00 F3 84 16 21 00 40 9F 6F C8 FB 90 0D 9F B7 C9 E6 12 80 A3 F3 20 62 01 98
X: 3
SWB: 16 05 40 C6 01 72 2F 9A 3F A1 00 F3 90 0C 9F B7 C9 60 7F E4 00 F3 B2 50 90 06 21 00 40 9F 8D C8 2F 9A 3D 3F
X: 3
SWB: 16 05 60 C6 9F 44 C6 9C 20 F6 15 9F 17 C6 F6 51 2F 2D 9A 9B C0 D4 3D 3F F6 15 9F 91 01 D2 00 90 0A 9F 44 C6
X: 3
SWB: 16 05 80 C6 F6 51 9C 25 9F 17 C6 2F 2D 9A 3D 3E 3F A7 01 F6 16 F6 25 56 C0 9F 91 01 D2 00 90 0E 9F 44 C6 46
X: 3
SWB: 16 05 A0 C6 C0 F6 52 F6 61 9C 24 9F 17 C6 A9 2F 2E 2D 9A 3F A7 01 66 01 F6 82 9C 23 42 C0 A9 2F 9A 3F A7 02
X: 3
SWB: 16 05 C0 C6 66 02 F6 82 9C 23 01 C0 AA 2F 9A FC 60 24 90 80 72 52 00 52 01 52 02 52 03 52 04 52 05 9A 3F E7
X: 3
SWB: 16 05 E0 C6 28 10 A6 02 63 30 9F E0 C1 2F 9A A1 02 F4 9A 63 FF 98 11 9A FC 60 C2 3F E4 42 F4 A3 F4 20 FC 50
X: 3
SWB: 16 05 00 C7 31 98 01 9A 3F A6 35 A6 24 21 F4 00 9F 48 CA A1 03 F4 62 0D 9F 08 C4 2F 9A 24 14 80 60 F7 F0 00
X: 3
SWB: 16 05 20 C7 9A 24 10 80 42 03 73 E7 28 04 A6 12 A2 30 73 A9 E7 08 04 E8 11 C2 01 9A 3F 24 92 80 60 7F F0 00
X: 3
SWB: 16 05 40 C7 21 00 20 9F 64 C8 2F 9A 3F 24 10 80 64 04 54 04 74 54 04 E6 13 01 A3 00 30 52 06 62 04 52 07 32
X: 3
SWB: 16 05 60 C7 21 00 20 9F 54 C8 2F 9A 24 10 80 42 03 E7 28 02 A6 12 9A 3F A6 24 C4 18 C3 07 B3 14 24 10 80 54
X: 3
SWB: 16 05 80 C7 07 65 80 A6 24 21 14 80 9F 48 CA 2F 9A 24 14 80 60 08 F1 00 9A D2 00 90 08 24 50 80 60 08 F1 00
X: 3
SWB: 16 05 A0 C7 9A 24 50 80 60 F7 F0 00 9A A6 24 A6 35 A1 00 F5 90 05 21 01 00 98 15 24 60 80 42 00 73 B3 B3 B2
X: 3
SWB: 16 05 C0 C7 E2 B3 B3 B2 E2 B3 B3 B2 E2 73 C2 01 A3 F5 20 24 60 80 62 01 52 00 54 01 D4 00 90 0C 62 04 52 00
X: 3
SWB: 16 05 E0 C7 D5 00 90 04 60 02 F1 00 9A A1 00 F5 90 04 21 01 00 9A 24 60 80 42 00 73 B3 B3 B2 E2 B3 B3 B2 E2
X: 3
SWB: 16 05 00 C8 B3 B3 B2 E2 73 C2 01 9A 24 60 80 60 01 F1 00 24 90 80 62 FB 52 00 9A FC 60 A6 20 F3 FD FC 50 9A
X: 3
SWB: 16 05 20 C8 FC 60 B2 A2 E4 02 FD A3 FD 20 FC 50 9A 3F 21 19 00 A6 24 21 00 01 9C 38 24 00 01 62 84 52 02 1C
X: 3
SWB: 16 05 40 C8 F6 21 FF FF 19 F8 A4 FC 00 A4 FD 00 A4 FA 00 A4 FB 00 2F 9A FC 60 E9 A3 F5 03 F8 EA 01 E9 13 1B
X: 3
SWB: 16 05 60 C8 F8 FC 50 9A FC 60 0A F8 E9 12 1A F8 FC 50 9A FC 60 0B F8 EB 01 E9 A2 EB 02 1A F8 FC 50 9A 2F FC
X: 3
SWB: 16 05 80 C8 00 2F 2E 2D 2C 2B 2A 29 A9 F6 09 28 FE 39 FC 60 0B F8 EB 01 E9 A0 EB 00 18 F8 FC 50 FB 90 02 AA
X: 3
SWB: 16 05 A0 C8 9A 29 9D 6D C9 60 7F F0 02 11 03 98 03 9D 6D C9 9D 79 C9 F6 90 A6 14 C4 20 E6 14 80 24 00 01 75
X: 3
SWB: 16 05 C0 C8 0B F8 01 03 84 08 40 02 B4 00 84 0C 98 2D EB 01 90 29 E9 A0 EB 00 18 F8 00 00 F6 08 1C F6 60 80
X: 3
SWB: 16 05 E0 C8 F1 02 C0 40 93 98 2E 2D 30 10 03 60 9F F0 02 C0 04 84 02 FC 40 28 9E 00 00 98 39 40 02 E6 40 40
X: 3
SWB: 16 05 00 C9 C0 44 84 04 00 00 F6 08 20 05 00 E8 24 B5 95 E4 55 FB 97 AE A1 04 FC 90 17 A1 00 FD 84 12 65 02
X: 3
SWB: 16 05 20 C9 D4 01 84 01 75 24 50 80 40 00 C0 08 B5 10 50 00 FC 80 99 7C 0C F6 30 50 02 10 03 99 73 FC 60 30
X: 3
SWB: 16 05 40 C9 18 F6 62 04 9D 89 C9 9D 8F C9 B2 82 8B F6 A1 00 FA A3 FB 00 99 5A 32 9D 6D C9 9D 79 C9 F6 25 9D
X: 3
SWB: 16 05 60 C9 89 C9 F9 50 90 02 F6 52 9D 8F C9 99 43 3F 3D 3E 0C F6 FC 60 60 40 F1 02 FD FC 60 0C F6 F9 40 90
X: 3
SWB: 16 05 80 C9 07 F6 80 10 00 30 18 F6 FD E7 28 02 9E 67 00 F9 20 90 12 20 FA FF E8 24 12 04 E6 13 D0 E4 52 FA
X: 3
SWB: 16 05 A0 C9 94 03 A3 FA 20 F6 42 24 00 01 E7 28 05 E8 24 12 00 53 02 30 10 03 FD 0A F6 84 02 72 9A 21 00 01
X: 3
SWB: 16 05 C0 C9 F6 23 E9 C3 F6 31 22 CD CC 9C 42 9A 31 24 F6 04 22 A0 07 98 07 F4 21 00 EC 94 EC 94 EA 54 83 F5
X: 3
SWB: 16 05 E0 C9 E9 A1 9A 3F FC 60 9F CC C9 E9 A1 24 A0 07 11 00 FC 50 2F 9A 3D 3F FC 60 24 A0 07 05 00 9F CC C9
X: 3
SWB: 16 05 00 CA FC 50 74 E9 C5 84 02 64 01 A6 42 2F 2D 9A 3F FC 60 9F F4 C9 D2 00 84 10 22 AC 02 21 F6 04 9C 39
X: 3
SWB: 16 05 20 CA 9F CC C9 24 A0 07 11 00 FC 50 2F 9A 3F 3D F6 25 F6 37 9D 31 D6 98 07 44 40 ED 95 9D 37 D6 EF 87
X: 3
SWB: 16 05 40 CA 8B F5 9D 5E D6 2D 2F 9A 9D 31 D6 B5 04 B5 A5 E0 05 00 B0 14 9D 37 D6 9D 5E D6 9A 3F F6 57 F6 25
X: 3
SWB: 16 05 60 CA A6 65 9D 31 D6 98 07 44 40 ED 95 9D 37 D6 B5 85 8B F5 9D 5E D6 F6 75 2F 9A 9D 31 D6 9D 37 D6 9D
X: 3
SWB: 16 05 80 CA 5E D6 9A 9D 31 D6 9D 37 D6 A6 54 9D 37 D6 9D 5E D6 9A 3D 3F 9C 30 21 15 39 9F 08 C4 A6 3B 64 80
X: 3
SWB: 16 05 A0 CA A6 43 62 19 9F 11 C4 D3 00 90 03 7A 98 08 7A E6 5B 00 84 02 6A 01 21 15 00 9F 08 C4 D3 00 90 01
X: 3
SWB: 16 05 C0 CA 7A A6 A2 2F 2D 9A 3F 9F 92 CA 2F 9A 3F A7 01 66 01 F6 82 21 08 01 9C 23 42 C0 A9 2F 9A 3F A7 02
X: 3
SWB: 16 05 E0 CA 66 02 F6 82 21 04 00 9C 23 01 C0 AA 2F 9A 3F 9F DD CA 74 E9 A0 90 02 64 01 A6 42 2F 9A 3F A7 02
X: 3
SWB: 16 05 00 CB 9F EE CA D2 00 84 0F 21 00 45 11 C0 66 02 F6 82 21 04 00 9F 8A C6 AA 2F 9A 3F A7 02 66 02 F6 82
X: 3
SWB: 16 05 20 CB 21 02 00 9C 23 01 C0 AA 2F 9A 3D 3F F6 15 66 0A F6 12 21 09 00 9C 23 72 52 4A 2F 2D 9A DD 00 88
X: 3
SWB: 16 05 40 CB 04 E9 B1 EA F2 9A A6 24 21 00 01 A6 40 B3 00 84 0A B2 92 D2 08 90 04 B3 63 99 F0 9A 3F F6 23 22
X: 3
SWB: 16 05 60 CB 64 00 9F 78 CF 20 64 00 E8 51 94 03 21 64 00 2F 9A 3D F6 25 D6 00 90 09 EA 51 80 05 21 64 00 98
X: 3
SWB: 16 05 80 CB 11 22 64 00 9C 44 ED 83 34 EB 21 EC 32 F6 54 35 9C 4B 2D 9A 3D 9C 44 20 32 00 E8 21 30 E8 32 24
X: 3
SWB: 16 05 A0 CB 64 00 35 9C 4A 2D 9A 3F 23 E8 03 9F 78 CF 2F 9A 3F 23 10 27 9F 0D CF 2F 9A 3D 3E 3F A7 0A F6 15
X: 3
SWB: 16 05 C0 CB 12 C4 13 C0 31 11 C2 4D 40 4E 41 4F 42 4C 43 A6 D2 A6 E3 32 3A 39 01 C4 02 C6 9C 45 AC 66 10 9C
X: 3
SWB: 16 05 E0 CB 4F 11 C6 12 C8 66 10 A6 D2 A6 E3 A6 F4 A6 C5 9C 4E 3A 39 01 C4 02 C6 9C 45 AC F4 21 C6 F4 3A C8
X: 3
SWB: 16 05 00 CC 11 C6 12 C8 01 C4 A6 30 A6 14 A6 15 3A 39 31 22 01 00 F4 C9 C4 F4 D2 C6 9C 45 AC F4 21 C6 F4 3A
X: 3
SWB: 16 05 20 CC C8 11 40 12 42 A5 0A 2F 2E 2D 9A F6 14 01 00 02 02 66 10 20 00 80 E8 21 30 E8 32 9C 4E 9A 3F 72
X: 3
SWB: 16 05 40 CC 9F 95 C7 9C 56 2F 9A F6 14 01 00 E9 A0 90 04 E9 91 11 00 9A 3D 3E 3F A7 0C 11 C6 12 C8 13 CA EB
X: 3
SWB: 16 05 60 CC 52 94 04 12 CA 13 C8 02 D4 01 C8 00 C6 9E 00 00 F6 15 F4 CD D2 F9 50 90 99 02 D4 01 CA 00 C6 9E
X: 3
SWB: 16 05 80 CC 00 00 F4 C9 D2 FB 84 04 01 CA 98 84 ED 41 B3 60 80 77 BB 60 80 10 06 CA F4 CE C8 02 C8 12 C2 21
X: 3
SWB: 16 05 A0 CC 01 00 11 C4 98 09 06 C8 F4 CE CA 02 CA 99 EE BD 60 88 04 EE 91 98 02 EE 81 B3 60 80 02 E9 91 E5
X: 3
SWB: 16 05 C0 CC 7D 30 B2 EC 01 C2 EE 21 F4 51 CA 94 02 01 CA F6 15 00 C8 E9 50 94 02 05 C8 02 D4 F6 51 00 C6 9E
X: 3
SWB: 16 05 E0 CC 00 00 F4 C9 D2 11 C0 30 E8 E1 8C 02 15 C2 F6 61 9C 3A 20 01 00 E8 E1 94 15 F8 C0 90 11 F4 91 C4
