Hi Team,
Could you please help to get me the thermal resistance junction-to-board for CSD87313DMS? Thanks in advance.
Hailiang
Hi Team,
Hailiang
Hello Hailiang,
Thanks for the inquiry. I pulled up the characterization data collected during product development. The max thermal resistance, Rθjc = 5.6°C/W measured to the thermal pads (S1, S2) on the bottom of the package mounted on a 1in², 2 oz. copper pad. Please let me know if you need any additional information.
John Wallace
TI FET Applications
Hi John,
Thanks. Is there any comments for the junction-to-board thermal resistance?
Hailiang
Hi Hailiang,
TI does not spec junction-to-board thermal resistance. However, the junction-to-case (thermal pad) thermal resistance is measured and specified with the device mounted on a PCB as described above and should be essentially the same as the pads are soldered directly to the PCB copper. Please see the blog at the link below for more information on how TI tests and specifies thermal resistance.
https://www.ti.com/lit/ta/ssztb80/ssztb80.pdf
John
