BQ25504 - Transducer current
Other Parts Discussed in Thread: BQ25504
I am testing the BQ25504 evaluation kit, using an external power supply to mimic the voltage from a thermoelectric generator.  A 10 ohm resistor is connected in series between the power supply and Vin pin of the BQ25504.
When the MPPT function is enabled, should the input current drawn from the power supply (transducer) equal V_in/(2*R_in)?  where V_in is the generated voltage from the transducer and R_in is the source resistance from the transducer.
Tzern
