TPS62130 - Maximum output capacitance
Other Parts Discussed in Thread: TPS62130
What is the maximum allowable TPS62130 output capacitance?
  • The TPS62130 is an internally compensated switching converter.  In general, the user must properly select the external filter components (output inductor and capacitor) to be stable with the fixed internal compensation.  Each specific IC's datasheet contains information on the allowable component selection.  An appication note on the TPS62130 allowable external components provides even more indepth information.  The title is "Optimizing the TPS62130/40/50/60/70 Output Filter" http://www.ti.com/lit/an/slva463/slva463.pdf
    This application note is referenced in the datasheet and is also in the TPS62130 technical documents.
