TPS92662A-Q1: CLK und SYNC has no output
Part Number: TPS92662A-Q1
we have the problem, that the communication with one driver works as expected, but when we will communicate with two drivers, there's no response. And the CLK and SYNC line doesn't have a waveform output on the first driver.
We worked on a older project also with two devices but with the older generation (TPS92662) an there the software worked as expected.
I compared the two datasheets from TPS92662 vs. TPS92662A and found out that the DSTR Pin and XTALDS Register are new .
Could that be the Problem? And when yes, what values do we need to use?
Hope you can help me.
Best regards
Sandra Mayinger
