Other Parts Discussed in Thread: TPS723, PMP30473
We are planning to -5V output voltage in our product. There are few questions about TPS723 series.
- Since TPS723 typical output is -2.5V, in order to generate -5V, it is necessary to use TPS72301 only, but TPS72325. Is it correct?
- According to the datasheet, Pin4 is NR. But TPS72301 is not NR, it is FB pin for the resistor devider. Is it still recommand that connect the bypass capacitor on FB pin for noise reduction?
York
