Part Number: UCD90160A
I have programmed this device using the Fusion Digital Power Designer at 100KHz and this works perfectly.
However I would like to be able to program it from a python script, the functions I have programmed are the monitoring pins on the device, I do not need to do any sequencing with my current solution.
From the Fusion Digital Power Designer I created a tifsp file (see file below - 66704510 Rev01 PD-GEN2.tifsp), below.
<?xml version="1.0" encoding="utf-8"?>
<MultiProjectsData xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<Version>1</Version>
<Timestamp>2025-04-23T18:01:49.1333204-07:00</Timestamp>
<Creator>Texas Instruments Fusion Digital Power Designer v7.10.1.0 [2023-10-27]</Creator>
<Project_Info_List>
<ProjectInfo>
<ProjectFile />
<ProjectData>
<Timestamp>2025-04-23T18:01:55.1440301-07:00</Timestamp>
<Devices>
<Device>
<PartID>UCD90160A</PartID>
<Address>52</Address>
<Is_Offline>true</Is_Offline>
<SAA_Number>1</SAA_Number>
<Saved_In_Offline_Mode>false</Saved_In_Offline_Mode>
<Saved_While_NVM_Write_Pending>false</Saved_While_NVM_Write_Pending>
<Device_ID>UCD90160A|2.4.3.0809|160916</Device_ID>
<Write_Protected>false</Write_Protected>
<Package>64</Package>
<Command_Device_Configs>
<item>
<key>
<unsignedByte>0</unsignedByte>
</key>
<value>
<CommandDeviceConfiguration>
<Is_Paged>false</Is_Paged>
</CommandDeviceConfiguration>
</value>
</item>
<item>
<key>
<unsignedByte>1</unsignedByte>
</key>
<value>
<Is_Paged>true</Is_Paged>
</value>
</item>
<item>
<key>
<unsignedByte>2</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>3</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>17</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>25</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>32</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>33</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>37</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>38</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>42</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>64</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>66</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>67</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>68</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>94</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>95</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>96</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>98</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>100</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>102</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>120</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>121</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>122</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>126</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>139</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>152</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>153</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>154</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>155</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>156</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>157</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>158</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>185</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>209</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>210</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>211</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>212</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>213</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>214</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>215</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>216</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>217</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>218</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>219</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>220</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>221</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>222</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>223</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>224</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>225</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>226</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>227</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>233</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>234</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>235</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>236</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>237</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>239</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>240</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>241</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>243</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>245</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>246</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>247</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>248</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>249</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>250</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>251</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>252</unsignedByte>
</key>
<value>
</value>
</item>
<item>
<key>
<unsignedByte>253</unsignedByte>
</key>
<value>
</value>
</item>
</Command_Device_Configs>
<Num_Outputs>16</Num_Outputs>
<Parameters>
<Parameter>
<ID>PWM_CONFIG_0</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_0 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 0; Duty Cycle: 1.0 %; Frequency: 15.28 MHz; Phase: 0.0 deg</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0xB3FE00E913F88000" />
<ParameterType>Custom</ParameterType>
<ParameterCategory>Configuration</ParameterCategory>
<Page>255</Page>
<Phase xsi:nil="true" />
<CustomIndex xsi:nil="true" />
</Parameter>
<Parameter>
<ID>PWM_CONFIG_1</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_1 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 1; Duty Cycle: 1.0 %; Frequency: 15.28 MHz; Phase: 0.0 deg</ValueText>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PWM_CONFIG_2</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_2 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 2; Duty Cycle: 1.0 %; Frequency: 15.28 MHz; Phase: 0.0 deg</ValueText>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PWM_CONFIG_3</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_3 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 3; Duty Cycle: 0.0 %; Frequency: 15.28 MHz; Phase: 0.0 deg</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x880000E913F88000" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PWM_CONFIG_4</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_4 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 4; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x8800000000008000" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PWM_CONFIG_5</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_5 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 5; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg</ValueText>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PWM_CONFIG_6</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_6 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 6; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg</ValueText>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PWM_CONFIG_7</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_7 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 7; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg</ValueText>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PWM_CONFIG_8</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_8 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 8; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x8800000000000000" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PWM_CONFIG_9</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_9 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 9; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg</ValueText>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PWM_CONFIG_10</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_10 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 10; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg</ValueText>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PWM_CONFIG_11</ID>
<Code>225</Code>
<IDAndCode>PWM_CONFIG_11 [MFR 17,0xE1]</IDAndCode>
<ValueText>Pin_ID = 11; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg</ValueText>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_0</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_0 [MFR 43,0xFB]</IDAndCode>
<ValueText>Enable: False; Out_Enable: False; Out_Value: False; Status: False</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x00" />
<ParameterCategory>Status</ParameterCategory>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_1</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_1 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_2</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_2 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_3</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_3 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_4</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_4 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_5</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_5 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_6</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_6 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_7</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_7 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_8</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_8 [MFR 43,0xFB]</IDAndCode>
<ValueText>Enable: False; Out_Enable: False; Out_Value: False; Status: True</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x08" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_9</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_9 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_10</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_10 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_11</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_11 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_12</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_12 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_13</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_13 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_14</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_14 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_15</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_15 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_16</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_16 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_17</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_17 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_18</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_18 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_19</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_19 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_20</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_20 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_21</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_21 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_22</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_22 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_23</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_23 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_24</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_24 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPIO_CONFIG_25</ID>
<Code>251</Code>
<IDAndCode>GPIO_CONFIG_25 [MFR 43,0xFB]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>CAPABILITY</ID>
<Code>25</Code>
<IDAndCode>CAPABILITY [0x19]</IDAndCode>
<ValueText>Max Bus: 400 Khz; PEC: Yes; SMBALERT#: Yes</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0xB0" />
<ParameterCategory>Manufacturer</ParameterCategory>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>CONSTANTS</ID>
<Code>223</Code>
<IDAndCode>CONSTANTS [MFR 15,0xDF]</IDAndCode>
<ValueText>Max # Digital Comparators: 6; Max # GPOs: 16; Max # GPIs: 8; Max # Pages: 16; Max # Fans: 0; Max # Monitors: 16; Max # Fault Detail Items: 18; Max # PWMs: 12</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x061008100010120C" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>DEVICE_ID</ID>
<Code>253</Code>
<IDAndCode>DEVICE_ID [MFR 45,0xFD]</IDAndCode>
<ValueText>UCD90160A|2.4.3.0809|160916</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x5543443930313630417C322E342E332E303830397C31363039313600" />
<ParameterType>String</ParameterType>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPI_CONFIG</ID>
<Code>249</Code>
<IDAndCode>GPI_CONFIG [MFR 41,0xF9]</IDAndCode>
<ValueText>Inputs: Unassigned;Unassigned;Unassigned;Unassigned;Unassigned;Unassigned;Unassigned;Unassigned;; Fault Responses: Max Glitch Time: 0.0 ms| Fault Response: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| Page Mask: ; Fault Pin Config: Max Glitch Time: 0.0 ms| Fault Response: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| Page Mask for Output: | Page Mask for Responses: </ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x00000000000000000000000000000000000000000000000000000000000000" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_1</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_1 [MFR 40,0xF8]</IDAndCode>
<ValueText>Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x000000000000000000000000000000000000000000" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_2</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_2 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_3</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_3 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_4</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_4 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_5</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_5 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_6</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_6 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_7</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_7 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_8</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_8 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_9</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_9 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_10</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_10 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_11</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_11 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_12</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_12 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_13</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_13 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_14</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_14 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_15</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_15 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>GPO_CONFIG_16</ID>
<Code>248</Code>
<IDAndCode>GPO_CONFIG_16 [MFR 40,0xF8]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>LOGGED_FAULT_DETAIL_ENABLES</ID>
<Code>239</Code>
<IDAndCode>LOGGED_FAULT_DETAIL_ENABLES [MFR 31,0xEF]</IDAndCode>
<ValueText>Common: LOG_NOT_EMPTY,SYSTEM_WATCHDOG_TIMEOUT,RESEQUENCE_ERROR,WATCHDOG_TIMEOUT,RESERVED4_OR_SINGLEEVTUPSET,RESERVED5,RESERVED6,RESERVED7; GPI: #1,2,3,4,5,6,7,8; Rail #1: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #2: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #3: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #4: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #5: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #6: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #7: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #8: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #9: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #10: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #11: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #12: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #13: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #14: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #15: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #16: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0xFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF" />
<ParameterType>Bitmask</ParameterType>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>LOGGED_FAULTS2</ID>
<Code>234</Code>
<IDAndCode>LOGGED_FAULTS [MFR 26,0xEA]</IDAndCode>
<ValueText>Common: LOG_NOT_EMPTY; GPI: <empty>; Rail #1: <EMPTY>; Rail #2: VOUT_UV; Rail #3: VOUT_UV; Rail #4: <EMPTY>; Rail #5: <EMPTY>; Rail #6: <EMPTY>; Rail #7: <EMPTY>; Rail #8: <EMPTY>; Rail #9: <EMPTY>; Rail #10: <EMPTY>; Rail #11: <EMPTY>; Rail #12: <EMPTY>; Rail #13: <EMPTY>; Rail #14: <EMPTY>; Rail #15: <EMPTY>; Rail #16: <EMPTY></ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x010000020200000000000000000000000000" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>MFR_DATE</ID>
<Code>157</Code>
<IDAndCode>MFR_DATE [0x9D]</IDAndCode>
<ValueText>YYMMDD</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x59594D4D4444" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>MFR_ID</ID>
<Code>153</Code>
<IDAndCode>MFR_ID [0x99]</IDAndCode>
<ValueText>MFR_ID</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x4D46525F4944" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>MFR_LOCATION</ID>
<Code>156</Code>
<IDAndCode>MFR_LOCATION [0x9C]</IDAndCode>
<ValueText>MFR_LOCATION</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x4D46525F4C4F434154494F4E" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>MFR_MODEL</ID>
<Code>154</Code>
<IDAndCode>MFR_MODEL [0x9A]</IDAndCode>
<ValueText>MFR_MODEL</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x4D46525F4D4F44454C" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>MFR_REVISION</ID>
<Code>155</Code>
<IDAndCode>MFR_REVISION [0x9B]</IDAndCode>
<ValueText>MFR_REVISION</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x4D46525F5245564953494F4E" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>MFR_SERIAL</ID>
<Code>158</Code>
<IDAndCode>MFR_SERIAL [0x9E]</IDAndCode>
<ValueText>000000</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x303030303030" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>MISC_CONFIG</ID>
<Code>252</Code>
<IDAndCode>MISC_CONFIG [MFR 44,0xFC]</IDAndCode>
<ValueText>Time Between Resequences: 0 msec; Resequence Abort: no; Max Resequences: 1; FIFO Mode: Disabled; Brownout Enable: no; Disable all logging: no; Resequence Rails Mask: 0x00 [0000000000000000b]</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x00000000" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>MONITOR_CONFIG</ID>
<Code>213</Code>
<IDAndCode>MONITOR_CONFIG [MFR 05,0xD5]</IDAndCode>
<ValueText>Pin 1 MON1: Rail #1, Type Voltage; Pin 2 MON2: Rail #2, Type Voltage; Pin 3 MON3: Rail #3, Type Voltage; Pin 4 MON4: Rail #4, Type Voltage, HW Comparator; Pin 5 MON5: Rail #5, Type Voltage; Pin 6 MON6: Rail #6, Type Voltage; Pin 55 MON7: Rail #7, Type Voltage; Pin 56 MON8: Rail #8, Type Voltage; Pin 57 MON9: Rail #9, Type Voltage; Pin 58 MON10: Rail #10, Type Voltage; Pin 59 MON11: Rail #11, Type Voltage; Pin 62 MON12: Rail #12, Type Voltage; Pin 63 MON13: Rail #13, Type Voltage; Pin 50 MON14: Rail #14, Type Voltage; Pin 52 MON15: Rail #15, Type Voltage; Pin 54 MON16: Rail #16, Type Voltage</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x202122832425262728292A2B2C2D2E2F" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>NUM_PAGES</ID>
<Code>214</Code>
<IDAndCode>NUM_PAGES [MFR 06,0xD6]</IDAndCode>
<ValueText>16</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x10" />
