Hi Team,
in lighting surge test in "power off " condition, VIN pin will feed into -10V and around 50us, is this pulse has any impact for device?
If passed, I have other two questions,
1) Can TPS5430 tolerance negative pulse to -20V with duration ~1ms?
(2) In I/P of TPS5430, there is a diode reversed shunt to ground. When negative pulse is coming, the negative voltage will be clamped to -Vf and large current will go through the diode. So what is maximum transient current or power of this diode?
