I am trying to read current values from CSADC1 and CSADC2, on the CURRENT1/2_HI and OC pins. When I read the CURRENT1 or OC1 I read the correct values. However when I read the CURRENT2 or OC2, I read garbage values. However, when I read CURRENT1 or OC1 and then CURRENT2 or OC2, all the values are correct.
I wanted to verify if this behaviour is intended, since nothing is mentioned in the reference manual regarding this.
SV