<ParameterType>UnitlessZeroDigit</ParameterType>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PIN_SELECTED_RAIL_STATES</ID>
<Code>221</Code>
<IDAndCode>PIN_SELECTED_RAIL_STATES [MFR 13,0xDD]</IDAndCode>
<ValueText>State 0: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 1: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 2: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 3: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 4: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 5: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 6: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 7: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x000000000000000000000000000000000000" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>PMBUS_REVISION</ID>
<Code>152</Code>
<IDAndCode>PMBUS_REVISION [0x98]</IDAndCode>
<ValueText>1.1,1.1 - Part I: 1.1, Part II: 1.1</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x21" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>RESET_COUNT2</ID>
<Code>220</Code>
<IDAndCode>RESET_COUNT [MFR 12,0xDC]</IDAndCode>
<ValueText>0 </ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x0000" />
<ValueNumeric>0</ValueNumeric>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>REAL_TIME_CLOCK</ID>
<Code>215</Code>
<IDAndCode>RUN_TIME_CLOCK [MFR 07,0xD7]</IDAndCode>
<ValueText>0 Days, 00:00:58.176</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x0000E34000000000" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>REAL_TIME_CLOCK_TRIM</ID>
<Code>216</Code>
<IDAndCode>RUN_TIME_CLOCK_TRIM [MFR 08,0xD8]</IDAndCode>
<ValueText>0.00 %</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x8800" />
<ParameterType>Percent</ParameterType>
<ParameterCategory>Calibration</ParameterCategory>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>STATUS_BYTE</ID>
<Code>120</Code>
<IDAndCode>STATUS_BYTE [0x78]</IDAndCode>
<ValueText>NONE_OF_ABOVE</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x01" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>STATUS_CML</ID>
<Code>126</Code>
<IDAndCode>STATUS_CML [0x7E]</IDAndCode>
<ValueText><EMPTY></ValueText>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>STATUS_WORD</ID>
<Code>121</Code>
<IDAndCode>STATUS_WORD [0x79]</IDAndCode>
<ValueText>NONE_OF_ABOVE,POWER_GOOD,MFR</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x1801" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>SYSTEM_RESET_CONFIG</ID>
<Code>210</Code>
<IDAndCode>SYSTEM_RESET_CONFIG [MFR 02,0xD2]</IDAndCode>
<ValueText>Disabled</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x000000000000000000" />
<Page>255</Page>
</Parameter>
<Parameter>
<ID>SYSTEM_WATCHDOG_CONFIG</ID>
<Code>211</Code>
<IDAndCode>SYSTEM_WATCHDOG_CONFIG [MFR 03,0xD3]</IDAndCode>
<Page>255</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #1]</IDAndCode>
<ValueText>EXP =-9</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x17" />
<Page>0</Page>
</Parameter>
<Parameter>
<ID>FAULT_RESPONSES</ID>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #1]</IDAndCode>
<ValueText>Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x000000000000" />
<Page>0</Page>
</Parameter>
<Parameter>
<ID>LOGGED_PAGE_PEAKS</ID>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #1]</IDAndCode>
<ValueText>Voltage: 23.764 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x872F" />
<Page>0</Page>
</Parameter>
<Parameter>
<ID>MARGIN_CONFIG</ID>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #1]</IDAndCode>
<ValueText>Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5</ValueText>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #1]</IDAndCode>
<ValueText>STORE_DEFAULT_ALL_DONE</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x00000200" />
<Page>0</Page>
</Parameter>
<Parameter>
<ID>ON_OFF_CONFIG</ID>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #1]</IDAndCode>
<ValueText>Mode: Always Converting</ValueText>
<ParameterCategory>OnOff</ParameterCategory>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #1]</IDAndCode>
<ValueText>Unit: ImmediateOff; Margin: None</ValueText>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>POWER_GOOD_OFF</ID>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #1]</IDAndCode>
<ValueText>19.199 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x2666" />
<ValueNumeric>19.199</ValueNumeric>
<ParameterType>Voltage</ParameterType>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>POWER_GOOD_ON</ID>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #1]</IDAndCode>
<ValueText>22.801 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x2D9A" />
<ValueNumeric>22.801</ValueNumeric>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>READ_RAIL_STATE</ID>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #1]</IDAndCode>
<ValueText>REGULATION</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x05" />
<Page>0</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #1]</IDAndCode>
<ValueText>23.740 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x2F7B" />
<ValueNumeric>23.74</ValueNumeric>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #1]</IDAndCode>
<ValueText>Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x94000000000000000000000000000000" />
<Page>0</Page>
</Parameter>
<Parameter>
<ID>STATUS_VOUT</ID>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #1]</IDAndCode>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #1]</IDAndCode>
<ValueText>0.0 ms</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x8000" />
<ParameterType>TimeOneDigitMilliseconds</ParameterType>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>TOFF_MAX_WARN_LIMIT</ID>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #1]</IDAndCode>
<ValueText><No Limit></ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x7FFF" />
<Page>0</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #1]</IDAndCode>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>TON_MAX_FAULT_LIMIT</ID>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #1]</IDAndCode>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>VOUT_CAL_MONITOR</ID>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #1]</IDAndCode>
<ValueText>0.000 V</ValueText>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>VOUT_COMMAND</ID>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #1]</IDAndCode>
<ValueText>24.000 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3000" />
<ValueNumeric>24</ValueNumeric>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>VOUT_MARGIN_HIGH</ID>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #1]</IDAndCode>
<ValueText>25.199 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3266" />
<ValueNumeric>25.199</ValueNumeric>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>VOUT_MARGIN_LOW</ID>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #1]</IDAndCode>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>VOUT_OV_FAULT_LIMIT</ID>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #1]</IDAndCode>
<ValueText>27.600 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3733" />
<ValueNumeric>27.6</ValueNumeric>
<ParameterCategory>Limits</ParameterCategory>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>VOUT_OV_WARN_LIMIT</ID>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #1]</IDAndCode>
<ValueText>26.400 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x34CD" />
<ValueNumeric>26.4</ValueNumeric>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>VOUT_SCALE_MONITOR</ID>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #1]</IDAndCode>
<ValueText>0.083 </ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x9AA8" />
<ValueNumeric>0.083</ValueNumeric>
<ParameterType>UnitlessThreeDigit</ParameterType>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>VOUT_UV_FAULT_LIMIT</ID>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #1]</IDAndCode>
<ValueText>20.400 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x28CD" />
<ValueNumeric>20.4</ValueNumeric>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>VOUT_UV_WARN_LIMIT</ID>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #1]</IDAndCode>
<ValueText>21.600 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x2B33" />
<ValueNumeric>21.6</ValueNumeric>
<Page>0</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #2]</IDAndCode>
<ValueText>EXP =-10</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x16" />
<Page>1</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #2]</IDAndCode>
<ValueText>Voltage: 11.905 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x9F2F" />
<Page>1</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #2]</IDAndCode>
<ValueText>10.200 V</ValueText>
<ValueNumeric>10.2</ValueNumeric>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #2]</IDAndCode>
<ValueText>10.800 V</ValueText>
<ValueNumeric>10.8</ValueNumeric>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #2]</IDAndCode>
<ValueText>11.858 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x2F6F" />
<ValueNumeric>11.858</ValueNumeric>
<Page>1</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #2]</IDAndCode>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x00000000000000000000000000000000" />
<Page>1</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #2]</IDAndCode>
<ValueText>12.000 V</ValueText>
<ValueNumeric>12</ValueNumeric>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #2]</IDAndCode>
<ValueText>12.600 V</ValueText>
<ValueNumeric>12.6</ValueNumeric>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #2]</IDAndCode>
<ValueText>11.400 V</ValueText>
<ValueNumeric>11.4</ValueNumeric>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #2]</IDAndCode>
<ValueText>13.800 V</ValueText>
<ValueNumeric>13.8</ValueNumeric>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #2]</IDAndCode>
<ValueText>13.200 V</ValueText>
<ValueNumeric>13.2</ValueNumeric>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #2]</IDAndCode>
<ValueText>0.166 </ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0xA2A8" />
<ValueNumeric>0.166</ValueNumeric>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #2]</IDAndCode>
<Page>1</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #3]</IDAndCode>
<ValueText>Voltage: 11.899 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x992F" />
<Page>2</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #3]</IDAndCode>
<ValueText>11.876 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x2F81" />
<ValueNumeric>11.876</ValueNumeric>
<Page>2</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #3]</IDAndCode>
<Page>2</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #4]</IDAndCode>
<ValueText>EXP =-12</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x14" />
<Page>3</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #4]</IDAndCode>
<ValueText>Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Shutdown immediately; Restart: Do not restart| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Shutdown immediately; Restart: Do not restart| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Shutdown immediately; Restart: Do not restart</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x808080000000" />
<Page>3</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #4]</IDAndCode>
<ValueText>Voltage: 5.112 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0xC951" />
<Page>3</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #4]</IDAndCode>
<ValueText>Mode: EnableActiveTrim; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 2, # 19 FPWM3_GPIO7</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x82" />
<Page>3</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #4]</IDAndCode>
<ValueText>4.250 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x4400" />
<ValueNumeric>4.25</ValueNumeric>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #4]</IDAndCode>
<ValueText>4.500 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x4800" />
<ValueNumeric>4.5</ValueNumeric>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #4]</IDAndCode>
<ValueText>4.988 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x4FCD" />
<ValueNumeric>4.988</ValueNumeric>
<Page>3</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #4]</IDAndCode>
<ValueText>5.000 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x5000" />
<ValueNumeric>5</ValueNumeric>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #4]</IDAndCode>
<ValueText>5.250 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x5400" />
<ValueNumeric>5.25</ValueNumeric>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #4]</IDAndCode>
<ValueText>4.950 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x4F33" />
<ValueNumeric>4.95</ValueNumeric>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #4]</IDAndCode>
<ValueText>5.750 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x5C00" />
<ValueNumeric>5.75</ValueNumeric>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #4]</IDAndCode>
<ValueText>5.500 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x5800" />
<ValueNumeric>5.5</ValueNumeric>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #4]</IDAndCode>
<ValueText>0.400 </ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0xAB33" />
<ValueNumeric>0.4</ValueNumeric>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #4]</IDAndCode>
<Page>3</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #5]</IDAndCode>
<ValueText>Voltage: 4.925 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0xCE4E" />
<Page>4</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #5]</IDAndCode>
<ValueText>4.914 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x4EA1" />
<ValueNumeric>4.914</ValueNumeric>
<Page>4</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #5]</IDAndCode>
<ValueText>4.750 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x4C00" />
<ValueNumeric>4.75</ValueNumeric>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #5]</IDAndCode>
<Page>4</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #6]</IDAndCode>
<ValueText>Voltage: 3.218 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x7C33" />
<Page>5</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #6]</IDAndCode>
<ValueText>Mode: EnableActiveTrim; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 3, # 20 FPWM4_GPIO8</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x83" />
<Page>5</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #6]</IDAndCode>
<ValueText>2.805 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x2CE1" />
<ValueNumeric>2.805</ValueNumeric>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #6]</IDAndCode>
<ValueText>2.970 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x2F85" />
<ValueNumeric>2.97</ValueNumeric>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #6]</IDAndCode>
<ValueText>3.192 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3314" />
<ValueNumeric>3.192</ValueNumeric>
<Page>5</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #6]</IDAndCode>
<ValueText>3.300 V</ValueText>
<ValueNumeric>3.3</ValueNumeric>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #6]</IDAndCode>
<ValueText>3.465 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3771" />
<ValueNumeric>3.465</ValueNumeric>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #6]</IDAndCode>
<ValueText>3.250 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3400" />
<ValueNumeric>3.25</ValueNumeric>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #6]</IDAndCode>
<ValueText>3.795 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3CB8" />
<ValueNumeric>3.795</ValueNumeric>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #6]</IDAndCode>
<ValueText>3.630 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3A14" />
<ValueNumeric>3.63</ValueNumeric>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #6]</IDAndCode>
<ValueText>0.606 </ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0xB26D" />
<ValueNumeric>0.606</ValueNumeric>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #6]</IDAndCode>
<Page>5</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #7]</IDAndCode>
<ValueText>Voltage: 3.325 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x3435" />
<Page>6</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #7]</IDAndCode>
<ValueText>Mode: EnableActiveTrim; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x80" />
<Page>6</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #7]</IDAndCode>
<ValueText>3.308 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x34EF" />
<ValueNumeric>3.308</ValueNumeric>
<Page>6</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #7]</IDAndCode>
<ValueText>3.350 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x359A" />
<ValueNumeric>3.35</ValueNumeric>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #7]</IDAndCode>
<ValueText>3.260 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3429" />
<ValueNumeric>3.26</ValueNumeric>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #7]</IDAndCode>
<Page>6</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #8]</IDAndCode>
<ValueText>Voltage: 3.688 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x033B" />
<Page>7</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #8]</IDAndCode>
<ValueText>Mode: EnableActiveTrim; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 1, # 18 FPWM2_GPIO6</ValueText>
<ValueEncoded xsi:type="PMBusByte" Hex="0x81" />
<Page>7</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #8]</IDAndCode>
<ValueText>3.060 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x30F6" />
<ValueNumeric>3.06</ValueNumeric>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #8]</IDAndCode>
<ValueText>3.240 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x33D7" />
<ValueNumeric>3.24</ValueNumeric>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #8]</IDAndCode>
<ValueText>3.599 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3997" />
<ValueNumeric>3.599</ValueNumeric>
<Page>7</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #8]</IDAndCode>
<ValueText>3.600 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x399A" />
<ValueNumeric>3.6</ValueNumeric>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #8]</IDAndCode>
<ValueText>3.780 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3C7B" />
<ValueNumeric>3.78</ValueNumeric>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #8]</IDAndCode>
<ValueText>3.560 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x38F6" />
<ValueNumeric>3.56</ValueNumeric>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #8]</IDAndCode>
<ValueText>4.140 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x423D" />
<ValueNumeric>4.14</ValueNumeric>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #8]</IDAndCode>
<ValueText>3.960 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3F5C" />
<ValueNumeric>3.96</ValueNumeric>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #8]</IDAndCode>
<ValueText>0.555 </ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0xB238" />
<ValueNumeric>0.555</ValueNumeric>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #8]</IDAndCode>
<Page>7</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #9]</IDAndCode>
<ValueText>Voltage: 0.086 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x2C00" />
<Page>8</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #9]</IDAndCode>
<ValueText>RAMP_UP</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x04" />
<Page>8</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #9]</IDAndCode>
<ValueText>0.018 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x0009" />
<ValueNumeric>0.018</ValueNumeric>
<Page>8</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #9]</IDAndCode>
<ValueText>1.000 </ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0xBA00" />
<ValueNumeric>1</ValueNumeric>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #9]</IDAndCode>
<Page>8</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #10]</IDAndCode>
<ValueText>Voltage: 0.039 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x2800" />
<Page>9</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #10]</IDAndCode>
<ValueText>0.007 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x0007" />
<ValueNumeric>0.007</ValueNumeric>
<Page>9</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #10]</IDAndCode>
<ParameterType>Custom</ParameterType>
<Page>9</Page>
<Phase xsi:nil="true" />
<CustomIndex xsi:nil="true" />
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #10]</IDAndCode>
