LM5146: How can i use external 12V VCC supply to drive IPD050N10N5 mosfets using LM5146 ?
Part Number: LM5146
I have simulated LM5146 in LTSpice using .lib unencrypted file available on TI website. If I don't apply external VCC it is working fine.
But when I'm trying to use external VCC, the VCC pin voltage is stuck at 7.5V.
I've already used diode at input Vin and External VCC(12V), but still I'm getting same results.
I've attached the node voltage result, please check and help.