X: 3
SWB: 16 05 00 CD 11 C4 20 29 00 E9 C0 87 A6 32 12 C8 98 04 01 C2 11 C8 01 C8 A5 0C 2F 2E 2D 9A 3D 3E 3F A7 06 F6
X: 3
SWB: 16 05 20 CD 16 F6 27 F4 CF 82 F4 CB 84 13 C0 05 80 F6 71 A6 30 A6 14 A6 15 11 C2 12 C4 3A 39 01 C6 02 C8 9C
X: 3
SWB: 16 05 40 CD 45 AC F6 53 A6 70 A6 18 A6 19 3C 3B 9C 45 AC ED 95 F6 54 A6 90 A6 1A A6 1B 9C 4A 03 86 04 88 E9
X: 3
SWB: 16 05 60 CD 23 EA 34 13 86 14 88 05 80 01 C0 F6 52 9C 43 03 C2 04 C4 3C 3B 9C 45 AC ED 95 F6 54 A6 90 A6 1A
X: 3
SWB: 16 05 80 CD A6 1B 9C 4A 03 8A 04 8C E9 23 EA 34 13 8A 14 8C F4 94 80 14 80 F6 71 F6 42 9C 48 02 82 E9 22 12
X: 3
SWB: 16 05 A0 CD 82 01 C0 F6 42 9C 48 02 84 E9 22 12 84 AE 2F 2E 2D 9A 3D 3E 3F A7 06 F6 15 12 C0 42 46 52 C2 43
X: 3
SWB: 16 05 C0 CD 47 53 C3 42 48 52 C4 43 49 53 C5 42 C2 E0 12 C3 E0 12 C4 B3 12 D2 00 90 41 01 4A 02 4C 9C 52 F6
X: 3
SWB: 16 05 E0 CD 16 F6 27 01 C0 F4 C9 42 11 C0 A6 30 A6 14 A6 15 9C 52 3A 39 F6 61 F6 72 9C 46 AC F6 16 F6 27 42
X: 3
SWB: 16 05 00 CE C2 43 C3 44 C4 45 C5 9C 52 3A 39 F6 61 F6 72 9C 4C AC 9D 27 D9 F4 21 44 98 02 01 44 AE 2F 2E 2D
X: 3
SWB: 16 05 20 CE 9A A2 A0 3E F6 16 A6 4A 22 00 80 98 11 BA 8A A6 A6 77 EB 64 EE 24 01 00 E9 E2 88 02 F6 12 E6 5A
X: 3
SWB: 16 05 40 CE 00 87 EA F6 21 2E A0 0A 9A 77 3F F6 57 F6 14 F6 25 31 EB 83 80 10 42 00 E0 C2 40 84 06 EC 94 ED
X: 3
SWB: 16 05 60 CE 95 99 EF E5 D3 33 F6 75 2F 9A 9C 43 66 10 20 00 80 E8 21 30 E8 32 9C 4E 9A 3D A2 C0 3F A7 02 F6
X: 3
SWB: 16 05 80 CE 14 12 C0 A6 6C 01 00 F6 45 98 0E F6 12 01 C0 9F 6C D6 F4 21 42 ED 95 ED 95 BC 8C E6 5C 00 87 EB
X: 3
SWB: 16 05 A0 CE AA 2F A0 0C 2D 9A 3D 3E F6 15 F6 26 F7 00 00 F7 00 00 9C 54 AC DA 00 94 0E F7 00 3F F7 00 00 F6
X: 3
SWB: 16 05 C0 CE 51 F6 62 9C 40 98 0C F7 00 3F F7 00 00 F6 51 F6 62 9C 41 AC 9D 27 D9 2E 2D 9A 66 10 20 00 80 E8
X: 3
SWB: 16 05 E0 CE 21 30 E8 32 9C 4E 9A 3F 9F E0 BF 9F 6E C5 72 9F B7 D1 FC 60 31 9F A9 C7 24 92 80 72 52 00 24 91
X: 3
SWB: 16 05 00 CF 80 52 00 24 90 80 52 00 9F E3 C9 2F 9A 3D 3E 3F A7 06 11 C0 12 C2 13 C4 F9 30 90 1D 9C 3A F6 16
X: 3
SWB: 16 05 20 CF 01 C2 9C 3A F6 15 01 C4 9C 3A F6 13 F6 52 F6 61 9F 78 CF F6 12 B3 60 80 03 22 FF 7F 01 C2 F4 41
X: 3
SWB: 16 05 40 CF C4 F4 41 C0 B3 60 80 02 EA B2 F6 21 AE 2F 2E 2D 9A 3F FC 60 D2 00 84 03 9B 19 00 73 9F A9 C7 99
X: 3
SWB: 16 05 60 CF FE EA C1 B3 60 80 01 31 9A 9C 44 66 10 20 00 80 E8 21 30 E8 32 9C 4E 9A 3D F6 35 90 22 9C 44 BB
X: 3
SWB: 16 05 80 CF B7 BA E6 34 EB 21 EC 32 F6 54 35 9C 4B A6 27 A6 36 B5 14 D4 00 84 08 A6 74 A6 65 F6 21 98 03 21
X: 3
SWB: 16 05 A0 CF FF FF 2D 9A 3D 3E 3F F6 24 4F CA 4C CB F6 15 84 03 31 98 15 E6 AC 40 90 04 F6 51 98 0C E6 AC 08
X: 3
SWB: 16 05 C0 CF 90 05 42 40 73 98 02 01 40 F8 C6 84 05 E6 0C EF 98 14 F9 40 84 06 6D 01 6E 01 98 0D 7D 05 C6 40
X: 3
SWB: 16 05 E0 CF 40 E0 50 00 80 02 6D 01 7E A6 CA 7B 22 06 00 ED 02 24 20 00 ED 04 20 02 00 EA C0 84 19 F9 40 90
X: 3
SWB: 16 05 00 D0 02 EB B3 E6 AA 07 D0 02 84 06 E9 E3 8C A5 98 43 E9 E3 80 9F 98 3D F9 40 90 02 E9 03 20 04 00 EA
X: 3
SWB: 16 05 20 D0 C0 84 0A 32 E9 C3 90 18 22 01 00 98 13 20 06 00 EA C0 90 03 32 98 09 F6 31 90 03 21 01 00 F6 12
X: 3
SWB: 16 05 40 D0 E6 AA 01 90 0A 31 F9 20 84 03 21 01 00 F6 12 F9 20 90 60 04 C8 42 01 A6 20 BF 00 90 07 E6 EC 00
X: 3
SWB: 16 05 60 D0 88 56 98 05 E6 EC 00 80 58 E6 5D 00 90 2E BF A3 E6 EC 00 88 08 B3 02 04 C8 52 01 98 0E FC 60 BF
X: 3
SWB: 16 05 80 D0 12 04 C8 52 01 A6 30 F0 00 FC 50 E6 5E 00 90 31 04 C6 42 00 D2 FF 90 29 B2 92 98 23 E6 EC 00 80
X: 3
SWB: 16 05 A0 D0 06 04 C8 A6 F0 F1 00 E6 AA 10 90 1F 05 C6 E0 92 40 98 16 E6 EC 00 80 09 BF A2 04 C8 E0 02 00 52
X: 3
SWB: 16 05 C0 D0 00 E6 AA 10 90 05 72 05 C6 52 40 2F 2E 2D 9A 3D 3E 3F A7 13 F6 16 12 CF 31 11 CD 63 01 53 CC 32
X: 3
SWB: 16 05 E0 D0 12 CA 98 B0 02 82 23 0A 00 F4 22 CA F6 81 9C 3F 05 C2 90 21 E0 60 C0 80 09 F6 81 F6 50 9E 00 00
X: 3
SWB: 16 05 00 D1 98 11 40 C1 C0 08 90 09 45 40 55 C2 78 58 C3 98 04 01 40 11 C2 02 C4 90 0F 40 C0 C0 40 90 09 F6
X: 3
SWB: 16 05 20 D1 81 F6 20 9E 00 00 11 C4 42 C0 9F A1 D1 A6 26 F8 CF 90 09 42 CC 04 CF E0 02 00 84 0F 02 84 90 11
X: 3
SWB: 16 05 40 D1 E5 2A 46 B5 DB 40 40 B3 00 84 06 42 C1 C2 F8 52 C1 E0 64 CC 54 CC D4 00 84 0D F8 CF 90 09 F4 94
X: 3
SWB: 16 05 60 D1 CF 14 CF 69 01 59 CC 40 C1 A2 00 A2 30 56 D3 72 52 D4 F4 61 D3 F4 21 86 39 00 CC 38 03 C8 02 CC
X: 3
SWB: 16 05 80 D1 01 CA 9F A4 CF F4 92 D3 12 D3 01 D0 E6 22 0A B3 D3 11 D0 AE 02 CD F4 52 80 83 49 A5 13 2F 2E 2D
X: 3
SWB: 16 05 A0 D1 9A 63 01 A6 27 C7 07 98 02 B3 63 B7 87 8B FA C2 3F E7 28 20 A6 12 9A 3F 74 D2 00 90 02 64 01 63
X: 3
SWB: 16 05 C0 D1 0F A6 42 9F 74 C3 21 02 FF 9F BA C1 21 00 80 9F 8D C8 21 07 07 9F A6 C3 21 08 07 9F A6 C3 21 09
X: 3
SWB: 16 05 E0 D1 00 9F A6 C3 A4 E9 00 21 0A 00 9F A6 C3 21 00 80 9F 64 C8 2F 9A 3D 3E 3F A7 04 A6 6D 12 C2 A6 24
X: 3
SWB: 16 05 00 D2 A6 35 12 C0 C2 1F 66 20 E5 C6 26 98 2E A6 6C BD 56 94 02 A6 DC A6 CA 7B F6 53 02 C2 21 D5 04 9C
X: 3
SWB: 16 05 20 D2 3F A6 C6 22 D5 04 01 C0 9C 27 01 C0 ED 21 11 C0 01 C2 ED 21 11 C2 E5 CD CD 66 20 E6 5D 00 87 CD
X: 3
SWB: 16 05 40 D2 AC 2F 2E 2D 9A 3D 0D FE 20 40 00 E8 25 01 40 20 C0 FF E8 25 E9 A0 90 14 20 42 00 E8 25 F4 21 40
X: 3
SWB: 16 05 60 D2 20 BE FF E8 25 E9 A0 90 03 31 98 2E 76 F6 54 20 44 00 E8 24 20 48 00 E8 25 01 40 02 42 F4 21 00
X: 3
SWB: 16 05 80 D2 F4 3A 02 D2 FE 84 0C D3 FF 84 08 D4 FF 84 04 D5 FF 90 02 66 01 E6 46 01 A6 62 2D 9A 3D 3F A7 04
X: 3
SWB: 16 05 A0 D2 0C FE 20 44 00 E8 24 F4 90 00 10 C0 30 F4 38 02 10 C2 25 D5 04 23 20 00 F6 42 E6 24 1C B5 D5 F6
X: 3
SWB: 16 05 C0 D2 51 9C 3F FC 60 09 FE E6 22 40 B3 D3 9C 28 FC 50 66 20 F6 52 09 FE E6 22 60 B3 D3 9F F5 D1 66 04
X: 3
SWB: 16 05 E0 D2 F6 82 09 FE E6 22 44 B3 D3 9F F5 D1 21 FE FF 22 FF FF F4 C9 C0 F4 D2 C2 11 C0 12 C2 66 04 F6 82
X: 3
SWB: 16 05 00 D3 09 FE E6 22 48 B3 D3 9F F5 D1 AC 2F 2D 9A 3D 3F 25 D5 04 C2 C0 11 40 E9 A1 11 42 66 04 F6 52 09
X: 3
SWB: 16 05 20 D3 FE E6 22 40 B3 D3 9F F5 D1 0C FE 20 40 00 E8 24 00 40 F4 C8 00 84 0B 9F 45 D2 D2 00 90 04 62 01
X: 3
SWB: 16 05 40 D3 98 04 9F 9C D2 72 2F 2D 9A 3D 3F 9F 45 D2 D2 00 90 3C 0C FE 20 40 00 E8 24 05 00 F6 51 E6 23 C0
X: 3
SWB: 16 05 60 D3 20 FF 1F E8 51 8C 20 FC 60 F6 51 9C 28 66 40 0A FE F6 51 9F F5 D1 66 40 0A FE F6 51 9F 49 CE FC
X: 3
SWB: 16 05 80 D3 50 FB 90 0A 72 98 19 72 ED A0 84 14 98 10 9F 9C D2 72 0C FE 20 40 00 E8 24 F4 A0 00 84 02 62 01
X: 3
SWB: 16 05 A0 D3 2F 2D 9A 3D 3E 3F A7 0E F6 15 12 C8 13 CA 9F 49 D3 D2 00 90 CE 21 C0 FF ED 01 11 C3 E6 0A 3F 98
