Part Number: TPS25200
Hi team,
May I know if this IC supports dynamic current limit?
Customer would like to change the external RILIM value while EN=High. Below points are important to the operation of this end equipment.
- RLIM decrease while EN=High to increase the current limit.
- RLIM increase while EN=High to decrease the current limit.
- While current limit value changes, there should be no hiccup/retry of the power switch. Continuous sourcing of the voltage is needed.
I see below E2E posts but did not see clear answers.
- https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1001116/tps25200-tps25200-soft-start---adjustable/3700410?tisearch=e2e-sitesearch&keymatch=TPS25200%2520dynamic#
- https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1254313/tps25200-dynamic-current-limit-part-check?tisearch=e2e-sitesearch&keymatch=TPS25200%20dynamic#
Luke
