Part Number: TPS61177A
Currently using default current setting & enable pin permanent high
in case i would like to change Configuration Parameters through I2C, do i need to toggle enable pin or genrate reset condition?
let me know, if below eequence is OK
- pwr ON
2. default enable pin high
3. PWM floating
4. I2C configuration
5. PWM pin switching based on brightness intensity requirement (expect new config. parameters get implemented)
Do i need to configure these parameter every time, after device reset?
Regards.
