After building our LiFePO4 pack with the BQ76972 AFE we encounter a problem. Within a month a customer calls us because his pack is out of balance. This is a result of one cell staying behind. With LiFePE4 you can only balance correctly above 3400mV like you probably know. But the AFE is looking at the lowest cell. This is wrong, because a slight difference in the cells results in one or more cells dropping below 3400mV. Lowering this value will result in balancing kicking in too early, balancing on impedance differences between the cells. So, if a pack is a bit out of balance, there is no way to rebalance the pack without sending it back to the supplier (us) and for us to open up the pack, balance manually, and then hope the customer charges his pack more often. This results in high service costs and customers may loose patience and decide to use another brand.
Is there any way, other than using a MCU to balance ourselves, to get the AFE to look at the highest cell to start balancing? We know about the relax balancing function, but that does not fix large imbalance issues.
Kind regards,
Robert Jan