X: 3
SWB: 16 05 C0 D3 F0 6B 40 E5 CB AB 5B CC 73 53 CD 01 CC F4 51 CA 8C 04 5B C2 98 04 43 CA 53 C2 5A C6 74 54 C7 46
X: 3
SWB: 16 05 E0 D3 C2 02 C8 01 C3 F4 21 C6 9F 49 CE FB 90 A4 09 FE 9C 28 A6 A6 02 C3 09 FE 9F F5 D1 A6 A6 02 C3 09
X: 3
SWB: 16 05 00 D4 FE 9F 49 CE 0C FE FB 90 0F A6 A6 02 C3 F6 41 9F 6F C6 9F 17 C6 72 98 A2 46 C2 02 C8 01 C6 EC 21
X: 3
SWB: 16 05 20 D4 9F F5 D1 46 C2 02 C8 09 FE F4 21 C6 9F 49 CE 0C FE FB 90 0A 46 C2 02 C8 01 C6 EC 21 99 D1 E0 CB
X: 3
SWB: 16 05 40 D4 C2 5B C5 44 C2 01 C6 E5 2A 24 B3 DB 06 C3 ED 26 46 C5 F6 62 F6 41 ED 21 9F F5 D1 46 C5 F6 62 09
X: 3
SWB: 16 05 60 D4 FE ED 21 9F 49 CE FB 90 0A 46 C5 F6 62 09 FE ED 21 99 9C 01 C3 9F 0E D3 D2 00 93 96 9F 49 D3 D2
X: 3
SWB: 16 05 80 D4 00 84 0F 0C FE 66 40 F6 42 20 40 00 E8 24 01 00 99 7D 42 C2 52 C0 73 53 C1 01 CA F4 C9 C0 11 CA
X: 3
SWB: 16 05 A0 D4 01 C8 F4 21 C0 11 C8 01 C3 E6 22 40 B3 D3 11 C3 7A F8 CA 87 0C 9F 17 C6 62 01 A5 0E 2F 2E 2D 9A
X: 3
SWB: 16 05 C0 D4 3D 3E 3F A7 03 11 C0 F6 26 56 C2 24 E0 5F 40 15 D0 96 90 5D 25 D5 04 23 0C 00 22 C0 5F F6 51 9C
X: 3
SWB: 16 05 E0 D4 3F 01 C0 11 4C 16 50 24 C0 48 14 4E 21 00 49 11 52 43 C2 53 54 68 FF 58 55 66 16 F6 52 21 E0 5F
X: 3
SWB: 16 05 00 D5 9F F5 D1 4A C2 E6 5A 40 94 02 6A 40 A6 A6 F6 62 21 00 49 9F F5 D1 A6 A6 02 C0 21 C0 48 9F F5 D1
X: 3
SWB: 16 05 20 D5 24 D5 04 62 96 52 00 66 01 F6 42 21 F5 5F 9F F5 D1 60 03 F3 F2 AB 2F 2E 2D 9A 38 F6 90 A2 00 39
X: 3
SWB: 16 05 40 D5 3A 3B 3C 3D 3E 3F FC 20 3F 9F 85 36 9B B0 C8 38 F6 90 A2 00 39 3A 3B 3C 3D 3E 3F FC 20 3F 26 90
X: 3
SWB: 16 05 60 D5 80 4A 80 E0 0A 82 40 80 C0 08 90 0D 60 F7 50 80 40 82 C0 08 90 03 9F AF 44 A6 A0 C0 04 90 07 60
X: 3
SWB: 16 05 80 D5 FB 50 80 9F DD D5 A6 A0 C0 01 90 07 60 FE 50 80 9F 97 41 A6 A0 C0 02 90 07 60 FD 50 80 9F D5 D5
X: 3
SWB: 16 05 A0 D5 9B B0 C8 38 F6 90 A2 00 39 3A 3B 3C 3D 3E 3F FC 20 3F 26 90 80 4A 80 E0 0A 82 C0 10 90 07 60 EF
X: 3
SWB: 16 05 C0 D5 50 80 9F EC 01 A6 A0 C0 20 90 07 60 DF 50 80 9F E8 01 9B B0 C8 24 92 80 60 FD F0 00 9A 24 92 80
X: 3
SWB: 16 05 E0 D5 60 FB F0 00 9A 38 F6 90 A2 00 39 3A 3B 3C 3D 3E 3F FC 20 3F 26 90 80 05 80 F4 05 82 C0 40 90 0B
X: 3
SWB: 16 05 00 D6 60 FE F0 86 60 BF 50 80 9F 20 D6 A6 B0 C0 02 90 03 9F 7B D6 A6 B0 C0 01 90 03 9F 9C 00 9B B0 C8
X: 3
SWB: 16 05 20 D6 9A 3F 24 92 80 60 80 F1 00 21 00 20 9F A2 C8 2F 9A F6 14 33 FC 60 FD 21 F6 04 E9 54 80 1B 21 A2
X: 3
SWB: 16 05 40 D6 07 E9 54 88 14 42 00 73 E5 C2 42 E5 D3 33 A6 80 C0 01 90 03 A6 23 72 E9 23 54 00 EC 94 FD 24 A0
X: 3
SWB: 16 05 60 D6 07 F4 23 00 13 00 FC 50 FD 62 01 9A 9C 43 66 0F 20 00 40 E8 21 30 E8 32 9C 4E 9A 24 92 80 60 FD
X: 3
SWB: 16 05 80 D6 F0 00 9A A2 A0 F6 14 01 C1 44 C3 47 C4 E0 60 C3 B7 77 90 90 B7 A0 90 7D E6 C7 7F 80 87 D7 30 94
X: 3
SWB: 16 05 A0 D6 08 47 C4 CF 80 84 69 98 6C E6 14 80 75 76 D7 17 8C 4B 90 18 E5 B7 00 B4 B4 B3 E3 B2 E2 B6 E6 B7
X: 3
SWB: 16 05 C0 D6 87 87 F4 B6 66 B2 D2 B3 D3 B4 D4 76 77 40 C4 C8 80 84 10 F4 21 00 F4 3A 02 E0 36 04 E0 37 05 88
X: 3
SWB: 16 05 E0 D6 34 98 39 F4 C9 00 F4 D2 02 E0 D6 04 E0 D7 05 88 1F E9 B1 B4 F4 B5 F5 B6 F6 B7 F7 98 1F A6 0A 77
X: 3
SWB: 16 05 00 D7 E9 61 B4 74 B5 75 B6 76 B7 77 BA 8A 87 F2 99 BD 23 00 00 98 03 23 FF FF F6 31 F6 32 11 00 12 02
X: 3
SWB: 16 05 20 D7 56 04 57 05 A0 0A 9A 3F 3D B4 60 B5 76 84 06 22 80 3F 31 98 B9 D6 86 94 06 B5 60 84 AF 98 B2 D6
X: 3
SWB: 16 05 40 D7 67 97 EC E6 26 18 B4 64 B5 60 B6 E5 B4 E4 9C 50 25 B1 00 24 18 72 9C 4A A6 26 A6 37 F6 41 F6 52
X: 3
SWB: 16 05 60 D7 BB 60 80 0E B6 86 B7 C7 20 18 72 E8 21 20 B1 00 E8 32 A6 45 A6 34 A6 23 72 B5 B5 B4 E4 B3 E3 B2
X: 3
SWB: 16 05 80 D7 E2 DF 00 84 02 D6 7F 8C 68 DF FF 84 02 D6 82 80 5B A7 09 56 C0 11 C1 12 C3 31 11 C5 52 C7 65 80
X: 3
SWB: 16 05 A0 D7 55 C8 76 A6 65 9F 98 D8 F4 C9 C1 F4 D2 C3 E9 B1 EA F2 B5 60 88 11 11 C1 12 C3 B6 97 01 C5 02 C7
X: 3
SWB: 16 05 C0 D7 9F 10 D9 11 C5 12 C7 B6 96 D6 18 97 D6 01 C6 44 C8 40 C5 E6 20 80 B2 D2 B3 D3 B4 D4 45 C0 E6 25
X: 3
SWB: 16 05 E0 D7 7F B4 64 B5 B5 B4 E4 A5 09 2D 2F 9A 31 32 2D 2F 9A 72 73 22 80 7F 99 F6 3F B4 60 B5 76 90 92 88
X: 3
SWB: 16 05 00 D8 90 A7 0D E6 C6 7F 56 CC 66 9E B4 64 B6 B5 B4 E4 9C 51 11 C0 12 C2 65 80 74 73 72 11 C4 12 C6 11
X: 3
SWB: 16 05 20 D8 C8 11 CA 76 B6 97 01 C4 02 C6 9F 10 D9 88 27 E0 55 C3 84 0D E0 54 C2 84 08 E0 53 C1 84 03 E0 52
X: 3
SWB: 16 05 40 D8 C0 8C 13 11 C4 12 C6 A6 65 9F 98 D8 F4 21 C8 11 C8 F4 3A CA 12 CA B6 96 D6 18 97 C8 42 CC E9 09
X: 3
SWB: 16 05 60 D8 A6 34 A6 35 9C 52 20 18 72 10 C0 20 31 3F 10 C2 9C 46 11 C0 12 C2 01 C8 02 CA 9C 52 B4 60 B5 76
X: 3
SWB: 16 05 80 D8 90 09 E6 C6 1F B4 64 B6 B5 B4 E4 9C 40 A5 0D 2F 9A 72 73 22 80 FF 99 F7 D5 09 94 23 24 00 01 72
X: 3
SWB: 16 05 A0 D8 73 64 10 E6 C5 0A 90 12 B9 B9 B8 E8 B9 B9 B8 E8 B4 B4 B3 E3 B2 E2 B5 85 87 EE EC C1 B4 C4 9A F6
X: 3
SWB: 16 05 C0 D8 74 E7 58 07 9E CA D8 F6 47 9A 21 D9 47 22 E6 33 9A 21 C8 F7 22 8F 1C 9A 21 B7 83 22 13 0F 9A 21
X: 3
SWB: 16 05 E0 D8 30 8C 22 C2 07 9A 21 62 53 22 F0 03 9A 21 8B 0A 22 FC 01 9A 21 53 01 22 FF 00 9A 21 2B C0 22 7F
X: 3
SWB: 16 05 00 D9 00 9A 21 05 F0 22 3F 00 9A 21 01 FC 22 1F 00 9A F6 14 F6 25 90 0C BB BB BA EA B9 E9 B8 E8 B7 87
X: 3
SWB: 16 05 20 D9 87 F4 EC 21 ED 32 9A 77 98 04 67 80 98 00 B5 60 B7 E7 D7 C0 90 50 B4 60 B5 76 90 4A E6 C6 7E 80
X: 3
SWB: 16 05 40 D9 45 90 43 E6 14 80 A6 32 A6 43 E6 F6 10 80 2A 90 15 D6 08 80 09 A6 06 A6 32 73 A6 60 90 08 B3 B3
X: 3
SWB: 16 05 60 D9 B2 E2 B6 86 87 F8 CF 40 90 01 FD B7 60 80 02 E9 B1 E5 40 73 C0 80 84 01 FD 21 FF FF B7 60 88 09
X: 3
