Hello Texas Instruments Support Team,
I am using the bq40z50 chip on one of my 4s BMS boards.
In Shutdown mode, the supply current is 730µA, which does not match the values in the documentation at all.
The consumption drops to 60µA when I desolder the 100-ohm resistor connected to the VCC pin.
However, the chip stops responding via SMBus in this case. This is strange because I understood that
VCC is an auxiliary supply and the chip should be able to operate without it, but in practice, this is not the case.
I have tried flashing different firmware versions, but nothing changes.
Could you please advise what might be causing such high current consumption?
