Part Number: TPS6594-Q1
Other Parts Discussed in Thread: DRA821,
Please suggest the part number of PMIC TPS6594141BRWERQ1 Programmer.
Gaurav
Gaurav
Hi Gaurav,
That orderable comes already pre-programmed with the configuration described in www.ti.com/lit/pdf/slvuby7. So you don't need to program the device yourself to have this loaded.
Katie
Hi Katie,
We're using a custom single PMIC design with DRA821. So we need a programmer.
Gaurav
Hi Gaurav,
TPS6594141BRWERQ1 that you mention in the initial post is a specific pre-programmed catalog configuration of the TPS6594-Q1. But you mention a custom configuration - if that is the case you would either work with TI sales to set up for a custom part number to be pre-programmed with your config by TI (there are certain volume minimums etc for this), or we also have a 3rd party we can work with that will program blank TPS6594-Q1 to your config for you. Finally, if you want to production program devices yourself, we do not sell a tool for that purpose (TPS6594-Q1 EVMs can program the parts but for evaluation purposes, not mass production) - but we do provide a programming guide to help you create your own implementation: Scalable PMIC NVM Update Guide (Rev. A) https://www.ti.com/lit/pdf/slvaf93
I hope this helps.
Katie