SWB: 16 05 80 D9 E6 20 80 B0 43 FD 73 72 FD 63 80 99 FA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 A0 D9 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 C0 D9 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 E0 D9 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 00 DA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 20 DA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 40 DA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 60 DA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 80 DA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 A0 DA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 C0 DA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 E0 DA FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 00 DB FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 20 DB FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 40 DB FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 60 DB FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 80 DB FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 A0 DB FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 C0 DB FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 E0 DB FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 00 DC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 20 DC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 40 DC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 60 DC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 80 DC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 A0 DC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 C0 DC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 E0 DC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 00 DD FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 20 DD FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 40 DD FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 60 DD FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 80 DD FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 A0 DD FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 C0 DD FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 E0 DD FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 00 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 20 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 40 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 60 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 80 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 A0 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 C0 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 E0 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 00 DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 20 DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 40 DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 60 DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 80 DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 A0 DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 C0 DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SWB: 16 05 E0 DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 3
SCW: 16 12 5B 8D
X: 50
SWW: 16 00 20 00
SWW: 16 1A DE 83
SWB: 16 05 20 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 100
SWW: 16 00 20 00
SWW: 16 1A DE 83
SCW: 16 13 26 EB
SWW: 16 00 40 00
SWW: 16 1A DE 83
SWB: 16 05 40 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 100
SWW: 16 00 40 00
SWW: 16 1A DE 83
SCW: 16 13 26 EB
SWW: 16 00 60 00
SWW: 16 1A DE 83
SWB: 16 05 60 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 250
SWW: 16 00 60 00
SWW: 16 1A DE 83
SCW: 16 13 26 EB
SWW: 16 00 00 00
SWW: 16 1A DE 83
SWB: 16 05 00 00 FF FF 5B 8D FF FF 19 10 00 45 00 05 03 00 58 05 04 75 02 0A 00 00 FF FF 00 00 90 00 03 12 00 70
X: 100
SWW: 16 1A DE 83
SWW: 16 00 00 00
SWW: 16 00 00 00
SWW: 16 1A DE 83
SCW: 16 13 E4 27
SWW: 16 00 80 00
SWW: 16 1A DE 83
SWB: 16 05 80 00 01 23 45 67 89 AB CD EF FE DC BA 98 76 54 32 10 14 04 72 36 FF FF FF FF 23 76 21 17 57 28 98 2A
X: 250
SWW: 16 00 80 00
SWW: 16 1A DE 83
SCW: 16 13 95 24
SWW: 16 00 A0 00
SWW: 16 1A DE 83
SWB: 16 05 A0 00 14 2B 8A 2C 18 2D 9B 2E 45 3C 89 5D FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 250
SWW: 16 00 A0 00
SWW: 16 1A DE 83
SCW: 16 13 F4 A4
SWW: 16 00 C0 00
SWW: 16 1A DE 83
SWB: 16 05 C0 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 100
SWW: 16 00 C0 00
SWW: 16 1A DE 83
SCW: 16 13 26 EB
SWW: 16 00 E0 00
SWW: 16 1A DE 83
SWB: 16 05 E0 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 100
SWW: 16 00 E0 00
SWW: 16 1A DE 83
SCW: 16 13 26 EB
;Set Field Updater tokens by poking 08 to 0000 and B8 to 0002
;Set Address to 0x0000
SWW: 16 09 00 00
;Read Value at address 0x0000
;SCW: 16 0B
;Set bit 3 and write value to address 0
;dataUpdate = (dataRead & 0xff) | 0x8; Instead setting hardcoded value that works
SWW: 16 0A 0A 00
;Set Address to 0x0002
SWW: 16 09 02 00
;Write Value B8 to 0x0002
SWW: 16 0A B8 00
SWW: 16 00 A0 01
SWW: 16 1A DE 83
SWB: 16 05 A0 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 100
SWW: 16 00 A0 01
SWW: 16 1A DE 83
SCW: 16 13 26 EB
SWW: 16 00 C0 01
SWW: 16 1A DE 83
SWB: 16 05 C0 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 100
SWW: 16 00 C0 01
SWW: 16 1A DE 83
SCW: 16 13 26 EB
SWW: 16 00 E0 01
SWW: 16 1A DE 83
SWB: 16 05 E0 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 250
SWW: 16 00 E0 01
SWW: 16 1A DE 83
SCW: 16 13 26 EB
SWW: 16 00 80 01
SWW: 16 1A DE 83
SWB: 16 05 82 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 250
SWW: 16 00 80 01
SWW: 16 1A DE 83
SCW: 16 13 26 EB
SWW: 16 00 00 00
SWW: 16 1A DE 83
SWB: 16 05 00 00 54 54
X: 100
SWW: 16 00 00 00
SWW: 16 1A DE 83
SCL: 16 03 20 54 54 5B 8D FF FF 19 10 00 45 00 05 03 00 58 05 04 75 02 0A 00 00 FF FF 00 00 90 00 03 12 00 70
SWW: 16 09 00 00
;SCW: 16 0B
SWW: 16 0A 0A 00
SWW: 16 09 02 00
SWW: 16 0A B8 00
SWW: 16 00 80 01
SWW: 16 1A DE 83
SWB: 16 05 80 01 FF FF
X: 250
SWW: 16 00 80 01
SWW: 16 1A DE 83
SCL: 16 03 20 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
X: 250
;Clear Tokens by poking 00 to both locations
SWW: 16 09 00 00
;SCW: 16 0B
;Clear bit 3 and write value to address 0
;dataUpdate = (dataRead & 0xff) | 0x8;Instead setting hardcoded value that works
SWW: 16 0A 02 00
SWW: 16 09 02 00
;Write Value 00 to 0x0002
SWW: 16 0A 00 00
;Execute Firmware
SWC: 16 08
Nirav Patel
Communication_Code_slua801.pdf
#include <string.h>
// esp-idf includes
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include "esp_err.h"
#include "esp_log.h"
#include "esp_psram.h"
#include "inttypes.h"
////Decoder includes
#include "bq40z50_interface.h"
#include "../hal/bq40z50.h"
#include "../hal/bq40z50_new.h"
#include "../hal/bq40z50_registers.h"
#include "../peripherals/i2c_hal.h"
#include "../peripherals/defer.h"
#include "../main/mem_util.h"
#define MAX_HEX_VALUES 40
static const char *TAG = "BQ40Z50-Interface";
static const char *TAG_GOLDENFILE = "BQ40Z50-Interface-GoldenFile";
extern const char goldenFileFlash_start[] asm("_binary_goldenimagefinal_fs_start");
extern const char goldenFileFlash_end[] asm("_binary_goldenimagefinal_fs_end");
// golden file write code variables
uint8_t bq40z50_i2c_addr = 0;
uint32_t fs_remaining_bytes = 0;
uint16_t fs_heap_size = 20000;
bool BQ40Z50_isICPresent()
    // Can we just access a register?