<ParameterCategory>Configuration</ParameterCategory>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #10]</IDAndCode>
<Page>9</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #11]</IDAndCode>
<ValueText>Voltage: 0.049 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x3200" />
<Page>10</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #11]</IDAndCode>
<ValueText>0.008 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x0008" />
<ValueNumeric>0.008</ValueNumeric>
<Page>10</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #11]</IDAndCode>
<ValueEncoded xsi:type="PMBusByte" Hex="0x00" />
<ParameterCategory>Status</ParameterCategory>
<Page>10</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #11]</IDAndCode>
<Page>10</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #12]</IDAndCode>
<ValueText>Voltage: 0.027 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x6E00" />
<Page>11</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #12]</IDAndCode>
<ValueText>0.002 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x000A" />
<ValueNumeric>0.002</ValueNumeric>
<Page>11</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #12]</IDAndCode>
<Page>11</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #13]</IDAndCode>
<ValueText>Voltage: 0.125 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0x0102" />
<Page>12</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #13]</IDAndCode>
<ParameterType>String</ParameterType>
<Page>12</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #13]</IDAndCode>
<ValueText>0.108 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x01BB" />
<ValueNumeric>0.108</ValueNumeric>
<Page>12</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #13]</IDAndCode>
<Page>12</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #14]</IDAndCode>
<ValueText>Voltage: 0.166 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0xA802" />
<Page>13</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #14]</IDAndCode>
<ValueText>0.161 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x0294" />
<ValueNumeric>0.161</ValueNumeric>
<Page>13</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #14]</IDAndCode>
<ParameterType>Bitmask</ParameterType>
<Page>13</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #14]</IDAndCode>
<ValueText>3.135 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x3229" />
<ValueNumeric>3.135</ValueNumeric>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #14]</IDAndCode>
<Page>13</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #15]</IDAndCode>
<ValueText>Voltage: 0.246 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0xF003" />
<Page>14</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #15]</IDAndCode>
<ValueText>0.222 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x038C" />
<ValueNumeric>0.222</ValueNumeric>
<Page>14</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #15]</IDAndCode>
<Page>14</Page>
</Parameter>
<Parameter>
<ID>VOUT_MODE</ID>
<Code>32</Code>
<IDAndCode>VOUT_MODE [0x20,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>233</Code>
<IDAndCode>FAULT_RESPONSES [MFR 25,0xE9,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>237</Code>
<IDAndCode>LOGGED_PAGE_PEAKS [MFR 29,0xED,Rail #16]</IDAndCode>
<ValueText>Voltage: 0.180 V</ValueText>
<ValueEncoded xsi:type="PMBusBlock" Hex="0xE202" />
<Page>15</Page>
</Parameter>
<Parameter>
<Code>245</Code>
<IDAndCode>MARGIN_CONFIG [MFR 37,0xF5,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<ID>MFR_STATUS</ID>
<Code>243</Code>
<IDAndCode>MFR_STATUS [MFR 35,0xF3,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>2</Code>
<IDAndCode>ON_OFF_CONFIG [0x02,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<ID>OPERATION</ID>
<Code>1</Code>
<IDAndCode>OPERATION [0x01,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>95</Code>
<IDAndCode>POWER_GOOD_OFF [0x5F,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>94</Code>
<IDAndCode>POWER_GOOD_ON [0x5E,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>185</Code>
<IDAndCode>READ_RAIL_STATE [0xB9,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<ID>READ_VOUT</ID>
<Code>139</Code>
<IDAndCode>READ_VOUT [0x8B,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<ID>SEQ_CONFIG</ID>
<Code>246</Code>
<IDAndCode>SEQ_CONFIG [MFR 38,0xF6,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>122</Code>
<IDAndCode>STATUS_VOUT [0x7A,Rail #16]</IDAndCode>
<ValueText><EMPTY></ValueText>
<Page>15</Page>
</Parameter>
<Parameter>
<ID>TOFF_DELAY</ID>
<Code>100</Code>
<IDAndCode>TOFF_DELAY [0x64,Rail #16]</IDAndCode>
<ValueNumeric>0</ValueNumeric>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>102</Code>
<IDAndCode>TOFF_MAX_WARN_LIMIT [0x66,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<ID>TON_DELAY</ID>
<Code>96</Code>
<IDAndCode>TON_DELAY [0x60,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>98</Code>
<IDAndCode>TON_MAX_FAULT_LIMIT [0x62,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>209</Code>
<IDAndCode>VOUT_CAL_MONITOR [MFR 01,0xD1,Rail #16]</IDAndCode>
<ValueEncoded xsi:type="PMBusWord" Hex="0x0000" />
<ParameterCategory>Calibration</ParameterCategory>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>33</Code>
<IDAndCode>VOUT_COMMAND [0x21,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>37</Code>
<IDAndCode>VOUT_MARGIN_HIGH [0x25,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>38</Code>
<IDAndCode>VOUT_MARGIN_LOW [0x26,Rail #16]</IDAndCode>
<ValueText>3.420 V</ValueText>
<ValueEncoded xsi:type="PMBusWord" Hex="0x36B8" />
<ValueNumeric>3.42</ValueNumeric>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>64</Code>
<IDAndCode>VOUT_OV_FAULT_LIMIT [0x40,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>66</Code>
<IDAndCode>VOUT_OV_WARN_LIMIT [0x42,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>42</Code>
<IDAndCode>VOUT_SCALE_MONITOR [0x2A,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>68</Code>
<IDAndCode>VOUT_UV_FAULT_LIMIT [0x44,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
<Parameter>
<Code>67</Code>
<IDAndCode>VOUT_UV_WARN_LIMIT [0x43,Rail #16]</IDAndCode>
<Page>15</Page>
</Parameter>
</Parameters>
<Hex_Data>
<DataRecord>
<Intel_Hex_String>:020000040001F9</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:20880000064D46525F4944000000000000000000000000094D46525F4D4F44454C000000C3</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208820000C4D46525F5245564953494F4E0C4D46525F4C4F434154494F4E0659594D4D443A</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:20884000440630303030303000000000000000001000000000000000000000000000FFFFA0</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:20886000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF000000000000000000000E</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:2088800000000000000000000008000000000000000F0147014701470000000000000000E9</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:2088A0000000000000000000000000000000000000000000000000000000000000E913F8C4</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:2088C00000E913F800E913F800E913F80000000000000000000000000000000000000000BC</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:2088E000000000000000000000000000000000000000000000000000000000000000000078</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:20890000000000000000000000000000000000000000000000000000000000000000000057</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:20892000000000000000000000000000000000000000000000000000000000000000000037</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:20894000008080800000000000000000000000000000000000000000000000000000000097</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208960000000000000000000000000000000000000000000000000000000000000000000F7</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208980000000000000000000000000000000000000000000000000000000008200838081D1</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:2089A0000000000000000000000000000000000000000000000000000000000000000000B7</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:2089C00000000000000000000102030405060708090A0B0C0D0E0F1000000000000000000F</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:2089E0000000000000000000F7F6F6F4F4F4F4F4F7F6F6F4F4F4F4F4000000000000000029</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208A00000000000000000000266628CD28CD440044002CE12CE130F628CD28CD28CD4400F5</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208A200044002CE12CE130F62D9A2B332B33480048002F852F8533D72B332B332B334800CB</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208A400048002F852F8533D70000000000000000000000000000000000000000000000005C</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208A600000000000000000007FFF0000000000000000000000000000000000000000000078</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208A80000000000000000000000000000000000000000000000000000000000000000000D6</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208AA0000000000000000000000000000000000000000000000000000000000000000000B6</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208AC000000000000000000000000000000000000000000000000000000000000000000096</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208AE00000000000000000003000300030005000500034CD34CD399A300030003000500091</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208B0000500034CD34CD399A326632663266540054003771359A3C7B326632663266540076</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208B20005400377137713C7B2D9A2D9A2D9A4F334C003400342938F62D9A2D9A2D9A4C0057</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208B40004C003229322936B83733373337335C005C003CB83CB8423D3733373337335C002E</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208B60005C003CB83CB8423D34CD34CD34CD580058003A143A143F5C34CD34CD34CD5800ED</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208B800058003A143A143F5C015402A802A80666066609B409B408E0100010001000100023</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208BA000100010001000100028CD28CD28CD440044002CE12CE130F628CD28CD28CD4400AB</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208BC00044002CE12CE130F62B332B332B33480048002F852F8533D72B332B332B33480093</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208BE00048002F852F8533D794000000000000000000000000000000000000000000000027</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208C0000000000000000000000000000000000000000000000000000000000000000000054</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208C2000000000000000000000000000000000000000000000000000000000000000000034</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208C4000000000000000000000000000000000000000000000000000000000000000000014</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208C60000000000000000000000000000000000000000000000000000000000000000000F4</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208C80000000000000000000000000000000000000000000000000000000000000000000D4</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208CA0000000000000000000000000000000000000000000000000000000000000000000B4</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208CC000000000000000000000000000000000000000000000000000000000000000000094</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208CE000000000000000000000000000000000000000000000000000000000000000000074</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208D0000000000000000000000000000000000000000000000000000000000000000000053</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208D2000000000000000000000000000000000000000000000000000000000000000000033</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208D4000000000000000000000000000000000000000000000000000000000000000000013</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208D60000000000000000000000000000000000000000000000000000000000000000000F3</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208D80000000000000000000000000000000000000000000000000000000000000000000D3</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208DA0000000000000000000000000000000000000000000000000000000000000000000B3</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208DC000000000000000000000000000000000000000000000000000000000000000000093</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208DE00000000000000000000000A2B1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208E0000000000000000000000000000000000000000000001000000000000000000000051</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208E2000000000000000000000000000000000000000000000000000000000000000000032</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208E4000000000000000000000000000000000000000000000000000000000000000000012</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208E60000000000000000000000000000000000000000000000000000000000000000000F2</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208E80000000000000000000000000000000000000000000000000000000000000000000D2</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208EA0000000000000000000000000000000000000000000000000000000000000000000B2</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208EC0000000000000000000000000002F872F992F9950844ECE336B34FF3A07000B000B34</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208EE000000C001901CC02A303AA02A10000000000013C3500000000000009B8FFFFFFFF5C</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208F0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208F2000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208F4000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208F6000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208F8000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208FA000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208FC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:208FE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91</Intel_Hex_String>
</DataRecord>
<DataRecord>
<Intel_Hex_String>:00000001FF</Intel_Hex_String>
</DataRecord>
</Hex_Data>
<Other>
<Custom_Commands>
<READ_VTRACK_REG>
<Enabled>false</Enabled>
<Label>Vtrack</Label>
<Gain>1</Gain>
<Offset>0</Offset>
<Reference>2</Reference>
</READ_VTRACK_REG>
</Custom_Commands>
<UCD31XX_CLA_User_Data />
</Other>
<Custom xsi:type="CustomProjectData">
<Logged_Fault_Detail2>
<Logged_Fault_Detail2 xsi:type="UCD90XXLoggedFaultDetailVer2">
<Raw_Data>0x0002DB3489000000B528</Raw_Data>
<Timestamp>
<Milliseconds>187188</Milliseconds>
<Days>0</Days>
</Timestamp>
<Index>0</Index>
<Page_Index>2</Page_Index>
<Fault_ID>1</Fault_ID>
<Fault_Value>10.17676</Fault_Value>
<Fault_Value_Bytes>
<Fault_Value_Bytes>181</Fault_Value_Bytes>
<Fault_Value_Bytes>40</Fault_Value_Bytes>
<Is_Paged>true</Is_Paged>
</Logged_Fault_Detail2>
<Raw_Data>0x0002DB3488800000BB28</Raw_Data>
<Timestamp>
<Days>0</Days>
</Timestamp>
<Index>1</Index>
<Page_Index>1</Page_Index>
<Fault_Value>10.18262</Fault_Value>
<Fault_Value_Bytes>
<Fault_Value_Bytes>187</Fault_Value_Bytes>
</Custom>
</Device>
</Devices>
<Sequencing_Config_V1>
<Show_Warning_For_Circular_Rail_Dependencies>true</Show_Warning_For_Circular_Rail_Dependencies>
<Traces />
<Int_Rail_Defs>
<RailDefinition>
<Part_ID>UCD90160A</Part_ID>
<Address>52</Address>
<Extra1>RAIL</Extra1>
<Name>P24V0</Name>
<Page_Index>0</Page_Index>
<Color />
<Ext_Tracking_Mode>None</Ext_Tracking_Mode>
<Control_Line>1</Control_Line>
<Ext_Tracking_Custom_Source_Name />
<Operation_Event_Times>
<Start>0</Start>
<Stop>0</Stop>
</Operation_Event_Times>
<Vout>0</Vout>
<Note>1. P24V0</Note>
</RailDefinition>
<RailDefinition>
<Name>P12V0_D</Name>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>2. P12V0_D</Note>
</RailDefinition>
<RailDefinition>
<Name>P12V0_A</Name>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>3. P12V0_A</Note>
</RailDefinition>
<RailDefinition>
<Name>P5V0</Name>
<Page_Index>3</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>4. P5V0</Note>
</RailDefinition>
<RailDefinition>
<Name>P5V_STBY</Name>
<Page_Index>4</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>5. P5V_STBY</Note>
</RailDefinition>
<RailDefinition>
<Name>P3V3</Name>
<Page_Index>5</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>6. P3V3</Note>
</RailDefinition>
<RailDefinition>
<Name>P3V3_STBY</Name>
<Page_Index>6</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>P3V3_STBY</Note>
</RailDefinition>
<RailDefinition>
<Name>P3V6</Name>
<Page_Index>7</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>8. P3V3</Note>
</RailDefinition>
<RailDefinition>
<Name>I24V0</Name>
<Page_Index>8</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>9. I24V0</Note>
</RailDefinition>
<RailDefinition>
<Name>I12V0_D</Name>
<Page_Index>9</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>I12V0_D</Note>
</RailDefinition>
<RailDefinition>
<Name>I12V0_A</Name>
<Page_Index>10</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>I12V0_A</Note>
</RailDefinition>
<RailDefinition>
<Name>I5V0</Name>
<Page_Index>11</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>I5V0</Note>
</RailDefinition>
<RailDefinition>
<Name>I5V_STBY</Name>
<Page_Index>12</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>I5V_STBY</Note>
</RailDefinition>
<RailDefinition>
<Name>I3V3</Name>
<Page_Index>13</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>I3V3</Note>
</RailDefinition>
<RailDefinition>
<Name>I3V3_STBY</Name>
<Page_Index>14</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>I3V3_STBY</Note>
</RailDefinition>
<RailDefinition>
<Name>I3V6</Name>
<Page_Index>15</Page_Index>
<Color />
<Start>0</Start>
<Stop>0</Stop>
<Vout>0</Vout>
<Note>I3V6</Note>
</RailDefinition>
</Int_Rail_Defs>
<Ext_Rail_Defs />
<Devices />
<Other_Names />
</Sequencing_Config_V1>
<Use_Old_UCD92XX_CLA_Gains>true</Use_Old_UCD92XX_CLA_Gains>
</ProjectData>
<Original_Device_Address>52</Original_Device_Address>
<Import_Order>0</Import_Order>
</ProjectInfo>
</Project_Info_List>
</MultiProjectsData>
From this I was able to extract the information into a json file, see below.
"command_number": 1,
"request": "WriteByte",
"address": "0x34",
"command": "0x00",
"data": "0xFF67",
"comment": "Turn all rails off via PAGE = 0xFF"
"command_number": 2,
"address": "0x34",
"command": "0x02",
"data": "0x18F6",
"command_number": 3,
"address": "0x34",
"command": "0x00",
"data": "0xFF67",
"command_number": 4,
"address": "0x34",
"command": "0x01",
"data": "0x0081",
"command_number": 5,
"address": "0x34",
"command": "0x00",
"data": "0x0094",
"comment": "Write VOUT_MODE [Rail #1] EXP =-9"
"command_number": 6,
"request": "ReadByte",
"address": "0x34",
"command": "0x00",
"data": "0x00",
"command_number": 7,
"address": "0x34",
"command": "0x20",
"data": "0x175F",
"command_number": 8,
"address": "0x34",
"command": "0x20",
"data": "0x17",
"command_number": 9,
"address": "0x34",
"command": "0x00",
"data": "0x0193",
"comment": "Write VOUT_MODE [Rail #2] EXP =-10"
"command_number": 10,
"address": "0x34",
"command": "0x00",
"data": "0x01",
"command_number": 11,
"address": "0x34",
"command": "0x20",
"data": "0x1658",
"command_number": 12,
"address": "0x34",
"command": "0x20",
"data": "0x16",
"command_number": 13,
"address": "0x34",
"command": "0x00",
"data": "0x029A",
"comment": "Write VOUT_MODE [Rail #3] EXP =-10"
"command_number": 14,
"address": "0x34",
"command": "0x00",
"data": "0x02",
"command_number": 15,
"address": "0x34",
"command": "0x20",
"data": "0x1658",
"command_number": 16,
"address": "0x34",
"command": "0x20",
"data": "0x16",
"command_number": 17,
"address": "0x34",
"command": "0x00",
"data": "0x039D",
"comment": "Write VOUT_MODE [Rail #4] EXP =-12"
"command_number": 18,
"address": "0x34",
"command": "0x00",
"data": "0x03",
"command_number": 19,
"address": "0x34",
"command": "0x20",
"data": "0x1456",
"command_number": 20,
"address": "0x34",
"command": "0x20",
"data": "0x14",
"command_number": 21,
"address": "0x34",
"command": "0x00",
"data": "0x0488",
"comment": "Write VOUT_MODE [Rail #5] EXP =-12"
"command_number": 22,
"address": "0x34",
"command": "0x00",
"data": "0x04",
"command_number": 23,
"address": "0x34",
"command": "0x20",
"data": "0x1456",
"command_number": 24,
"address": "0x34",
"command": "0x20",
"data": "0x14",
"command_number": 25,
"address": "0x34",
"command": "0x00",
"data": "0x058F",
"comment": "Write VOUT_MODE [Rail #6] EXP =-12"
"command_number": 26,
"address": "0x34",
"command": "0x00",
"data": "0x05",
"command_number": 27,
"address": "0x34",
