TPS2490: Reverse current
Part Number: TPS2490
Dear,
TPS2490.
I have an application where after normal inrush procedure, the current flow will be reverse through the sense resistor and mosfet. So current flows from Vout to Vin.
Hence the SENSE pin goes above the VCC. E.g. maximum 50mV.
Can you guarantee that the IC keeps the mosfet on in this case?
Thank you for clarification.
John