    bq40z50_reg_operationStatus opStats = {};
    esp_err_t error = BQ40Z50_getOperationalStatus(&opStats);
    if (error != ESP_OK)
        return false;
    return true;
void BQ40Z50_getBasicInfo()
    uint16_t temp16u = 0;
    int16_t temp16i = 0;
    uint32_t temp32u = 0;
    ESP_LOGI(TAG, "Printing basic fuel gauge info:");
    if (BQ40Z50_getCellVoltage_sum(&temp16u) == ESP_OK)
        ESP_LOGI(TAG, " - TOTAL Voltage  \t%" PRIu16 " mV", temp16u);
    if (BQ40Z50_getCellVoltage_individual(1, &temp16u) == ESP_OK)
        ESP_LOGI(TAG, " - Cell 1 voltage \t%" PRIu16 " mV", temp16u);
    if (BQ40Z50_getCellVoltage_individual(2, &temp16u) == ESP_OK)
        ESP_LOGI(TAG, " - Cell 2 voltage \t%" PRIu16 " mV", temp16u);
    if (BQ40Z50_getCurrent(&temp16i) == ESP_OK)
        ESP_LOGI(TAG, " - Current        \t%" PRIi16 " mA", temp16i);
    if (BQ40Z50_getDesignCapacity(&temp32u) == ESP_OK)
        ESP_LOGI(TAG, " - Design Capacity\t%" PRIu32 " mAh", temp32u);
    if (BQ40Z50_getDesignVoltage(&temp32u) == ESP_OK)
        ESP_LOGI(TAG, " - Design Voltage \t%" PRIu32 " mV", temp32u);
// Operational Configuration
void BQ40Z50_triggerDeviceReset()
    BQ40Z50_Device_Reset();
void BQ40Z50_wipeUnit()
    bq40z50_interface_security_modes_t initalMode = BQ40Z50_getSecurityMode();
    if (initalMode == BQ40Z50_SECURITY_MODE_FAILED)
        ESP_LOGW(TAG, "Failed to query for current security mode");
        return;
    bool securitySetResult = false;
    if (BQ40Z50_setSecurityModeAndValidate(BQ40Z50_SECURITY_MODE_UNSEALED, &securitySetResult) != ESP_OK)
        ESP_LOGW(TAG, "Failed to set and validate security mode, transactions failed");
        return;
    if (!securitySetResult)
        ESP_LOGW(TAG, "Failed to set and validate security mode, security did not change");
        return;
    // Perform the actual wiping of the unit
    // - More should probably be here?
    BQ40Z50_resetData_all();
    // Finally reset modes
    if (BQ40Z50_setSecurityModeAndValidate(initalMode, &securitySetResult) != ESP_OK)
        ESP_LOGW(TAG, "Failed to set and validate security mode, transactions failed, resetting");
        return;
        ESP_LOGW(TAG, "Failed to set and validate security mode, security did not change, resetting");
        return;
// Status Registers pretty printing
void BQ40Z50_queryAndPrintOperationalStatus()
    bq40z50_reg_operationStatus status = {};
    if (BQ40Z50_getOperationalStatus(&status) != ESP_OK)
        ESP_LOGW(TAG, "Failed to query and print operational status!");
    else
        BQ40Z50_printOperationalStatus(&status);
void BQ40Z50_printOperationalStatus(const bq40z50_reg_operationStatus *opsStruct)
    ESP_LOGI(TAG, "Operational Status Register:");
    ESP_LOGI(TAG, " - Emergency FET shutdown active: %d (EMSHUT, Bit 29)", opsStruct->is_emergency_fet_shutdown_active);
    ESP_LOGI(TAG, " - Cell balancing active: %d (CB, Bit 28)", opsStruct->are_we_cell_balancing_status);
    ESP_LOGI(TAG, " - CC measurement in sleep mode enabled: %d (SLPCC, Bit 27)", opsStruct->is_cc_measurement_in_sleep_mode_enabled);
    ESP_LOGI(TAG, " - ADC measurement in sleep mode enabled: %d (SLPAD, Bit 26)", opsStruct->is_adc_measurement_in_sleep_mode_enabled);
    ESP_LOGI(TAG, " - Performing auto CC calibration: %d (SMBLCAL, Bit 25)", opsStruct->performing_auto_cc_calibration);
    ESP_LOGI(TAG, " - Initialization after full reset: %d (INIT, Bit 24)", opsStruct->init_after_full_reset);
    ESP_LOGI(TAG, " - Sleep mode triggered by command: %d (SLEEPM, Bit 23)", opsStruct->are_in_sleep_mode_triggered_by_command);
    ESP_LOGI(TAG, " - Bus in fast mode (400kHz): %d (XL, Bit 22)", opsStruct->is_bus_in_fast_mode);
    ESP_LOGI(TAG, " - Calibration output active (offset): %d (CAL_OFFSET, Bit 21)", opsStruct->is_calibration_output_active_offset);
    ESP_LOGI(TAG, " - Calibration output active: %d (CAL, Bit 20)", opsStruct->is_calibration_output_active);
    ESP_LOGI(TAG, " - In auto calibration mode: %d (AUTOCALM, Bit 19)", opsStruct->is_in_auto_cal_mode);
    ESP_LOGI(TAG, " - Authentication in progress: %d (AUTH, Bit 18)", opsStruct->is_auth_in_progress);
    ESP_LOGI(TAG, " - LED display on: %d (LED, Bit 17)", opsStruct->is_led_display_on);
    ESP_LOGI(TAG, " - Shutdown triggered by command: %d (SDM, Bit 16)", opsStruct->was_shutdown_triggered_by_command);
    ESP_LOGI(TAG, " - In sleep mode: %d (SLEEP, Bit 15)", opsStruct->is_in_sleep);
    ESP_LOGI(TAG, " - Charging disabled: %d (XCHG, Bit 14)", opsStruct->is_charging_disabled);
    ESP_LOGI(TAG, " - Discharging disabled: %d (XDSG, Bit 13)", opsStruct->is_discharging_disabled);
    ESP_LOGI(TAG, " - Permanent failure present: %d (PF, Bit 12)", opsStruct->is_permanent_failure_present);
    ESP_LOGI(TAG, " - Safety failure present: %d (SS, Bit 11)", opsStruct->is_safety_failure_present);
    ESP_LOGI(TAG, " - Shutdown triggered by low pack voltage: %d (SDV, Bit 10)", opsStruct->was_shutdown_triggered_by_low_pack_voltage);
    ESP_LOGI(TAG, " - Security mode: %s (SEC1/SEC2, Bits 9-8)", BQ40Z50_securityModeToChar((bq40z50_interface_security_modes_t)opsStruct->security_mode));
    ESP_LOGI(TAG, " - Battery trip point interrupt: %d (BTP_INT, Bit 7)", opsStruct->battery_trip_point_interrupt);
    ESP_LOGI(TAG, " - Fuse status active: %d (FUSE, Bit 5)", opsStruct->fuse_status);
    ESP_LOGI(TAG, " - Precharge FET enabled: %d (PCHG, Bit 3)", opsStruct->is_precharge_fet_enabled);
    ESP_LOGI(TAG, " - Charge FET enabled: %d (CHG, Bit 2)", opsStruct->is_charge_fet_enabled);
    ESP_LOGI(TAG, " - Discharge FET enabled: %d (DSG, Bit 1)", opsStruct->is_discharge_fet_enabled);
    ESP_LOGI(TAG, " - System present (low): %d (PRES, Bit 0)", opsStruct->is_system_present_low);
void BQ40Z50_queryAndPrintChargingStatus()
    bq40z50_reg_chargingStatus status = {};
    if (BQ40Z50_getChargingStatus(&status) != ESP_OK)
        ESP_LOGW(TAG, "Failed to query and print charging status!");
    else
        BQ40Z50_printChargingStatus(&status);
void BQ40Z50_printChargingStatus(const bq40z50_reg_chargingStatus *status)
    ESP_LOGI(TAG, "Charging Status Register:");
    ESP_LOGI(TAG, " - Near charge termination: %d (NCT, Bit 19)", status->near_charge_termination);
    ESP_LOGI(TAG, " - Charging loss compensation: %d (CCC, Bit 18)", status->charging_loss_compensation);
    ESP_LOGI(TAG, " - Charging voltage rate of change: %d (CVR, Bit 17)", status->charging_voltage_rate_of_change);
    ESP_LOGI(TAG, " - Charging current rate of change: %d (CVR, Bit 16)", status->charging_current_rate_of_change);
    ESP_LOGI(TAG, " - Charge termination: %d (VCT, Bit 15)", status->charge_termination);
    ESP_LOGI(TAG, " - Maintenance charge: %d (MCHG, Bit 14)", status->maintenance_charge);
    ESP_LOGI(TAG, " - Suspend charge: %d (SU, Bit 13)", status->suspend_charge);
    ESP_LOGI(TAG, " - Charge inhibit: %d (IN, Bit 12)", status->charge_inhibit);
    ESP_LOGI(TAG, " - High voltage region: %d (HV, Bit 11)", status->high_voltage_region);
    ESP_LOGI(TAG, " - Mid voltage region: %d (MV, Bit 10)", status->mid_voltage_region);
    ESP_LOGI(TAG, " - Low voltage region: %d (LV, Bit 9)", status->low_voltage_region);
    ESP_LOGI(TAG, " - Precharge voltage region: %d (PV, Bit 9)", status->precharge_voltage_region);
    ESP_LOGI(TAG, " - Over temp region: %d (OT, Bit 6)", status->over_temp_region);
    ESP_LOGI(TAG, " - High temp region: %d (HT, Bit 5)", status->high_temp_region);
    ESP_LOGI(TAG, " - Standard high temp region: %d (STH, Bit 4)", status->standard_high_temp_region);
    ESP_LOGI(TAG, " - Recommended temp region: %d (RT, Bit 3)", status->recommended_temp_region);
    ESP_LOGI(TAG, " - Standard low temp region: %d (STL, Bit 2)", status->standard_low_temp_region);
    ESP_LOGI(TAG, " - Low temp region: %d (LT, Bit 1)", status->low_temp_region);
    ESP_LOGI(TAG, " - Under temp region: %d (UT, Bit 0)", status->under_temp_region);
void BQ40Z50_queryAndPrintGaugingStatus()
    bq40z50_reg_gaugingStatus status = {};
    if (BQ40Z50_getGaugingStatus(&status) != ESP_OK)
        ESP_LOGW(TAG, "Failed to query and print gauging status!");
    else
        BQ40Z50_printGaugingStatus(&status);
void BQ40Z50_printGaugingStatus(const bq40z50_reg_gaugingStatus *status)
    ESP_LOGI(TAG, "Gauging Status Register:");
    ESP_LOGI(TAG, " - Open circuit voltage in flat region: %d (OCVFR, Bit 20)", status->open_circuit_voltage_in_flat_region);
    ESP_LOGI(TAG, " - Load mode: %d (LDMD, Bit 19)", status->load_mode);
    ESP_LOGI(TAG, " - Resistance update: %d (RX, Bit 18)", status->resistance_update);
    ESP_LOGI(TAG, " - Qmax update: %d (QMAX, Bit 17)", status->qmax_update);
    ESP_LOGI(TAG, " - Discharge qualified for learning: %d (VDQ, Bit 16)", status->discharge_qualified_for_learning);
    ESP_LOGI(TAG, " - Negative scale factor mode: %d (NSFM, Bit 15)", status->negative_scale_factor_mode);
    ESP_LOGI(TAG, " - OCV update in sleep mode: %d (SLPQMAX, Bit 13)", status->ocv_update_in_sleep_mode);
    ESP_LOGI(TAG, " - Impedance track gauging: %d (QEN, Bit 12)", status->impedance_track_gauging);
    ESP_LOGI(TAG, " - Voltages ok for qmax update: %d (VOK, Bit 11)", status->voltages_ok_for_qmax_update);
    ESP_LOGI(TAG, " - Not resistance updates: %d (R_DIS, Bit 10)", status->not_resistance_updates);
