BQ27520-G4: Effects of differences between battery cells and battery packs
Part Number: BQ27520-G4
Other Parts Discussed in Thread: GPCCHEM
Dear Sirs and Madams,
Is the ChemID=7661 registered in bqStuio a property of cell only?
"Panasonic , UF463443GUM (820mAh), 7661, LiMn2O4 (CoNi)/carbon, 4.2V"
The battery we are considering is a battery pack equipped with UF463443GUM (820mAh).
This ChemID=7661 was also selected in the GPCCHEM report.
When I set ChemID=7661 and ran the learning cycle, the Update Status became 02 and the Ra Tables were updated without any problems.
Design Capacity : 820mAh
Charge current : 410mA (C/2)
Tabper current : 40mA
Discharge current : 110mA (C/7.5)
Full charege voltage : 4200mV
Term voltage : 3200mV
However, the SOH is low at 94% or 95%.
Do you think this drop in SOH is due to the impedance of the battery pack's protection circuit?
In this case, is there any workaround other than sending this battery pack to your company and having a new ChemID created?
Masashi
