Hello TI community,
I am designing a buck converter using the LM5116MHX/NOPB, targeting a 5V 5A output from a 6–60V DC input. The schematic and PCB layout have been completed, and I am currently facing a major issue during initial testing.
Problem Description:
When powered up, HO (high-side gate drive) turns on, causing the input voltage to appear directly at the output, but no buck conversion occurs.
The LO (low-side gate drive) remains off and shows no gate voltage, so the low-side MOSFET does not switch at all.
No regulated output is achieved, and the output simply tracks the input.
Debugging Actions Taken:
Verified component placement and soldering, including MOSFETs and bootstrap components.
Checked continuity and voltage levels at EN, UVLO, SS, HO, LO, HB, SW, and VCC pins.
Compared my schematic to TI reference designs and evaluation boards.
Ensured correct orientation of bootstrap diode and appropriate capacitor values.
Schematic and Images:
I have attached the schematic PDF, the KiCad PCB render, and actual assembly photos for reference.
Key Questions:
What are possible causes for HO being always on while LO stays off?
Which components or pins are most critical in bootstrap operation and gate drive for LO?
Are there recommended troubleshooting steps for this situation with LM5116?
Any specific advice regarding PCB layout, component values, or signal measurement points?
I appreciate any help or pointers from those familiar with the LM5116’s behavior and troubleshooting.
Thank you!