"command": "0x20",
"data": "0x1456",
"command_number": 28,
"address": "0x34",
"command": "0x20",
"data": "0x14",
"command_number": 29,
"address": "0x34",
"command": "0x00",
"data": "0x0686",
"comment": "Write VOUT_MODE [Rail #7] EXP =-12"
"command_number": 30,
"address": "0x34",
"command": "0x00",
"data": "0x06",
"command_number": 31,
"address": "0x34",
"command": "0x20",
"data": "0x1456",
"command_number": 32,
"address": "0x34",
"command": "0x20",
"data": "0x14",
"command_number": 33,
"address": "0x34",
"command": "0x00",
"data": "0x0781",
"comment": "Write VOUT_MODE [Rail #8] EXP =-12"
"command_number": 34,
"address": "0x34",
"command": "0x00",
"data": "0x07",
"command_number": 35,
"address": "0x34",
"command": "0x20",
"data": "0x1456",
"command_number": 36,
"address": "0x34",
"command": "0x20",
"data": "0x14",
"command_number": 37,
"address": "0x34",
"command": "0x00",
"data": "0x08AC",
"comment": "Write VOUT_MODE [Rail #9] EXP =-9"
"command_number": 38,
"address": "0x34",
"command": "0x00",
"data": "0x08",
"command_number": 39,
"address": "0x34",
"command": "0x20",
"data": "0x175F",
"command_number": 40,
"address": "0x34",
"command": "0x20",
"data": "0x17",
"command_number": 41,
"address": "0x34",
"command": "0x00",
"data": "0x09AB",
"comment": "Write VOUT_MODE [Rail #10] EXP =-10"
"command_number": 42,
"address": "0x34",
"command": "0x00",
"data": "0x09",
"command_number": 43,
"address": "0x34",
"command": "0x20",
"data": "0x1658",
"command_number": 44,
"address": "0x34",
"command": "0x20",
"data": "0x16",
"command_number": 45,
"address": "0x34",
"command": "0x00",
"data": "0x0AA2",
"comment": "Write VOUT_MODE [Rail #11] EXP =-10"
"command_number": 46,
"address": "0x34",
"command": "0x00",
"data": "0x0A",
"command_number": 47,
"address": "0x34",
"command": "0x20",
"data": "0x1658",
"command_number": 48,
"address": "0x34",
"command": "0x20",
"data": "0x16",
"command_number": 49,
"address": "0x34",
"command": "0x00",
"data": "0x0BA5",
"comment": "Write VOUT_MODE [Rail #12] EXP =-12"
"command_number": 50,
"address": "0x34",
"command": "0x00",
"data": "0x0B",
"command_number": 51,
"address": "0x34",
"command": "0x20",
"data": "0x1456",
"command_number": 52,
"address": "0x34",
"command": "0x20",
"data": "0x14",
"command_number": 53,
"address": "0x34",
"command": "0x00",
"data": "0x0CB0",
"comment": "Write VOUT_MODE [Rail #13] EXP =-12"
"command_number": 54,
"address": "0x34",
"command": "0x00",
"data": "0x0C",
"command_number": 55,
"address": "0x34",
"command": "0x20",
"data": "0x1456",
"command_number": 56,
"address": "0x34",
"command": "0x20",
"data": "0x14",
"command_number": 57,
"address": "0x34",
"command": "0x00",
"data": "0x0DB7",
"comment": "Write VOUT_MODE [Rail #14] EXP =-12"
"command_number": 58,
"address": "0x34",
"command": "0x00",
"data": "0x0D",
"command_number": 59,
"address": "0x34",
"command": "0x20",
"data": "0x1456",
"command_number": 60,
"address": "0x34",
"command": "0x20",
"data": "0x14",
"command_number": 61,
"address": "0x34",
"command": "0x00",
"data": "0x0EBE",
"comment": "Write VOUT_MODE [Rail #15] EXP =-12"
"command_number": 62,
"address": "0x34",
"command": "0x00",
"data": "0x0E",
"command_number": 63,
"address": "0x34",
"command": "0x20",
"data": "0x1456",
"command_number": 64,
"address": "0x34",
"command": "0x20",
"data": "0x14",
"command_number": 65,
"address": "0x34",
"command": "0x00",
"data": "0x0FB9",
"comment": "Write VOUT_MODE [Rail #16] EXP =-12"
"command_number": 66,
"address": "0x34",
"command": "0x00",
"data": "0x0F",
"command_number": 67,
"address": "0x34",
"command": "0x20",
"data": "0x1456",
"command_number": 68,
"address": "0x34",
"command": "0x20",
"data": "0x14",
"command_number": 69,
"request": "BlockWrite",
"address": "0x34",
"command": "0xD5",
"data": "0x10202122832425262728292A2B2C2D2E2FFD",
"comment": "Write MONITOR_CONFIG [MFR 05] Pin 1 MON1: Rail #1, Type Voltage; Pin 2 MON2: Rail #2, Type Voltage; Pin 3 MON3: Rail #3, Type Voltage; Pin 4 MON4: Rail #4, Type Voltage, HW Comparator; Pin 5 MON5: Rail #5, Type Voltage; Pin 6 MON6: Rail #6, Type Voltage; Pin 55 MON7: Rail #7, Type Voltage; Pin 56 MON8: Rail #8, Type Voltage; Pin 57 MON9: Rail #9, Type Voltage; Pin 58 MON10: Rail #10, Type Voltage; Pin 59 MON11: Rail #11, Type Voltage; Pin 62 MON12: Rail #12, Type Voltage; Pin 63 MON13: Rail #13, Type Voltage; Pin 50 MON14: Rail #14, Type Voltage; Pin 52 MON15: Rail #15, Type Voltage; Pin 54 MON16: Rail #16, Type Voltage"
"command_number": 70,
"request": "BlockRead",
"address": "0x34",
"command": "0xD5",
"data": "0x10202122832425262728292A2B2C2D2E2F",
"command_number": 71,
"address": "0x34",
"command": "0xF9",
"data": "0x1F0000000000000000000000000000000000000000000000000000000000000082",
"comment": "Write GPI_CONFIG [MFR 41] Inputs: Unassigned;Unassigned;Unassigned;Unassigned;Unassigned;Unassigned;Unassigned;Unassigned;; Fault Responses: Max Glitch Time: 0.0 ms| Fault Response: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| Page Mask: ; Fault Pin Config: Max Glitch Time: 0.0 ms| Fault Response: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| Page Mask for Output: | Page Mask for Responses:"
"command_number": 72,
"address": "0x34",
"command": "0xF9",
"data": "0x1F00000000000000000000000000000000000000000000000000000000000000",
"command_number": 73,
"address": "0x34",
"command": "0x00",
"data": "0x0094",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #1] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 74,
"address": "0x34",
"command": "0x00",
"data": "0x00",
"command_number": 75,
"address": "0x34",
"command": "0xF6",
"data": "0x109400000000000000000000000000000034",
"command_number": 76,
"address": "0x34",
"command": "0xF6",
"data": "0x1094000000000000000000000000000000",
"command_number": 77,
"address": "0x34",
"command": "0x00",
"data": "0x0193",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #2] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 78,
"address": "0x34",
"command": "0x00",
"data": "0x01",
"command_number": 79,
"address": "0x34",
"command": "0xF6",
"data": "0x10000000000000000000000000000000001B",
"command_number": 80,
"address": "0x34",
"command": "0xF6",
"data": "0x1000000000000000000000000000000000",
"command_number": 81,
"address": "0x34",
"command": "0x00",
"data": "0x029A",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #3] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 82,
"address": "0x34",
"command": "0x00",
"data": "0x02",
"command_number": 83,
"address": "0x34",
"command": "0xF6",
"command_number": 84,
"address": "0x34",
"command": "0xF6",
"command_number": 85,
"address": "0x34",
"command": "0x00",
"data": "0x039D",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #4] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 86,
"address": "0x34",
"command": "0x00",
"data": "0x03",
"command_number": 87,
"address": "0x34",
"command": "0xF6",
"command_number": 88,
"address": "0x34",
"command": "0xF6",
"command_number": 89,
"address": "0x34",
"command": "0x00",
"data": "0x0488",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #5] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 90,
"address": "0x34",
"command": "0x00",
"data": "0x04",
"command_number": 91,
"address": "0x34",
"command": "0xF6",
"command_number": 92,
"address": "0x34",
"command": "0xF6",
"command_number": 93,
"address": "0x34",
"command": "0x00",
"data": "0x058F",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #6] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 94,
"address": "0x34",
"command": "0x00",
"data": "0x05",
"command_number": 95,
"address": "0x34",
"command": "0xF6",
"command_number": 96,
"address": "0x34",
"command": "0xF6",
"command_number": 97,
"address": "0x34",
"command": "0x00",
"data": "0x0686",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #7] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 98,
"address": "0x34",
"command": "0x00",
"data": "0x06",
"command_number": 99,
"address": "0x34",
"command": "0xF6",
"command_number": 100,
"address": "0x34",
"command": "0xF6",
"command_number": 101,
"address": "0x34",
"command": "0x00",
"data": "0x0781",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #8] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 102,
"address": "0x34",
"command": "0x00",
"data": "0x07",
"command_number": 103,
"address": "0x34",
"command": "0xF6",
"command_number": 104,
"address": "0x34",
"command": "0xF6",
"command_number": 105,
"address": "0x34",
"command": "0x00",
"data": "0x08AC",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #9] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 106,
"address": "0x34",
"command": "0x00",
"data": "0x08",
"command_number": 107,
"address": "0x34",
"command": "0xF6",
"command_number": 108,
"address": "0x34",
"command": "0xF6",
"command_number": 109,
"address": "0x34",
"command": "0x00",
"data": "0x09AB",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #10] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 110,
"address": "0x34",
"command": "0x00",
"data": "0x09",
"command_number": 111,
"address": "0x34",
"command": "0xF6",
"command_number": 112,
"address": "0x34",
"command": "0xF6",
"command_number": 113,
"address": "0x34",
"command": "0x00",
"data": "0x0AA2",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #11] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 114,
"address": "0x34",
"command": "0x00",
"data": "0x0A",
"command_number": 115,
"address": "0x34",
"command": "0xF6",
"command_number": 116,
"address": "0x34",
"command": "0xF6",
"command_number": 117,
"address": "0x34",
"command": "0x00",
"data": "0x0BA5",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #12] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 118,
"address": "0x34",
"command": "0x00",
"data": "0x0B",
"command_number": 119,
"address": "0x34",
"command": "0xF6",
"command_number": 120,
"address": "0x34",
"command": "0xF6",
"command_number": 121,
"address": "0x34",
"command": "0x00",
"data": "0x0CB0",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #13] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 122,
"address": "0x34",
"command": "0x00",
"data": "0x0C",
"command_number": 123,
"address": "0x34",
"command": "0xF6",
"command_number": 124,
"address": "0x34",
"command": "0xF6",
"command_number": 125,
"address": "0x34",
"command": "0x00",
"data": "0x0DB7",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #14] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 126,
"address": "0x34",
"command": "0x00",
"data": "0x0D",
"command_number": 127,
"address": "0x34",
"command": "0xF6",
"command_number": 128,
"address": "0x34",
"command": "0xF6",
"command_number": 129,
"address": "0x34",
"command": "0x00",
"data": "0x0EBE",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #15] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 130,
"address": "0x34",
"command": "0x00",
"data": "0x0E",
"command_number": 131,
"address": "0x34",
"command": "0xF6",
"command_number": 132,
"address": "0x34",
"command": "0xF6",
"command_number": 133,
"address": "0x34",
"command": "0x00",
"data": "0x0FB9",
"comment": "Write SEQ_CONFIG [MFR 38,Rail #16] Rail On Dep: <None> | GPI On Dep: <None> | GPO On Dep: <None> | Rail Off Dep: <None> | GPI Off Dep: <None> | GPO Off Dep: <None> | Fault Dep: <None> | Enable: Unassigned; Seq On Timeout: 0 / Wait Indefinitely; Seq Off Timeout: 0 / Wait Indefinitely"
"command_number": 134,
"address": "0x34",
"command": "0x00",
"data": "0x0F",
"command_number": 135,
"address": "0x34",
"command": "0xF6",
"command_number": 136,
"address": "0x34",
"command": "0xF6",
"command_number": 137,
"address": "0x34",
"command": "0xF7",
"data": "0x00EB",
"comment": "Write GPO_CONFIG_1 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 138,
"address": "0x34",
"command": "0xF7",
"data": "0x00",
"command_number": 139,
"address": "0x34",
"command": "0xF8",
"data": "0x15000000000000000000000000000000000000000000DC",
"command_number": 140,
"address": "0x34",
"command": "0xF8",
"data": "0x15000000000000000000000000000000000000000000",
"command_number": 141,
"address": "0x34",
"command": "0xF7",
"data": "0x01EC",
"comment": "Write GPO_CONFIG_2 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 142,
"address": "0x34",
"command": "0xF7",
"data": "0x01",
"command_number": 143,
"address": "0x34",
"command": "0xF8",
"command_number": 144,
"address": "0x34",
"command": "0xF8",
"command_number": 145,
"address": "0x34",
"command": "0xF7",
"data": "0x02E5",
"comment": "Write GPO_CONFIG_3 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 146,
"address": "0x34",
"command": "0xF7",
"data": "0x02",
"command_number": 147,
"address": "0x34",
"command": "0xF8",
"command_number": 148,
"address": "0x34",
"command": "0xF8",
"command_number": 149,
"address": "0x34",
"command": "0xF7",
"data": "0x03E2",
"comment": "Write GPO_CONFIG_4 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 150,
"address": "0x34",
"command": "0xF7",
"data": "0x03",
"command_number": 151,
"address": "0x34",
"command": "0xF8",
"command_number": 152,
"address": "0x34",
"command": "0xF8",
"command_number": 153,
"address": "0x34",
"command": "0xF7",
"data": "0x04F7",
"comment": "Write GPO_CONFIG_5 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 154,
"address": "0x34",
"command": "0xF7",
"data": "0x04",
"command_number": 155,
"address": "0x34",
"command": "0xF8",
"command_number": 156,
"address": "0x34",
"command": "0xF8",
"command_number": 157,
"address": "0x34",
"command": "0xF7",
"data": "0x05F0",
"comment": "Write GPO_CONFIG_6 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 158,
"address": "0x34",
"command": "0xF7",
"data": "0x05",
"command_number": 159,
"address": "0x34",
"command": "0xF8",
"command_number": 160,
"address": "0x34",
"command": "0xF8",
"command_number": 161,
"address": "0x34",
"command": "0xF7",
"data": "0x06F9",
"comment": "Write GPO_CONFIG_7 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 162,
"address": "0x34",
"command": "0xF7",
"data": "0x06",
"command_number": 163,
"address": "0x34",
"command": "0xF8",
"command_number": 164,
"address": "0x34",
"command": "0xF8",
"command_number": 165,
"address": "0x34",
"command": "0xF7",
"data": "0x07FE",
"comment": "Write GPO_CONFIG_8 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 166,
"address": "0x34",
"command": "0xF7",
"data": "0x07",
"command_number": 167,
"address": "0x34",
"command": "0xF8",
"command_number": 168,
"address": "0x34",
"command": "0xF8",
"command_number": 169,
"address": "0x34",
"command": "0xF7",
"data": "0x08D3",
"comment": "Write GPO_CONFIG_9 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 170,
"address": "0x34",
"command": "0xF7",
"data": "0x08",
"command_number": 171,
"address": "0x34",
"command": "0xF8",
"command_number": 172,
"address": "0x34",
"command": "0xF8",
"command_number": 173,
"address": "0x34",
"command": "0xF7",
"data": "0x09D4",
"comment": "Write GPO_CONFIG_10 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 174,
"address": "0x34",
"command": "0xF7",
"data": "0x09",
"command_number": 175,
"address": "0x34",
"command": "0xF8",
"command_number": 176,
"address": "0x34",
"command": "0xF8",
"command_number": 177,
"address": "0x34",
"command": "0xF7",
"data": "0x0ADD",
"comment": "Write GPO_CONFIG_11 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 178,
"address": "0x34",
"command": "0xF7",
"data": "0x0A",
"command_number": 179,
"address": "0x34",
"command": "0xF8",
"command_number": 180,
"address": "0x34",
"command": "0xF8",
"command_number": 181,
"address": "0x34",
"command": "0xF7",
"data": "0x0BDA",
"comment": "Write GPO_CONFIG_12 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 182,
"address": "0x34",
"command": "0xF7",
"data": "0x0B",
"command_number": 183,
"address": "0x34",
"command": "0xF8",
"command_number": 184,
"address": "0x34",
"command": "0xF8",
"command_number": 185,
"address": "0x34",
"command": "0xF7",
"data": "0x0CCF",
"comment": "Write GPO_CONFIG_13 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 186,
"address": "0x34",
"command": "0xF7",
"data": "0x0C",
"command_number": 187,
"address": "0x34",
"command": "0xF8",
"command_number": 188,
"address": "0x34",
"command": "0xF8",
"command_number": 189,
"address": "0x34",
"command": "0xF7",
"data": "0x0DC8",
"comment": "Write GPO_CONFIG_14 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 190,
"address": "0x34",
"command": "0xF7",
"data": "0x0D",
"command_number": 191,
"address": "0x34",
"command": "0xF8",
"command_number": 192,
"address": "0x34",
"command": "0xF8",
"command_number": 193,
"address": "0x34",
"command": "0xF7",
"data": "0x0EC1",
"comment": "Write GPO_CONFIG_15 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 194,
"address": "0x34",
"command": "0xF7",
"data": "0x0E",
"command_number": 195,
"address": "0x34",
"command": "0xF8",
"command_number": 196,
"address": "0x34",
"command": "0xF8",
"command_number": 197,
"address": "0x34",
"command": "0xF7",
"data": "0x0FC6",
"comment": "Write GPO_CONFIG_16 [MFR 40] Unassigned; No Mask; Delay Time: 0 ms; Assert Delay disabled; Assert Delay disabled"
"command_number": 198,
"address": "0x34",
"command": "0xF7",
"data": "0x0F",
"command_number": 199,
"address": "0x34",
"command": "0xF8",
"command_number": 200,
"address": "0x34",
"command": "0xF8",
"command_number": 201,
"address": "0x34",
"command": "0xE0",
"data": "0x00D7",
"comment": "Write PWM_CONFIG_0 [MFR 17] Pin_ID = 0; Duty Cycle: 1.0 %; Frequency: 15.28 MHz; Phase: 0.0 deg"
"command_number": 202,
"address": "0x34",
"command": "0xE0",
"data": "0x00",
"command_number": 203,
"address": "0x34",
"command": "0xE1",
"data": "0x08B3FE00E913F880005A",
"command_number": 204,
"address": "0x34",
"command": "0xE1",
"data": "0x08B3FE00E913F88000",
"command_number": 205,
"address": "0x34",
"command": "0xE0",
"data": "0x01D0",
"comment": "Write PWM_CONFIG_1 [MFR 17] Pin_ID = 1; Duty Cycle: 1.0 %; Frequency: 15.28 MHz; Phase: 0.0 deg"
"command_number": 206,
"address": "0x34",
"command": "0xE0",
"data": "0x01",
"command_number": 207,
"address": "0x34",
"command": "0xE1",
"command_number": 208,
"address": "0x34",
"command": "0xE1",
"command_number": 209,
"address": "0x34",
"command": "0xE0",
"data": "0x02D9",
"comment": "Write PWM_CONFIG_2 [MFR 17] Pin_ID = 2; Duty Cycle: 1.0 %; Frequency: 15.28 MHz; Phase: 0.0 deg"
"command_number": 210,
"address": "0x34",
"command": "0xE0",
"data": "0x02",
"command_number": 211,
"address": "0x34",
"command": "0xE1",
"command_number": 212,
"address": "0x34",
"command": "0xE1",
"command_number": 213,
"address": "0x34",
"command": "0xE0",
"data": "0x03DE",
"comment": "Write PWM_CONFIG_3 [MFR 17] Pin_ID = 3; Duty Cycle: 0.0 %; Frequency: 15.28 MHz; Phase: 0.0 deg"
"command_number": 214,
"address": "0x34",
"command": "0xE0",
"data": "0x03",
"command_number": 215,
"address": "0x34",
"command": "0xE1",
"data": "0x08880000E913F8800035",
"command_number": 216,
"address": "0x34",
"command": "0xE1",
"data": "0x08880000E913F88000",
"command_number": 217,
"address": "0x34",
"command": "0xE0",
"data": "0x04CB",
"comment": "Write PWM_CONFIG_4 [MFR 17] Pin_ID = 4; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg"
"command_number": 218,
"address": "0x34",
"command": "0xE0",
"data": "0x04",
"command_number": 219,
"address": "0x34",
"command": "0xE1",
"data": "0x08880000000000800015",
"command_number": 220,
"address": "0x34",
"command": "0xE1",
"data": "0x088800000000008000",
"command_number": 221,
"address": "0x34",
"command": "0xE0",
"data": "0x05CC",
"comment": "Write PWM_CONFIG_5 [MFR 17] Pin_ID = 5; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg"
"command_number": 222,
"address": "0x34",
"command": "0xE0",
"data": "0x05",
"command_number": 223,
"address": "0x34",
"command": "0xE1",
"command_number": 224,
"address": "0x34",
"command": "0xE1",
"command_number": 225,
"address": "0x34",
"command": "0xE0",
"data": "0x06C5",
"comment": "Write PWM_CONFIG_6 [MFR 17] Pin_ID = 6; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg"
"command_number": 226,
"address": "0x34",
"command": "0xE0",
"data": "0x06",
"command_number": 227,
"address": "0x34",
"command": "0xE1",
"command_number": 228,
"address": "0x34",
"command": "0xE1",
"command_number": 229,
"address": "0x34",
"command": "0xE0",
"data": "0x07C2",
"comment": "Write PWM_CONFIG_7 [MFR 17] Pin_ID = 7; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg"
"command_number": 230,
"address": "0x34",
"command": "0xE0",
"data": "0x07",
"command_number": 231,
"address": "0x34",
"command": "0xE1",
"command_number": 232,
