Part Number: TPS6594EVM
Hello , i have three questions ,
I am using the TPS6594EVM to connect to an external PMIC in a a custom board , the PMIC adress is 0x28 , is that normal?
When i try to program the PMIC i get this error , i connected the I2C pins using the j28 and supplied VIO with 3v3 from the EVK .
when i try to read back the register its all 0x00 , is the EVK damaged or the PMIC locked?
thank you