    ESP_LOGI(TAG, " - Rest: %d (REST, Bit 8)", status->rest);
    ESP_LOGI(TAG, " - Condition flag: %d (CF, Bit 7)", status->condition_flag);
    ESP_LOGI(TAG, " - Discharge relax mode: %d (DSG, Bit 6)", status->discharge_relax_mode);
    ESP_LOGI(TAG, " - End of discharge termination voltage reached: %d (EDV, Bit 5)", status->end_of_discharge_termination_voltage_reached);
    ESP_LOGI(TAG, " - Is cell balancing enabled: %d (BAL_EN, Bit 4)", status->is_cell_balancing_enabled);
    ESP_LOGI(TAG, " - Did terminate charge: %d (TC, Bit 3)", status->did_terminate_charge);
    ESP_LOGI(TAG, " - Did terminate discharge: %d (TD, Bit 2)", status->did_terminate_discharge);
    ESP_LOGI(TAG, " - Is fully charged: %d (FC, Bit 1)", status->is_fully_charged);
    ESP_LOGI(TAG, " - Is fully discharged: %d (FD, Bit 0)", status->is_fully_discharged);
void BQ40Z50_queryAndPrintManufacturingStatus()
    bq40z50_reg_manufacturingStatus status = {};
    if (BQ40Z50_getManufacturingStatus_manufacturer(&status) != ESP_OK)
        ESP_LOGW(TAG, "Failed to query and print manufacturing status!");
    else
        BQ40Z50_printManufacturingStatus(&status);
void BQ40Z50_printManufacturingStatus(const bq40z50_reg_manufacturingStatus *status)
    ESP_LOGI(TAG, "Manufacturing Status Register:");
    ESP_LOGI(TAG, " - In calibration mode: %d (CAL_TEST, Bit 15)", status->is_in_calibration_mode);
    ESP_LOGI(TAG, " - In lifetime speed up mode: %d (LT_TEST, Bit 14)", status->is_in_lifetime_speed_up_mode);
    ESP_LOGI(TAG, " - LED enabled: %d (LED_EN, Bit 9)", status->led_enabled);
    ESP_LOGI(TAG, " - Fuse enabled: %d (FUSE_EN, Bit 8)", status->fuse_en);
    ESP_LOGI(TAG, " - Black box recorder enabled: %d (BBR_EN, Bit 7)", status->black_box_recorder_en);
    ESP_LOGI(TAG, " - Permanent failure enabled: %d (PF_EN, Bit 6)", status->permanent_failure_en);
    ESP_LOGI(TAG, " - Lifetime data collection enabled: %d (LF_EN, Bit 5)", status->lifetime_data_collection_en);
    ESP_LOGI(TAG, " - All FETs enabled: %d (FET_EN, Bit 4)", status->all_fets_en);
    ESP_LOGI(TAG, " - Gauging enabled: %d (GAUGE_EN, Bit 3)", status->gauging_en);
    ESP_LOGI(TAG, " - Discharge FET test enabled: %d (Bit 2)", status->discharge_fet_test_en);
    ESP_LOGI(TAG, " - Charge FET test enabled: %d (Bit 1)", status->charge_fet_test_en);
    ESP_LOGI(TAG, " - Precharge FET test enabled: %d (Bit 0)", status->precharge_fet_test_en);
// Safety / Fault Printing
esp_err_t BQ40Z50_isThereASafetyFault(bool *isThereASafetyFault)
    // Query for the safety fault
    bq40z50_reg_safetyStatus safetyStruct = {};
    if (BQ40Z50_getSafetyStatus(&safetyStruct) != ESP_OK)
        ESP_LOGW(TAG, "isThereASafetyFault: Failed to query for safety fault");
        return ESP_FAIL;
    // Check to see if any register is set!
    *isThereASafetyFault = safetyStruct.val != 0;
    return ESP_OK;
void BQ40Z50_printSafetyFault(bq40z50_reg_safetyStatus *safetyStruct)
    if (safetyStruct->val == 0)
        return;
    ESP_LOGW(TAG, "Found Safety Fault in Fuel Gauge!");
    if (safetyStruct->overcurrent_in_discharge)
        ESP_LOGW(TAG, " - Over current event during discharge! (OCDL, Bit 29)");
    if (safetyStruct->cell_overvoltage_latch)
        ESP_LOGW(TAG, " - Over voltage latch set! (COVL, Bit 28)");
    if (safetyStruct->underTemperature_during_discharge)
        ESP_LOGW(TAG, " - Under temperature during discharge! (UTD, Bit 27)");
    if (safetyStruct->underTemperature_during_charge)
        ESP_LOGW(TAG, " - Under temperature during charge! (UTC, Bit 26)");
    if (safetyStruct->overPrecharge_current)
        ESP_LOGW(TAG, " - Over precharge current! (PCHGC, Bit 25)");
    if (safetyStruct->overCharging_voltage)
        ESP_LOGW(TAG, " - Over charging voltage! (CHGV, Bit 24)");
    if (safetyStruct->overCharging_current)
        ESP_LOGW(TAG, " - Over charging current! (CHGC, Bit 23)");
    if (safetyStruct->overCharge)
        ESP_LOGW(TAG, " - Over charge! (OC, Bit 22)");
    if (safetyStruct->charge_timeout)
        ESP_LOGW(TAG, " - Charge timeout! (CTO, Bit 20)");
    if (safetyStruct->preCharge_timeout)
        ESP_LOGW(TAG, " - Precharge timeout! (PTO, Bit 18)");
    if (safetyStruct->overTemperature_fet)
        ESP_LOGW(TAG, " - Over temperature FET! (OTF, Bit 16)");
    if (safetyStruct->cell_underVoltage_compensated)
        ESP_LOGW(TAG, " - Cell under voltage compensated! (CUVC, Bit 14)");
    if (safetyStruct->overTemperature_during_discharge)
        ESP_LOGW(TAG, " - Over temperature during discharge! (OTD, Bit 13)");
    if (safetyStruct->overTemperature_during_charge)
        ESP_LOGW(TAG, " - Over temperature during charge! (OTC, Bit 12)");
    if (safetyStruct->short_circuit_during_discharge_latch)
        ESP_LOGW(TAG, " - Short circuit during discharge latch! (ASCDL, Bit 11)");
    if (safetyStruct->short_circuit_during_discharge)
        ESP_LOGW(TAG, " - Short circuit during discharge! (ASCD, Bit 10)");
    if (safetyStruct->short_circuit_during_charge_latch)
        ESP_LOGW(TAG, " - Short circuit during charge latch! (ASCCL, Bit 9)");
    if (safetyStruct->short_circuit_during_charge)
        ESP_LOGW(TAG, " - Short circuit during charge! (ASCC, Bit 8)");
    if (safetyStruct->overLoad_during_discharge_latch)
        ESP_LOGW(TAG, " - Overload during discharge latch! (AOLDL, Bit 7)");
    if (safetyStruct->overLoad_during_discharge)
        ESP_LOGW(TAG, " - Overload during discharge! (AOLD, Bit 6)");
    if (safetyStruct->overCurrent_during_discharge_2)
        ESP_LOGW(TAG, " - Over current during discharge 2! (OCD2, Bit 5)");
    if (safetyStruct->overCurrent_during_discharge_1)
        ESP_LOGW(TAG, " - Over current during discharge 1! (OCD1, Bit 4)");
    if (safetyStruct->overCurrent_during_charge_2)
        ESP_LOGW(TAG, " - Over current during charge 2! (OCC2, Bit 3)");
    if (safetyStruct->overCurrent_during_charge_1)
        ESP_LOGW(TAG, " - Over current during charge 1! (OCC1, Bit 2)");
    if (safetyStruct->cell_overVoltage)
        ESP_LOGW(TAG, " - Cell over voltage! (COV, Bit 1)");
    if (safetyStruct->cell_underVoltage)
        ESP_LOGW(TAG, " - Cell under voltage! (CUV, Bit 0)");
esp_err_t BQ40Z50_isThereAPermanentFault(bool *isThereAPermanentFault)
    bq40z50_reg_permanentFailureStatus pfStruct = {};
    if (BQ40Z50_getPermanentFailureStatus(&pfStruct) != ESP_OK)
        ESP_LOGW(TAG, "isThereAPermanentFault: Failed to query for permanent failure fault");
        return ESP_FAIL;
    *isThereAPermanentFault = pfStruct.val != 0;
    return ESP_OK;
void BQ40Z50_printPermanentFault(bq40z50_reg_permanentFailureStatus *permanentFailureStruct)
    if (permanentFailureStruct->val == 0)
        return;
    ESP_LOGW(TAG, "Found Permanent Fault in Fuel Gauge!");
    if (permanentFailureStruct->ts4_openFailure)
        ESP_LOGW(TAG, " - TS4 open failure! (TS4, Bit 31)");
    if (permanentFailureStruct->ts3_openFailure)
        ESP_LOGW(TAG, " - TS3 open failure! (TS3, Bit 30)");
    if (permanentFailureStruct->ts2_openFailure)
        ESP_LOGW(TAG, " - TS2 open failure! (TS2, Bit 29)");
    if (permanentFailureStruct->ts1_openFailure)
        ESP_LOGW(TAG, " - TS1 open failure! (TS1, Bit 28)");
    if (permanentFailureStruct->data_flash_wearOut_failure)
        ESP_LOGW(TAG, " - Data flash wear out failure! (DFW, Bit 26)");
    if (permanentFailureStruct->instruction_flash_checksum_failure)
        ESP_LOGW(TAG, " - Instruction flash checksum failure! (IFC, Bit 24)");
    if (permanentFailureStruct->ptc_failure)
        ESP_LOGW(TAG, " - PTC failure! (PTC, Bit 23)");
    if (permanentFailureStruct->second_level_protector_failure)
        ESP_LOGW(TAG, " - Second level protector failure! (2LVL, Bit 22)");
    if (permanentFailureStruct->analog_frontend_communications_failure)
        ESP_LOGW(TAG, " - Analog frontend communications failure! (AFEC, Bit 21)");
    if (permanentFailureStruct->analog_frontend_register_failure)
        ESP_LOGW(TAG, " - Analog frontend register failure! (AFER, Bit 20)");
    if (permanentFailureStruct->chemical_fuse_failure)
        ESP_LOGW(TAG, " - Chemical fuse failure! (FUSE, Bit 19)");
    if (permanentFailureStruct->overcurrent_in_discharge)
        ESP_LOGW(TAG, " - Overcurrent in discharge! (OCDL, Bit 18)");
    if (permanentFailureStruct->discharge_fet_failure)
        ESP_LOGW(TAG, " - Discharge FET failure! (DFETF, Bit 17)");
    if (permanentFailureStruct->charge_fet_failure)
        ESP_LOGW(TAG, " - Charge FET failure! (CFETF, Bit 16)");
    if (permanentFailureStruct->short_circuit_in_discharge)
        ESP_LOGW(TAG, " - Short circuit in discharge! (ASCDL, Bit 15)");
    if (permanentFailureStruct->short_circuit_in_charge)
        ESP_LOGW(TAG, " - Short circuit in charge! (ASCCL, Bit 14)");
    if (permanentFailureStruct->overload_in_discharge)
        ESP_LOGW(TAG, " - Overload in discharge! (AOLDL, Bit 13)");
    if (permanentFailureStruct->voltage_imbalance_whileActive)
        ESP_LOGW(TAG, " - Voltage imbalance while active! (VIMA, Bit 12)");
    if (permanentFailureStruct->voltage_imbalance_whileAtRest)
        ESP_LOGW(TAG, " - Voltage imbalance while at rest! (VIMR, Bit 11)");
    if (permanentFailureStruct->capacity_degradation_failure)
        ESP_LOGW(TAG, " - Capacity degradation failure! (CD, Bit 10)");
