Hi Team,
1. I would like to understand how the PWM signal is supplied to the LED driver. Is it generated externally by the microcontroller, or does the LED driver itself have built-in PWM capability that can be configured through programming? If the LED driver supports internal PWM control, could you please share a reference or documentation?
2. I also need the pin diagram and pin description for the LED driver.
Thankyou & Regards,
Harun Reddy.
