BQ24085 Test set up
Other Parts Discussed in Thread: BQ24085
Dear Community
We build the battery charger follow BQ24085 EVM. Could you help to recommend test circuit to check the board during production process? Which point or part we need to check?  This is because we cannot do fully test in the production line. We just would like to roughly check the board before it become to finish goods.
NT
  • How about the test procedure and load test board on the EVM User’s guide of this board? Is that going to be enough?
  • Please note that the Texas Instruments IC is tested at production.  Your test should check to see whether or not your board is manufactured properly at assembly.  I agree with Tahar that the test proceedure in the user's guide is a good starting point.  It will be best if you review this and make the final decision on what you want to test in your production flow.  Those decisions change from customer to customer depending on their needs.