    if (permanentFailureStruct->impedance_failure)
        ESP_LOGW(TAG, " - Impedance failure! (IMP, Bit 9)");
    if (permanentFailureStruct->cell_balancing_failure)
        ESP_LOGW(TAG, " - Cell balancing failure! (CB, Bit 8)");
    if (permanentFailureStruct->qmax_imbalance_failure)
        ESP_LOGW(TAG, " - Qmax imbalance failure! (QIM, Bit 7)");
    if (permanentFailureStruct->safety_overTemperature_fet_failure)
        ESP_LOGW(TAG, " - Safety over temperature FET failure! (SOTF, Bit 6)");
    if (permanentFailureStruct->cell_overvoltage_latch)
        ESP_LOGW(TAG, " - Cell overvoltage latch! (COVL, Bit 5)");
    if (permanentFailureStruct->safety_overTemperature_cell_failure)
        ESP_LOGW(TAG, " - Safety over temperature cell failure! (SOT, Bit 4)");
    if (permanentFailureStruct->safety_overCurrent_in_discharge)
        ESP_LOGW(TAG, " - Safety overcurrent in discharge! (SOCD, Bit 3)");
    if (permanentFailureStruct->safety_overCurrent_in_charge)
        ESP_LOGW(TAG, " - Safety overcurrent in charge! (SOCC, Bit 2)");
    if (permanentFailureStruct->safety_cell_overVoltage_failure)
        ESP_LOGW(TAG, " - Safety cell overvoltage failure! (SOV, Bit 1)");
    if (permanentFailureStruct->safety_cell_underVoltage_failure)
        ESP_LOGW(TAG, " - Safety cell undervoltage failure! (SUV, Bit 0)");
// Security Mode Handling
// Found in https://www.ti.com/lit/ug/sluubk0b/sluubk0b.pdf
// - Page 80, SEction 11.5
bq40z50_interface_security_modes_t BQ40Z50_getSecurityMode()
    uint8_t attempts = 0;
    esp_err_t error = ESP_OK;
    // This seems to fail on occasionally
    while (attempts <= 3)
            attempts++;
            vTaskDelay(pdMS_TO_TICKS(100));
        else
            // Since I made the bq40z50_interface_security_modes_t match the registers
            // We can just directly return it and have it match!
            ESP_LOGI(TAG, "getSecurityMode: Mode: %d (%s)", opStats.security_mode, BQ40Z50_securityModeToChar(opStats.security_mode));
            return opStats.security_mode;
    ESP_LOGI(TAG, "getSecurityMode: Failed to query: %s", esp_err_to_name(error));
    return BQ40Z50_SECURITY_MODE_FAILED;
esp_err_t BQ40Z50_validateSecurityMode(bq40z50_interface_security_modes_t desiredMode, bool *isInDesiredMode)
    // See what the current security mode is
    bq40z50_interface_security_modes_t currentMode = BQ40Z50_getSecurityMode();
    if (currentMode == BQ40Z50_SECURITY_MODE_FAILED)
        // Since the function failed to get it, we can just exit with a fail code
        ESP_LOGW(TAG, "validateSecurityMode: Failed to query for current security mode");
        *isInDesiredMode = false;
        return ESP_FAIL;
    ESP_LOGI(TAG, "validateSecurityMode: Found: %s, Desired: %s", BQ40Z50_securityModeToChar(currentMode), BQ40Z50_securityModeToChar(desiredMode));
    *isInDesiredMode = currentMode == desiredMode;
    return ESP_OK;
esp_err_t BQ40Z50_setSecurityMode(bq40z50_interface_security_modes_t desiredMode)
        ESP_LOGW(TAG, "setSecurityMode: Failed to query for current security mode");
        return ESP_FAIL;
    // Since we know what the current mode is, we know what steps we need to do to change it
    // First, check to see if the current mode is the same as the desired one
    // As we can just exit as ok, since we dont need to do anything
    if (currentMode == desiredMode)
        ESP_LOGI(TAG, "setSecurityMode: Desired and actual security is the same");
        return ESP_OK;
    // We now need to figure out how to get the unit to what we want to do
    // Sealed -> UnSealed = Unseal
    // Sealed -> Full Access = Unseal, Enabled Full Access
    // UnSealed -> Sealed = Seal
    // UnSealed -> Full Access = Enable Full Access
    // Full Access -> Sealed = Seal
    // Full Access -> UnSealed = Seal, Unseal
    // Small delay to allow IC to breath / preempt by RTOS
    vTaskDelay(pdMS_TO_TICKS(50));
    // Keep in mind, that any operation for setting security mode needs some delay
    // - This ensures its propagates through the chip!
    // - Initally was 2s. 1s seems fine,
    if (currentMode == BQ40Z50_SECURITY_MODE_SEALED)
        if (desiredMode == BQ40Z50_SECURITY_MODE_UNSEALED)
            if (BQ40Z50_security_unseal() != ESP_OK)
                ESP_LOGE(TAG, "setSecurityMode: SE -> US: Failed to unseal");
                return ESP_FAIL;
            return ESP_OK;
        else if (desiredMode == BQ40Z50_SECURITY_MODE_FULLACCESS)
                ESP_LOGE(TAG, "setSecurityMode: SE -> FA: Failed to unseal");
                return ESP_FAIL;
            vTaskDelay(pdMS_TO_TICKS(BQ40Z50_INTERFACE_SECURITY_TIMEOUT_MS));
            if (BQ40Z50_security_fullAccess() != ESP_OK)
                ESP_LOGE(TAG, "setSecurityMode: SE -> FA: Failed to set full access");
                return ESP_FAIL;
            return ESP_OK;
    else if (currentMode == BQ40Z50_SECURITY_MODE_UNSEALED)
        if (desiredMode == BQ40Z50_SECURITY_MODE_SEALED)
            if (BQ40Z50_security_seal() != ESP_OK)
                ESP_LOGE(TAG, "setSecurityMode: US -> SE: Failed to seal");
                return ESP_FAIL;
            return ESP_OK;
                ESP_LOGE(TAG, "setSecurityMode: US -> FA: Failed to set full access");
                return ESP_FAIL;
            return ESP_OK;
    else if (currentMode == BQ40Z50_SECURITY_MODE_FULLACCESS)
                ESP_LOGE(TAG, "setSecurityMode: FA -> SE: Failed to seal");
                return ESP_FAIL;
            return ESP_OK;
        else if (desiredMode == BQ40Z50_SECURITY_MODE_UNSEALED)
                ESP_LOGE(TAG, "setSecurityMode: FA -> US: Failed to seal");
                return ESP_FAIL;
                ESP_LOGE(TAG, "setSecurityMode: FA -> US: Failed to unseal");
                return ESP_FAIL;
            return ESP_OK;
    ESP_LOGW(TAG, "setSecurityMode: Failed to know how to go %s -> %s", BQ40Z50_securityModeToChar(currentMode), BQ40Z50_securityModeToChar(desiredMode));
    return ESP_FAIL;
esp_err_t BQ40Z50_setSecurityModeAndValidate(bq40z50_interface_security_modes_t desiredMode, bool *isInDesiredMode)
    BQ40Z50_queryAndPrintOperationalStatus();
    // Set the security mode first
    if (BQ40Z50_setSecurityMode(desiredMode) != ESP_OK)
        ESP_LOGW(TAG, "setSecurityModeAndValidate: Failed to set security mode");
        return ESP_FAIL;
    // Ensure there is some delay between queries
    vTaskDelay(pdMS_TO_TICKS(5000));
    // Then test to see if that was set correctly
    if (BQ40Z50_validateSecurityMode(desiredMode, isInDesiredMode) != ESP_OK)
        ESP_LOGW(TAG, "setSecurityModeAndValidate: Failed to validate security mode");
        return ESP_FAIL;
    return ESP_OK;
char *BQ40Z50_securityModeToChar(bq40z50_interface_security_modes_t securityMode)
    switch (securityMode)
    case BQ40Z50_SECURITY_MODE_RESERVED:
        return "Reserved";
    case BQ40Z50_SECURITY_MODE_FULLACCESS:
        return "Full Access";
    case BQ40Z50_SECURITY_MODE_UNSEALED:
        return "Unsealed";
    case BQ40Z50_SECURITY_MODE_SEALED:
        return "Sealed";
    case BQ40Z50_SECURITY_MODE_FAILED:
        return "Failed";
    default:
        return "Unknown";
// Legacy FG programming before golden file
esp_err_t BQ40Z50_configure_gaugeThresholds()
    esp_err_t error;
    error = BQ40Z50_set_DesignCapacity(12000); // 12000 2S2P - 6000mAh each
    error |= BQ40Z50_set_DesignVoltage(7400); // 2S2P  3.7V each
    error |= BQ40Z50_set_TaperCurrent(200); //    C/10  x2
    error |= BQ40Z50_set_DischargeCurrentThreshold(100); // 100mA is the default value
    error |= BQ40Z50_set_ChargeCurrentThreshold(50); // 50mA is the default value
    error |= BQ40Z50_set_QuitCurrent(10); // 10mA is the default value
    error |= BQ40Z50_set_TermVoltage(6000); // 6 V - 2S2sP
    return error;
esp_err_t BQ40Z50_configure_protections()
    esp_err_t error;
    error = BQ40Z50_set_cell_CUV_protection(3000);
    error |= BQ40Z50_set_OCC_protection(2200, 2400);
    error |= BQ40Z50_set_OCD_protection(3800, 4000);
    error |= BQ40Z50_set_HW_OLD_protection(0xF0);
    error |= BQ40Z50_set_HW_SCC_protection(0x70);
    error |= BQ40Z50_set_HW_SCD_protection(0x70, 0xE0);
    return error;
// Golden File Operations
 * @brief Will check to see if the golden file has been programmed onto the IC yet
 * @return true - It was found installed
 * @return false - Was not able to correlate if has been installed, or any other error
esp_err_t BQ40Z50_isGoldenFileInstalled(bool *outcome)
    // Since we will never set the design capacity / voltage with direct commands
    // We know that the golden file is installed if they are set
    // So we just need to know that they are at
    // Query for designed values
    uint32_t designedCapacity = 0;
    error = BQ40Z50_getDesignCapacity(&designedCapacity);
        *outcome = false;
        return error;
    uint32_t designedVoltage = 0;
    error = BQ40Z50_getDesignVoltage(&designedVoltage);
        *outcome = false;
        return error;
    // Check to see if they are as intended
    if (designedCapacity == 12000 || designedVoltage == 7400)
        // Values are as expected, so we must have flashed it previously
        *outcome = true;
    else
        // Values are not as expected!