"address": "0x34",
"command": "0xE1",
"command_number": 233,
"address": "0x34",
"command": "0xE0",
"data": "0x08EF",
"comment": "Write PWM_CONFIG_8 [MFR 17] Pin_ID = 8; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg"
"command_number": 234,
"address": "0x34",
"command": "0xE0",
"data": "0x08",
"command_number": 235,
"address": "0x34",
"command": "0xE1",
"data": "0x088800000000000000A3",
"command_number": 236,
"address": "0x34",
"command": "0xE1",
"data": "0x088800000000000000",
"command_number": 237,
"address": "0x34",
"command": "0xE0",
"data": "0x09E8",
"comment": "Write PWM_CONFIG_9 [MFR 17] Pin_ID = 9; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg"
"command_number": 238,
"address": "0x34",
"command": "0xE0",
"data": "0x09",
"command_number": 239,
"address": "0x34",
"command": "0xE1",
"command_number": 240,
"address": "0x34",
"command": "0xE1",
"command_number": 241,
"address": "0x34",
"command": "0xE0",
"data": "0x0AE1",
"comment": "Write PWM_CONFIG_10 [MFR 17] Pin_ID = 10; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg"
"command_number": 242,
"address": "0x34",
"command": "0xE0",
"data": "0x0A",
"command_number": 243,
"address": "0x34",
"command": "0xE1",
"command_number": 244,
"address": "0x34",
"command": "0xE1",
"command_number": 245,
"address": "0x34",
"command": "0xE0",
"data": "0x0BE6",
"comment": "Write PWM_CONFIG_11 [MFR 17] Pin_ID = 11; Duty Cycle: 0.0 %; Frequency: 0 Hz; Phase: 0.0 deg"
"command_number": 246,
"address": "0x34",
"command": "0xE0",
"data": "0x0B",
"command_number": 247,
"address": "0x34",
"command": "0xE1",
"command_number": 248,
"address": "0x34",
"command": "0xE1",
"command_number": 249,
"address": "0x34",
"command": "0x00",
"data": "0x0094",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #1] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 250,
"address": "0x34",
"command": "0x00",
"data": "0x00",
"command_number": 251,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 252,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 253,
"address": "0x34",
"command": "0x00",
"data": "0x0193",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #2] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 254,
"address": "0x34",
"command": "0x00",
"data": "0x01",
"command_number": 255,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 256,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 257,
"address": "0x34",
"command": "0x00",
"data": "0x029A",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #3] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 258,
"address": "0x34",
"command": "0x00",
"data": "0x02",
"command_number": 259,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 260,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 261,
"address": "0x34",
"command": "0x00",
"data": "0x039D",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #4] Mode: EnableActiveTrim; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 2, # 19 FPWM3_GPIO7"
"command_number": 262,
"address": "0x34",
"command": "0x00",
"data": "0x03",
"command_number": 263,
"address": "0x34",
"command": "0xF5",
"data": "0x8246",
"command_number": 264,
"address": "0x34",
"command": "0xF5",
"data": "0x82",
"command_number": 265,
"address": "0x34",
"command": "0x00",
"data": "0x0488",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #5] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 266,
"address": "0x34",
"command": "0x00",
"data": "0x04",
"command_number": 267,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 268,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 269,
"address": "0x34",
"command": "0x00",
"data": "0x058F",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #6] Mode: EnableActiveTrim; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 3, # 20 FPWM4_GPIO8"
"command_number": 270,
"address": "0x34",
"command": "0x00",
"data": "0x05",
"command_number": 271,
"address": "0x34",
"command": "0xF5",
"data": "0x8341",
"command_number": 272,
"address": "0x34",
"command": "0xF5",
"data": "0x83",
"command_number": 273,
"address": "0x34",
"command": "0x00",
"data": "0x0686",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #7] Mode: EnableActiveTrim; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 274,
"address": "0x34",
"command": "0x00",
"data": "0x06",
"command_number": 275,
"address": "0x34",
"command": "0xF5",
"data": "0x8048",
"command_number": 276,
"address": "0x34",
"command": "0xF5",
"data": "0x80",
"command_number": 277,
"address": "0x34",
"command": "0x00",
"data": "0x0781",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #8] Mode: EnableActiveTrim; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 1, # 18 FPWM2_GPIO6"
"command_number": 278,
"address": "0x34",
"command": "0x00",
"data": "0x07",
"command_number": 279,
"address": "0x34",
"command": "0xF5",
"data": "0x814F",
"command_number": 280,
"address": "0x34",
"command": "0xF5",
"data": "0x81",
"command_number": 281,
"address": "0x34",
"command": "0x00",
"data": "0x08AC",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #9] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 282,
"address": "0x34",
"command": "0x00",
"data": "0x08",
"command_number": 283,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 284,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 285,
"address": "0x34",
"command": "0x00",
"data": "0x09AB",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #10] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 286,
"address": "0x34",
"command": "0x00",
"data": "0x09",
"command_number": 287,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 288,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 289,
"address": "0x34",
"command": "0x00",
"data": "0x0AA2",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #11] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 290,
"address": "0x34",
"command": "0x00",
"data": "0x0A",
"command_number": 291,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 292,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 293,
"address": "0x34",
"command": "0x00",
"data": "0x0BA5",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #12] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 294,
"address": "0x34",
"command": "0x00",
"data": "0x0B",
"command_number": 295,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 296,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 297,
"address": "0x34",
"command": "0x00",
"data": "0x0CB0",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #13] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 298,
"address": "0x34",
"command": "0x00",
"data": "0x0C",
"command_number": 299,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 300,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 301,
"address": "0x34",
"command": "0x00",
"data": "0x0DB7",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #14] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 302,
"address": "0x34",
"command": "0x00",
"data": "0x0D",
"command_number": 303,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 304,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 305,
"address": "0x34",
"command": "0x00",
"data": "0x0EBE",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #15] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 306,
"address": "0x34",
"command": "0x00",
"data": "0x0E",
"command_number": 307,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 308,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 309,
"address": "0x34",
"command": "0x00",
"data": "0x0FB9",
"comment": "Write MARGIN_CONFIG [MFR 37,Rail #16] Mode: Disabled; Increase Duty Cycle decreases Voltage; Ignore Faults: False; PWM Pin: ID 0, # 17 FPWM1_GPIO5"
"command_number": 310,
"address": "0x34",
"command": "0x00",
"data": "0x0F",
"command_number": 311,
"address": "0x34",
"command": "0xF5",
"data": "0x00C1",
"command_number": 312,
"address": "0x34",
"command": "0xF5",
"data": "0x00",
"command_number": 313,
"address": "0x34",
"command": "0xFA",
"data": "0x0002",
"comment": "Write GPIO_CONFIG_0 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: False"
"command_number": 314,
"address": "0x34",
"command": "0xFA",
"data": "0x00",
"command_number": 315,
"address": "0x34",
"command": "0xFB",
"data": "0x0017",
"command_number": 316,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 317,
"address": "0x34",
"command": "0xFA",
"data": "0x0105",
"comment": "Write GPIO_CONFIG_1 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: False"
"command_number": 318,
"address": "0x34",
"command": "0xFA",
"data": "0x01",
"command_number": 319,
"address": "0x34",
"command": "0xFB",
"data": "0x0017",
"command_number": 320,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 321,
"address": "0x34",
"command": "0xFA",
"data": "0x020C",
"comment": "Write GPIO_CONFIG_2 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: False"
"command_number": 322,
"address": "0x34",
"command": "0xFA",
"data": "0x02",
"command_number": 323,
"address": "0x34",
"command": "0xFB",
"data": "0x0017",
"command_number": 324,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 325,
"address": "0x34",
"command": "0xFA",
"data": "0x030B",
"comment": "Write GPIO_CONFIG_3 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: False"
"command_number": 326,
"address": "0x34",
"command": "0xFA",
"data": "0x03",
"command_number": 327,
"address": "0x34",
"command": "0xFB",
"data": "0x0017",
"command_number": 328,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 329,
"address": "0x34",
"command": "0xFA",
"data": "0x041E",
"comment": "Write GPIO_CONFIG_4 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: False"
"command_number": 330,
"address": "0x34",
"command": "0xFA",
"data": "0x04",
"command_number": 331,
"address": "0x34",
"command": "0xFB",
"data": "0x0017",
"command_number": 332,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 333,
"address": "0x34",
"command": "0xFA",
"data": "0x0519",
"comment": "Write GPIO_CONFIG_5 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: False"
"command_number": 334,
"address": "0x34",
"command": "0xFA",
"data": "0x05",
"command_number": 335,
"address": "0x34",
"command": "0xFB",
"data": "0x0017",
"command_number": 336,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 337,
"address": "0x34",
"command": "0xFA",
"data": "0x0610",
"comment": "Write GPIO_CONFIG_6 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: False"
"command_number": 338,
"address": "0x34",
"command": "0xFA",
"data": "0x06",
"command_number": 339,
"address": "0x34",
"command": "0xFB",
"data": "0x0017",
"command_number": 340,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 341,
"address": "0x34",
"command": "0xFA",
"data": "0x0717",
"comment": "Write GPIO_CONFIG_7 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: False"
"command_number": 342,
"address": "0x34",
"command": "0xFA",
"data": "0x07",
"command_number": 343,
"address": "0x34",
"command": "0xFB",
"data": "0x0017",
"command_number": 344,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 345,
"address": "0x34",
"command": "0xFA",
"data": "0x083A",
"comment": "Write GPIO_CONFIG_8 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 346,
"address": "0x34",
"command": "0xFA",
"data": "0x08",
"command_number": 347,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 348,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 349,
"address": "0x34",
"command": "0xFA",
"data": "0x093D",
"comment": "Write GPIO_CONFIG_9 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 350,
"address": "0x34",
"command": "0xFA",
"data": "0x09",
"command_number": 351,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 352,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 353,
"address": "0x34",
"command": "0xFA",
"data": "0x0A34",
"comment": "Write GPIO_CONFIG_10 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 354,
"address": "0x34",
"command": "0xFA",
"data": "0x0A",
"command_number": 355,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 356,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 357,
"address": "0x34",
"command": "0xFA",
"data": "0x0B33",
"comment": "Write GPIO_CONFIG_11 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 358,
"address": "0x34",
"command": "0xFA",
"data": "0x0B",
"command_number": 359,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 360,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 361,
"address": "0x34",
"command": "0xFA",
"data": "0x0C26",
"comment": "Write GPIO_CONFIG_12 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 362,
"address": "0x34",
"command": "0xFA",
"data": "0x0C",
"command_number": 363,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 364,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 365,
"address": "0x34",
"command": "0xFA",
"data": "0x0D21",
"comment": "Write GPIO_CONFIG_13 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 366,
"address": "0x34",
"command": "0xFA",
"data": "0x0D",
"command_number": 367,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 368,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 369,
"address": "0x34",
"command": "0xFA",
"data": "0x0E28",
"comment": "Write GPIO_CONFIG_14 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 370,
"address": "0x34",
"command": "0xFA",
"data": "0x0E",
"command_number": 371,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 372,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 373,
"address": "0x34",
"command": "0xFA",
"data": "0x0F2F",
"comment": "Write GPIO_CONFIG_15 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 374,
"address": "0x34",
"command": "0xFA",
"data": "0x0F",
"command_number": 375,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 376,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 377,
"address": "0x34",
"command": "0xFA",
"data": "0x1072",
"comment": "Write GPIO_CONFIG_16 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 378,
"address": "0x34",
"command": "0xFA",
"data": "0x10",
"command_number": 379,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 380,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 381,
"address": "0x34",
"command": "0xFA",
"data": "0x1175",
"comment": "Write GPIO_CONFIG_17 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 382,
"address": "0x34",
"command": "0xFA",
"data": "0x11",
"command_number": 383,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 384,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 385,
"address": "0x34",
"command": "0xFA",
"data": "0x127C",
"comment": "Write GPIO_CONFIG_18 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 386,
"address": "0x34",
"command": "0xFA",
"data": "0x12",
"command_number": 387,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 388,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 389,
"address": "0x34",
"command": "0xFA",
"data": "0x137B",
"comment": "Write GPIO_CONFIG_19 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 390,
"address": "0x34",
"command": "0xFA",
"data": "0x13",
"command_number": 391,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 392,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 393,
"address": "0x34",
"command": "0xFA",
"data": "0x146E",
"comment": "Write GPIO_CONFIG_20 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 394,
"address": "0x34",
"command": "0xFA",
"data": "0x14",
"command_number": 395,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 396,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 397,
"address": "0x34",
"command": "0xFA",
"data": "0x1569",
"comment": "Write GPIO_CONFIG_21 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 398,
"address": "0x34",
"command": "0xFA",
"data": "0x15",
"command_number": 399,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 400,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 401,
"address": "0x34",
"command": "0xFA",
"data": "0x1660",
"comment": "Write GPIO_CONFIG_22 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 402,
"address": "0x34",
"command": "0xFA",
"data": "0x16",
"command_number": 403,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 404,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 405,
"address": "0x34",
"command": "0xFA",
"data": "0x1767",
"comment": "Write GPIO_CONFIG_23 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 406,
"address": "0x34",
"command": "0xFA",
"data": "0x17",
"command_number": 407,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 408,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 409,
"address": "0x34",
"command": "0xFA",
"data": "0x184A",
"comment": "Write GPIO_CONFIG_24 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 410,
"address": "0x34",
"command": "0xFA",
"data": "0x18",
"command_number": 411,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 412,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 413,
"address": "0x34",
"command": "0xFA",
"data": "0x194D",
"comment": "Write GPIO_CONFIG_25 [MFR 43] Enable: False; Out_Enable: False; Out_Value: False; Status: True"
"command_number": 414,
"address": "0x34",
"command": "0xFA",
"data": "0x19",
"command_number": 415,
"address": "0x34",
"command": "0xFB",
"data": "0x082F",
"command_number": 416,
"address": "0x34",
"command": "0xFB",
"data": "0x00",
"command_number": 417,
"address": "0x34",
"command": "0xEF",
"data": "0x12FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C",
"comment": "Write LOGGED_FAULT_DETAIL_ENABLES [MFR 31] Common: LOG_NOT_EMPTY,SYSTEM_WATCHDOG_TIMEOUT,RESEQUENCE_ERROR,WATCHDOG_TIMEOUT,RESERVED4_OR_SINGLEEVTUPSET,RESERVED5,RESERVED6,RESERVED7; GPI: #1,2,3,4,5,6,7,8; Rail #1: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #2: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #3: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #4: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #5: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #6: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #7: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #8: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #9: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #10: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #11: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #12: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #13: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #14: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #15: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT; Rail #16: VOUT_OV,VOUT_UV,TON_MAX,RESERVED3,RESERVED4,RESERVED5,SEQ_ON_TIMEOUT,SEQ_OFF_TIMEOUT"
"command_number": 418,
"address": "0x34",
"command": "0xEF",
"data": "0x12FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF",
"command_number": 419,
"address": "0x34",
"command": "0x9D",
"data": "0x0659594D4D4444FC",
"comment": "Write MFR_DATE YYMMDD"
"command_number": 420,
"address": "0x34",
"command": "0x9D",
"data": "0x0659594D4D4444",
"command_number": 421,
"address": "0x34",
"command": "0x99",
"data": "0x064D46525F4944A0",
"comment": "Write MFR_ID MFR_ID"
"command_number": 422,
"address": "0x34",
"command": "0x99",
"data": "0x064D46525F4944",
"command_number": 423,
"address": "0x34",
"command": "0x9C",
"data": "0x0C4D46525F4C4F434154494F4E25",
"comment": "Write MFR_LOCATION MFR_LOCATION"
"command_number": 424,
"address": "0x34",
"command": "0x9C",
"data": "0x0C4D46525F4C4F434154494F4E",
"command_number": 425,
"address": "0x34",
"command": "0x9A",
"data": "0x094D46525F4D4F44454CEE",
"comment": "Write MFR_MODEL MFR_MODEL"
"command_number": 426,
"address": "0x34",
"command": "0x9A",
"data": "0x094D46525F4D4F44454C",
"command_number": 427,
"address": "0x34",
"command": "0x9B",
"data": "0x0C4D46525F5245564953494F4E6E",
"comment": "Write MFR_REVISION MFR_REVISION"
"command_number": 428,
"address": "0x34",
"command": "0x9B",
"data": "0x0C4D46525F5245564953494F4E",
"command_number": 429,
"address": "0x34",
"command": "0x9E",
"data": "0x06303030303030B2",
"comment": "Write MFR_SERIAL 000000"
"command_number": 430,
"address": "0x34",
"command": "0x9E",
"data": "0x06303030303030",
"command_number": 431,
"address": "0x34",
"command": "0xFC",
"data": "0x040000000055",
"comment": "Write MISC_CONFIG [MFR 44] Time Between Resequences: 0 msec; Resequence Abort: no; Max Resequences: 1; FIFO Mode: Disabled; Brownout Enable: no; Disable all logging: no; Resequence Rails Mask: 0x00 [0000000000000000b]"
"command_number": 432,
"address": "0x34",
"command": "0xFC",
"data": "0x0400000000",
"command_number": 433,
"address": "0x34",
"command": "0xDD",
