UCC28070: UCC28070 multiple current sharing in three phase power application
Part Number: UCC28070
Other Parts Discussed in Thread: UCC29002,
I am using this in a three phase power system, I am looking for current sharing techniques.
  • Hi Paul,
    Do you have a block diagram and schematic of your system so I can better support your question? The UCC29002 is our go-to load share controller. We have many resources available to help with your design.
    Jonathan Wong
  • I have a 3 phase 400Hz, powering 3kw, I am synchronizing and using six current sense transformers. I am implementing a passive current sharing with a droop current share control. I have a 400V bus powered by the three PFCs. I see your datasheet have some on parallel but don't discuss current sharing.
  • Hi Paul,
    What do you mean by "passive current sharing"? Is this where the UCC29002 comes in?
    I am not sure what you mean by "have some on parallel but don't discuss current sharing". By placing the 3 modules in parallel with each module having a UCC29002 load share controller, you will have an equal load among all three phases.
    The UCC28070 will not mention load sharing since that is a PFC controller. Below are some diagrams that may help with your understanding. The load share controller design will be independent from the power topology design.
    5531.UCC29002 Sharing Blocks2.pdf
    Jonathan Wong
