Hi Team,
Could you please provide the noise rate specifications for LM61480RPHR, LM61495RPHR, and REF7040QFKHT? This info is needed for our design review.
Arshad
Hi Team,
Arshad
Thanks Arsha for your question,
I will look into it and get back to you today
Hi Arshad,
Please find the noise rate specifications for the requested parts below:
• LM61480RPHR / LM61495RPHR: As these are buck DC-DC converters, standard “noise rate” specifications such as voltage noise density (expressed in nV/√Hz) are typically not provided. However, the datasheets and technical documentation focus on EMI performance, output ripple, and switching noise characteristics, which determine overall noise. No explicit voltage noise spectral density value is specified in the datasheets for these models.
• REF7040QFKHT:
• 1/f Noise (0.1 Hz to 10 Hz): 0.23 ppm p-p
• 10 Hz to 1 kHz: 0.35 ppm rms
Thanks and Regards
Naresh