"data": "0x12000000000000000000000000000000000000E3",
"comment": "Write PIN_SELECTED_RAIL_STATES [MFR 13] State 0: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 1: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 2: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 3: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 4: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 5: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 6: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off; State 7: Enabled=No, Turn Off Mode=ImmediateOff, Rails States= Rail #1 Off, Rail #2 Off, Rail #3 Off, Rail #4 Off, Rail #5 Off, Rail #6 Off, Rail #7 Off, Rail #8 Off, Rail #9 Off, Rail #10 Off, Rail #11 Off, Rail #12 Off, Rail #13 Off, Rail #14 Off, Rail #15 Off, Rail #16 Off"
"command_number": 434,
"address": "0x34",
"command": "0xDD",
"data": "0x12000000000000000000000000000000000000",
"command_number": 435,
"request": "WriteWord",
"address": "0x34",
"command": "0xDC",
"data": "0x000030",
"comment": "Write RESET_COUNT [MFR 12] 0"
"command_number": 436,
"request": "ReadWord",
"address": "0x34",
"command": "0xDC",
"data": "0x0000",
"command_number": 437,
"address": "0x34",
"command": "0xD8",
"data": "0x00882A",
"comment": "Write RUN_TIME_CLOCK_TRIM [MFR 08] 0.00 %"
"command_number": 438,
"address": "0x34",
"command": "0xD8",
"data": "0x0088",
"command_number": 439,
"address": "0x34",
"command": "0xD2",
"data": "0x09000000000000000000C2",
"comment": "Write SYSTEM_RESET_CONFIG [MFR 02] Disabled"
"command_number": 440,
"address": "0x34",
"command": "0xD2",
"data": "0x09000000000000000000",
"command_number": 441,
"address": "0x34",
"command": "0xD3",
"data": "0x0400000000FE",
"comment": "Write SYSTEM_WATCHDOG_CONFIG [MFR 03] Disabled"
"command_number": 442,
"address": "0x34",
"command": "0xD3",
"command_number": 443,
"address": "0x34",
"command": "0x00",
"data": "0x0094",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #1] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 444,
"address": "0x34",
"command": "0x00",
"data": "0x00",
"command_number": 445,
"address": "0x34",
"command": "0xE9",
"data": "0x060000000000009C",
"command_number": 446,
"address": "0x34",
"command": "0xE9",
"data": "0x06000000000000",
"command_number": 447,
"address": "0x34",
"command": "0x5F",
"data": "0x6626FF",
"comment": "Write POWER_GOOD_OFF [Rail #1] 19.199 V"
"command_number": 448,
"address": "0x34",
"command": "0x5F",
"data": "0x6626",
"command_number": 449,
"address": "0x34",
"command": "0x5E",
"data": "0x9A2D4D",
"comment": "Write POWER_GOOD_ON [Rail #1] 22.801 V"
"command_number": 450,
"address": "0x34",
"command": "0x5E",
"data": "0x9A2D",
"command_number": 451,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #1] 0.0 ms"
"command_number": 452,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 453,
"address": "0x34",
"command": "0x66",
"data": "0xFF7FF0",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #1] <No Limit>"
"command_number": 454,
"address": "0x34",
"command": "0x66",
"data": "0xFF7F",
"command_number": 455,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #1] 0.0 ms"
"command_number": 456,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 457,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #1] <No Limit>"
"command_number": 458,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 459,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #1] 0.000 V"
"command_number": 460,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 461,
"address": "0x34",
"command": "0x21",
"data": "0x00305D",
"comment": "Write VOUT_COMMAND [Rail #1] 24.000 V"
"command_number": 462,
"address": "0x34",
"command": "0x21",
"data": "0x0030",
"command_number": 463,
"address": "0x34",
"command": "0x25",
"data": "0x663273",
"comment": "Write VOUT_MARGIN_HIGH [Rail #1] 25.199 V"
"command_number": 464,
"address": "0x34",
"command": "0x25",
"data": "0x6632",
"command_number": 465,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D7B",
"comment": "Write VOUT_MARGIN_LOW [Rail #1] 22.801 V"
"command_number": 466,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D",
"command_number": 467,
"address": "0x34",
"command": "0x40",
"data": "0x333720",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #1] 27.600 V"
"command_number": 468,
"address": "0x34",
"command": "0x40",
"data": "0x3337",
"command_number": 469,
"address": "0x34",
"command": "0x42",
"data": "0xCD343D",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #1] 26.400 V"
"command_number": 470,
"address": "0x34",
"command": "0x42",
"data": "0xCD34",
"command_number": 471,
"address": "0x34",
"command": "0x2A",
"data": "0xA89A5E",
"comment": "Write VOUT_SCALE_MONITOR [Rail #1] 0.083"
"command_number": 472,
"address": "0x34",
"command": "0x2A",
"data": "0xA89A",
"command_number": 473,
"address": "0x34",
"command": "0x44",
"data": "0xCD2814",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #1] 20.400 V"
"command_number": 474,
"address": "0x34",
"command": "0x44",
"data": "0xCD28",
"command_number": 475,
"address": "0x34",
"command": "0x43",
"data": "0x332BC9",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #1] 21.600 V"
"command_number": 476,
"address": "0x34",
"command": "0x43",
"data": "0x332B",
"command_number": 477,
"address": "0x34",
"command": "0x00",
"data": "0x0193",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #2] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 478,
"address": "0x34",
"command": "0x00",
"data": "0x01",
"command_number": 479,
"address": "0x34",
"command": "0xE9",
"command_number": 480,
"address": "0x34",
"command": "0xE9",
"command_number": 481,
"address": "0x34",
"command": "0x5F",
"data": "0xCD285A",
"comment": "Write POWER_GOOD_OFF [Rail #2] 10.200 V"
"command_number": 482,
"address": "0x34",
"command": "0x5F",
"data": "0xCD28",
"command_number": 483,
"address": "0x34",
"command": "0x5E",
"data": "0x332BFA",
"comment": "Write POWER_GOOD_ON [Rail #2] 10.800 V"
"command_number": 484,
"address": "0x34",
"command": "0x5E",
"data": "0x332B",
"command_number": 485,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #2] 0.0 ms"
"command_number": 486,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 487,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #2] 0.0 ms"
"command_number": 488,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 489,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #2] 0.0 ms"
"command_number": 490,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 491,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #2] <No Limit>"
"command_number": 492,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 493,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #2] 0.000 V"
"command_number": 494,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 495,
"address": "0x34",
"command": "0x21",
"data": "0x00305D",
"comment": "Write VOUT_COMMAND [Rail #2] 12.000 V"
"command_number": 496,
"address": "0x34",
"command": "0x21",
"data": "0x0030",
"command_number": 497,
"address": "0x34",
"command": "0x25",
"data": "0x663273",
"comment": "Write VOUT_MARGIN_HIGH [Rail #2] 12.600 V"
"command_number": 498,
"address": "0x34",
"command": "0x25",
"data": "0x6632",
"command_number": 499,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D7B",
"comment": "Write VOUT_MARGIN_LOW [Rail #2] 11.400 V"
"command_number": 500,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D",
"command_number": 501,
"address": "0x34",
"command": "0x40",
"data": "0x333720",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #2] 13.800 V"
"command_number": 502,
"address": "0x34",
"command": "0x40",
"data": "0x3337",
"command_number": 503,
"address": "0x34",
"command": "0x42",
"data": "0xCD343D",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #2] 13.200 V"
"command_number": 504,
"address": "0x34",
"command": "0x42",
"data": "0xCD34",
"command_number": 505,
"address": "0x34",
"command": "0x2A",
"data": "0xA8A2F6",
"comment": "Write VOUT_SCALE_MONITOR [Rail #2] 0.166"
"command_number": 506,
"address": "0x34",
"command": "0x2A",
"data": "0xA8A2",
"command_number": 507,
"address": "0x34",
"command": "0x44",
"data": "0xCD2814",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #2] 10.200 V"
"command_number": 508,
"address": "0x34",
"command": "0x44",
"data": "0xCD28",
"command_number": 509,
"address": "0x34",
"command": "0x43",
"data": "0x332BC9",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #2] 10.800 V"
"command_number": 510,
"address": "0x34",
"command": "0x43",
"data": "0x332B",
"command_number": 511,
"request": "WriteByte",
"address": "0x34",
"command": "0x00",
"data": "0x029A",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #3] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 512,
"request": "ReadByte",
"address": "0x34",
"command": "0x00",
"data": "0x02",
"command_number": 513,
"address": "0x34",
"command": "0xE9",
"command_number": 514,
"address": "0x34",
"command": "0xE9",
"command_number": 515,
"address": "0x34",
"command": "0x5F",
"data": "0xCD285A",
"comment": "Write POWER_GOOD_OFF [Rail #3] 10.200 V"
"command_number": 516,
"address": "0x34",
"command": "0x5F",
"data": "0xCD28",
"command_number": 517,
"address": "0x34",
"command": "0x5E",
"data": "0x332BFA",
"comment": "Write POWER_GOOD_ON [Rail #3] 10.800 V"
"command_number": 518,
"address": "0x34",
"command": "0x5E",
"data": "0x332B",
"command_number": 519,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #3] 0.0 ms"
"command_number": 520,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 521,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #3] 0.0 ms"
"command_number": 522,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 523,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #3] 0.0 ms"
"command_number": 524,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 525,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #3] <No Limit>"
"command_number": 526,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 527,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #3] 0.000 V"
"command_number": 528,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 529,
"address": "0x34",
"command": "0x21",
"data": "0x00305D",
"comment": "Write VOUT_COMMAND [Rail #3] 12.000 V"
"command_number": 530,
"address": "0x34",
"command": "0x21",
"data": "0x0030",
"command_number": 531,
"address": "0x34",
"command": "0x25",
"data": "0x663273",
"comment": "Write VOUT_MARGIN_HIGH [Rail #3] 12.600 V"
"command_number": 532,
"address": "0x34",
"command": "0x25",
"data": "0x6632",
"command_number": 533,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D7B",
"comment": "Write VOUT_MARGIN_LOW [Rail #3] 11.400 V"
"command_number": 534,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D",
"command_number": 535,
"address": "0x34",
"command": "0x40",
"data": "0x333720",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #3] 13.800 V"
"command_number": 536,
"address": "0x34",
"command": "0x40",
"data": "0x3337",
"command_number": 537,
"address": "0x34",
"command": "0x42",
"data": "0xCD343D",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #3] 13.200 V"
"command_number": 538,
"address": "0x34",
"command": "0x42",
"data": "0xCD34",
"command_number": 539,
"address": "0x34",
"command": "0x2A",
"data": "0xA8A2F6",
"comment": "Write VOUT_SCALE_MONITOR [Rail #3] 0.166"
"command_number": 540,
"address": "0x34",
"command": "0x2A",
"data": "0xA8A2",
"command_number": 541,
"address": "0x34",
"command": "0x44",
"data": "0xCD2814",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #3] 10.200 V"
"command_number": 542,
"address": "0x34",
"command": "0x44",
"data": "0xCD28",
"command_number": 543,
"address": "0x34",
"command": "0x43",
"data": "0x332BC9",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #3] 10.800 V"
"command_number": 544,
"address": "0x34",
"command": "0x43",
"data": "0x332B",
"command_number": 545,
"address": "0x34",
"command": "0x00",
"data": "0x039D",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #4] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Shutdown immediately; Restart: Do not restart| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Shutdown immediately; Restart: Do not restart| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Shutdown immediately; Restart: Do not restart"
"command_number": 546,
"address": "0x34",
"command": "0x00",
"data": "0x03",
"command_number": 547,
"request": "BlockWrite",
"address": "0x34",
"command": "0xE9",
"data": "0x06808080000000D6",
"command_number": 548,
"address": "0x34",
"command": "0xE9",
"data": "0x06808080000000",
"command_number": 549,
"address": "0x34",
"command": "0x5F",
"data": "0x00445D",
"comment": "Write POWER_GOOD_OFF [Rail #4] 4.250 V"
"command_number": 550,
"address": "0x34",
"command": "0x5F",
"data": "0x0044",
"command_number": 551,
"address": "0x34",
"command": "0x5E",
"data": "0x004812",
"comment": "Write POWER_GOOD_ON [Rail #4] 4.500 V"
"command_number": 552,
"address": "0x34",
"command": "0x5E",
"data": "0x0048",
"command_number": 553,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #4] 0.0 ms"
"command_number": 554,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 555,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #4] 0.0 ms"
"command_number": 556,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 557,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #4] 0.0 ms"
"command_number": 558,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 559,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #4] <No Limit>"
"command_number": 560,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 561,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #4] 0.000 V"
"command_number": 562,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 563,
"address": "0x34",
"command": "0x21",
"data": "0x00507A",
"comment": "Write VOUT_COMMAND [Rail #4] 5.000 V"
"command_number": 564,
"address": "0x34",
"command": "0x21",
"data": "0x0050",
"command_number": 565,
"address": "0x34",
"command": "0x25",
"data": "0x0054CD",
"comment": "Write VOUT_MARGIN_HIGH [Rail #4] 5.250 V"
"command_number": 566,
"address": "0x34",
"command": "0x25",
"data": "0x0054",
"command_number": 567,
"address": "0x34",
"command": "0x26",
"data": "0x334FF7",
"comment": "Write VOUT_MARGIN_LOW [Rail #4] 4.950 V"
"command_number": 568,
"address": "0x34",
"command": "0x26",
"data": "0x334F",
"command_number": 569,
"address": "0x34",
"command": "0x40",
"data": "0x005CF0",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #4] 5.750 V"
"command_number": 570,
"address": "0x34",
"command": "0x40",
"data": "0x005C",
"command_number": 571,
"address": "0x34",
"command": "0x42",
"data": "0x00583A",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #4] 5.500 V"
"command_number": 572,
"address": "0x34",
"command": "0x42",
"data": "0x0058",
"command_number": 573,
"address": "0x34",
"command": "0x2A",
"data": "0x33ABBF",
"comment": "Write VOUT_SCALE_MONITOR [Rail #4] 0.400"
"command_number": 574,
"address": "0x34",
"command": "0x2A",
"data": "0x33AB",
"command_number": 575,
"address": "0x34",
"command": "0x44",
"data": "0x004413",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #4] 4.250 V"
"command_number": 576,
"address": "0x34",
"command": "0x44",
"data": "0x0044",
"command_number": 577,
"address": "0x34",
"command": "0x43",
"data": "0x004821",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #4] 4.500 V"
"command_number": 578,
"address": "0x34",
"command": "0x43",
"data": "0x0048",
"command_number": 579,
"address": "0x34",
"command": "0x00",
"data": "0x0488",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #5] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 580,
"address": "0x34",
"command": "0x00",
"data": "0x04",
"command_number": 581,
"address": "0x34",
"command": "0xE9",
"command_number": 582,
"request": "BlockRead",
"address": "0x34",
"command": "0xE9",
"command_number": 583,
"address": "0x34",
"command": "0x5F",
"data": "0x00445D",
"comment": "Write POWER_GOOD_OFF [Rail #5] 4.250 V"
"command_number": 584,
"address": "0x34",
"command": "0x5F",
"data": "0x0044",
"command_number": 585,
"address": "0x34",
"command": "0x5E",
"data": "0x004812",
"comment": "Write POWER_GOOD_ON [Rail #5] 4.500 V"
"command_number": 586,
"address": "0x34",
"command": "0x5E",
"data": "0x0048",
"command_number": 587,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #5] 0.0 ms"
"command_number": 588,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 589,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #5] 0.0 ms"
"command_number": 590,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 591,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #5] 0.0 ms"
"command_number": 592,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 593,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #5] <No Limit>"
"command_number": 594,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 595,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #5] 0.000 V"
"command_number": 596,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 597,
"address": "0x34",
"command": "0x21",
"data": "0x00507A",
"comment": "Write VOUT_COMMAND [Rail #5] 5.000 V"
"command_number": 598,
"address": "0x34",
"command": "0x21",
"data": "0x0050",
"command_number": 599,
"address": "0x34",
"command": "0x25",
"data": "0x0054CD",
"comment": "Write VOUT_MARGIN_HIGH [Rail #5] 5.250 V"
"command_number": 600,
"address": "0x34",
"command": "0x25",
"data": "0x0054",
"command_number": 601,
"address": "0x34",
"command": "0x26",
"data": "0x004C38",
"comment": "Write VOUT_MARGIN_LOW [Rail #5] 4.750 V"
"command_number": 602,
"address": "0x34",
"command": "0x26",
"data": "0x004C",
"command_number": 603,
"address": "0x34",
"command": "0x40",
"data": "0x005CF0",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #5] 5.750 V"
"command_number": 604,
"address": "0x34",
"command": "0x40",
"data": "0x005C",
"command_number": 605,
"address": "0x34",
"command": "0x42",
"data": "0x00583A",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #5] 5.500 V"
"command_number": 606,
"address": "0x34",
"command": "0x42",
"data": "0x0058",
"command_number": 607,
"address": "0x34",
"command": "0x2A",
"data": "0x33ABBF",
"comment": "Write VOUT_SCALE_MONITOR [Rail #5] 0.400"
"command_number": 608,
"address": "0x34",
"command": "0x2A",
"data": "0x33AB",
"command_number": 609,
"address": "0x34",
"command": "0x44",
"data": "0x004413",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #5] 4.250 V"
"command_number": 610,
"address": "0x34",
"command": "0x44",
"data": "0x0044",
"command_number": 611,
"address": "0x34",
"command": "0x43",
"data": "0x004821",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #5] 4.500 V"
"command_number": 612,
"address": "0x34",
"command": "0x43",
"data": "0x0048",
"command_number": 613,
"address": "0x34",
"command": "0x00",
"data": "0x058F",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #6] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 614,
"address": "0x34",
"command": "0x00",
"data": "0x05",
"command_number": 615,
"address": "0x34",
"command": "0xE9",
"command_number": 616,
"address": "0x34",
"command": "0xE9",
"command_number": 617,
"address": "0x34",
"command": "0x5F",
"data": "0xE12C14",
"comment": "Write POWER_GOOD_OFF [Rail #6] 2.805 V"
"command_number": 618,
"address": "0x34",
"command": "0x5F",
"data": "0xE12C",
"command_number": 619,
"address": "0x34",
"command": "0x5E",
"data": "0x852FD7",
"comment": "Write POWER_GOOD_ON [Rail #6] 2.970 V"
"command_number": 620,
"address": "0x34",
"command": "0x5E",
"data": "0x852F",
"command_number": 621,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #6] 0.0 ms"
"command_number": 622,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 623,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #6] 0.0 ms"
"command_number": 624,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 625,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #6] 0.0 ms"
"command_number": 626,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 627,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #6] <No Limit>"
"command_number": 628,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 629,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #6] 0.000 V"
"command_number": 630,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 631,
"address": "0x34",
"command": "0x21",
"data": "0xCD3445",
"comment": "Write VOUT_COMMAND [Rail #6] 3.300 V"
"command_number": 632,
"address": "0x34",
"command": "0x21",
"data": "0xCD34",
"command_number": 633,
"address": "0x34",
"command": "0x25",
