Part Number: TPS7A02
We have used a TPS7A0233 in one our products that is supplied by a Li-ion battery. The whole board is supplied by this LDO which is always ON, and there is no other parts on Vbat line. The overall current consumption in shutdown mode at Vbat<3.6v is about 200nA. However, at higher Vbat the board shutdown current increases up to 140uA at Vbat=4.2v. This is has been confimed by testing on several boards, and also by replacing the LDO with a simple diode where the shutdown current becomes less than 500nA at Vbat=4.2v (board Vcc becomes ~4.0v).
Apparently, this is the ground current of the LDO, but considering the datasheet, we did not expect such high current when Iout=200nA.
Could you please inform us if there is remedy for this? Or, introduce us a replacement part without such high ground current at higher input voltage?
Thanks in advance
