Hi everyone,
Can anyone provide me design formulas used in designing adapter for water heater is 12V,1.2A using ucc28610 controller.
plz do the needful. the requirement is urgent.
regards
santosh
Hi everyone,
regards
santosh
Did you use the Design Calculator that is in the UCC28610 product folder?
Yes i am using design calculator but i want to know how each values are derived specially transformer magnetics(primary inductance, turns ratio,primary n secondary turns, bias turns), can u provide me any formula sheet to start my design.
santosh sawal
The calculations involve a series of iterations in which some key parameters MUST be met:
Using these criteria, the calculator takes the specified input and output requirements and calculates the required parts in order to get a reliable design. I have enclosed a pdf of my MathCAD workbook that I used as a basis of the Excel Design Calculator. I have updated the input capacitor equations and the CL resistor so this is not identicle to the web version (which will be revised as soon as possible).