"data": "0x713754",
"comment": "Write VOUT_MARGIN_HIGH [Rail #6] 3.465 V"
"command_number": 634,
"address": "0x34",
"command": "0x25",
"data": "0x7137",
"command_number": 635,
"address": "0x34",
"command": "0x26",
"data": "0x003457",
"comment": "Write VOUT_MARGIN_LOW [Rail #6] 3.250 V"
"command_number": 636,
"address": "0x34",
"command": "0x26",
"data": "0x0034",
"command_number": 637,
"address": "0x34",
"command": "0x40",
"data": "0xB83C30",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #6] 3.795 V"
"command_number": 638,
"address": "0x34",
"command": "0x40",
"data": "0xB83C",
"command_number": 639,
"address": "0x34",
"command": "0x42",
"data": "0x143A10",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #6] 3.630 V"
"command_number": 640,
"address": "0x34",
"command": "0x42",
"data": "0x143A",
"command_number": 641,
"address": "0x34",
"command": "0x2A",
"data": "0x6DB22A",
"comment": "Write VOUT_SCALE_MONITOR [Rail #6] 0.606"
"command_number": 642,
"address": "0x34",
"command": "0x2A",
"data": "0x6DB2",
"command_number": 643,
"address": "0x34",
"command": "0x44",
"data": "0xE12C5A",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #6] 2.805 V"
"command_number": 644,
"address": "0x34",
"command": "0x44",
"data": "0xE12C",
"command_number": 645,
"address": "0x34",
"command": "0x43",
"data": "0x852FE4",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #6] 2.970 V"
"command_number": 646,
"address": "0x34",
"command": "0x43",
"data": "0x852F",
"command_number": 647,
"address": "0x34",
"command": "0x00",
"data": "0x0686",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #7] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 648,
"address": "0x34",
"command": "0x00",
"data": "0x06",
"command_number": 649,
"address": "0x34",
"command": "0xE9",
"command_number": 650,
"address": "0x34",
"command": "0xE9",
"command_number": 651,
"address": "0x34",
"command": "0x5F",
"data": "0xE12C14",
"comment": "Write POWER_GOOD_OFF [Rail #7] 2.805 V"
"command_number": 652,
"address": "0x34",
"command": "0x5F",
"data": "0xE12C",
"command_number": 653,
"address": "0x34",
"command": "0x5E",
"data": "0x852FD7",
"comment": "Write POWER_GOOD_ON [Rail #7] 2.970 V"
"command_number": 654,
"address": "0x34",
"command": "0x5E",
"data": "0x852F",
"command_number": 655,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #7] 0.0 ms"
"command_number": 656,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 657,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #7] 0.0 ms"
"command_number": 658,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 659,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #7] 0.0 ms"
"command_number": 660,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 661,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #7] <No Limit>"
"command_number": 662,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 663,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #7] 0.000 V"
"command_number": 664,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 665,
"address": "0x34",
"command": "0x21",
"data": "0xCD3445",
"comment": "Write VOUT_COMMAND [Rail #7] 3.300 V"
"command_number": 666,
"address": "0x34",
"command": "0x21",
"data": "0xCD34",
"command_number": 667,
"address": "0x34",
"command": "0x25",
"data": "0x9A358E",
"comment": "Write VOUT_MARGIN_HIGH [Rail #7] 3.350 V"
"command_number": 668,
"address": "0x34",
"command": "0x25",
"data": "0x9A35",
"command_number": 669,
"address": "0x34",
"command": "0x26",
"data": "0x293444",
"comment": "Write VOUT_MARGIN_LOW [Rail #7] 3.260 V"
"command_number": 670,
"address": "0x34",
"command": "0x26",
"data": "0x2934",
"command_number": 671,
"address": "0x34",
"command": "0x40",
"data": "0xB83C30",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #7] 3.795 V"
"command_number": 672,
"address": "0x34",
"command": "0x40",
"data": "0xB83C",
"command_number": 673,
"address": "0x34",
"command": "0x42",
"data": "0x143A10",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #7] 3.630 V"
"command_number": 674,
"address": "0x34",
"command": "0x42",
"data": "0x143A",
"command_number": 675,
"address": "0x34",
"command": "0x2A",
"data": "0x6DB22A",
"comment": "Write VOUT_SCALE_MONITOR [Rail #7] 0.606"
"command_number": 676,
"address": "0x34",
"command": "0x2A",
"data": "0x6DB2",
"command_number": 677,
"address": "0x34",
"command": "0x44",
"data": "0xE12C5A",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #7] 2.805 V"
"command_number": 678,
"address": "0x34",
"command": "0x44",
"data": "0xE12C",
"command_number": 679,
"address": "0x34",
"command": "0x43",
"data": "0x852FE4",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #7] 2.970 V"
"command_number": 680,
"address": "0x34",
"command": "0x43",
"data": "0x852F",
"command_number": 681,
"address": "0x34",
"command": "0x00",
"data": "0x0781",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #8] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 682,
"address": "0x34",
"command": "0x00",
"data": "0x07",
"command_number": 683,
"address": "0x34",
"command": "0xE9",
"command_number": 684,
"address": "0x34",
"command": "0xE9",
"command_number": 685,
"address": "0x34",
"command": "0x5F",
"data": "0xF6307C",
"comment": "Write POWER_GOOD_OFF [Rail #8] 3.060 V"
"command_number": 686,
"address": "0x34",
"command": "0x5F",
"data": "0xF630",
"command_number": 687,
"address": "0x34",
"command": "0x5E",
"data": "0xD733A5",
"comment": "Write POWER_GOOD_ON [Rail #8] 3.240 V"
"command_number": 688,
"address": "0x34",
"command": "0x5E",
"data": "0xD733",
"command_number": 689,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #8] 0.0 ms"
"command_number": 690,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 691,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #8] 0.0 ms"
"command_number": 692,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 693,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #8] 0.0 ms"
"command_number": 694,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 695,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #8] <No Limit>"
"command_number": 696,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 697,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #8] 0.000 V"
"command_number": 698,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 699,
"address": "0x34",
"command": "0x21",
"data": "0x9A3901",
"comment": "Write VOUT_COMMAND [Rail #8] 3.600 V"
"command_number": 700,
"address": "0x34",
"command": "0x21",
"data": "0x9A39",
"command_number": 701,
"address": "0x34",
"command": "0x25",
"data": "0x7B3CE7",
"comment": "Write VOUT_MARGIN_HIGH [Rail #8] 3.780 V"
"command_number": 702,
"address": "0x34",
"command": "0x25",
"data": "0x7B3C",
"command_number": 703,
"address": "0x34",
"command": "0x26",
"data": "0xF63819",
"comment": "Write VOUT_MARGIN_LOW [Rail #8] 3.560 V"
"command_number": 704,
"address": "0x34",
"command": "0x26",
"data": "0xF638",
"command_number": 705,
"address": "0x34",
"command": "0x40",
"data": "0x3D42BA",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #8] 4.140 V"
"command_number": 706,
"address": "0x34",
"command": "0x40",
"data": "0x3D42",
"command_number": 707,
"address": "0x34",
"command": "0x42",
"data": "0x5C3FF8",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #8] 3.960 V"
"command_number": 708,
"address": "0x34",
"command": "0x42",
"data": "0x5C3F",
"command_number": 709,
"address": "0x34",
"command": "0x2A",
"data": "0x38B267",
"comment": "Write VOUT_SCALE_MONITOR [Rail #8] 0.555"
"command_number": 710,
"address": "0x34",
"command": "0x2A",
"data": "0x38B2",
"command_number": 711,
"address": "0x34",
"command": "0x44",
"data": "0xF63032",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #8] 3.060 V"
"command_number": 712,
"address": "0x34",
"command": "0x44",
"data": "0xF630",
"command_number": 713,
"address": "0x34",
"command": "0x43",
"data": "0xD73396",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #8] 3.240 V"
"command_number": 714,
"address": "0x34",
"command": "0x43",
"data": "0xD733",
"command_number": 715,
"address": "0x34",
"command": "0x00",
"data": "0x08AC",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #9] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 716,
"address": "0x34",
"command": "0x00",
"data": "0x08",
"command_number": 717,
"address": "0x34",
"command": "0xE9",
"command_number": 718,
"address": "0x34",
"command": "0xE9",
"command_number": 719,
"address": "0x34",
"command": "0x5F",
"data": "0xCD285A",
"comment": "Write POWER_GOOD_OFF [Rail #9] 20.400 V"
"command_number": 720,
"address": "0x34",
"command": "0x5F",
"data": "0xCD28",
"command_number": 721,
"address": "0x34",
"command": "0x5E",
"data": "0x332BFA",
"comment": "Write POWER_GOOD_ON [Rail #9] 21.600 V"
"command_number": 722,
"address": "0x34",
"command": "0x5E",
"data": "0x332B",
"command_number": 723,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #9] 0.0 ms"
"command_number": 724,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 725,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #9] 0.0 ms"
"command_number": 726,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 727,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #9] 0.0 ms"
"command_number": 728,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 729,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #9] <No Limit>"
"command_number": 730,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 731,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #9] 0.000 V"
"command_number": 732,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 733,
"address": "0x34",
"command": "0x21",
"data": "0x00305D",
"comment": "Write VOUT_COMMAND [Rail #9] 24.000 V"
"command_number": 734,
"address": "0x34",
"command": "0x21",
"data": "0x0030",
"command_number": 735,
"address": "0x34",
"command": "0x25",
"data": "0x663273",
"comment": "Write VOUT_MARGIN_HIGH [Rail #9] 25.199 V"
"command_number": 736,
"address": "0x34",
"command": "0x25",
"data": "0x6632",
"command_number": 737,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D7B",
"comment": "Write VOUT_MARGIN_LOW [Rail #9] 22.801 V"
"command_number": 738,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D",
"command_number": 739,
"address": "0x34",
"command": "0x40",
"data": "0x333720",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #9] 27.600 V"
"command_number": 740,
"address": "0x34",
"command": "0x40",
"data": "0x3337",
"command_number": 741,
"address": "0x34",
"command": "0x42",
"data": "0xCD343D",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #9] 26.400 V"
"command_number": 742,
"address": "0x34",
"command": "0x42",
"data": "0xCD34",
"command_number": 743,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA0E",
"comment": "Write VOUT_SCALE_MONITOR [Rail #9] 1.000"
"command_number": 744,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA",
"command_number": 745,
"address": "0x34",
"command": "0x44",
"data": "0xCD2814",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #9] 20.400 V"
"command_number": 746,
"address": "0x34",
"command": "0x44",
"data": "0xCD28",
"command_number": 747,
"address": "0x34",
"command": "0x43",
"data": "0x332BC9",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #9] 21.600 V"
"command_number": 748,
"address": "0x34",
"command": "0x43",
"data": "0x332B",
"command_number": 749,
"address": "0x34",
"command": "0x00",
"data": "0x09AB",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #10] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 750,
"address": "0x34",
"command": "0x00",
"data": "0x09",
"command_number": 751,
"address": "0x34",
"command": "0xE9",
"command_number": 752,
"address": "0x34",
"command": "0xE9",
"command_number": 753,
"address": "0x34",
"command": "0x5F",
"data": "0xCD285A",
"comment": "Write POWER_GOOD_OFF [Rail #10] 10.200 V"
"command_number": 754,
"address": "0x34",
"command": "0x5F",
"data": "0xCD28",
"command_number": 755,
"address": "0x34",
"command": "0x5E",
"data": "0x332BFA",
"comment": "Write POWER_GOOD_ON [Rail #10] 10.800 V"
"command_number": 756,
"address": "0x34",
"command": "0x5E",
"data": "0x332B",
"command_number": 757,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #10] 0.0 ms"
"command_number": 758,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 759,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #10] 0.0 ms"
"command_number": 760,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 761,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #10] 0.0 ms"
"command_number": 762,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 763,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #10] <No Limit>"
"command_number": 764,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 765,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #10] 0.000 V"
"command_number": 766,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 767,
"address": "0x34",
"command": "0x21",
"data": "0x00305D",
"comment": "Write VOUT_COMMAND [Rail #10] 12.000 V"
"command_number": 768,
"address": "0x34",
"command": "0x21",
"data": "0x0030",
"command_number": 769,
"address": "0x34",
"command": "0x25",
"data": "0x663273",
"comment": "Write VOUT_MARGIN_HIGH [Rail #10] 12.600 V"
"command_number": 770,
"address": "0x34",
"command": "0x25",
"data": "0x6632",
"command_number": 771,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D7B",
"comment": "Write VOUT_MARGIN_LOW [Rail #10] 11.400 V"
"command_number": 772,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D",
"command_number": 773,
"address": "0x34",
"command": "0x40",
"data": "0x333720",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #10] 13.800 V"
"command_number": 774,
"address": "0x34",
"command": "0x40",
"data": "0x3337",
"command_number": 775,
"address": "0x34",
"command": "0x42",
"data": "0xCD343D",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #10] 13.200 V"
"command_number": 776,
"address": "0x34",
"command": "0x42",
"data": "0xCD34",
"command_number": 777,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA0E",
"comment": "Write VOUT_SCALE_MONITOR [Rail #10] 1.000"
"command_number": 778,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA",
"command_number": 779,
"address": "0x34",
"command": "0x44",
"data": "0xCD2814",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #10] 10.200 V"
"command_number": 780,
"address": "0x34",
"command": "0x44",
"data": "0xCD28",
"command_number": 781,
"address": "0x34",
"command": "0x43",
"data": "0x332BC9",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #10] 10.800 V"
"command_number": 782,
"address": "0x34",
"command": "0x43",
"data": "0x332B",
"command_number": 783,
"address": "0x34",
"command": "0x00",
"data": "0x0AA2",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #11] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 784,
"address": "0x34",
"command": "0x00",
"data": "0x0A",
"command_number": 785,
"address": "0x34",
"command": "0xE9",
"command_number": 786,
"address": "0x34",
"command": "0xE9",
"command_number": 787,
"address": "0x34",
"command": "0x5F",
"data": "0xCD285A",
"comment": "Write POWER_GOOD_OFF [Rail #11] 10.200 V"
"command_number": 788,
"address": "0x34",
"command": "0x5F",
"data": "0xCD28",
"command_number": 789,
"address": "0x34",
"command": "0x5E",
"data": "0x332BFA",
"comment": "Write POWER_GOOD_ON [Rail #11] 10.800 V"
"command_number": 790,
"address": "0x34",
"command": "0x5E",
"data": "0x332B",
"command_number": 791,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #11] 0.0 ms"
"command_number": 792,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 793,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #11] 0.0 ms"
"command_number": 794,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 795,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #11] 0.0 ms"
"command_number": 796,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 797,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #11] <No Limit>"
"command_number": 798,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 799,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #11] 0.000 V"
"command_number": 800,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 801,
"address": "0x34",
"command": "0x21",
"data": "0x00305D",
"comment": "Write VOUT_COMMAND [Rail #11] 12.000 V"
"command_number": 802,
"address": "0x34",
"command": "0x21",
"data": "0x0030",
"command_number": 803,
"address": "0x34",
"command": "0x25",
"data": "0x663273",
"comment": "Write VOUT_MARGIN_HIGH [Rail #11] 12.600 V"
"command_number": 804,
"address": "0x34",
"command": "0x25",
"data": "0x6632",
"command_number": 805,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D7B",
"comment": "Write VOUT_MARGIN_LOW [Rail #11] 11.400 V"
"command_number": 806,
"address": "0x34",
"command": "0x26",
"data": "0x9A2D",
"command_number": 807,
"address": "0x34",
"command": "0x40",
"data": "0x333720",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #11] 13.800 V"
"command_number": 808,
"address": "0x34",
"command": "0x40",
"data": "0x3337",
"command_number": 809,
"address": "0x34",
"command": "0x42",
"data": "0xCD343D",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #11] 13.200 V"
"command_number": 810,
"address": "0x34",
"command": "0x42",
"data": "0xCD34",
"command_number": 811,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA0E",
"comment": "Write VOUT_SCALE_MONITOR [Rail #11] 1.000"
"command_number": 812,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA",
"command_number": 813,
"address": "0x34",
"command": "0x44",
"data": "0xCD2814",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #11] 10.200 V"
"command_number": 814,
"address": "0x34",
"command": "0x44",
"data": "0xCD28",
"command_number": 815,
"address": "0x34",
"command": "0x43",
"data": "0x332BC9",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #11] 10.800 V"
"command_number": 816,
"address": "0x34",
"command": "0x43",
"data": "0x332B",
"command_number": 817,
"address": "0x34",
"command": "0x00",
"data": "0x0BA5",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #12] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 818,
"address": "0x34",
"command": "0x00",
"data": "0x0B",
"command_number": 819,
"address": "0x34",
"command": "0xE9",
"command_number": 820,
"address": "0x34",
"command": "0xE9",
"command_number": 821,
"address": "0x34",
"command": "0x5F",
"data": "0x00445D",
"comment": "Write POWER_GOOD_OFF [Rail #12] 4.250 V"
"command_number": 822,
"address": "0x34",
"command": "0x5F",
"data": "0x0044",
"command_number": 823,
"address": "0x34",
"command": "0x5E",
"data": "0x004812",
"comment": "Write POWER_GOOD_ON [Rail #12] 4.500 V"
"command_number": 824,
"address": "0x34",
"command": "0x5E",
"data": "0x0048",
"command_number": 825,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #12] 0.0 ms"
"command_number": 826,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 827,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #12] 0.0 ms"
"command_number": 828,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 829,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #12] 0.0 ms"
"command_number": 830,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 831,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #12] <No Limit>"
"command_number": 832,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 833,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #12] 0.000 V"
"command_number": 834,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 835,
"address": "0x34",
"command": "0x21",
"data": "0x00507A",
"comment": "Write VOUT_COMMAND [Rail #12] 5.000 V"
"command_number": 836,
"address": "0x34",
"command": "0x21",
"data": "0x0050",
"command_number": 837,
"address": "0x34",
"command": "0x25",
"data": "0x0054CD",
"comment": "Write VOUT_MARGIN_HIGH [Rail #12] 5.250 V"
"command_number": 838,
"address": "0x34",
"command": "0x25",
"data": "0x0054",
"command_number": 839,
"address": "0x34",
"command": "0x26",
"data": "0x004C38",
"comment": "Write VOUT_MARGIN_LOW [Rail #12] 4.750 V"
"command_number": 840,
"address": "0x34",
"command": "0x26",
"data": "0x004C",
"command_number": 841,
"address": "0x34",
"command": "0x40",
"data": "0x005CF0",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #12] 5.750 V"
"command_number": 842,
"address": "0x34",
"command": "0x40",
"data": "0x005C",
"command_number": 843,
"address": "0x34",
"command": "0x42",
"data": "0x00583A",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #12] 5.500 V"
"command_number": 844,
"address": "0x34",
"command": "0x42",
"data": "0x0058",