        *outcome = false;
    return ESP_OK;
// Function to parse a single line of hex values and store them in an array
static int BQ40Z50_goldenFile_parseHexValues(const char *hex_string, uint8_t hex_array[])
    int count = 0;
    const char *ptr = hex_string;
    while (*ptr)
        // Skip spaces
        while (*ptr == ' ')
            ptr++;
        // Convert the hex string to an integer and store it in the array
        if (*ptr != '\0')
            hex_array[count++] = (uint8_t)strtoul(ptr, NULL, 16);
        // Move to the next hex value
        while (*ptr && *ptr != ' ')
            ptr++;
    return count;
#define GOLDENFILE_PRINT_LINES 100
static esp_err_t BQ40Z50_goldenFile_parseFile(const char *data)
    const size_t goldenFileSize = goldenFileFlash_end - goldenFileFlash_start - 1;
    char line[256]; // Buffer to store each line
    uint32_t linesParsed = 0;
    int i = 0;
    esp_err_t error_fg = ESP_OK;
    while (*data)
        if (*data == '\r' && *(data + 1) == '\n')
        {                   // Check for \r\n (0x0d 0x0a)
            line[i] = '\0'; // Null-terminate the current line
            // Process the line
            if (line[0] == ';')
            else if (strncmp(line, "SWW:", 4) == 0)
                // printf("SWW Command: %s\n", line + 5);
                uint8_t hex_array[MAX_HEX_VALUES];
                BQ40Z50_goldenFile_parseHexValues(line + 5, hex_array);
                // printf("Data: %02x %02x %02x %02x \n",(hex_array[0]>>1),hex_array[1],hex_array[2],hex_array[3]);
                if(i2c_write_two_bytes((hex_array[0] >> 1), hex_array[1], &hex_array[2]) != ESP_OK) {
                    ESP_LOGE(TAG_GOLDENFILE, "SWW Command failed!!!");
            else if (strncmp(line, "SWB:", 4) == 0)
                // printf("SWB Command: %s\n", line + 5);
                int hex_count = BQ40Z50_goldenFile_parseHexValues(line + 5, hex_array);
                // for (int j = 0; j < hex_count; j++) {
                //     printf("0x%02X ", hex_array[j]);
                // printf("\nSWB Data: %02x %02x %02x %02x total data size:%d\n",(hex_array[0]>>1),hex_array[1],hex_array[2],hex_array[3],(hex_count-2));
                if (hex_array[1] == 0x44)
                    ESP_LOGI(TAG_GOLDENFILE, "Manufacturer Block command");
                    uint8_t dataframe[3];
                    dataframe[0] = 0x02; // data size in bytes
                    dataframe[1] = hex_array[2];
                    dataframe[2] = hex_array[3];
                    esp_err_t ret = i2c_master_write_DataFlash(I2C_MASTER_NUM, (hex_array[0] >> 1), hex_array[1], &dataframe[0], sizeof(dataframe));
                    if (ret == ESP_OK)
                        ESP_LOGI(TAG_GOLDENFILE, "ROM mode set!!!");
                else
                    static uint16_t count = 0;
                    count++;
                    if(i2c_write_SWB((hex_array[0] >> 1), hex_array[1], &hex_array[2], (hex_count - 2)) != ESP_OK) {
                        ESP_LOGE(TAG_GOLDENFILE, "SWB Command failed!!! %d", count);
                    vTaskDelay(pdMS_TO_TICKS(200));
            else if (strncmp(line, "SCL:", 4) == 0)
                // printf("SCL Command: %s\n", line + 5);
                // printf("Data: %02x %02x %02x %02x \n",(hex_array[0]>>1),hex_array[1],hex_array[2],hex_array[hex_array[2]-1]);
                uint8_t dataframe[hex_array[2] + 1];
                // i2c_master_read_slave_reg(I2C_MASTER_NUM,(hex_array[0]>>1), hex_array[1], &dataframe[0],33);
                i2c_read_SCL(I2C_MASTER_NUM, (hex_array[0] >> 1), hex_array[1], &dataframe[0], (hex_array[2] + 1));
                ESP_LOGI(TAG_GOLDENFILE, "SCL Data read: %02x %02x %02x %02x", dataframe[0], dataframe[1], dataframe[2], dataframe[hex_array[2] - 1]);
                // if (memcmp(dataframe[0], hex_array[2], hex_array[2]+1) == 0) {
                //     printf("SCL Command OK.\n");
                // } else {
                //     printf("NO. SCL Command NOT OK.\n");
            else if (strncmp(line, "SWC:", 4) == 0)
                // printf("SWC Command: %s\n", line + 5);
                i2c_write_SWC((hex_array[0] >> 1), hex_array[1]);
            else if (strncmp(line, "SCW:", 4) == 0)
                // printf("SCW Command: %s\n", line + 5);
                uint8_t dataframe[2];
                i2c_master_read_two_bytes((hex_array[0] >> 1), hex_array[1], &dataframe[0]);
                if (dataframe[0] == hex_array[2] && dataframe[1] == hex_array[3])
                    // ESP_LOGI(TAG_GOLDENFILE, "SCW Command OK!!!!");
                else
                    ESP_LOGW(TAG_GOLDENFILE, "SCW Command not OK!");
            else if (strncmp(line, "X:", 2) == 0)
                // Convert the X value to an integer
                int x_value = atoi(line + 3);
                vTaskDelay(pdMS_TO_TICKS(x_value));
            else
                ESP_LOGW(TAG_GOLDENFILE, "Unknown command: %s", line);
            if (linesParsed % GOLDENFILE_PRINT_LINES == 0)
                ESP_LOGI(TAG_GOLDENFILE, "Parsed %" PRIu32 " / 4295 lines", linesParsed);
            i = 0;     // Reset the line buffer index
            data += 2; // Skip the \r\n characters
            linesParsed++;
        else
            line[i++] = *data++; // Add character to the line buffer
    return error_fg;
esp_err_t BQ40Z50_goldenFile_program()
    // TODO Im pretty sure we dont need to allocate RAM to do this transfer
    // We are only using it as a way to move though a pointer
    // Which we can just abstract out and look at the flash directly?
    // Its working, so I wont change it. but this ia a massive point of refactor!
    esp_err_t ret = ESP_OK;
    // Print basic info of the golden file
    ESP_LOGI(TAG_GOLDENFILE, "Battery golden file size = %d bytes ", goldenFileSize);
    // Ensure we IC is in the correct security mode
    bool wasSecurityModeSetCorrectly = false;
    ret = BQ40Z50_setSecurityModeAndValidate(BQ40Z50_SECURITY_MODE_FULLACCESS, &wasSecurityModeSetCorrectly);
    if (ret != ESP_OK || !wasSecurityModeSetCorrectly)
        ESP_LOGE(TAG_GOLDENFILE, "Failed to set and validate security mode!");
        return ESP_FAIL;
    // Allocate and the memory required to store the golden file
    ESP_LOGI(TAG_GOLDENFILE, "Allocating golden file memory");
    char *ptrFS;
    ptrFS = (char *)MALLOC_PSRAM(goldenFileSize + 1);
    if (ptrFS == NULL)
        ESP_LOGE(TAG_GOLDENFILE, "Golden file memory allocation failed.");
        return ESP_FAIL;
    // Then copy the flash storage into the new allocated RAM block
    memcpy(ptrFS, &goldenFileFlash_start[0], goldenFileSize);
    // Ensure the last byte is set to a termination character
    ptrFS[goldenFileSize] = 0x00;
    // Finally, actually send / program the golden file
    ESP_LOGI(TAG_GOLDENFILE, "Attempting to send golden file...");
    ret = BQ40Z50_goldenFile_parseFile(ptrFS);
    if (ret == ESP_OK)
        ESP_LOGI(TAG_GOLDENFILE, "Golden file successfully transferred.");
    else
        ESP_LOGE(TAG_GOLDENFILE, "Failed to transfer Golden file.");
    // Ensure the large memory block is freed
    FREE(ptrFS);
    // Return if it was successful or not as an error code
    return ret;
bq40z50_interface.h
