I have a customer doing a redesign of a UPS board. They have a couple of questions on the LM5118:
1. What is the maximum current output supported? Can the device drive the gates of bigger FETs than the one used on the evaluation board?
2. Is it possible to dynamically adjust the voltage set point? We want to use this as a charger and we need lower the charge voltage after charging the battery.
3. The datasheet indicates that I monitors current to protect the FETs. Is there an output that can be monitored for this?