"command_number": 845,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA0E",
"comment": "Write VOUT_SCALE_MONITOR [Rail #12] 1.000"
"command_number": 846,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA",
"command_number": 847,
"address": "0x34",
"command": "0x44",
"data": "0x004413",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #12] 4.250 V"
"command_number": 848,
"address": "0x34",
"command": "0x44",
"data": "0x0044",
"command_number": 849,
"address": "0x34",
"command": "0x43",
"data": "0x004821",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #12] 4.500 V"
"command_number": 850,
"address": "0x34",
"command": "0x43",
"data": "0x0048",
"command_number": 851,
"address": "0x34",
"command": "0x00",
"data": "0x0CB0",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #13] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 852,
"address": "0x34",
"command": "0x00",
"data": "0x0C",
"command_number": 853,
"address": "0x34",
"command": "0xE9",
"command_number": 854,
"address": "0x34",
"command": "0xE9",
"command_number": 855,
"address": "0x34",
"command": "0x5F",
"data": "0x00445D",
"comment": "Write POWER_GOOD_OFF [Rail #13] 4.250 V"
"command_number": 856,
"address": "0x34",
"command": "0x5F",
"data": "0x0044",
"command_number": 857,
"address": "0x34",
"command": "0x5E",
"data": "0x004812",
"comment": "Write POWER_GOOD_ON [Rail #13] 4.500 V"
"command_number": 858,
"address": "0x34",
"command": "0x5E",
"data": "0x0048",
"command_number": 859,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #13] 0.0 ms"
"command_number": 860,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 861,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #13] 0.0 ms"
"command_number": 862,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 863,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #13] 0.0 ms"
"command_number": 864,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 865,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #13] <No Limit>"
"command_number": 866,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 867,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #13] 0.000 V"
"command_number": 868,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 869,
"address": "0x34",
"command": "0x21",
"data": "0x00507A",
"comment": "Write VOUT_COMMAND [Rail #13] 5.000 V"
"command_number": 870,
"address": "0x34",
"command": "0x21",
"data": "0x0050",
"command_number": 871,
"address": "0x34",
"command": "0x25",
"data": "0x0054CD",
"comment": "Write VOUT_MARGIN_HIGH [Rail #13] 5.250 V"
"command_number": 872,
"address": "0x34",
"command": "0x25",
"data": "0x0054",
"command_number": 873,
"address": "0x34",
"command": "0x26",
"data": "0x004C38",
"comment": "Write VOUT_MARGIN_LOW [Rail #13] 4.750 V"
"command_number": 874,
"address": "0x34",
"command": "0x26",
"data": "0x004C",
"command_number": 875,
"address": "0x34",
"command": "0x40",
"data": "0x005CF0",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #13] 5.750 V"
"command_number": 876,
"address": "0x34",
"command": "0x40",
"data": "0x005C",
"command_number": 877,
"address": "0x34",
"command": "0x42",
"data": "0x00583A",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #13] 5.500 V"
"command_number": 878,
"address": "0x34",
"command": "0x42",
"data": "0x0058",
"command_number": 879,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA0E",
"comment": "Write VOUT_SCALE_MONITOR [Rail #13] 1.000"
"command_number": 880,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA",
"command_number": 881,
"address": "0x34",
"command": "0x44",
"data": "0x004413",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #13] 4.250 V"
"command_number": 882,
"address": "0x34",
"command": "0x44",
"data": "0x0044",
"command_number": 883,
"address": "0x34",
"command": "0x43",
"data": "0x004821",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #13] 4.500 V"
"command_number": 884,
"address": "0x34",
"command": "0x43",
"data": "0x0048",
"command_number": 885,
"address": "0x34",
"command": "0x00",
"data": "0x0DB7",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #14] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 886,
"address": "0x34",
"command": "0x00",
"data": "0x0D",
"command_number": 887,
"address": "0x34",
"command": "0xE9",
"command_number": 888,
"address": "0x34",
"command": "0xE9",
"command_number": 889,
"address": "0x34",
"command": "0x5F",
"data": "0xE12C14",
"comment": "Write POWER_GOOD_OFF [Rail #14] 2.805 V"
"command_number": 890,
"address": "0x34",
"command": "0x5F",
"data": "0xE12C",
"command_number": 891,
"address": "0x34",
"command": "0x5E",
"data": "0x852FD7",
"comment": "Write POWER_GOOD_ON [Rail #14] 2.970 V"
"command_number": 892,
"address": "0x34",
"command": "0x5E",
"data": "0x852F",
"command_number": 893,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #14] 0.0 ms"
"command_number": 894,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 895,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #14] 0.0 ms"
"command_number": 896,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 897,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #14] 0.0 ms"
"command_number": 898,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 899,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #14] <No Limit>"
"command_number": 900,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 901,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #14] 0.000 V"
"command_number": 902,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 903,
"address": "0x34",
"command": "0x21",
"data": "0xCD3445",
"comment": "Write VOUT_COMMAND [Rail #14] 3.300 V"
"command_number": 904,
"address": "0x34",
"command": "0x21",
"data": "0xCD34",
"command_number": 905,
"address": "0x34",
"command": "0x25",
"data": "0x713754",
"comment": "Write VOUT_MARGIN_HIGH [Rail #14] 3.465 V"
"command_number": 906,
"address": "0x34",
"command": "0x25",
"data": "0x7137",
"command_number": 907,
"address": "0x34",
"command": "0x26",
"data": "0x293256",
"comment": "Write VOUT_MARGIN_LOW [Rail #14] 3.135 V"
"command_number": 908,
"address": "0x34",
"command": "0x26",
"data": "0x2932",
"command_number": 909,
"address": "0x34",
"command": "0x40",
"data": "0xB83C30",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #14] 3.795 V"
"command_number": 910,
"address": "0x34",
"command": "0x40",
"data": "0xB83C",
"command_number": 911,
"address": "0x34",
"command": "0x42",
"data": "0x143A10",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #14] 3.630 V"
"command_number": 912,
"address": "0x34",
"command": "0x42",
"data": "0x143A",
"command_number": 913,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA0E",
"comment": "Write VOUT_SCALE_MONITOR [Rail #14] 1.000"
"command_number": 914,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA",
"command_number": 915,
"address": "0x34",
"command": "0x44",
"data": "0xE12C5A",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #14] 2.805 V"
"command_number": 916,
"address": "0x34",
"command": "0x44",
"data": "0xE12C",
"command_number": 917,
"address": "0x34",
"command": "0x43",
"data": "0x852FE4",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #14] 2.970 V"
"command_number": 918,
"address": "0x34",
"command": "0x43",
"data": "0x852F",
"command_number": 919,
"address": "0x34",
"command": "0x00",
"data": "0x0EBE",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #15] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 920,
"address": "0x34",
"command": "0x00",
"data": "0x0E",
"command_number": 921,
"address": "0x34",
"command": "0xE9",
"command_number": 922,
"address": "0x34",
"command": "0xE9",
"command_number": 923,
"address": "0x34",
"command": "0x5F",
"data": "0xE12C14",
"comment": "Write POWER_GOOD_OFF [Rail #15] 2.805 V"
"command_number": 924,
"address": "0x34",
"command": "0x5F",
"data": "0xE12C",
"command_number": 925,
"address": "0x34",
"command": "0x5E",
"data": "0x852FD7",
"comment": "Write POWER_GOOD_ON [Rail #15] 2.970 V"
"command_number": 926,
"address": "0x34",
"command": "0x5E",
"data": "0x852F",
"command_number": 927,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #15] 0.0 ms"
"command_number": 928,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 929,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #15] 0.0 ms"
"command_number": 930,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 931,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #15] 0.0 ms"
"command_number": 932,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 933,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #15] <No Limit>"
"command_number": 934,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 935,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #15] 0.000 V"
"command_number": 936,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 937,
"address": "0x34",
"command": "0x21",
"data": "0xCD3445",
"comment": "Write VOUT_COMMAND [Rail #15] 3.300 V"
"command_number": 938,
"address": "0x34",
"command": "0x21",
"data": "0xCD34",
"command_number": 939,
"address": "0x34",
"command": "0x25",
"data": "0x713754",
"comment": "Write VOUT_MARGIN_HIGH [Rail #15] 3.465 V"
"command_number": 940,
"address": "0x34",
"command": "0x25",
"data": "0x7137",
"command_number": 941,
"address": "0x34",
"command": "0x26",
"data": "0x293256",
"comment": "Write VOUT_MARGIN_LOW [Rail #15] 3.135 V"
"command_number": 942,
"address": "0x34",
"command": "0x26",
"data": "0x2932",
"command_number": 943,
"address": "0x34",
"command": "0x40",
"data": "0xB83C30",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #15] 3.795 V"
"command_number": 944,
"address": "0x34",
"command": "0x40",
"data": "0xB83C",
"command_number": 945,
"address": "0x34",
"command": "0x42",
"data": "0x143A10",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #15] 3.630 V"
"command_number": 946,
"address": "0x34",
"command": "0x42",
"data": "0x143A",
"command_number": 947,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA0E",
"comment": "Write VOUT_SCALE_MONITOR [Rail #15] 1.000"
"command_number": 948,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA",
"command_number": 949,
"address": "0x34",
"command": "0x44",
"data": "0xE12C5A",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #15] 2.805 V"
"command_number": 950,
"address": "0x34",
"command": "0x44",
"data": "0xE12C",
"command_number": 951,
"address": "0x34",
"command": "0x43",
"data": "0x852FE4",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #15] 2.970 V"
"command_number": 952,
"address": "0x34",
"command": "0x43",
"data": "0x852F",
"command_number": 953,
"address": "0x34",
"command": "0x00",
"data": "0x0FB9",
"comment": "Write FAULT_RESPONSES [MFR 25,Rail #16] Retry Time: 0 msec| Max Volt Glitch Time: 0.0 msec| Max Other Glitch Time: 0 msec| VOUT_OV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| VOUT_UV: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A| TON_MAX: Resequence: Disabled; Glitch filter: Disabled; Response: Ignore; Restart: N/A"
"command_number": 954,
"address": "0x34",
"command": "0x00",
"data": "0x0F",
"command_number": 955,
"address": "0x34",
"command": "0xE9",
"command_number": 956,
"address": "0x34",
"command": "0xE9",
"command_number": 957,
"request": "WriteWord",
"address": "0x34",
"command": "0x5F",
"data": "0xF6307C",
"comment": "Write POWER_GOOD_OFF [Rail #16] 3.060 V"
"command_number": 958,
"request": "ReadWord",
"address": "0x34",
"command": "0x5F",
"data": "0xF630",
"command_number": 959,
"address": "0x34",
"command": "0x5E",
"data": "0xD733A5",
"comment": "Write POWER_GOOD_ON [Rail #16] 3.240 V"
"command_number": 960,
"address": "0x34",
"command": "0x5E",
"data": "0xD733",
"command_number": 961,
"address": "0x34",
"command": "0x64",
"data": "0x008002",
"comment": "Write TOFF_DELAY [Rail #16] 0.0 ms"
"command_number": 962,
"address": "0x34",
"command": "0x64",
"data": "0x0080",
"command_number": 963,
"address": "0x34",
"command": "0x66",
"data": "0x0080D4",
"comment": "Write TOFF_MAX_WARN_LIMIT [Rail #16] 0.0 ms"
"command_number": 964,
"address": "0x34",
"command": "0x66",
"data": "0x0080",
"command_number": 965,
"address": "0x34",
"command": "0x60",
"data": "0x0080A9",
"comment": "Write TON_DELAY [Rail #16] 0.0 ms"
"command_number": 966,
"address": "0x34",
"command": "0x60",
"data": "0x0080",
"command_number": 967,
"address": "0x34",
"command": "0x62",
"data": "0x00807F",
"comment": "Write TON_MAX_FAULT_LIMIT [Rail #16] <No Limit>"
"command_number": 968,
"address": "0x34",
"command": "0x62",
"data": "0x0080",
"command_number": 969,
"address": "0x34",
"command": "0xD1",
"data": "0x0000A1",
"comment": "Write VOUT_CAL_MONITOR [MFR 01,Rail #16] 0.000 V"
"command_number": 970,
"address": "0x34",
"command": "0xD1",
"data": "0x0000",
"command_number": 971,
"address": "0x34",
"command": "0x21",
"data": "0x9A3901",
"comment": "Write VOUT_COMMAND [Rail #16] 3.600 V"
"command_number": 972,
"address": "0x34",
"command": "0x21",
"data": "0x9A39",
"command_number": 973,
"address": "0x34",
"command": "0x25",
"data": "0x7B3CE7",
"comment": "Write VOUT_MARGIN_HIGH [Rail #16] 3.780 V"
"command_number": 974,
"address": "0x34",
"command": "0x25",
"data": "0x7B3C",
"command_number": 975,
"address": "0x34",
"command": "0x26",
"data": "0xB836BE",
"comment": "Write VOUT_MARGIN_LOW [Rail #16] 3.420 V"
"command_number": 976,
"address": "0x34",
"command": "0x26",
"data": "0xB836",
"command_number": 977,
"address": "0x34",
"command": "0x40",
"data": "0x3D42BA",
"comment": "Write VOUT_OV_FAULT_LIMIT [Rail #16] 4.140 V"
"command_number": 978,
"address": "0x34",
"command": "0x40",
"data": "0x3D42",
"command_number": 979,
"address": "0x34",
"command": "0x42",
"data": "0x5C3FF8",
"comment": "Write VOUT_OV_WARN_LIMIT [Rail #16] 3.960 V"
"command_number": 980,
"address": "0x34",
"command": "0x42",
"data": "0x5C3F",
"command_number": 981,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA0E",
"comment": "Write VOUT_SCALE_MONITOR [Rail #16] 1.000"
"command_number": 982,
"address": "0x34",
"command": "0x2A",
"data": "0x00BA",
"command_number": 983,
"address": "0x34",
"command": "0x44",
"data": "0xF63032",
"comment": "Write VOUT_UV_FAULT_LIMIT [Rail #16] 3.060 V"
"command_number": 984,
"address": "0x34",
"command": "0x44",
"data": "0xF630",
"command_number": 985,
"address": "0x34",
"command": "0x43",
"data": "0xD73396",
"comment": "Write VOUT_UV_WARN_LIMIT [Rail #16] 3.240 V"
"command_number": 986,
"address": "0x34",
"command": "0x43",
"data": "0xD733",
"command_number": 987,
"address": "0x34",
"command": "0x00",
"data": "0x0094",
"comment": "Write ON_OFF_CONFIG [Rail #1] Mode: Always Converting"
"command_number": 988,
"address": "0x34",
"command": "0x00",
"data": "0x00",
"command_number": 989,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 990,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 991,
"address": "0x34",
"command": "0x00",
"data": "0x0193",
"comment": "Write ON_OFF_CONFIG [Rail #2] Mode: Always Converting"
"command_number": 992,
"address": "0x34",
"command": "0x00",
"data": "0x01",
"command_number": 993,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 994,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 995,
"address": "0x34",
"command": "0x00",
"data": "0x029A",
"comment": "Write ON_OFF_CONFIG [Rail #3] Mode: Always Converting"
"command_number": 996,
"address": "0x34",
"command": "0x00",
"data": "0x02",
"command_number": 997,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 998,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 999,
"address": "0x34",
"command": "0x00",
"data": "0x039D",
"comment": "Write ON_OFF_CONFIG [Rail #4] Mode: Always Converting"
"command_number": 1000,
"address": "0x34",
"command": "0x00",
"data": "0x03",
"command_number": 1001,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1002,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1003,
"address": "0x34",
"command": "0x00",
"data": "0x0488",
"comment": "Write ON_OFF_CONFIG [Rail #5] Mode: Always Converting"
"command_number": 1004,
"address": "0x34",
"command": "0x00",
"data": "0x04",
"command_number": 1005,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1006,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1007,
"address": "0x34",
"command": "0x00",
"data": "0x058F",
"comment": "Write ON_OFF_CONFIG [Rail #6] Mode: Always Converting"
"command_number": 1008,
"address": "0x34",
"command": "0x00",
"data": "0x05",
"command_number": 1009,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1010,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1011,
"address": "0x34",
"command": "0x00",
"data": "0x0686",
"comment": "Write ON_OFF_CONFIG [Rail #7] Mode: Always Converting"
"command_number": 1012,
"address": "0x34",
"command": "0x00",
"data": "0x06",
"command_number": 1013,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1014,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1015,
"address": "0x34",
"command": "0x00",
"data": "0x0781",
"comment": "Write ON_OFF_CONFIG [Rail #8] Mode: Always Converting"
"command_number": 1016,
"address": "0x34",
"command": "0x00",
"data": "0x07",
"command_number": 1017,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1018,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1019,
"address": "0x34",
"command": "0x00",
"data": "0x08AC",
"comment": "Write ON_OFF_CONFIG [Rail #9] Mode: Always Converting"
"command_number": 1020,
"address": "0x34",
"command": "0x00",
"data": "0x08",
"command_number": 1021,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1022,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1023,
"address": "0x34",
"command": "0x00",
"data": "0x09AB",
"comment": "Write ON_OFF_CONFIG [Rail #10] Mode: Always Converting"
"command_number": 1024,
"address": "0x34",
"command": "0x00",
"data": "0x09",
"command_number": 1025,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1026,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1027,
"address": "0x34",
"command": "0x00",
"data": "0x0AA2",
"comment": "Write ON_OFF_CONFIG [Rail #11] Mode: Always Converting"
"command_number": 1028,
"address": "0x34",
"command": "0x00",
"data": "0x0A",
"command_number": 1029,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1030,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1031,
"address": "0x34",
"command": "0x00",
"data": "0x0BA5",
"comment": "Write ON_OFF_CONFIG [Rail #12] Mode: Always Converting"
"command_number": 1032,
"address": "0x34",
"command": "0x00",
"data": "0x0B",
"command_number": 1033,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1034,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1035,
"address": "0x34",
"command": "0x00",
"data": "0x0CB0",
"comment": "Write ON_OFF_CONFIG [Rail #13] Mode: Always Converting"
"command_number": 1036,
"address": "0x34",
"command": "0x00",
"data": "0x0C",
"command_number": 1037,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1038,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1039,
"address": "0x34",
"command": "0x00",
"data": "0x0DB7",
"comment": "Write ON_OFF_CONFIG [Rail #14] Mode: Always Converting"
"command_number": 1040,
"address": "0x34",
"command": "0x00",
"data": "0x0D",
"command_number": 1041,
"request": "WriteByte",
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1042,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1043,
"address": "0x34",
"command": "0x00",
"data": "0x0EBE",
"comment": "Write ON_OFF_CONFIG [Rail #15] Mode: Always Converting"
"command_number": 1044,
"address": "0x34",
"command": "0x00",
"data": "0x0E",
"command_number": 1045,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1046,
"request": "ReadByte",
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1047,
"address": "0x34",
"command": "0x00",
"data": "0x0FB9",
"comment": "Write ON_OFF_CONFIG [Rail #16] Mode: Always Converting"
"command_number": 1048,
"address": "0x34",
"command": "0x00",
"data": "0x0F",
"command_number": 1049,
"address": "0x34",
"command": "0x02",
"data": "0x00BE",
"command_number": 1050,
"address": "0x34",
"command": "0x02",
"data": "0x00",
"command_number": 1051,
"request": "wait",
"address": "0x34",
"command": "0x00",
"data": "0x00",
"comment": "Store configuration to data flash"
"command_number": 1052,
"request": "onewriteonly",
"address": "0x34",
"command": "0x11",
"data": "0x00",
"comment": "Execute STORE_DEFAULT_ALL"
"command_number": 1053,
"request": "wait",
"address": "0x34",
"command": "0x00",
"data": "0x00",
"command_number": 1054,
"address": "0x34",
"command": "0xF3",
"data": "0x04000002",
"comment": "Check store to data flash"
]I use the following code to program the IC.
